Please add this NVIDIA 1050 Variant
BlazinDimes
Post by BlazinDimes »
Name: NVIDIA GeForce GTX 1050
Device ID: 10DE 1C91 - 103C 86D4
*********************** Log Started 2020-03-14T18:59:33Z ***********************
18:59:33:************************* Folding@home Client *************************
18:59:33:        Website: https://foldingathome.org/
18:59:33:      Copyright: (c) 2009-2018 foldingathome.org
18:59:33:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:33:           Args: --open-web-control
18:59:33:         Config: <none>
18:59:33:******************************** Build ********************************
18:59:33:        Version: 7.5.1
18:59:33:           Date: May 11 2018
18:59:33:           Time: 13:06:32
18:59:33:     Repository: Git
18:59:33:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:59:33:         Branch: master
18:59:33:       Compiler: Visual C++ 2008
18:59:33:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:59:33:       Platform: win32 10
18:59:33:           Bits: 32
18:59:33:           Mode: Release
18:59:33:******************************* System ********************************
18:59:33:            CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
18:59:33:         CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
18:59:33:           CPUs: 8
18:59:33:         Memory: 13.92GiB
18:59:33:    Free Memory: 9.01GiB
18:59:33:        Threads: WINDOWS_THREADS
18:59:33:     OS Version: 6.2
18:59:33:    Has Battery: true
18:59:33:     On Battery: false
18:59:33:     UTC Offset: -5
18:59:33:            PID: 8952
18:59:33:            CWD: C:\Users\Justin\AppData\Roaming\FAHClient
18:59:33:             OS: Windows 10 Enterprise
18:59:33:        OS Arch: AMD64
18:59:33:           GPUs: 0
18:59:33:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
18:59:33:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
18:59:33:OpenCL Device 1: Platform:1 Device:0 Bus:5 Slot:0 Compute:1.2 Driver:3004.8
18:59:33:  Win32 Service: false
18:59:33:***********************************************************************
18:59:33:<config>
18:59:33:  <!-- Folding Slots -->
18:59:33:</config>
18:59:33:Connecting to assign1.foldingathome.org:8080
18:59:33:Updated GPUs.txt
18:59:33:Read GPUs.txt
18:59:33:Trying to access database...
18:59:33:Successfully acquired database lock
18:59:33:Enabled folding slot 00: PAUSED cpu:3 (not configured)
18:59:37:17:127.0.0.1:New Web connection
19:00:18:Set client configured
19:00:18:WU00:FS00:Connecting to 65.254.110.245:8080
19:00:19:WU00:FS00:Connecting to 65.254.110.245:8080
19:00:19:WU00:FS00:Assigned to work server 155.247.164.214
19:00:19:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
19:00:19:WU00:FS00:Connecting to 155.247.164.214:8080
19:00:19:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
19:00:20:WU00:FS00:Assigned to work server 155.247.164.214
19:00:20:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 155.247.164.214
19:00:20:WU00:FS00:Connecting to 155.247.164.214:8080
19:00:20:WU00:FS00:Downloading 2.97MiB
19:00:23:WU00:FS00:Download complete
19:00:23:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:0 clone:5724 gen:8 core:0xa7 unit:0x000000089bf7a4d65e6c6ae7a1e902d1
19:00:23:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
19:00:23:WU00:FS00:Connecting to cores.foldingathome.org:80
19:00:23:WU00:FS00:FahCore a7: Downloading 6.71MiB
19:00:29:WU00:FS00:FahCore a7: 80.09%
19:00:30:WU00:FS00:FahCore a7: Download complete
19:00:30:WU00:FS00:Valid core signature
19:00:31:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
19:00:31:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
19:00:31:WU00:FS00:Starting
19:00:31:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
19:00:31:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
19:00:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Justin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8952 -checkpoint 15 -np 3
19:00:31:WU00:FS00:Started FahCore on PID 10300
19:00:32:WU00:FS00:Core PID:3356
19:00:32:WU00:FS00:FahCore 0xa7 started
19:00:32:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T19:00:32Z ***********************
19:00:32:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:00:32:WU00:FS00:0xa7:       Type: 0xa7
19:00:32:WU00:FS00:0xa7:       Core: Gromacs
19:00:32:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10300 -checkpoint 15 -np
19:00:32:WU00:FS00:0xa7:             3
19:00:32:WU00:FS00:0xa7:************************************ CBang *************************************
19:00:32:WU00:FS00:0xa7:       Date: Oct 26 2019
