Stats Bad Gateway ?
- Hardware configuration: 2700X
Stats Bad Gateway ?
Hello,
I have installed today the folding@home and i am using it in 1 computer with 2700X and GTX780 (it says unsupported for the card and it's 0% all the time).
The 2700X has already completed 2 full cycles of project.
But i cannot see my stats, i have registered my passkey ,and the username in the advanced control options.
But i cannot see my stats when i search them online, it sasys "BAD GATEWAY"..
Any suggestions ?
Any suggestions ?
Re: Stats Bad Gateway ?
Your GTX 780 meets the hardware requirements to fold. It is a Kepler family GPU and does Double Precision math, which F@H needs. https://www.techpowerup.com/gpu-specs/g ... -780.c1701
Here is how to give us a log so we can see what the problem is. The first 200 lines will show us the client version, your OS, what CPU you have, what GPU you have, what driver version you have, how you configured F@H, etc. We know very little of that.
viewtopic.php?f=24&t=26036
With that we can make much better guesses. Be sure you downloaded your drivers from your vendor, Nvidia. (This Driver is for Windows 10 64 bit but that is an uninformed guess on my part, I have no way to know, yet) https://www.geforce.com/drivers/results/158180
Hello, yes i have my drivers updated, and the specific ones.JimboPalmer wrote:Your GTX 780 meets the hardware requirements to fold. It is a Kepler family GPU and does Double Precision math, which F@H needs. https://www.techpowerup.com/gpu-specs/g ... -780.c1701
Do you need the entire LOG file,as you instructed me ? (without the "Follow" tick) it's a lot of lines.
Anyone else guyz ?
Not currently folding
The first 200 lines will help us see if its a configuration problem or that its now set up properly but just waiting for work.
As stated, just need the first 200 lines of the log, you may have to hit Refresh if copying from the log window in FAHControl. A small sample showing an error and the section just before and after is also useful.
Stats Reading bad gateway all the time.
Recently started a competition with some of my friends, but everytime we try to look at the team, or singular stats we get a bad gateway error.
Log from the program:
*********************** Log Started 2020-03-16T18:59:54Z ***********************
18:59:54:************************* Folding@home Client *************************
18:59:54: Website: https://foldingathome.org/
18:59:54: Copyright: (c) 2009-2018 foldingathome.org
18:59:54: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:54: Args: --open-web-control
18:59:54: Config: C:\Users\patin\AppData\Roaming\FAHClient\config.xml
18:59:54:******************************** Build ********************************
18:59:54: Version: 7.5.1
18:59:54: Date: May 11 2018
18:59:54: Time: 13:06:32
18:59:54: Repository: Git
18:59:54: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:59:54: Branch: master
18:59:54: Compiler: Visual C++ 2008
18:59:54: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:59:54: Platform: win32 10
18:59:54: Bits: 32
18:59:54: Mode: Release
18:59:54:******************************* System ********************************
18:59:54: CPU: AMD Ryzen 7 3700X 8-Core Processor
18:59:54: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:59:54: CPUs: 16
18:59:54: Memory: 15.95GiB
18:59:54: Free Memory: 14.20GiB
18:59:54: Threads: WINDOWS_THREADS
18:59:54: OS Version: 6.2
18:59:54: Has Battery: false
18:59:54: On Battery: false
18:59:54: UTC Offset: -6
18:59:54: PID: 7388
18:59:54: CWD: C:\Users\patin\AppData\Roaming\FAHClient
18:59:54: OS: Windows 10 Enterprise
18:59:54: OS Arch: AMD64
18:59:54: GPUs: 1
18:59:54: GPU 0: Bus:43 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
18:59:54: / 5700/5700 XT]
18:59:54: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:59:54: specified module could not be found.
18:59:54:
18:59:54:OpenCL Device 0: Platform:0 Device:0 Bus:43 Slot:0 Compute:1.2 Driver:3004.8
18:59:54: Win32 Service: false
18:59:54:***********************************************************************
18:59:54:<config>
18:59:54: <!-- Slot Control -->
18:59:54: <power v='FULL'/>
18:59:54:
18:59:54: <!-- User Information -->
18:59:54: <team v='237079'/>
18:59:54: <user v='Bub'/>
18:59:54:
18:59:54: <!-- Folding Slots -->
18:59:54: <slot id='0' type='CPU'/>
18:59:54: <slot id='1' type='GPU'/>
18:59:54:</config>
18:59:54:Trying to access database...
