GPU folding not starting
Kirnal
Post by Kirnal »
Hello,
My GPU folding is not starting. I have a 1080 ti. Below is the output from the log
*********************** Log Started 2020-03-14T17:25:26Z ***********************
17:25:26:************************* Folding@home Client *************************
17:25:26:        Website: https://foldingathome.org/
17:25:26:      Copyright: (c) 2009-2018 foldingathome.org
17:25:26:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:25:26:           Args: --open-web-control
17:25:26:         Config: C:\Users\Wowba\AppData\Roaming\FAHClient\config.xml
17:25:26:******************************** Build ********************************
17:25:26:        Version: 7.5.1
17:25:26:           Date: May 11 2018
17:25:26:           Time: 13:06:32
17:25:26:     Repository: Git
17:25:26:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:25:26:         Branch: master
17:25:26:       Compiler: Visual C++ 2008
17:25:26:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:25:26:       Platform: win32 10
17:25:26:           Bits: 32
17:25:26:           Mode: Release
17:25:26:******************************* System ********************************
17:25:26:            CPU: AMD Ryzen 9 3900X 12-Core Processor
17:25:26:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
17:25:26:           CPUs: 24
17:25:26:         Memory: 31.95GiB
17:25:26:    Free Memory: 22.93GiB
17:25:26:        Threads: WINDOWS_THREADS
17:25:26:     OS Version: 6.2
17:25:26:    Has Battery: false
17:25:26:     On Battery: false
17:25:26:     UTC Offset: -4
17:25:26:            PID: 15620
17:25:26:            CWD: C:\Users\Wowba\AppData\Roaming\FAHClient
17:25:26:             OS: Windows 10 Enterprise
17:25:26:        OS Arch: AMD64
17:25:26:           GPUs: 1
17:25:26:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:8 GP102 [GeForce GTX 1080 Ti] 11380
17:25:26:  CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:6.1 Driver:10.2
17:25:26:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:442.59
17:25:26:  Win32 Service: false
17:25:26:***********************************************************************
17:25:26:<config>
17:25:26:  <!-- Network -->
17:25:26:  <proxy v=':8080'/>
17:25:26:
17:25:26:  <!-- Slot Control -->
17:25:26:  <power v='FULL'/>
17:25:26:
17:25:26:  <!-- User Information -->
17:25:26:  <team v='225605'/>
17:25:26:  <user v='Kirnal'/>
17:25:26:
17:25:26:  <!-- Folding Slots -->
17:25:26:  <slot id='1' type='GPU'/>
17:25:26:  <slot id='0' type='CPU'/>
17:25:26:</config>
17:25:27:Trying to access database...
17:25:27:Successfully acquired database lock
17:25:27:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380
17:25:27:Enabled folding slot 00: READY cpu:23
17:25:27:WU00:FS00:Starting
17:25:27:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Wowba\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15620 -checkpoint 15 -np 23
17:25:27:WU00:FS00:Started FahCore on PID 13284
17:25:27:WU00:FS00:Core PID:14396
17:25:27:WU00:FS00:FahCore 0xa7 started
17:25:27:WU01:FS01:Connecting to 65.254.110.245:8080
17:25:27:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T17:25:27Z ***********************
17:25:27:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:25:27:WU00:FS00:0xa7:       Type: 0xa7
17:25:27:WU00:FS00:0xa7:       Core: Gromacs
17:25:27:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 13284 -checkpoint 15 -np
17:25:27:WU00:FS00:0xa7:             23
17:25:27:WU00:FS00:0xa7:************************************ CBang *************************************
17:25:27:WU00:FS00:0xa7:       Date: Oct 26 2019
17:25:27:WU00:FS00:0xa7:       Time: 01:38:25
17:25:27:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:25:27:WU00:FS00:0xa7:     Branch: master
17:25:27:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
17:25:27:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:25:27:WU00:FS00:0xa7:   Platform: win32 10
17:25:27:WU00:FS00:0xa7:       Bits: 64
17:25:27:WU00:FS00:0xa7:       Mode: Release
17:25:27:WU00:FS00:0xa7:************************************ System ************************************
17:25:27:WU00:FS00:0xa7:        CPU: AMD Ryzen 9 3900X 12-Core Processor
