GPU unsupported
raiden0134
GPU unsupported
Post by raiden0134 »
*********************** Log Started 2020-03-14T14:49:37Z ***********************
14:49:37:************************* Folding@home Client *************************
14:49:37:        Website: https://foldingathome.org/
14:49:37:      Copyright: (c) 2009-2018 foldingathome.org
14:49:37:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:49:37:           Args: --open-web-control
14:49:37:         Config: C:\Users\ROG\AppData\Roaming\FAHClient\config.xml
14:49:37:******************************** Build ********************************
14:49:37:        Version: 7.5.1
14:49:37:           Date: May 11 2018
14:49:37:           Time: 13:06:32
14:49:37:     Repository: Git
14:49:37:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:49:37:         Branch: master
14:49:37:       Compiler: Visual C++ 2008
14:49:37:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:49:37:       Platform: win32 10
14:49:37:           Bits: 32
14:49:37:           Mode: Release
14:49:37:******************************* System ********************************
14:49:37:            CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
14:49:37:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
14:49:37:           CPUs: 8
14:49:37:         Memory: 15.89GiB
14:49:37:    Free Memory: 4.91GiB
14:49:37:        Threads: WINDOWS_THREADS
14:49:37:     OS Version: 6.2
14:49:37:    Has Battery: true
14:49:37:     On Battery: false
14:49:37:     UTC Offset: 1
14:49:37:            PID: 14348
14:49:37:            CWD: C:\Users\ROG\AppData\Roaming\FAHClient
14:49:37:             OS: Windows 10 Enterprise
14:49:37:        OS Arch: AMD64
14:49:37:           GPUs: 1
14:49:37:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP107M [GeForce GTX 1050 Ti
14:49:37:                 Mobile]
14:49:37:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
14:49:37:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
14:49:37:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
14:49:37:  Win32 Service: false
14:49:37:***********************************************************************
14:49:37:<config>
14:49:37:  <!-- Network -->
14:49:37:  <proxy v=':8080'/>
14:49:37:
14:49:37:  <!-- Slot Control -->
14:49:37:  <power v='full'/>
14:49:37:
14:49:37:  <!-- User Information -->
14:49:37:  <passkey v='********************************'/>
14:49:37:  <team v='225605'/>
14:49:37:  <user v='Raiden_0134'/>
14:49:37:
14:49:37:  <!-- Folding Slots -->
14:49:37:  <slot id='1' type='GPU'/>
14:49:37:</config>
14:49:37:Trying to access database...
14:49:37:Successfully acquired database lock
14:49:37:Enabled folding slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Ti Mobile]
14:49:37:WARNING:WU00:No longer matches Slot 1's configuration and there are no other matching slots, dumping
14:49:37:WU00:FS01:Sending unit results: id:00 state:SEND error:DUMPED project:14198 run:8 clone:498 gen:1 core:0xa7 unit:0x000000019bf7a4d55e66ceec679cb7bb
14:49:37:WU00:FS01:Connecting to 155.247.164.213:8080
14:49:37:WU01:FS01:Connecting to 65.254.110.245:8080
14:49:38:WARNING:WU00:FS01:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
14:49:38:WU00:FS01:Trying to send results to collection server
14:49:38:WU00:FS01:Connecting to 155.247.164.214:8080
14:49:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:49:38:WU01:FS01:Connecting to 18.218.241.186:80
14:49:38:WU00:FS01:Server responded WORK_ACK (400)
14:49:38:WU00:FS01:Cleaning up
14:49:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:49:38:ERROR:WU01:FS01:Exception: Could not get an assignment
14:49:38:WU01:FS01:Connecting to 65.254.110.245:8080
14:49:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:49:39:WU01:FS01:Connecting to 18.218.241.186:80
14:49:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:49:39:ERROR:WU01:FS01:Exception: Could not get an assignment
14:50:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:50:38:WU01:FS01:Connecting to 65.254.110.245:8080
14:50:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:50:39:WU01:FS01:Connecting to 18.218.241.186:80
14:50:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:50:39:ERROR:WU01:FS01:Exception: Could not get an assignment
14:52:16:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:52:16:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:52:16:ERROR:WU01:FS01:Exception: Could not get an assignment
14:54:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:54:52:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:54:52:ERROR:WU01:FS01:Exception: Could not get an assignment
14:55:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
14:56:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:56:29:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:56:29:ERROR:WU01:FS01:Exception: Could not get an assignment
0x10ec:0x8168:3:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIe GBE Family Controller
0x8086:0xa121:0:31:2:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
0x8086:0xa160:0:21:0:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A160
0x8086:0xa171:0:31:3:Intel Corporation:High Definition Audio Controller
0x10ec:0x5229:4:0:0:Realtek Semiconductor Co., Ltd.:Realtek PCIE CardReader
0x8086:0xa123:0:31:4:Intel Corporation:Synaptics SMBus Driver
0x10de:0x1c8c:1:0:0:NVIDIA Corporation:NVIDIA GeForce GTX 1050 Ti
0x8086:0xa116:0:28:6:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #7 - A116
0x8086:0xa12f:0:20:0:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0xa131:0:20:2:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
0x8086:0xa103:0:23:0:Intel Corporation:Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
0x8086:0xa113:0:28:3:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #4 - A113
0x8086:0x5910:0:0:0:Intel Corporation:Intel(R) Host Bridge/DRAM Registers - 5910
0x8086:0xa13a:0:22:0:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x591b:0:2:0:Intel Corporation:Intel(R) HD Graphics 630
0x8086:0x1911:0:8:0:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
0x8086:0x095a:2:0:0:Intel Corporation:Intel(R) Dual Band Wireless-AC 7265
0x8086:0xa112:0:28:0:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #3 - A112
0x8086:0x1901:0:1:0:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
0x8086:0xa152:0:31:0:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family LPC Controller (HM175) - A152
Re: GPU unsupported
This GPU is already in the list of supported GPUs.
Re: GPU unsupported
Post by foldy »
Probably this: Temporary server outages
viewtopic.php?p=312692#p312692
