GPU (1070_ Getting No WUs available for this configuration
gotperl
Post by gotperl »
From searching I see other people getting these in the past, but not sure if it is something with my system or not.
*********************** Log Started 2020-03-14T11:49:56Z ***********************
11:49:56:************************* Folding@home Client *************************
11:49:56:        Website: https://foldingathome.org/
11:49:56:      Copyright: (c) 2009-2018 foldingathome.org
11:49:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:49:56:           Args:
11:49:56:         Config: C:\Users\jorda\AppData\Roaming\FAHClient\config.xml
11:49:56:******************************** Build ********************************
11:49:56:        Version: 7.5.1
11:49:56:           Date: May 11 2018
11:49:56:           Time: 13:06:32
11:49:56:     Repository: Git
11:49:56:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:49:56:         Branch: master
11:49:56:       Compiler: Visual C++ 2008
11:49:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:49:56:       Platform: win32 10
11:49:56:           Bits: 32
11:49:56:           Mode: Release
11:49:56:******************************* System ********************************
11:49:56:            CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:49:56:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:49:56:           CPUs: 12
11:49:56:         Memory: 7.96GiB
11:49:56:    Free Memory: 5.44GiB
11:49:56:        Threads: WINDOWS_THREADS
11:49:56:     OS Version: 6.2
11:49:56:    Has Battery: false
11:49:56:     On Battery: false
11:49:56:     UTC Offset: -6
11:49:56:            PID: 10368
11:49:56:            CWD: C:\Users\jorda\AppData\Roaming\FAHClient
11:49:56:             OS: Windows 10 Home
11:49:56:        OS Arch: AMD64
11:49:56:           GPUs: 1
11:49:56:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070] 6463
11:49:56:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
11:49:56:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
11:49:56:  Win32 Service: false
11:49:56:***********************************************************************
11:49:56:<config>
11:49:56:  <!-- Network -->
11:49:56:  <proxy v=':8080'/>
11:49:56:
11:49:56:  <!-- User Information -->
11:49:56:  <user v='gotperl'/>
11:49:56:
11:49:56:  <!-- Folding Slots -->
11:49:56:  <slot id='0' type='CPU'/>
11:49:56:  <slot id='1' type='GPU'>
11:49:56:    <gpu-index v='0'/>
11:49:56:  </slot>
11:49:56:</config>
11:49:56:Trying to access database...
11:49:56:Successfully acquired database lock
11:49:56:Enabled folding slot 00: READY cpu:10
11:49:56:Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463
11:49:56:WU00:FS00:Starting
11:49:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jorda\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10368 -checkpoint 15 -np 10
11:49:56:WU00:FS00:Started FahCore on PID 5648
11:49:56:WU00:FS00:Core PID:10852
11:49:56:WU00:FS00:FahCore 0xa7 started
11:49:57:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T11:49:56Z ***********************
11:49:57:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:49:57:WU00:FS00:0xa7:       Type: 0xa7
11:49:57:WU00:FS00:0xa7:       Core: Gromacs
11:49:57:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5648 -checkpoint 15 -np
11:49:57:WU00:FS00:0xa7:             10
11:49:57:WU00:FS00:0xa7:************************************ CBang *************************************
11:49:57:WU00:FS00:0xa7:       Date: Oct 26 2019
11:49:57:WU00:FS00:0xa7:       Time: 01:38:25
11:49:57:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:49:57:WU00:FS00:0xa7:     Branch: master
11:49:57:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:49:57:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:49:57:WU00:FS00:0xa7:   Platform: win32 10
11:49:57:WU00:FS00:0xa7:       Bits: 64
11:49:57:WU00:FS00:0xa7:       Mode: Release
11:49:57:WU00:FS00:0xa7:************************************ System ************************************
11:49:57:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:49:57:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:49:57:WU00:FS00:0xa7:       CPUs: 12
11:49:57:WU00:FS00:0xa7:     Memory: 7.96GiB
11:49:57:WU00:FS00:0xa7:Free Memory: 5.39GiB
