GPU Utilization - Capped around 45%
thebestplaya
Post by thebestplaya »
Hi! I recently learned about FaH and felt like it would be a great way to spend my laptop's resources while I'm not directly using it. However, I have noticed something - when I look in the task manager, it seems that the process being run (FahCore_22, specifically) is only using about ~45% of my gpu's maximum capabilities. Is there any way to increase that usage? To me, it's ~50% of the gpu not being utilized, so I may as well have it be dedicated to Fah. I already set the priority of the specific FahCore_22.exe to high (from low), so I'm not very sure what else I can do to try and maximize GPU usage. Would any of you be able to let me know more? Thanks so much!
Re: GPU Utilization - Capped around 45%
In a laptop it is possible your GPU is being limited for thermal reasons. Also, if you haven't changed what Task Manager is displaying from the default, then it is not showing the actual GPU utilization. Other GPU monitoring tools such as GPU-Z are more direct at displaying utilization.
What do you use to check your GPU utilization ? If it is Windows Task Manager, it is normal : by default, it displays "3D" load which is not an accurate picture of FAH load. You need to select "Compute" instead.
You can also use GPUZ 3rd party tool that is doing very well at showing everything about your GPU.
