RX580 not folding / utilised
PositiveLad
Post by PositiveLad »
Hi Guys,
Brand new to folding. Found this project via the GamesRadar article about using my gaming rig to tackle COVID-19. Sounds a great idea.
My set up is
AMD Ryzen 2600 6C/12T CPU
16GB DDR4 RAM
AMD Radeon RX580 8GB GPU
2TB SSD storage
100mbps DSL
Running Windows 10 (fully patched) and the latest AMD 2020 drivers.
I've downloaded and installed the client, which is now running but on CPU only. GPU is showing but sitting as ready only. Is there another step I need to finish to enable GPU folding?
MY LOG:
21:23:29:WU01:FS01:0x22:*********************** Log Started 2020-03-14T21:23:28Z ***********************
21:23:29:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:23:29:WU01:FS01:0x22:       Type: 0x22
21:23:29:WU01:FS01:0x22:       Core: Core22
21:23:29:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:23:29:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:23:29:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:23:29:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:23:29:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 15084 -checkpoint 15
21:23:29:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:23:29:WU01:FS01:0x22:     Config: <none>
21:23:29:WU01:FS01:0x22:************************************ Build *************************************
21:23:29:WU01:FS01:0x22:    Version: 0.0.2
21:23:29:WU01:FS01:0x22:       Date: Dec 6 2019
21:23:29:WU01:FS01:0x22:       Time: 21:30:31
21:23:29:WU01:FS01:0x22: Repository: Git
21:23:29:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:23:29:WU01:FS01:0x22:     Branch: HEAD
21:23:29:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:23:29:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:23:29:WU01:FS01:0x22:   Platform: win32 10
21:23:29:WU01:FS01:0x22:       Bits: 64
21:23:29:WU01:FS01:0x22:       Mode: Release
21:23:29:WU01:FS01:0x22:************************************ System ************************************
21:23:29:WU01:FS01:0x22:        CPU: AMD Ryzen 5 2600 Six-Core Processor
21:23:29:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
21:23:29:WU01:FS01:0x22:       CPUs: 12
21:23:29:WU01:FS01:0x22:     Memory: 15.95GiB
21:23:29:WU01:FS01:0x22:Free Memory: 10.59GiB
21:23:29:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:23:29:WU01:FS01:0x22: OS Version: 6.2
21:23:29:WU01:FS01:0x22:Has Battery: false
21:23:29:WU01:FS01:0x22: On Battery: false
21:23:29:WU01:FS01:0x22: UTC Offset: 0
21:23:29:WU01:FS01:0x22:        PID: 8444
21:23:29:WU01:FS01:0x22:        CWD: C:\Users\tomha\AppData\Roaming\FAHClient\work
21:23:29:WU01:FS01:0x22:         OS: Windows 10 Pro
21:23:29:WU01:FS01:0x22:    OS Arch: AMD64
21:23:29:WU01:FS01:0x22:********************************************************************************
21:23:29:WU01:FS01:0x22:Project: 11752 (Run 0, Clone 9292, Gen 2)
21:23:29:WU01:FS01:0x22:Unit: 0x000000038ca304e75e6bc0095d0ecac7
21:23:29:WU01:FS01:0x22:Reading tar file core.xml
21:23:29:WU01:FS01:0x22:Reading tar file integrator.xml
21:23:29:WU01:FS01:0x22:Reading tar file state.xml
21:23:29:WU01:FS01:0x22:Reading tar file system.xml
21:23:29:WU01:FS01:0x22:Digital signatures verified
21:23:29:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:23:29:WU01:FS01:0x22:Version 0.0.2
21:23:54:WU01:FS01:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
21:23:54:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:23:54:WU01:FS01:0x22:Saving result file science.log
21:23:54:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:23:54:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:23:54:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11752 run:0 clone:9292 gen:2 core:0x22 unit:0x000000038ca304e75e6bc0095d0ecac7
21:23:54:WU01:FS01:Uploading 8.00KiB to 140.163.4.231
21:23:54:WU01:FS01:Connecting to 140.163.4.231:8080
21:23:55:WU02:FS01:Connecting to 65.254.110.245:8080
21:23:55:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:23:55:WU02:FS01:Connecting to 18.218.241.186:80
21:23:55:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:23:55:ERROR:WU02:FS01:Exception: Could not get an assignment
21:23:56:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:23:56:WU02:FS01:Connecting to 18.218.241.186:80
21:23:56:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:23:56:ERROR:WU02:FS01:Exception: Could not get an assignment
21:23:59:WU01:FS01:Upload complete
21:23:59:WU01:FS01:Server responded WORK_ACK (400)
21:23:59:WU01:FS01:Cleaning up
21:24:02:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
