Currently the visualizer is set to demo only. Under connection it states "Trying." CPU is working just fine, however the GPU is not working at all, just says "Ready." I assume the GPU issue is the same one that everyone else is having so I will let the PC run for awhile to see if that changes, however I haven't seen anyone mention that their visualizer is not showing the actual protein being folded by the CPU. I ran through the preferences and settings but wasn't sure of what to change (if anything) to get it to show what the actual CPU is working on. As it sits, the Visualizer shows:
[Current Work Unit]
Project:
FahCore:
Progress:
Time Left:
[Status]
Snapshots: # of 4 (counting down from 4)
Connection: Trying
Protein: Demo
Slot:
[Donor]
Name:
Team:
My name and team were filled out. The FAHControl seems to be working (CPU progress is at 4%, which I'm assuming it finished the last task as it was at 87% when I started this post).
The log file shows the following:
*********************** Log Started 2020-03-14T15:36:44Z ***********************
15:37:39:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:38:39:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:40:16:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:42:53:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
15:47:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:47:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:47:08:ERROR:WU01:FS01:Exception: Could not get an assignment
Under System Info:
CPU: Intel Core i7-9700K CPU @ 3.60 GHz
Memory: 31.91 GiB
Free Memory: 26.72 GiB
Threads: WINDOWS_THREADS
PID: 15696
OS: Win 10 Home
OS Arch: AMD64
GPUs: 0
CUDA Device 0: Platform: 0 Device: 0 Bus: 1 Slot: 0 Compute: 7.5 Driver: 10.2
OpenCL Device 0: Platform: 0 Device: 0 Bus: 1 Slot: 0 Compute: 1.2 Driver: 442.37
Win32 Service: False
I'm on build version 7.5.1 of the client.
My GPU is a RTX 2080 Ti
Visualizer In Demo Mode
MarMun_1701
3D visualization only shows 'demo'?
If I open the 'viewer' window, I only see the 'demo' protein.
Also, no infos for project, FahCore, Progress, etc...
Connection is stuck at 'trying'...
Any ideas?
Here my logs:
Any ideas?
Here my logs:
*********************** Log Started 2020-03-14T14:01:31Z ***********************
14:02:33:WU00:FS00:Connecting to 65.254.110.245:8080
14:02:34:WU00:FS00:Assigned to work server 128.252.203.9
14:02:34:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 128.252.203.9
14:02:34:WU00:FS00:Connecting to 128.252.203.9:8080
14:02:34:WU00:FS00:Downloading 8.14MiB
14:02:36:WU00:FS00:Download complete
14:02:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13829 run:425 clone:0 gen:107 core:0xa7 unit:0x0000007c80fccb095d66d3e96dffb303
14:02:36:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
14:02:36:WU00:FS00:Connecting to cores.foldingathome.org:80
14:02:36:WU00:FS00:FahCore a7: Downloading 6.71MiB
14:02:38:WU00:FS00:FahCore a7: Download complete
14:02:38:WU00:FS00:Valid core signature
14:02:38:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
14:02:38:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
14:02:38:WU00:FS00:Starting
14:02:38:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Martin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9184 -checkpoint 15 -np 2
14:02:38:WU00:FS00:Started FahCore on PID 14280
14:02:39:WU00:FS00:Core PID:14216
14:02:39:WU00:FS00:FahCore 0xa7 started
14:02:39:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T14:02:39Z ***********************
14:02:39:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:02:39:WU00:FS00:0xa7: Type: 0xa7
14:02:39:WU00:FS00:0xa7: Core: Gromacs
14:02:39:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 14280 -checkpoint 15 -np
14:02:39:WU00:FS00:0xa7: 2
14:02:39:WU00:FS00:0xa7:************************************ CBang *************************************
14:02:39:WU00:FS00:0xa7: Date: Oct 26 2019
14:02:39:WU00:FS00:0xa7: Time: 01:38:25
14:02:39:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:02:39:WU00:FS00:0xa7: Branch: master
14:02:39:WU00:FS00:0xa7: Compiler: Visual C++ 2008
14:02:39:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:02:39:WU00:FS00:0xa7: Platform: win32 10
14:02:39:WU00:FS00:0xa7: Bits: 64
14:02:39:WU00:FS00:0xa7: Mode: Release
14:02:39:WU00:FS00:0xa7:************************************ System ************************************
