Stuck on download
Someone05
Stuck on download
Post by Someone05 »
I just downloaded folding@home last night and both the cpu and GPU were folding fine but this morning my GPU can not find an assignment
*********************** Log Started 2020-03-14T11:44:00Z ***********************
11:44:00:************************* Folding@home Client *************************
11:44:00:        Website: https://foldingathome.org/
11:44:00:      Copyright: (c) 2009-2018 foldingathome.org
11:44:00:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:44:00:           Args: --open-web-control
11:44:00:         Config: <none>
11:44:00:******************************** Build ********************************
11:44:00:        Version: 7.5.1
11:44:00:           Date: May 11 2018
11:44:00:           Time: 13:06:32
11:44:00:     Repository: Git
11:44:00:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:44:00:         Branch: master
11:44:00:       Compiler: Visual C++ 2008
11:44:00:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:44:00:       Platform: win32 10
11:44:00:           Bits: 32
11:44:00:           Mode: Release
11:44:00:******************************* System ********************************
11:44:00:            CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
11:44:00:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:44:00:           CPUs: 8
11:44:00:         Memory: 15.89GiB
11:44:00:    Free Memory: 10.31GiB
11:44:00:        Threads: WINDOWS_THREADS
11:44:00:     OS Version: 6.2
11:44:00:    Has Battery: true
11:44:00:     On Battery: false
11:44:00:     UTC Offset: 0
11:44:00:            PID: 16924
11:44:00:            CWD: C:\Users\Brian\AppData\Roaming\FAHClient
11:44:00:             OS: Windows 10 Home
11:44:00:        OS Arch: AMD64
11:44:00:           GPUs: 0
11:44:00:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
11:44:00:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
11:44:00:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:22.20
11:44:00:  Win32 Service: false
11:44:00:***********************************************************************
11:44:00:<config>
11:44:00:  <!-- Folding Slots -->
11:44:00:</config>
11:44:00:Connecting to assign1.foldingathome.org:8080
11:44:01:Updated GPUs.txt
11:44:01:Read GPUs.txt
11:44:01:Trying to access database...
11:44:01:Successfully acquired database lock
11:44:01:Enabled folding slot 00: PAUSED cpu:3 (not configured)
11:44:01:Enabled folding slot 01: PAUSED gpu:0:GP106M [GeForce GTX 1060 Mobile] (not configured)
11:44:17:55:127.0.0.1:New Web connection
11:44:59:Set client configured
11:44:59:WU00:FS00:Connecting to 65.254.110.245:8080
11:45:00:WU00:FS00:Connecting to 65.254.110.245:8080
11:45:00:WU00:FS00:Assigned to work server 128.252.203.10
11:45:00:WU00:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.10
11:45:00:WU00:FS00:Connecting to 128.252.203.10:8080
11:45:02:Saving configuration to config.xml
11:45:02:<config>
11:45:02:  <!-- User Information -->
11:45:02:  <passkey v='********************************'/>
11:45:02:  <user v='Someone05'/>
11:45:02:
11:45:02:  <!-- Folding Slots -->
11:45:02:  <slot id='0' type='CPU'/>
11:45:02:  <slot id='1' type='GPU'/>
11:45:02:</config>
11:45:02:WU00:FS00:Downloading 1.06MiB
11:45:02:WU00:FS00:Download complete
11:45:02:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14524 run:351 clone:1 gen:1 core:0xa7 unit:0x0000000180fccb0a5e459baaa55ec4b4
11:45:02:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
11:45:02:WU00:FS00:Connecting to cores.foldingathome.org:80
11:45:05:WU00:FS00:FahCore a7: Downloading 6.71MiB
11:45:06:WU01:FS01:Connecting to 65.254.110.245:8080
11:45:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:45:06:WU01:FS01:Connecting to 18.218.241.186:80
11:45:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:45:07:ERROR:WU01:FS01:Exception: Could not get an assignment
11:45:07:WU01:FS01:Connecting to 65.254.110.245:8080
11:45:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:45:07:WU01:FS01:Connecting to 18.218.241.186:80
11:45:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:45:08:ERROR:WU01:FS01:Exception: Could not get an assignment
11:45:09:WU00:FS00:FahCore a7: Download complete
11:45:09:WU00:FS00:Valid core signature
11:45:09:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
11:45:09:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
11:45:09:WU00:FS00:Starting
11:45:09:WARNING:WU00:FS00:Changed SMP threads from 3 to 7 this can cause some work units to fail
11:45:09:WARNING:WU00:FS00:AS lowered CPUs from 7 to 3
