AMD Vega Frontier Edition Liquid
exander
Post by exander »
Can I fold with this GPU? I new to this, GPU stays at 0% load.
Re: AMD Vega Frontier Edition Liquid
If you are not getting assignments - viewtopic.php?f=24&t=32424
If the client does not recognize the GPU as supported, post the first couple hundred lines of the log file here and someone can take a look at it.
Yes your card is supported. It needs to support OPENCL 1.2 or better and it does. It needs to have hardware support for Double Precision Math and it does.
You may need the latest Driver straight from AMD and there is an ID you may need to look up if no one else has ever used the card to Fold with.
https://www.techpowerup.com/gpu-specs/r ... oled.c2982
exander
Post by exander »
Currently it says:
CPUs: 16
GPUs: 1
So I suppose it is recognized.
It also says GPU is ready. So it is probably relevant to outage.
I currently have 800k ppd, should I update the driver. Does it seem ok? I am using 18.8.1 Gaming Driver, because I had problems with newer one (https://community.amd.com/thread/237413). Should I upgrade to new drivers?