14:02:39:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
14:02:39:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:02:39:WU00:FS00:0xa7: CPUs: 4
14:02:39:WU00:FS00:0xa7: Memory: 15.94GiB
14:02:39:WU00:FS00:0xa7:Free Memory: 11.22GiB
14:02:39:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
14:02:39:WU00:FS00:0xa7: OS Version: 6.2
14:02:39:WU00:FS00:0xa7:Has Battery: false
14:02:39:WU00:FS00:0xa7: On Battery: false
14:02:39:WU00:FS00:0xa7: UTC Offset: 1
14:02:39:WU00:FS00:0xa7: PID: 14216
14:02:39:WU00:FS00:0xa7: CWD: C:\Users\Martin\AppData\Roaming\FAHClient\work
14:02:39:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:02:39:WU00:FS00:0xa7: Version: 0.0.18
14:02:39:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:02:39:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
14:02:39:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
14:02:39:WU00:FS00:0xa7: Time: 01:52:30
14:02:39:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:02:39:WU00:FS00:0xa7:************************************ Build *************************************
14:02:39:WU00:FS00:0xa7: SIMD: avx_256
14:02:39:WU00:FS00:0xa7:********************************************************************************
14:02:39:WU00:FS00:0xa7:Project: 13829 (Run 425, Clone 0, Gen 107)
14:02:39:WU00:FS00:0xa7:Unit: 0x0000007c80fccb095d66d3e96dffb303
14:02:39:WU00:FS00:0xa7:Reading tar file core.xml
14:02:39:WU00:FS00:0xa7:Reading tar file frame107.tpr
14:02:39:WU00:FS00:0xa7:Digital signatures verified
14:02:39:WU00:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -cpt 15 -nt 2
14:02:39:WU00:FS00:0xa7:Steps: first=13375000 total=125000
14:02:42:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
14:06:30:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
14:10:15:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
14:14:21:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
14:18:19:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
14:22:06:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
15:22:34:WARNING:WU00:FS00:Detected clock skew (59 mins 59 secs), I/O delay, laptop hibernation or other slowdown noted, adjusting time estimates
15:22:35:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
15:22:35:WARNING:WU00:FS00:FahCore returned: WU_STALLED (127 = 0x7f)
15:22:35:WU00:FS00:Starting
15:22:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Martin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9184 -checkpoint 15 -np 2
15:22:35:WU00:FS00:Started FahCore on PID 6440
15:22:35:WU00:FS00:Core PID:6548
15:22:35:WU00:FS00:FahCore 0xa7 started
15:22:36:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T15:22:35Z ***********************
15:22:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:22:36:WU00:FS00:0xa7: Type: 0xa7
15:22:36:WU00:FS00:0xa7: Core: Gromacs
15:22:36:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6440 -checkpoint 15 -np 2
15:22:36:WU00:FS00:0xa7:************************************ CBang *************************************
15:22:36:WU00:FS00:0xa7: Date: Oct 26 2019
15:22:36:WU00:FS00:0xa7: Time: 01:38:25
15:22:36:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:22:36:WU00:FS00:0xa7: Branch: master
15:22:36:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:22:36:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:22:36:WU00:FS00:0xa7: Platform: win32 10
15:22:36:WU00:FS00:0xa7: Bits: 64
15:22:36:WU00:FS00:0xa7: Mode: Release
15:22:36:WU00:FS00:0xa7:************************************ System ************************************
15:22:36:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
15:22:36:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:22:36:WU00:FS00:0xa7: CPUs: 4
15:22:36:WU00:FS00:0xa7: Memory: 15.94GiB
15:22:36:WU00:FS00:0xa7:Free Memory: 11.78GiB
15:22:36:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:22:36:WU00:FS00:0xa7: OS Version: 6.2
15:22:36:WU00:FS00:0xa7:Has Battery: false
15:22:36:WU00:FS00:0xa7: On Battery: false
15:22:36:WU00:FS00:0xa7: UTC Offset: 1
15:22:36:WU00:FS00:0xa7: PID: 6548
15:22:36:WU00:FS00:0xa7: CWD: C:\Users\Martin\AppData\Roaming\FAHClient\work
15:22:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:22:36:WU00:FS00:0xa7: Version: 0.0.18
15:22:36:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:22:36:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:22:36:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:22:36:WU00:FS00:0xa7: Time: 01:52:30