11:49:57:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:49:57:WU00:FS00:0xa7: OS Version: 6.2
11:49:57:WU00:FS00:0xa7:Has Battery: false
11:49:57:WU00:FS00:0xa7: On Battery: false
11:49:57:WU00:FS00:0xa7: UTC Offset: -6
11:49:57:WU00:FS00:0xa7:        PID: 10852
11:49:57:WU00:FS00:0xa7:        CWD: C:\Users\jorda\AppData\Roaming\FAHClient\work
11:49:57:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:49:57:WU00:FS00:0xa7:    Version: 0.0.18
11:49:57:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:49:57:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:49:57:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:49:57:WU00:FS00:0xa7:       Time: 01:52:30
11:49:57:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:49:57:WU00:FS00:0xa7:************************************ Build *************************************
11:49:57:WU00:FS00:0xa7:       SIMD: avx_256
11:49:57:WU00:FS00:0xa7:********************************************************************************
11:49:57:WU00:FS00:0xa7:Project: 14198 (Run 8, Clone 347, Gen 0)
11:49:57:WU00:FS00:0xa7:Unit: 0x000000009bf7a4d55e66cef48d3b141e
11:49:57:WU00:FS00:0xa7:Digital signatures verified
11:49:57:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpi state.cpt -cpt 15 -nt 10
11:49:57:WU00:FS00:0xa7:ERROR:Guru Meditation #a6b192893d6f0fe1.b9df759fb4fb152c (1059.1207) '00/01/pullx.xvg'
11:49:57:WU00:FS00:0xa7:WARNING:Unexpected exit() call
11:49:57:WU00:FS00:0xa7:WARNING:Unexpected exit from science code
11:49:57:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
11:49:57:WU00:FS00:0xa7:Saving result file frame0.trr
11:49:57:WU00:FS00:0xa7:Saving result file md.log
11:49:57:WU00:FS00:0xa7:Saving result file pullf.xvg
11:49:57:WU00:FS00:0xa7:ERROR:Guru Meditation #efac82eab2aabbfc.4b1571955bf221d9 (560.628) '00/01/pullf.xvg'
11:49:57:WU01:FS01:Connecting to 65.254.110.245:8080
11:49:57:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:49:57:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
11:49:57:WARNING:WU00:FS00:Too many errors, failing
11:49:57:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:14198 run:8 clone:347 gen:0 core:0xa7 unit:0x000000009bf7a4d55e66cef48d3b141e
11:49:57:WU00:FS00:Uploading 1.21MiB to 155.247.164.213
11:49:57:WU00:FS00:Connecting to 155.247.164.213:8080
11:49:58:WU02:FS00:Connecting to 65.254.110.245:8080
11:49:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:49:58:WU01:FS01:Connecting to 18.218.241.186:80
11:49:58:WU02:FS00:Assigned to work server 128.252.203.10
11:49:58:WU02:FS00:Requesting new work unit for slot 00: READY cpu:10 from 128.252.203.10
11:49:58:WU02:FS00:Connecting to 128.252.203.10:8080
11:49:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:49:59:ERROR:WU01:FS01:Exception: Could not get an assignment
11:49:59:WU02:FS00:Downloading 1.06MiB
11:49:59:WU01:FS01:Connecting to 65.254.110.245:8080
11:49:59:WU02:FS00:Download complete
11:49:59:WU00:FS00:Upload complete
11:49:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:49:59:WU01:FS01:Connecting to 18.218.241.186:80
11:49:59:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14524 run:964 clone:1 gen:0 core:0xa7 unit:0x0000000080fccb0a5e459b8e0632658c
11:49:59:WU02:FS00:Starting
11:49:59:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jorda\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10368 -checkpoint 15 -np 10
11:49:59:WU02:FS00:Started FahCore on PID 11760
11:49:59:WU02:FS00:Core PID:11784
11:49:59:WU02:FS00:FahCore 0xa7 started
11:49:59:WU00:FS00:Server responded WORK_QUIT (404)
11:49:59:WARNING:WU00:FS00:Server did not like results, dumping
11:49:59:WU00:FS00:Cleaning up
11:50:00:WU02:FS00:0xa7:*********************** Log Started 2020-03-14T11:49:59Z ***********************
11:50:00:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:50:00:WU02:FS00:0xa7:       Type: 0xa7
11:50:00:WU02:FS00:0xa7:       Core: Gromacs
11:50:00:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 11760 -checkpoint 15 -np
11:50:00:WU02:FS00:0xa7:             10
11:50:00:WU02:FS00:0xa7:************************************ CBang *************************************
11:50:00:WU02:FS00:0xa7:       Date: Oct 26 2019
11:50:00:WU02:FS00:0xa7:       Time: 01:38:25