11:45:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Brian\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 16924 -checkpoint 15 -np 3
11:45:09:WU00:FS00:Started FahCore on PID 652
11:45:10:WU00:FS00:Core PID:13480
11:45:10:WU00:FS00:FahCore 0xa7 started
11:45:10:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T11:45:10Z ***********************
11:45:10:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:45:10:WU00:FS00:0xa7:       Type: 0xa7
11:45:10:WU00:FS00:0xa7:       Core: Gromacs
11:45:10:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 652 -checkpoint 15 -np 3
11:45:10:WU00:FS00:0xa7:************************************ CBang *************************************
11:45:10:WU00:FS00:0xa7:       Date: Oct 26 2019
11:45:10:WU00:FS00:0xa7:       Time: 01:38:25
11:45:10:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:45:10:WU00:FS00:0xa7:     Branch: master
11:45:10:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:45:10:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:45:10:WU00:FS00:0xa7:   Platform: win32 10
11:45:10:WU00:FS00:0xa7:       Bits: 64
11:45:10:WU00:FS00:0xa7:       Mode: Release
11:45:10:WU00:FS00:0xa7:************************************ System ************************************
11:45:10:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
11:45:10:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
11:45:10:WU00:FS00:0xa7:       CPUs: 8
11:45:10:WU00:FS00:0xa7:     Memory: 15.89GiB
11:45:10:WU00:FS00:0xa7:Free Memory: 9.96GiB
11:45:10:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:45:10:WU00:FS00:0xa7: OS Version: 6.2
11:45:10:WU00:FS00:0xa7:Has Battery: true
11:45:10:WU00:FS00:0xa7: On Battery: false
11:45:10:WU00:FS00:0xa7: UTC Offset: 0
11:45:10:WU00:FS00:0xa7:        PID: 13480
11:45:10:WU00:FS00:0xa7:        CWD: C:\Users\Brian\AppData\Roaming\FAHClient\work
11:45:10:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:45:10:WU00:FS00:0xa7:    Version: 0.0.18
11:45:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:45:10:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:45:10:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:45:10:WU00:FS00:0xa7:       Time: 01:52:30
11:45:10:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:45:10:WU00:FS00:0xa7:************************************ Build *************************************
11:45:10:WU00:FS00:0xa7:       SIMD: avx_256
11:45:10:WU00:FS00:0xa7:********************************************************************************
11:45:10:WU00:FS00:0xa7:Project: 14524 (Run 351, Clone 1, Gen 1)
11:45:10:WU00:FS00:0xa7:Unit: 0x0000000180fccb0a5e459baaa55ec4b4
11:45:10:WU00:FS00:0xa7:Reading tar file core.xml
11:45:10:WU00:FS00:0xa7:Reading tar file frame1.tpr
11:45:10:WU00:FS00:0xa7:Digital signatures verified
11:45:10:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -cpt 15 -nt 3
11:45:10:WU00:FS00:0xa7:Steps: first=250000 total=250000
11:45:11:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
11:46:03:Saving configuration to config.xml
11:46:03:<config>
11:46:03:  <!-- Slot Control -->
11:46:03:  <power v='FULL'/>
11:46:03:
11:46:03:  <!-- User Information -->
11:46:03:  <passkey v='********************************'/>
11:46:03:  <user v='Someone05'/>
11:46:03:
11:46:03:  <!-- Folding Slots -->
11:46:03:  <slot id='0' type='CPU'/>
11:46:03:  <slot id='1' type='GPU'/>
11:46:03:</config>
11:46:07:WU01:FS01:Connecting to 65.254.110.245:8080
11:46:07:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
11:46:07:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:46:07:WU01:FS01:Connecting to 18.218.241.186:80
11:46:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:46:08:ERROR:WU01:FS01:Exception: Could not get an assignment
11:47:05:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
11:47:44:WU01:FS01:Connecting to 65.254.110.245:8080
11:47:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:47:45:WU01:FS01:Connecting to 18.218.241.186:80
11:47:45:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:47:45:ERROR:WU01:FS01:Exception: Could not get an assignment
11:48:03:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
11:49:01:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
11:50:00:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11:50:21:WU01:FS01:Connecting to 65.254.110.245:8080
11:50:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:50:22:WU01:FS01:Connecting to 18.218.241.186:80
11:50:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:50:22:ERROR:WU01:FS01:Exception: Could not get an assignment
11:50:58:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
Re: Stuck on download