15:22:36:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:22:36:WU00:FS00:0xa7:************************************ Build *************************************
15:22:36:WU00:FS00:0xa7: SIMD: avx_256
15:22:36:WU00:FS00:0xa7:********************************************************************************
15:22:36:WU00:FS00:0xa7:Project: 13829 (Run 425, Clone 0, Gen 107)
15:22:36:WU00:FS00:0xa7:Unit: 0x0000007c80fccb095d66d3e96dffb303
15:22:36:WU00:FS00:0xa7:Digital signatures verified
15:22:36:WU00:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -cpi state.cpt -cpt 15 -nt 2
15:22:36:WU00:FS00:0xa7:Steps: first=13375000 total=125000
15:22:38:WU00:FS00:0xa7:Completed 4801 out of 125000 steps (3%)
15:23:13:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
15:27:02:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
15:30:46:WU00:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
15:32:59:FS00:Shutting core down
15:33:00:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6548
15:33:00:WU00:FS00:0xa7:Exiting, please wait. . .
15:33:02:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:33:02:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:33:03:WU00:FS00:Starting
15:33:03:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
15:33:03:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
15:33:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Martin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9184 -checkpoint 15 -np 2
15:33:03:WU00:FS00:Started FahCore on PID 1012
15:33:03:WU00:FS00:Core PID:12728
15:33:03:WU00:FS00:FahCore 0xa7 started
15:33:03:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T15:33:03Z ***********************
15:33:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:33:03:WU00:FS00:0xa7: Type: 0xa7
15:33:03:WU00:FS00:0xa7: Core: Gromacs
15:33:03:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 1012 -checkpoint 15 -np 2
15:33:03:WU00:FS00:0xa7:************************************ CBang *************************************
15:33:03:WU00:FS00:0xa7: Date: Oct 26 2019
15:33:03:WU00:FS00:0xa7: Time: 01:38:25
15:33:03:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:33:03:WU00:FS00:0xa7: Branch: master
15:33:03:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:33:03:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:33:03:WU00:FS00:0xa7: Platform: win32 10
15:33:03:WU00:FS00:0xa7: Bits: 64
15:33:03:WU00:FS00:0xa7: Mode: Release
15:33:03:WU00:FS00:0xa7:************************************ System ************************************
15:33:03:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
15:33:03:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:33:03:WU00:FS00:0xa7: CPUs: 4
15:33:03:WU00:FS00:0xa7: Memory: 15.94GiB
15:33:03:WU00:FS00:0xa7:Free Memory: 12.28GiB
15:33:03:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:33:03:WU00:FS00:0xa7: OS Version: 6.2
15:33:03:WU00:FS00:0xa7:Has Battery: false
15:33:03:WU00:FS00:0xa7: On Battery: false
15:33:03:WU00:FS00:0xa7: UTC Offset: 1
15:33:03:WU00:FS00:0xa7: PID: 12728
15:33:03:WU00:FS00:0xa7: CWD: C:\Users\Martin\AppData\Roaming\FAHClient\work
15:33:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:33:03:WU00:FS00:0xa7: Version: 0.0.18
15:33:03:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:33:03:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:33:03:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:33:03:WU00:FS00:0xa7: Time: 01:52:30
15:33:03:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:33:03:WU00:FS00:0xa7:************************************ Build *************************************
15:33:03:WU00:FS00:0xa7: SIMD: avx_256
15:33:03:WU00:FS00:0xa7:********************************************************************************
15:33:03:WU00:FS00:0xa7:Project: 13829 (Run 425, Clone 0, Gen 107)
15:33:03:WU00:FS00:0xa7:Unit: 0x0000007c80fccb095d66d3e96dffb303
15:33:03:WU00:FS00:0xa7:Digital signatures verified
15:33:03:WU00:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -cpi state.cpt -cpt 15 -nt 2
15:33:03:WU00:FS00:0xa7:Steps: first=13375000 total=125000
15:33:05:WU00:FS00:0xa7:Completed 8262 out of 125000 steps (6%)
15:33:54:FS00:Shutting core down
15:33:55:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 12728
15:33:55:WU00:FS00:0xa7:Exiting, please wait. . .