11:50:00:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:50:00:WU02:FS00:0xa7:     Branch: master
11:50:00:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
11:50:00:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:50:00:WU02:FS00:0xa7:   Platform: win32 10
11:50:00:WU02:FS00:0xa7:       Bits: 64
11:50:00:WU02:FS00:0xa7:       Mode: Release
11:50:00:WU02:FS00:0xa7:************************************ System ************************************
11:50:00:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:50:00:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:50:00:WU02:FS00:0xa7:       CPUs: 12
11:50:00:WU02:FS00:0xa7:     Memory: 7.96GiB
11:50:00:WU02:FS00:0xa7:Free Memory: 5.12GiB
11:50:00:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
11:50:00:WU02:FS00:0xa7: OS Version: 6.2
11:50:00:WU02:FS00:0xa7:Has Battery: false
11:50:00:WU02:FS00:0xa7: On Battery: false
11:50:00:WU02:FS00:0xa7: UTC Offset: -6
11:50:00:WU02:FS00:0xa7:        PID: 11784
11:50:00:WU02:FS00:0xa7:        CWD: C:\Users\jorda\AppData\Roaming\FAHClient\work
11:50:00:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
11:50:00:WU02:FS00:0xa7:    Version: 0.0.18
11:50:00:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:50:00:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:50:00:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
11:50:00:WU02:FS00:0xa7:       Time: 01:52:30
11:50:00:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:50:00:WU02:FS00:0xa7:************************************ Build *************************************
11:50:00:WU02:FS00:0xa7:       SIMD: avx_256
11:50:00:WU02:FS00:0xa7:********************************************************************************
11:50:00:WU02:FS00:0xa7:Project: 14524 (Run 964, Clone 1, Gen 0)
11:50:00:WU02:FS00:0xa7:Unit: 0x0000000080fccb0a5e459b8e0632658c
11:50:00:WU02:FS00:0xa7:Reading tar file core.xml
11:50:00:WU02:FS00:0xa7:Reading tar file frame0.tpr
11:50:00:WU02:FS00:0xa7:Digital signatures verified
11:50:00:WU02:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpt 15 -nt 10
11:50:00:WU02:FS00:0xa7:Steps: first=0 total=250000
11:50:00:WU02:FS00:0xa7:ERROR:
11:50:00:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
11:50:00:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
11:50:00:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 6902
11:50:00:WU02:FS00:0xa7:ERROR:Fatal error:
11:50:00:WU02:FS00:0xa7:ERROR:There is no domain decomposition for 10 ranks that is compatible with the given box and a minimum cell size of 1.4227 nm
11:50:00:WU02:FS00:0xa7:ERROR:Change the number of ranks or mdrun option -rcon or -dds or your LINCS settings
11:50:00:WU02:FS00:0xa7:ERROR:Look in the log file for details on the domain decomposition
11:50:00:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:50:00:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:50:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:50:00:ERROR:WU01:FS01:Exception: Could not get an assignment
11:50:05:WU02:FS00:0xa7:WARNING:Unexpected exit() call
11:50:05:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
11:50:05:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
11:50:05:WU02:FS00:0xa7:Saving result file md.log
11:50:05:WU02:FS00:0xa7:Saving result file science.log
11:50:05:WU02:FS00:0xa7:WARNING:While cleaning up: boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01/md.log"
11:50:05:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
11:50:05:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:50:05:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:14524 run:964 clone:1 gen:0 core:0xa7 unit:0x0000000080fccb0a5e459b8e0632658c
11:50:05:WU02:FS00:Uploading 19.00KiB to 128.252.203.10
11:50:05:WU02:FS00:Connecting to 128.252.203.10:8080
11:50:05:WU02:FS00:Upload complete
11:50:05:WU02:FS00:Server responded WORK_ACK (400)
11:50:05:WU02:FS00:Cleaning up
11:50:05:WU00:FS00:Connecting to 65.254.110.245:8080
11:50:06:WU00:FS00:Assigned to work server 155.247.166.219
11:50:06:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 155.247.166.219
11:50:06:WU00:FS00:Connecting to 155.247.166.219:8080
11:50:06:WU00:FS00:Downloading 6.67MiB
11:50:09:WU00:FS00:Download complete