19:00:32:WU00:FS00:0xa7:       Time: 01:38:25
19:00:32:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:00:32:WU00:FS00:0xa7:     Branch: master
19:00:32:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:00:32:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:00:32:WU00:FS00:0xa7:   Platform: win32 10
19:00:32:WU00:FS00:0xa7:       Bits: 64
19:00:32:WU00:FS00:0xa7:       Mode: Release
19:00:32:WU00:FS00:0xa7:************************************ System ************************************
19:00:32:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
19:00:32:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 24 Stepping 1
19:00:32:WU00:FS00:0xa7:       CPUs: 8
19:00:32:WU00:FS00:0xa7:     Memory: 13.92GiB
19:00:32:WU00:FS00:0xa7:Free Memory: 8.53GiB
19:00:32:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:00:32:WU00:FS00:0xa7: OS Version: 6.2
19:00:32:WU00:FS00:0xa7:Has Battery: true
19:00:32:WU00:FS00:0xa7: On Battery: false
19:00:32:WU00:FS00:0xa7: UTC Offset: -5
19:00:32:WU00:FS00:0xa7:        PID: 3356
19:00:32:WU00:FS00:0xa7:        CWD: C:\Users\Justin\AppData\Roaming\FAHClient\work
19:00:32:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:00:32:WU00:FS00:0xa7:    Version: 0.0.18
19:00:32:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:00:32:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:00:32:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:00:32:WU00:FS00:0xa7:       Time: 01:52:30
19:00:32:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:00:32:WU00:FS00:0xa7:************************************ Build *************************************
19:00:32:WU00:FS00:0xa7:       SIMD: avx_256
19:00:32:WU00:FS00:0xa7:********************************************************************************
19:00:32:WU00:FS00:0xa7:Project: 14328 (Run 0, Clone 5724, Gen 8)
19:00:32:WU00:FS00:0xa7:Unit: 0x000000089bf7a4d65e6c6ae7a1e902d1
19:00:32:WU00:FS00:0xa7:Reading tar file core.xml
19:00:32:WU00:FS00:0xa7:Reading tar file frame8.tpr
19:00:32:WU00:FS00:0xa7:Digital signatures verified
19:00:32:WU00:FS00:0xa7:Calling: mdrun -s frame8.tpr -o frame8.trr -cpt 15 -nt 3
19:00:32:WU00:FS00:0xa7:Steps: first=2000000 total=250000
19:00:34:Saving configuration to config.xml
19:00:34:<config>
19:00:34:  <!-- Slot Control -->
19:00:34:  <power v='MEDIUM'/>
19:00:34:
19:00:34:  <!-- User Information -->
19:00:34:  <passkey v='********************************'/>
19:00:34:  <team v='225605'/>
19:00:34:  <user v='BlazinDimes'/>
19:00:34:
19:00:34:  <!-- Folding Slots -->
19:00:34:  <slot id='0' type='CPU'/>
19:00:34:</config>
19:00:34:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
Re: Please add this NVIDIA 1050 Variant
Do you know what makes this variant unique?
Also note:
indicates you saw this problem
Subject: Temporary server outages
Post by foldy »
Yes it is mobile variant missing from GPUs.txt
GP107M [GeForce GTX 1050 3 GB Max-Q]
https://devicehunt.com/view/type/pci/ve ... evice/1C31
BlazinDimes
It's in an HP gaming laptop so I assume it has something to do with it being a retail unit.
EDIT: Also yes I'm getting a lot of Gateway issues and I assumed it was due to heavy load from new users such as myself.
BlazinDimes
Not sure if it is worth using but I also have the Vega 8 which isn't recognized.
AMD Radeon(TM) Vega 8 Graphics
1002 15D8 - 103C 86D4
iGPUs are seldom worthwhile but CPUs with AVX2 are.
I can't figure out if the Picasso GPU supports DoublePrecision Floating point.
Post by foldy »
AMD Vega 8 has double presicion :-) But it may be too slow for FAH GPU work units.
https://www.techpowerup.com/gpu-specs/r ... ga-8.c3042
Added some GPUs that were missing in this family :
1c90 GP107M [GeForce MX150]
1c91 GP107M [GeForce GTX 1050 3 GB Max-Q]
1c94 GP107M [GeForce MX350]
1c96 GP107M [GeForce MX350]
JimTheoHome
Post by JimTheoHome »
Not sure if this is the right place, but my GPU is able to process WU, but my CPU stopped getting any access. Not sure if it is my configuration or what.
I7-7700@3.60 GHz. 8 CPU. Win10, folding slot 00 (doesn't appear to work now. Was working last Thursday)
GeForce GTX 1050Ti
Folding slot 01 (seems to be getting WU consistently and currently processing)
And as usual, "bad gateway" just like everyone else it seems.
Any suggestions?
JimTheoHome
I did get it to go. I changed the number of CPU's assigned from -1 to 4 (instead of all would be 6). Looked like it reset and now is working.
JimTheoHome wrote:Not sure if this is the right place
No it's not. This subforum is to make request to support new GPUs.
See : Temporary server outages
