Hi all, I have been inactive for a long time in SETI and F@H projects, I just wondered why my GPU is pushing 1% and CPU is 100%, quite a difference in usage it seems, is there a specific driver version I should be using perhaps?
Gigabyte RX 590 8GB
RX590 usage
Re: RX590 usage
How are you checking the load on your GPU? That can matter, some tools default to showing the CPU load needed for the GPU driver and not the load on the GPU itself.
Also, if your GPU was not getting a WU - Subject: Temporary server outages
