GPU stuck on ready / downloading
BigSeb
Post by BigSeb »
Hi,
I just installed folding@home and wanted to run it both on my cpu and gpu, but my gpu is stuck on ready.
Here is the log:
*********************** Log Started 2020-03-14T11:53:36Z ***********************
11:53:36:************************* Folding@home Client *************************
11:53:36:        Website: https://foldingathome.org/
11:53:36:      Copyright: (c) 2009-2018 foldingathome.org
11:53:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:53:36:           Args: --open-web-control
11:53:36:         Config: C:\Users\Sebastian\AppData\Roaming\FAHClient\config.xml
11:53:36:******************************** Build ********************************
11:53:36:        Version: 7.5.1
11:53:36:           Date: May 11 2018
11:53:36:           Time: 13:06:32
11:53:36:     Repository: Git
11:53:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:53:36:         Branch: master
11:53:36:       Compiler: Visual C++ 2008
11:53:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:53:36:       Platform: win32 10
11:53:36:           Bits: 32
11:53:36:           Mode: Release
11:53:36:******************************* System ********************************
11:53:36:            CPU: AMD Ryzen 7 3700X 8-Core Processor
11:53:36:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
11:53:36:           CPUs: 16
11:53:36:         Memory: 31.95GiB
11:53:36:    Free Memory: 27.11GiB
11:53:36:        Threads: WINDOWS_THREADS
11:53:36:     OS Version: 6.2
11:53:36:    Has Battery: false
11:53:36:     On Battery: false
11:53:36:     UTC Offset: 1
11:53:36:            PID: 9900
11:53:36:            CWD: C:\Users\Sebastian\AppData\Roaming\FAHClient
11:53:36:             OS: Windows 10 Home
11:53:36:        OS Arch: AMD64
11:53:36:           GPUs: 1
11:53:36:          GPU 0: Bus:10 Slot:0 Func:0 NVIDIA:7 TU106 [GeForce RTX 2070 Rev. A] M
11:53:36:                 7465
11:53:36:  CUDA Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:7.5 Driver:10.2
11:53:36:OpenCL Device 0: Platform:0 Device:0 Bus:10 Slot:0 Compute:1.2 Driver:442.59
11:53:36:  Win32 Service: false
11:53:36:***********************************************************************
11:53:36:<config>
11:53:36:  <!-- Network -->
11:53:36:  <proxy v=':8080'/>
11:53:36:
11:53:36:  <!-- Slot Control -->
11:53:36:  <power v='full'/>
11:53:36:
11:53:36:  <!-- User Information -->
11:53:36:  <user v='BigSeb'/>
11:53:36:
11:53:36:  <!-- Folding Slots -->
11:53:36:  <slot id='0' type='CPU'/>
11:53:36:  <slot id='1' type='GPU'/>
11:53:36:</config>
11:53:36:Trying to access database...
11:53:36:Successfully acquired database lock
11:53:36:Enabled folding slot 00: READY cpu:15
11:53:36:Enabled folding slot 01: READY gpu:0:TU106 [GeForce RTX 2070 Rev. A] M 7465
11:53:36:WU00:FS00:Starting
11:53:36:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
11:53:36:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Sebastian\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 9900 -checkpoint 15 -np 14
11:53:36:WU00:FS00:Started FahCore on PID 12604
11:53:36:WU00:FS00:Core PID:8460
11:53:36:WU00:FS00:FahCore 0xa7 started
11:53:36:WU01:FS01:Connecting to 65.254.110.245:8080
11:53:36:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T11:53:36Z ***********************
11:53:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:53:36:WU00:FS00:0xa7:       Type: 0xa7
11:53:36:WU00:FS00:0xa7:       Core: Gromacs
11:53:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12604 -checkpoint 15 -np
11:53:36:WU00:FS00:0xa7:             14
11:53:36:WU00:FS00:0xa7:************************************ CBang *************************************
11:53:36:WU00:FS00:0xa7:       Date: Oct 26 2019
11:53:36:WU00:FS00:0xa7:       Time: 01:38:25
11:53:36:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:53:36:WU00:FS00:0xa7:     Branch: master
11:53:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:53:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:53:36:WU00:FS00:0xa7:   Platform: win32 10
11:53:36:WU00:FS00:0xa7:       Bits: 64
11:53:36:WU00:FS00:0xa7:       Mode: Release
11:53:36:WU00:FS00:0xa7:************************************ System ************************************
11:53:36:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 3700X 8-Core Processor
11:53:36:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
11:53:36:WU00:FS00:0xa7:       CPUs: 16
11:53:36:WU00:FS00:0xa7:     Memory: 31.95GiB
11:53:36:WU00:FS00:0xa7:Free Memory: 27.09GiB
11:53:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:53:36:WU00:FS00:0xa7: OS Version: 6.2
11:53:36:WU00:FS00:0xa7:Has Battery: false
11:53:36:WU00:FS00:0xa7: On Battery: false
11:53:36:WU00:FS00:0xa7: UTC Offset: 1
11:53:36:WU00:FS00:0xa7:        PID: 8460
11:53:36:WU00:FS00:0xa7:        CWD: C:\Users\Sebastian\AppData\Roaming\FAHClient\work
11:53:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:53:36:WU00:FS00:0xa7:    Version: 0.0.18
11:53:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:53:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:53:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:53:36:WU00:FS00:0xa7:       Time: 01:52:30