15:33:56:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:34:03:WU00:FS00:Starting
15:34:03:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
15:34:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Martin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9184 -checkpoint 15 -np 2
15:34:03:WU00:FS00:Started FahCore on PID 8060
15:34:03:WU00:FS00:Core PID:10856
15:34:03:WU00:FS00:FahCore 0xa7 started
15:34:03:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T15:34:03Z ***********************
15:34:03:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:34:03:WU00:FS00:0xa7: Type: 0xa7
15:34:03:WU00:FS00:0xa7: Core: Gromacs
15:34:03:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 8060 -checkpoint 15 -np 2
15:34:03:WU00:FS00:0xa7:************************************ CBang *************************************
15:34:03:WU00:FS00:0xa7: Date: Oct 26 2019
15:34:03:WU00:FS00:0xa7: Time: 01:38:25
15:34:03:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:34:03:WU00:FS00:0xa7: Branch: master
15:34:03:WU00:FS00:0xa7: Compiler: Visual C++ 2008
15:34:03:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:34:03:WU00:FS00:0xa7: Platform: win32 10
15:34:03:WU00:FS00:0xa7: Bits: 64
15:34:03:WU00:FS00:0xa7: Mode: Release
15:34:03:WU00:FS00:0xa7:************************************ System ************************************
15:34:03:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
15:34:03:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
15:34:03:WU00:FS00:0xa7: CPUs: 4
15:34:03:WU00:FS00:0xa7: Memory: 15.94GiB
15:34:03:WU00:FS00:0xa7:Free Memory: 12.26GiB
15:34:03:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
15:34:03:WU00:FS00:0xa7: OS Version: 6.2
15:34:03:WU00:FS00:0xa7:Has Battery: false
15:34:03:WU00:FS00:0xa7: On Battery: false
15:34:03:WU00:FS00:0xa7: UTC Offset: 1
15:34:03:WU00:FS00:0xa7: PID: 10856
15:34:03:WU00:FS00:0xa7: CWD: C:\Users\Martin\AppData\Roaming\FAHClient\work
15:34:03:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
15:34:03:WU00:FS00:0xa7: Version: 0.0.18
15:34:03:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:34:03:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
15:34:03:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
15:34:03:WU00:FS00:0xa7: Time: 01:52:30
15:34:03:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:34:03:WU00:FS00:0xa7:************************************ Build *************************************
15:34:03:WU00:FS00:0xa7: SIMD: avx_256
15:34:03:WU00:FS00:0xa7:********************************************************************************
15:34:03:WU00:FS00:0xa7:Project: 13829 (Run 425, Clone 0, Gen 107)
15:34:03:WU00:FS00:0xa7:Unit: 0x0000007c80fccb095d66d3e96dffb303
15:34:03:WU00:FS00:0xa7:Digital signatures verified
15:34:03:WU00:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -cpi state.cpt -cpt 15 -nt 2
15:34:03:WU00:FS00:0xa7:Steps: first=13375000 total=125000
15:34:05:WU00:FS00:0xa7:Completed 8542 out of 125000 steps (6%)
15:34:42:WU00:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
15:38:26:WU00:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
15:42:28:WU00:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
15:46:14:WU00:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
15:50:06:WU00:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
15:53:51:WU00:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
15:57:41:WU00:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
16:01:38:WU00:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
16:05:36:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
16:09:23:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
16:13:10:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
16:17:01:WU00:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
16:20:47:WU00:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
16:24:31:WU00:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
16:27:46:FS00:Paused
16:27:46:FS00:Shutting core down
16:27:46:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10856
16:27:46:WU00:FS00:0xa7:Exiting, please wait. . .