11:50:09:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14300 run:17 clone:163 gen:11 core:0xa7 unit:0x000000100002894b5e56c04e12d48b1f
11:50:09:WU00:FS00:Starting
11:50:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jorda\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10368 -checkpoint 15 -np 10
11:50:09:WU00:FS00:Started FahCore on PID 12908
11:50:09:WU00:FS00:Core PID:12932
11:50:09:WU00:FS00:FahCore 0xa7 started
11:50:09:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T11:50:09Z ***********************
11:50:09:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:50:09:WU00:FS00:0xa7:       Type: 0xa7
11:50:09:WU00:FS00:0xa7:       Core: Gromacs
11:50:09:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12908 -checkpoint 15 -np
11:50:09:WU00:FS00:0xa7:             10
11:50:09:WU00:FS00:0xa7:************************************ CBang *************************************
11:50:09:WU00:FS00:0xa7:       Date: Oct 26 2019
11:50:09:WU00:FS00:0xa7:       Time: 01:38:25
11:50:09:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:50:09:WU00:FS00:0xa7:     Branch: master
11:50:09:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:50:09:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:50:09:WU00:FS00:0xa7:   Platform: win32 10
11:50:09:WU00:FS00:0xa7:       Bits: 64
11:50:09:WU00:FS00:0xa7:       Mode: Release
11:50:09:WU00:FS00:0xa7:************************************ System ************************************
11:50:09:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:50:09:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:50:09:WU00:FS00:0xa7:       CPUs: 12
11:50:09:WU00:FS00:0xa7:     Memory: 7.96GiB
11:50:09:WU00:FS00:0xa7:Free Memory: 4.99GiB
11:50:09:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:50:09:WU00:FS00:0xa7: OS Version: 6.2
11:50:09:WU00:FS00:0xa7:Has Battery: false
11:50:09:WU00:FS00:0xa7: On Battery: false
11:50:09:WU00:FS00:0xa7: UTC Offset: -6
11:50:09:WU00:FS00:0xa7:        PID: 12932
11:50:09:WU00:FS00:0xa7:        CWD: C:\Users\jorda\AppData\Roaming\FAHClient\work
11:50:09:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:50:09:WU00:FS00:0xa7:    Version: 0.0.18
11:50:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:50:09:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:50:09:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:50:09:WU00:FS00:0xa7:       Time: 01:52:30
11:50:09:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:50:09:WU00:FS00:0xa7:************************************ Build *************************************
11:50:09:WU00:FS00:0xa7:       SIMD: avx_256
11:50:09:WU00:FS00:0xa7:********************************************************************************
11:50:09:WU00:FS00:0xa7:Project: 14300 (Run 17, Clone 163, Gen 11)
11:50:09:WU00:FS00:0xa7:Unit: 0x000000100002894b5e56c04e12d48b1f
11:50:09:WU00:FS00:0xa7:Reading tar file core.xml
11:50:09:WU00:FS00:0xa7:Reading tar file frame11.tpr
11:50:09:WU00:FS00:0xa7:Digital signatures verified
11:50:09:WU00:FS00:0xa7:Calling: mdrun -s frame11.tpr -o frame11.trr -cpt 15 -nt 10
11:50:09:WU00:FS00:0xa7:Steps: first=5500000 total=500000
11:50:12:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
11:50:18:WU00:FS00:0xa7:ERROR:
11:50:18:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:50:18:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
11:50:18:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec_top.c, line: 394
11:50:18:WU00:FS00:0xa7:ERROR:Fatal error:
11:50:18:WU00:FS00:0xa7:ERROR:1 of the 251792 bonded interactions could not be calculated because some atoms involved moved further apart than the multi-body cut-off distance (1.036 nm) or the two-body cut-off distance (1.036 nm), see option -rdd, for pairs and tabulated bonds also see option -ddcheck
11:50:18:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:50:18:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:50:25:WU00:FS00:0xa7:ERROR:
11:50:25:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:50:25:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
11:50:25:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec_top.c, line: 394
11:50:25:WU00:FS00:0xa7:ERROR:Fatal error:
11:50:25:WU00:FS00:0xa7:ERROR:1 of the 251792 bonded interactions could not be calculated because some atoms involved moved further apart than the multi-body cut-off distance (1.036 nm) or the two-body cut-off distance (1.036 nm), see option -rdd, for pairs and tabulated bonds also see option -ddcheck
11:50:25:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:50:25:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:50:33:WU00:FS00:0xa7:ERROR:
11:50:33:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:50:33:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
11:50:33:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec_top.c, line: 394
11:50:33:WU00:FS00:0xa7:ERROR:Fatal error:
11:50:33:WU00:FS00:0xa7:ERROR:1 of the 251792 bonded interactions could not be calculated because some atoms involved moved further apart than the multi-body cut-off distance (1.036 nm) or the two-body cut-off distance (1.036 nm), see option -rdd, for pairs and tabulated bonds also see option -ddcheck
11:50:33:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:50:33:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:50:38:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
11:50:38:WU00:FS00:0xa7:Saving result file dhdl.xvg
11:50:38:WU00:FS00:0xa7:Saving result file frame11.trr
11:50:38:WU00:FS00:0xa7:Saving result file md.log
11:50:38:WU00:FS00:0xa7:Saving result file science.log
11:50:38:WU00:FS00:0xa7:Saving result file traj_comp.xtc
11:50:38:WU00:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
11:50:38:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:50:38:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:14300 run:17 clone:163 gen:11 core:0xa7 unit:0x000000100002894b5e56c04e12d48b1f
11:50:38:WU00:FS00:Uploading 5.91MiB to 155.247.166.219
11:50:38:WU00:FS00:Connecting to 155.247.166.219:8080
11:50:38:WU02:FS00:Connecting to 65.254.110.245:8080
11:50:39:WU02:FS00:Assigned to work server 155.247.164.213
11:50:39:WU02:FS00:Requesting new work unit for slot 00: READY cpu:10 from 155.247.164.213
11:50:39:WU02:FS00:Connecting to 155.247.164.213:8080
11:50:39:WU02:FS00:Downloading 1.23MiB
11:50:39:WU02:FS00:Download complete
11:50:39:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14198 run:2 clone:303 gen:2 core:0xa7 unit:0x000000029bf7a4d55e66d00e251001a8
11:50:39:WU02:FS00:Starting
11:50:39:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jorda\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10368 -checkpoint 15 -np 10
11:50:39:WU02:FS00:Started FahCore on PID 2128
11:50:39:WU02:FS00:Core PID:2316
11:50:39:WU02:FS00:FahCore 0xa7 started
11:50:40:WU02:FS00:0xa7:*********************** Log Started 2020-03-14T11:50:39Z ***********************
11:50:40:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:50:40:WU02:FS00:0xa7:       Type: 0xa7
11:50:40:WU02:FS00:0xa7:       Core: Gromacs
11:50:40:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2128 -checkpoint 15 -np
11:50:40:WU02:FS00:0xa7:             10
11:50:40:WU02:FS00:0xa7:************************************ CBang *************************************
11:50:40:WU02:FS00:0xa7:       Date: Oct 26 2019
11:50:40:WU02:FS00:0xa7:       Time: 01:38:25
11:50:40:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:50:40:WU02:FS00:0xa7:     Branch: master
11:50:40:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
11:50:40:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:50:40:WU02:FS00:0xa7:   Platform: win32 10
11:50:40:WU02:FS00:0xa7:       Bits: 64
11:50:40:WU02:FS00:0xa7:       Mode: Release
11:50:40:WU02:FS00:0xa7:************************************ System ************************************
11:50:40:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
11:50:40:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
11:50:40:WU02:FS00:0xa7:       CPUs: 12
11:50:40:WU02:FS00:0xa7:     Memory: 7.96GiB
11:50:40:WU02:FS00:0xa7:Free Memory: 5.01GiB
11:50:40:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
11:50:40:WU02:FS00:0xa7: OS Version: 6.2
11:50:40:WU02:FS00:0xa7:Has Battery: false
11:50:40:WU02:FS00:0xa7: On Battery: false
11:50:40:WU02:FS00:0xa7: UTC Offset: -6
11:50:40:WU02:FS00:0xa7:        PID: 2316
11:50:40:WU02:FS00:0xa7:        CWD: C:\Users\jorda\AppData\Roaming\FAHClient\work
11:50:40:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
