rx580 "Ready" and web client keeps reloading
warzinak
Post by warzinak »
Id like to start doing this but my GPU is not doing anything, it just says "Ready"
Also my web client just keeps reloading every second and not connecting
I can see a lot of other people have this issue.
Here is my log.
*********************** Log Started 2020-03-14T14:52:00Z ***********************
14:52:00:************************* Folding@home Client *************************
14:52:00:        Website: https://foldingathome.org/
14:52:00:      Copyright: (c) 2009-2018 foldingathome.org
14:52:00:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:52:00:           Args: --open-web-control
14:52:00:         Config: C:\Users\David\AppData\Roaming\FAHClient\config.xml
14:52:00:******************************** Build ********************************
14:52:00:        Version: 7.5.1
14:52:00:           Date: May 11 2018
14:52:00:           Time: 13:06:32
14:52:00:     Repository: Git
14:52:00:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:52:00:         Branch: master
14:52:00:       Compiler: Visual C++ 2008
14:52:00:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:52:00:       Platform: win32 10
14:52:00:           Bits: 32
14:52:00:           Mode: Release
14:52:00:******************************* System ********************************
14:52:00:            CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
14:52:00:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:52:00:           CPUs: 4
14:52:00:         Memory: 15.89GiB
14:52:00:    Free Memory: 10.99GiB
14:52:00:        Threads: WINDOWS_THREADS
14:52:00:     OS Version: 6.2
14:52:00:    Has Battery: false
14:52:00:     On Battery: false
14:52:00:     UTC Offset: 0
14:52:00:            PID: 13276
14:52:00:            CWD: C:\Users\David\AppData\Roaming\FAHClient
14:52:00:             OS: Windows 10 Enterprise
14:52:00:        OS Arch: AMD64
14:52:00:           GPUs: 1
14:52:00:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX
14:52:00:                 470/480/570/580]
14:52:00:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
14:52:00:                 specified module could not be found.
14:52:00:
14:52:00:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
14:52:00:OpenCL Device 2: Platform:1 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:10.18
14:52:00:  Win32 Service: false
14:52:00:***********************************************************************
14:52:00:<config>
14:52:00:  <!-- Network -->
14:52:00:  <proxy v=':8080'/>
14:52:00:
14:52:00:  <!-- Slot Control -->
14:52:00:  <power v='FULL'/>
14:52:00:
14:52:00:  <!-- User Information -->
14:52:00:  <user v='Warzinak'/>
14:52:00:
14:52:00:  <!-- Folding Slots -->
14:52:00:  <slot id='1' type='GPU'/>
14:52:00:</config>
14:52:00:Trying to access database...
14:52:00:Successfully acquired database lock
14:52:00:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
14:52:00:WU00:FS01:Connecting to 65.254.110.245:8080
14:52:01:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:52:01:WU00:FS01:Connecting to 18.218.241.186:80
14:52:01:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:52:01:ERROR:WU00:FS01:Exception: Could not get an assignment
14:52:02:WU00:FS01:Connecting to 65.254.110.245:8080
14:52:02:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:52:02:WU00:FS01:Connecting to 18.218.241.186:80
14:52:02:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:52:02:ERROR:WU00:FS01:Exception: Could not get an assignment
14:53:02:WU00:FS01:Connecting to 65.254.110.245:8080
14:53:02:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:53:02:WU00:FS01:Connecting to 18.218.241.186:80
14:53:03:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:53:03:ERROR:WU00:FS01:Exception: Could not get an assignment
Re: rx580 "Ready" and web client keeps reloading
