155.247.166.220 503 HTTP_SERVICE_UNAVAILABLE
psimaster
Post by psimaster »
My GPU has not been receiving WU's, due to being unable to connect to the server.
17:30:38:FS00:Unpaused
17:30:38:FS01:Unpaused
17:30:38:WU02:FS01:Connecting to 65.254.110.245:8080
17:30:38:WU02:FS01:Assigned to work server 155.247.166.220
17:30:38:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.220
17:30:38:WU02:FS01:Connecting to 155.247.166.220:8080
17:30:38:ERROR:WU02:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:30:38:WU00:FS00:Starting
17:30:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Blank\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12800 -checkpoint 15 -np 7
17:30:38:WU00:FS00:Started FahCore on PID 16324
17:30:38:WU00:FS00:Core PID:16988
17:30:38:WU00:FS00:FahCore 0xa7 started
17:30:39:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:30:38Z ***********************
17:30:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:30:39:WU00:FS00:0xa7:       Type: 0xa7
17:30:39:WU00:FS00:0xa7:       Core: Gromacs
17:30:39:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 16324 -checkpoint 15 -np
17:30:39:WU00:FS00:0xa7:             7
17:30:39:WU00:FS00:0xa7:************************************ CBang *************************************
17:30:39:WU00:FS00:0xa7:       Date: Oct 26 2019
17:30:39:WU00:FS00:0xa7:       Time: 01:38:25
17:30:39:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:30:39:WU00:FS00:0xa7:     Branch: master
17:30:39:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:30:39:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:30:39:WU00:FS00:0xa7:   Platform: win32 10
17:30:39:WU00:FS00:0xa7:       Bits: 64
17:30:39:WU00:FS00:0xa7:       Mode: Release
17:30:39:WU00:FS00:0xa7:************************************ System ************************************
17:30:39:WU00:FS00:0xa7:        CPU: AMD FX(tm)-8350 Eight-Core Processor
17:30:39:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
17:30:39:WU00:FS00:0xa7:       CPUs: 8
17:30:39:WU00:FS00:0xa7:     Memory: 16.00GiB
17:30:39:WU00:FS00:0xa7:Free Memory: 9.12GiB
17:30:39:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:30:39:WU00:FS00:0xa7: OS Version: 6.2
17:30:39:WU00:FS00:0xa7:Has Battery: false
17:30:39:WU00:FS00:0xa7: On Battery: false
17:30:39:WU00:FS00:0xa7: UTC Offset: -4
17:30:39:WU00:FS00:0xa7:        PID: 16988
17:30:39:WU00:FS00:0xa7:        CWD: C:\Users\Blank\AppData\Roaming\FAHClient\work
17:30:39:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:30:39:WU00:FS00:0xa7:    Version: 0.0.18
17:30:39:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:30:39:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:30:39:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:30:39:WU00:FS00:0xa7:       Time: 01:52:30
17:30:39:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:30:39:WU00:FS00:0xa7:************************************ Build *************************************
17:30:39:WU00:FS00:0xa7:       SIMD: avx_256
17:30:39:WU00:FS00:0xa7:********************************************************************************
17:30:39:WU00:FS00:0xa7:Project: 14303 (Run 3, Clone 465, Gen 2)
17:30:39:WU00:FS00:0xa7:Unit: 0x000000029bf7a4d55e66cc5ea806d4a4
17:30:39:WU00:FS00:0xa7:Digital signatures verified
17:30:39:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
17:30:39:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 6
17:30:39:WU00:FS00:0xa7:Steps: first=1000000 total=500000
17:30:39:WU00:FS00:0xa7:Completed 347372 out of 500000 steps (69%)
Re: 155.247.166.220 503 HTTP_SERVICE_UNAVAILABLE
Post by foldy »
Did it work before? Then maybe the server is down. Or did it work never before? Then maybe you have some firewall which refuses connection?
soa_rru
Post by soa_rru »
Same for me on 2 rigs atm.
Halabec
Post by Halabec »
This is happening to me as of this morning as well. I'd been happily folding along for weeks now. When I woke up this morning, I had the "No WUs available for this configuration" reported in the "No more WUs for my GPU available?" thread. After exiting and restarting the client, I now get HTTP_SERVICE_UNAVAILABLE.