17:25:27:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
17:25:27:WU00:FS00:0xa7:       CPUs: 24
17:25:27:WU00:FS00:0xa7:     Memory: 31.95GiB
17:25:27:WU00:FS00:0xa7:Free Memory: 22.92GiB
17:25:27:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
17:25:27:WU00:FS00:0xa7: OS Version: 6.2
17:25:27:WU00:FS00:0xa7:Has Battery: false
17:25:27:WU00:FS00:0xa7: On Battery: false
17:25:27:WU00:FS00:0xa7: UTC Offset: -4
17:25:27:WU00:FS00:0xa7:        PID: 14396
17:25:27:WU00:FS00:0xa7:        CWD: C:\Users\Wowba\AppData\Roaming\FAHClient\work
17:25:27:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
17:25:27:WU00:FS00:0xa7:    Version: 0.0.18
17:25:27:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:25:27:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
17:25:27:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
17:25:27:WU00:FS00:0xa7:       Time: 01:52:30
17:25:27:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:25:27:WU00:FS00:0xa7:************************************ Build *************************************
17:25:27:WU00:FS00:0xa7:       SIMD: avx_256
17:25:27:WU00:FS00:0xa7:********************************************************************************
17:25:27:WU00:FS00:0xa7:Project: 14304 (Run 2, Clone 778, Gen 1)
17:25:27:WU00:FS00:0xa7:Unit: 0x000000019bf7a4d55e66cac26360ab98
17:25:27:WU00:FS00:0xa7:Digital signatures verified
17:25:27:WU00:FS00:0xa7:Reducing thread count from 23 to 22 to avoid domain decomposition by a prime number > 3
17:25:27:WU00:FS00:0xa7:Reducing thread count from 22 to 21 to avoid domain decomposition with large prime factor 11
17:25:27:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpi state.cpt -cpt 15 -nt 21
17:25:27:WU00:FS00:0xa7:Steps: first=500000 total=500000
17:25:27:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:25:27:WU01:FS01:Connecting to 18.218.241.186:80
17:25:27:WU01:FS01:Assigned to work server 140.163.4.241
17:25:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 140.163.4.241
17:25:27:WU01:FS01:Connecting to 140.163.4.241:8080
17:25:28:WU00:FS00:0xa7:Completed 179602 out of 500000 steps (35%)
17:25:30:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
17:25:44:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
17:25:45:ERROR:WU01:FS01:Exception: Server did not assign work unit
17:25:45:WU01:FS01:Connecting to 65.254.110.245:8080
17:25:45:WU01:FS01:Assigned to work server 155.247.166.220
17:25:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.220
17:25:45:WU01:FS01:Connecting to 155.247.166.220:8080
17:25:46:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
17:25:58:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
17:26:11:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
17:26:24:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
17:26:38:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
17:26:45:WU01:FS01:Connecting to 65.254.110.245:8080
17:26:45:WU01:FS01:Assigned to work server 155.247.166.220
17:26:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.220
17:26:45:WU01:FS01:Connecting to 155.247.166.220:8080
17:26:45:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:26:51:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
17:27:05:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
17:27:18:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
17:27:32:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
17:27:45:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
17:27:59:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
17:28:13:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
17:28:22:WU01:FS01:Connecting to 65.254.110.245:8080
17:28:22:WU01:FS01:Assigned to work server 155.247.166.220
17:28:22:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] 11380 from 155.247.166.220
17:28:22:WU01:FS01:Connecting to 155.247.166.220:8080
17:28:23:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:28:26:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
17:28:40:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
17:28:53:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
17:29:07:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
Re: GPU folding not starting