11:50:40:WU02:FS00:0xa7:    Version: 0.0.18
11:50:40:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:50:40:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:50:40:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
11:50:40:WU02:FS00:0xa7:       Time: 01:52:30
11:50:40:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:50:40:WU02:FS00:0xa7:************************************ Build *************************************
11:50:40:WU02:FS00:0xa7:       SIMD: avx_256
11:50:40:WU02:FS00:0xa7:********************************************************************************
11:50:40:WU02:FS00:0xa7:Project: 14198 (Run 2, Clone 303, Gen 2)
11:50:40:WU02:FS00:0xa7:Unit: 0x000000029bf7a4d55e66d00e251001a8
11:50:40:WU02:FS00:0xa7:Reading tar file core.xml
11:50:40:WU02:FS00:0xa7:Reading tar file frame2.tpr
11:50:40:WU02:FS00:0xa7:Digital signatures verified
11:50:40:WU02:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpt 15 -nt 10
11:50:40:WU02:FS00:0xa7:Steps: first=1000000 total=500000
11:50:40:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
11:50:42:WU00:FS00:Upload complete
11:50:42:WU00:FS00:Server responded WORK_ACK (400)
11:50:42:WU00:FS00:Cleaning up
11:50:59:WU01:FS01:Connecting to 65.254.110.245:8080
11:50:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:50:59:WU01:FS01:Connecting to 18.218.241.186:80
11:50:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:50:59:ERROR:WU01:FS01:Exception: Could not get an assignment
11:51:07:WU02:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
11:51:35:WU02:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
11:52:03:WU02:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
11:52:30:WU02:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
11:52:36:WU01:FS01:Connecting to 65.254.110.245:8080
11:52:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:52:36:WU01:FS01:Connecting to 18.218.241.186:80
11:52:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:52:37:ERROR:WU01:FS01:Exception: Could not get an assignment
11:52:58:WU02:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
11:53:29:WU02:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
11:53:57:WU02:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
11:54:26:WU02:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
11:54:55:WU02:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
11:55:13:WU01:FS01:Connecting to 65.254.110.245:8080
11:55:13:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:55:13:WU01:FS01:Connecting to 18.218.241.186:80
11:55:14:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:55:14:ERROR:WU01:FS01:Exception: Could not get an assignment
11:55:25:WU02:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
11:55:55:WU02:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
11:56:24:WU02:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:56:54:WU02:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:57:24:WU02:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
11:57:55:WU02:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
11:58:25:WU02:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
11:58:55:WU02:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
Re: GPU (1070_ Getting No WUs available for this configurati
Post by muziqaz »
Your GPU slot is hitting unstable server issue, which is still "normal", and you are not the only one.
Your CPU slot though is hitting 3 different issues:
Server overload
Unstable work unit, which has been rectified already
Unstable hardware (still trying to verify)
Is you CPU overclocked by any chance? Folding@Home can tax modern hardware to its limit, beyond what other programs can do, so even if you thought your PC is stable, F@H will bring out any instability out.
From last few lines in your log, I see CPU is finally folding
FAH Omega tester
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
"No WUs available for this configuration" indicates that the server is stable, but F@h's userbase has expanded 10x in the past two weeks and workunits are being exhausted faster than they can be regenerated. The research times are spinning up new servers and getting more projects into the queue. Keep everything on and it should pick up workunits when they are available.