*********************** Log Started 2020-03-14T15:32:47Z ***********************
15:32:47:************************* Folding@home Client *************************
15:32:47:        Website: https://foldingathome.org/
15:32:47:      Copyright: (c) 2009-2018 foldingathome.org
15:32:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:32:47:           Args: --open-web-control
15:32:47:         Config: C:\Users\Jason\AppData\Roaming\FAHClient\config.xml
15:32:47:******************************** Build ********************************
15:32:47:        Version: 7.5.1
15:32:47:           Date: May 11 2018
15:32:47:           Time: 13:06:32
15:32:47:     Repository: Git
15:32:47:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:32:47:         Branch: master
15:32:47:       Compiler: Visual C++ 2008
15:32:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:32:47:       Platform: win32 10
15:32:47:           Bits: 32
15:32:47:           Mode: Release
15:32:47:******************************* System ********************************
15:32:47:            CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
15:32:47:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:32:47:           CPUs: 8
15:32:47:         Memory: 31.94GiB
15:32:47:    Free Memory: 19.01GiB
15:32:47:        Threads: WINDOWS_THREADS
15:32:47:     OS Version: 6.2
15:32:47:    Has Battery: false
15:32:47:     On Battery: false
15:32:47:     UTC Offset: -7
15:32:47:            PID: 36140
15:32:47:            CWD: C:\Users\Jason\AppData\Roaming\FAHClient
15:32:47:             OS: Windows 10 Enterprise
15:32:47:        OS Arch: AMD64
15:32:47:           GPUs: 1
15:32:47:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev. A]
15:32:47:                 M 13448
15:32:47:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
15:32:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
15:32:47:  Win32 Service: false
15:32:47:***********************************************************************
15:32:47:<config>
15:32:47:  <!-- Network -->
15:32:47:  <proxy v=':8080'/>
15:32:47:
15:32:47:  <!-- Slot Control -->
15:32:47:  <power v='full'/>
15:32:47:
15:32:47:  <!-- User Information -->
15:32:47:  <passkey v='********************************'/>
15:32:47:  <user v='JasonGore'/>
15:32:47:
15:32:47:  <!-- Folding Slots -->
15:32:47:  <slot id='1' type='GPU'/>
15:32:47:</config>
15:32:47:Trying to access database...
15:32:47:Successfully acquired database lock
15:32:47:Enabled folding slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
15:32:47:WU00:FS01:Connecting to 65.254.110.245:8080
15:32:48:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:32:48:WU00:FS01:Connecting to 18.218.241.186:80
15:32:48:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:32:48:ERROR:WU00:FS01:Exception: Could not get an assignment
15:32:48:WU00:FS01:Connecting to 65.254.110.245:8080
15:32:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:32:49:WU00:FS01:Connecting to 18.218.241.186:80
15:32:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:32:49:ERROR:WU00:FS01:Exception: Could not get an assignment
15:32:50:10:127.0.0.1:New Web connection
15:33:49:WU00:FS01:Connecting to 65.254.110.245:8080
15:33:49:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:33:49:WU00:FS01:Connecting to 18.218.241.186:80
15:33:49:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:33:49:ERROR:WU00:FS01:Exception: Could not get an assignment
15:35:26:WU00:FS01:Connecting to 65.254.110.245:8080
15:35:26:WU00:FS01:Assigned to work server 155.247.166.220
15:35:26:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
15:35:26:WU00:FS01:Connecting to 155.247.166.220:8080
15:35:26:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:38:03:WU00:FS01:Connecting to 65.254.110.245:8080
15:38:03:WU00:FS01:Assigned to work server 155.247.166.220
15:38:03:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
15:38:03:WU00:FS01:Connecting to 155.247.166.220:8080
15:38:03:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:42:17:WU00:FS01:Connecting to 65.254.110.245:8080
15:42:17:WU00:FS01:Assigned to work server 155.247.166.220
15:42:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
15:42:17:WU00:FS01:Connecting to 155.247.166.220:8080
15:42:18:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:49:09:WU00:FS01:Connecting to 65.254.110.245:8080
15:49:09:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:49:09:WU00:FS01:Connecting to 18.218.241.186:80
15:49:09:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:49:09:ERROR:WU00:FS01:Exception: Could not get an assignment
16:00:14:WU00:FS01:Connecting to 65.254.110.245:8080
16:00:14:WU00:FS01:Assigned to work server 155.247.166.220
16:00:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
16:00:14:WU00:FS01:Connecting to 155.247.166.220:8080
16:00:15:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
16:18:11:WU00:FS01:Connecting to 65.254.110.245:8080
16:18:11:WU00:FS01:Assigned to work server 155.247.166.220
16:18:11:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
16:18:11:WU00:FS01:Connecting to 155.247.166.220:8080
16:18:11:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
16:47:13:WU00:FS01:Connecting to 65.254.110.245:8080
16:47:13:WU00:FS01:Assigned to work server 155.247.166.220
16:47:13:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
16:47:13:WU00:FS01:Connecting to 155.247.166.220:8080
16:47:14:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:34:12:WU00:FS01:Connecting to 65.254.110.245:8080
17:34:12:WU00:FS01:Assigned to work server 155.247.166.220
17:34:12:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 155.247.166.220
17:34:12:WU00:FS01:Connecting to 155.247.166.220:8080
17:34:13:ERROR:WU00:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
psimaster
Post by psimaster »
Just load it in your browser and you will see the 503 HTTP_SERVICE_UNAVAILABLE error.
http://155.247.166.220/
Educated guess: The server is busy generating new WUs.
Many servers ran out of GPU WU's overnight and it has to be taken off-line during that processing.
psimaster
Post by psimaster »
I'm now getting WU's from 140.163.4.231.
There are three 155 servers down.
Who's editing my posts? :eo