16:27:48:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:27:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:27:58:FS00:Unpaused
16:27:58:WU00:FS00:Starting
16:27:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Martin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9184 -checkpoint 15 -np 2
16:27:58:WU00:FS00:Started FahCore on PID 7128
16:27:58:WU00:FS00:Core PID:6420
16:27:58:WU00:FS00:FahCore 0xa7 started
16:27:58:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T16:27:58Z ***********************
16:27:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:27:58:WU00:FS00:0xa7: Type: 0xa7
16:27:58:WU00:FS00:0xa7: Core: Gromacs
16:27:58:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 7128 -checkpoint 15 -np 2
16:27:58:WU00:FS00:0xa7:************************************ CBang *************************************
16:27:58:WU00:FS00:0xa7: Date: Oct 26 2019
16:27:58:WU00:FS00:0xa7: Time: 01:38:25
16:27:58:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:27:58:WU00:FS00:0xa7: Branch: master
16:27:58:WU00:FS00:0xa7: Compiler: Visual C++ 2008
16:27:58:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:27:58:WU00:FS00:0xa7: Platform: win32 10
16:27:58:WU00:FS00:0xa7: Bits: 64
16:27:58:WU00:FS00:0xa7: Mode: Release
16:27:58:WU00:FS00:0xa7:************************************ System ************************************
16:27:58:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
16:27:58:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
16:27:58:WU00:FS00:0xa7: CPUs: 4
16:27:58:WU00:FS00:0xa7: Memory: 15.94GiB
16:27:58:WU00:FS00:0xa7:Free Memory: 11.44GiB
16:27:58:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
16:27:58:WU00:FS00:0xa7: OS Version: 6.2
16:27:58:WU00:FS00:0xa7:Has Battery: false
16:27:58:WU00:FS00:0xa7: On Battery: false
16:27:58:WU00:FS00:0xa7: UTC Offset: 1
16:27:58:WU00:FS00:0xa7: PID: 6420
16:27:58:WU00:FS00:0xa7: CWD: C:\Users\Martin\AppData\Roaming\FAHClient\work
16:27:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:27:58:WU00:FS00:0xa7: Version: 0.0.18
16:27:58:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:27:58:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
16:27:58:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
16:27:58:WU00:FS00:0xa7: Time: 01:52:30
16:27:58:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:27:58:WU00:FS00:0xa7:************************************ Build *************************************
16:27:58:WU00:FS00:0xa7: SIMD: avx_256
16:27:58:WU00:FS00:0xa7:********************************************************************************
16:27:58:WU00:FS00:0xa7:Project: 13829 (Run 425, Clone 0, Gen 107)
16:27:58:WU00:FS00:0xa7:Unit: 0x0000007c80fccb095d66d3e96dffb303
16:27:58:WU00:FS00:0xa7:Digital signatures verified
16:27:58:WU00:FS00:0xa7:Calling: mdrun -s frame107.tpr -o frame107.trr -x frame107.xtc -cpi state.cpt -cpt 15 -nt 2
16:27:58:WU00:FS00:0xa7:Steps: first=13375000 total=125000
16:28:01:WU00:FS00:0xa7:Completed 26082 out of 125000 steps (20%)
16:28:30:WU00:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
16:32:17:WU00:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
16:36:15:WU00:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
Re: Visualizer In Demo Mode
There is a known issue with the current version of FAHViewer not working to display other than the demo when used on Windows.
As for trouble getting WU's assigned, please see this - Subject: Temporary server outages