18:59:54:Successfully acquired database lock
18:59:54:Enabled folding slot 00: READY cpu:15
18:59:54:Enabled folding slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
18:59:54:WU02:FS00:Starting
18:59:54:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\patin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 7388 -checkpoint 15 -np 15
18:59:54:WU02:FS00:Started FahCore on PID 4804
18:59:54:WU02:FS00:Core PID:6508
18:59:54:WU02:FS00:FahCore 0xa7 started
18:59:55:WU00:FS01:Starting
18:59:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\patin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 7388 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:59:55:WU00:FS01:Started FahCore on PID 7492
18:59:55:WU02:FS00:0xa7:*********************** Log Started 2020-03-16T18:59:54Z ***********************
18:59:55:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:59:55:WU02:FS00:0xa7: Type: 0xa7
18:59:55:WU02:FS00:0xa7: Core: Gromacs
18:59:55:WU02:FS00:0xa7: Args: -dir 02 -suffix 01 -version 705 -lifeline 4804 -checkpoint 15 -np
18:59:55:WU02:FS00:0xa7: 15
18:59:55:WU02:FS00:0xa7:************************************ CBang *************************************
18:59:55:WU02:FS00:0xa7: Date: Oct 26 2019
18:59:55:WU02:FS00:0xa7: Time: 01:38:25
18:59:55:WU02:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:59:55:WU02:FS00:0xa7: Branch: master
18:59:55:WU02:FS00:0xa7: Compiler: Visual C++ 2008
18:59:55:WU02:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:59:55:WU02:FS00:0xa7: Platform: win32 10
18:59:55:WU02:FS00:0xa7: Bits: 64
18:59:55:WU02:FS00:0xa7: Mode: Release
18:59:55:WU02:FS00:0xa7:************************************ System ************************************
18:59:55:WU02:FS00:0xa7: CPU: AMD Ryzen 7 3700X 8-Core Processor
18:59:55:WU02:FS00:0xa7: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:59:55:WU02:FS00:0xa7: CPUs: 16
18:59:55:WU02:FS00:0xa7: Memory: 15.95GiB
18:59:55:WU02:FS00:0xa7:Free Memory: 14.15GiB
18:59:55:WU02:FS00:0xa7: Threads: WINDOWS_THREADS
18:59:55:WU02:FS00:0xa7: OS Version: 6.2
18:59:55:WU02:FS00:0xa7:Has Battery: false
18:59:55:WU02:FS00:0xa7: On Battery: false
18:59:55:WU02:FS00:0xa7: UTC Offset: -6
18:59:55:WU02:FS00:0xa7: PID: 6508
18:59:55:WU02:FS00:0xa7: CWD: C:\Users\patin\AppData\Roaming\FAHClient\work
18:59:55:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:59:55:WU02:FS00:0xa7: Version: 0.0.18
18:59:55:WU02:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:59:55:WU02:FS00:0xa7: Copyright: 2019 foldingathome.org
18:59:55:WU02:FS00:0xa7: Homepage: https://foldingathome.org/
18:59:55:WU02:FS00:0xa7: Time: 01:52:30
18:59:55:WU02:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:59:55:WU02:FS00:0xa7:************************************ Build *************************************
18:59:55:WU02:FS00:0xa7: SIMD: avx_256
18:59:55:WU02:FS00:0xa7:********************************************************************************
18:59:55:WU02:FS00:0xa7:Project: 13831 (Run 172, Clone 2, Gen 103)
18:59:55:WU02:FS00:0xa7:Unit: 0x0000007c80fccb095d693b856b5af216
18:59:55:WU02:FS00:0xa7:Digital signatures verified
18:59:55:WU02:FS00:0xa7:Calling: mdrun -s frame103.tpr -o frame103.trr -x frame103.xtc -cpi state.cpt -cpt 15 -nt 15
18:59:55:WU00:FS01:Core PID:8196
18:59:55:WU00:FS01:FahCore 0x22 started
18:59:55:WU00:FS01:0x22:*********************** Log Started 2020-03-16T18:59:55Z ***********************
18:59:55:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:59:55:WU00:FS01:0x22: Type: 0x22
18:59:55:WU00:FS01:0x22: Core: Core22
18:59:55:WU00:FS01:0x22: Website: https://foldingathome.org/
18:59:55:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:59:55:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:59:55:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:59:55:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 7492 -checkpoint 15
18:59:55:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:59:55:WU00:FS01:0x22: Config: <none>
18:59:55:WU00:FS01:0x22:************************************ Build *************************************
18:59:55:WU00:FS01:0x22: Version: 0.0.2
18:59:55:WU00:FS01:0x22: Date: Dec 6 2019
18:59:55:WU00:FS01:0x22: Time: 21:30:31
18:59:55:WU00:FS01:0x22: Repository: Git
18:59:55:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:59:55:WU00:FS01:0x22: Branch: HEAD
18:59:55:WU00:FS01:0x22: Compiler: Visual C++ 2008
