Can't change from default theme
Rayburn76206
Post by Rayburn76206 »
4a3876256eee2c0777ea2b17dbcd33d034453122590917db4ac86639c52d3133b3dc680d038fad9f
Re: Can't change from default theme
Known problem.
Several of the themes conflicted with something in the Client. I guess the quick-fix was to force you to use one that works.
Given the exceptional level of current scientific activity, don't expect the next revision of the client any time soon.
Rayburn76206
Was that done recently then? Or is it an older thing that I've just stumbled across?
Also, don't suppose there's any way of changing the theme through the config files?
I know it has been a problem for a while.
When I installed the latest client I already knew about it and never tried to change the theme.