11:53:36:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:53:36:WU00:FS00:0xa7:************************************ Build *************************************
11:53:36:WU00:FS00:0xa7:       SIMD: avx_256
11:53:36:WU00:FS00:0xa7:********************************************************************************
11:53:36:WU00:FS00:0xa7:Project: 14198 (Run 9, Clone 256, Gen 5)
11:53:36:WU00:FS00:0xa7:Unit: 0x000000059bf7a4d55e66cecda74739b0
11:53:36:WU00:FS00:0xa7:Digital signatures verified
11:53:36:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
11:53:36:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
11:53:36:WU00:FS00:0xa7:Calling: mdrun -s frame5.tpr -o frame5.trr -cpi state.cpt -cpt 15 -nt 12
11:53:36:WU00:FS00:0xa7:Steps: first=2500000 total=500000
11:53:37:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:53:37:WU01:FS01:Connecting to 18.218.241.186:80
11:53:37:WU00:FS00:0xa7:Completed 56352 out of 500000 steps (11%)
11:53:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:53:37:ERROR:WU01:FS01:Exception: Could not get an assignment
11:53:37:WU01:FS01:Connecting to 65.254.110.245:8080
11:53:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:53:38:ERROR:WU01:FS01:Exception: Could not get an assignment
11:53:51:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:54:10:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:54:29:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
11:54:37:WU01:FS01:Connecting to 65.254.110.245:8080
11:54:38:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:54:38:WU01:FS01:Connecting to 18.218.241.186:80
11:54:38:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:54:38:ERROR:WU01:FS01:Exception: Could not get an assignment
11:54:48:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
11:55:07:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
11:55:25:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
11:55:44:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
11:56:05:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
11:56:15:WU01:FS01:Connecting to 65.254.110.245:8080
11:56:15:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:56:15:WU01:FS01:Connecting to 18.218.241.186:80
11:56:15:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:56:15:ERROR:WU01:FS01:Exception: Could not get an assignment
11:56:25:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
11:56:44:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
11:57:03:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
11:57:22:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
11:57:41:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
11:58:00:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
11:58:19:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
11:58:38:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
11:58:52:WU01:FS01:Connecting to 65.254.110.245:8080
11:58:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:58:52:WU01:FS01:Connecting to 18.218.241.186:80
11:58:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:58:53:ERROR:WU01:FS01:Exception: Could not get an assignment
11:58:57:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
11:59:17:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
11:59:35:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
11:59:54:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
12:00:13:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
12:00:32:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
12:00:51:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
12:01:10:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
12:01:29:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
12:01:48:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
12:02:07:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
12:02:27:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
12:02:46:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
12:03:05:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
12:03:06:WU01:FS01:Connecting to 65.254.110.245:8080
12:03:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:03:07:WU01:FS01:Connecting to 18.218.241.186:80
12:03:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:03:07:ERROR:WU01:FS01:Exception: Could not get an assignment
12:03:24:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
12:03:43:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
12:04:02:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
12:04:21:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
12:04:40:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:04:59:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
12:05:18:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
12:05:37:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
Re: GPU stuck on ready / downloading
MrGuvernment
Post by MrGuvernment »
Back end, need WU to be pushed out I beleive. I have it as well. Just wait and eventually work will come.
MrGuvernment
That is pretty awesome, I mean on one hand it sucks that people only came back for CoronaVirus, hopefully some other projects get more WU out there as well.