21:24:36:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
21:24:55:WU02:FS01:Connecting to 65.254.110.245:8080
21:24:56:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:24:56:WU02:FS01:Connecting to 18.218.241.186:80
21:24:56:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:24:56:ERROR:WU02:FS01:Exception: Could not get an assignment
21:25:02:Saving configuration to config.xml
21:25:02:<config>
21:25:02:  <!-- Network -->
21:25:02:  <proxy v=':8080'/>
21:25:02:
21:25:02:  <!-- Slot Control -->
21:25:02:  <power v='FULL'/>
21:25:02:
21:25:02:  <!-- User Information -->
21:25:02:  <team v='225605'/>
21:25:02:  <user v='PositiveLad'/>
21:25:02:
21:25:02:  <!-- Folding Slots -->
21:25:02:  <slot id='0' type='CPU'/>
21:25:02:  <slot id='1' type='GPU'/>
21:25:02:</config>
21:25:10:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
21:25:28:Saving configuration to config.xml
21:25:28:<config>
21:25:28:  <!-- Network -->
21:25:28:  <proxy v=':8080'/>
21:25:28:
21:25:28:  <!-- Slot Control -->
21:25:28:  <power v='FULL'/>
21:25:28:
21:25:28:  <!-- User Information -->
21:25:28:  <team v='225605'/>
21:25:28:  <user v='PositiveLad'/>
21:25:28:
21:25:28:  <!-- Folding Slots -->
21:25:28:  <slot id='0' type='CPU'/>
21:25:28:  <slot id='1' type='GPU'/>
21:25:28:</config>
21:25:45:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
21:26:24:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
21:26:33:WU02:FS01:Connecting to 65.254.110.245:8080
21:26:33:WU02:FS01:Assigned to work server 155.247.166.220
21:26:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
21:26:33:WU02:FS01:Connecting to 155.247.166.220:8080
21:26:33:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
21:26:59:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
21:27:29:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
21:27:33:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
21:28:10:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
21:28:48:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
21:29:10:WU02:FS01:Connecting to 65.254.110.245:8080
21:29:10:WU02:FS01:Assigned to work server 155.247.166.220
21:29:10:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
21:29:10:WU02:FS01:Connecting to 155.247.166.220:8080
21:29:10:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
21:29:28:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
21:30:06:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
21:30:47:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
21:31:26:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
21:32:01:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
21:32:34:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
21:33:08:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
21:33:24:WU02:FS01:Connecting to 65.254.110.245:8080
21:33:25:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:33:25:WU02:FS01:Connecting to 18.218.241.186:80
21:33:25:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:33:25:ERROR:WU02:FS01:Exception: Could not get an assignment
21:33:42:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
21:34:16:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
21:34:50:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
Thanks in advance, Tom
Re: RX580 not folding / utilised
PositiveLad
Hey Bruce,
Thanks for that. Might well be that. Great there's so much new support.
I'll leave it crunching on CPU overnight and hope it picks up a GPU WU soon :)
Tom
GGeorgss
Post by GGeorgss »
I have the opposite problem. Running on a following rig:
AMD Ryzen 7 3700X 8C/16T
16GB DDR4 RAM (3200)
1TB SSD PCIe Gen4
250mbps DSL
My GPU is chewing on, but my CPU is rolling it's thumbs
Hope the servers will be fixed soon.
Edit: Now the CPU is also chewing on...
Jone
Post by Jone »
What kind of PPD are you seeing? My RX580's show 40k to 80k but I read in older posts they should be at 300k.
Jone wrote:What kind of PPD are you seeing? My RX580's show 40k to 80k but I read in older posts they should be at 300k.
The higher PPD probably includes the QRB from using a passkey.
If you search on passkey here you will see that some are having troubles getting them by email. They are working on that, hopefully fixed soon.
Jone
Post by Jone »
Quick Return Bonus? Is PPD not the best way to measure the performance then? I just want to know that my GPU's are performing like they should.
hmfcriley
Post by hmfcriley »
I'm getting around 600k PPD as it stands from my RX580 when both GPU's are being utilised (which hasn't been often with the server issues the last few days).