18:59:55:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:59:55:WU00:FS01:0x22: Platform: win32 10
18:59:55:WU00:FS01:0x22: Bits: 64
18:59:55:WU00:FS01:0x22: Mode: Release
18:59:55:WU00:FS01:0x22:************************************ System ************************************
18:59:55:WU00:FS01:0x22: CPU: AMD Ryzen 7 3700X 8-Core Processor
18:59:55:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
18:59:55:WU00:FS01:0x22: CPUs: 16
18:59:55:WU00:FS01:0x22: Memory: 15.95GiB
18:59:55:WU00:FS01:0x22:Free Memory: 14.04GiB
18:59:55:WU00:FS01:0x22: Threads: WINDOWS_THREADS
18:59:55:WU00:FS01:0x22: OS Version: 6.2
18:59:55:WU00:FS01:0x22:Has Battery: false
18:59:55:WU00:FS01:0x22: On Battery: false
18:59:55:WU00:FS01:0x22: UTC Offset: -6
18:59:55:WU00:FS01:0x22: PID: 8196
18:59:55:WU00:FS01:0x22: CWD: C:\Users\patin\AppData\Roaming\FAHClient\work
18:59:55:WU00:FS01:0x22: OS: Windows 10 Pro
18:59:55:WU00:FS01:0x22: OS Arch: AMD64
18:59:55:WU00:FS01:0x22:********************************************************************************
18:59:55:WU00:FS01:0x22:Project: 11745 (Run 0, Clone 7014, Gen 2)
18:59:55:WU00:FS01:0x22:Unit: 0x000000028ca304f15e6bc3b59c9e431d
18:59:55:WU00:FS01:0x22:Digital signatures verified
18:59:55:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:59:55:WU00:FS01:0x22:Version 0.0.2
18:59:56:WU00:FS01:0x22: Found a checkpoint file
18:59:56:WU02:FS00:0xa7:Steps: first=12875000 total=12875000
18:59:58:WU02:FS00:0xa7:Completed 868631 out of 12875000 steps (6%)
19:00:06:8:127.0.0.1:New Web connection
19:00:08:22:127.0.0.1:New Web connection
19:00:29:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
19:00:29:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:01:44:WU00:FS01:0x22:Completed 510000 out of 1000000 steps (51%)
19:02:50:WU00:FS01:0x22:Completed 520000 out of 1000000 steps (52%)
19:03:51:WU00:FS01:0x22:Completed 530000 out of 1000000 steps (53%)
19:04:52:WU00:FS01:0x22:Completed 540000 out of 1000000 steps (54%)
19:05:55:WU00:FS01:0x22:Completed 550000 out of 1000000 steps (55%)
19:07:07:WU00:FS01:0x22:Completed 560000 out of 1000000 steps (56%)
19:08:05:WU00:FS01:0x22:Completed 570000 out of 1000000 steps (57%)
19:09:04:WU00:FS01:0x22:Completed 580000 out of 1000000 steps (58%)
19:10:02:WU00:FS01:0x22:Completed 590000 out of 1000000 steps (59%)
19:11:56:WU00:FS01:0x22:Completed 600000 out of 1000000 steps (60%)
19:14:18:WU00:FS01:0x22:Completed 610000 out of 1000000 steps (61%)
19:16:33:WU00:FS01:0x22:Completed 620000 out of 1000000 steps (62%)
19:18:04:WU00:FS01:0x22:Completed 630000 out of 1000000 steps (63%)
19:19:16:WU00:FS01:0x22:Completed 640000 out of 1000000 steps (64%)
19:19:38:WU02:FS00:0xa7:Completed 901250 out of 12875000 steps (7%)
19:20:18:WU00:FS01:0x22:Completed 650000 out of 1000000 steps (65%)
19:21:32:WU00:FS01:0x22:Completed 660000 out of 1000000 steps (66%)
19:22:32:WU00:FS01:0x22:Completed 670000 out of 1000000 steps (67%)
19:23:35:WU00:FS01:0x22:Completed 680000 out of 1000000 steps (68%)
19:24:43:WU00:FS01:0x22:Completed 690000 out of 1000000 steps (69%)
Re: Stats Reading bad gateway all the time.
The flat files used by third party site to report folding stats are still being updated, one such site is http://folding.extremeoverclocking.com/. They don't report on all teams, but if you are in the top 2000 you should be able to check there.
Bad Gateway means that the gateway, itself is under a DoS attack and requests are exceeding it's capabilities. With all the interest in COVAID-19, many parts of FAH are highly stressed (alnog with everybody trying frantically to fix things). I suggest you postpone the competition until FAH can recover from a massive influx of new Donors.
there's also a direct html page of your team which stays very up to date. I'd post it directly if not for this brand new account which doesn't allow links. It's practically the same domain except instead of starting with 'stats,' it is 'apps' then there's a slash with 'teamstats,' another slash and finally 'team' and add your team number (dot) html.
happy folding!
happy folding!
Statistics inform that there is a Bad Gateway
It's nowadays longer that your statistic aren't working anymore. It's frustrating for everybody that are using your platform.
Thanks for reading
I hope you would make something
Quentin
Team 238180
Thanks for reading
Quentin
Team 238180
