GPu ready but not working
tomplayer07
Hi everyone! New to the site. I downloaded and installed the software on my pc but the gpu is not working. Here are my specs: i5 4440-r9 280-8 gb ram. I know it is not very powerful but in the next few months I will upgrade it with a r5 3600 and a rx 5700 xt. Thank you for the support.
Paragon
- Hardware configuration: Rig1 (Dedicated SMP): AMD Phenom II X6 1100T, Gigabyte GA-880GMA-USB3 board, 8 GB Kingston 1333 DDR3 Ram, Seasonic S12 II 380 Watt PSU, Noctua CPU Cooler
Rig2 (Part-Time GPU): Intel Q6600, Gigabyte 965P-S3 Board, EVGA 460 GTX Graphics, 8 GB Kingston 800 DDR2 Ram, Seasonic Gold X-650 PSU, Artic Cooling Freezer 7 CPU Cooler - Location: United States
Re: GPu ready but not working
Hi, and welcome! Not many gpu work units are available right now due to all the new donors, but the team is working on it.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
There's been an overwhelming flood of newcomers to Folding@home due to the high interest in helping out with the WuFlu research. This has led to a complete exhaustion of the available workunits in the queue, so sometimes your software might wait for a bit while its looking for more work. This situation should improve soon as the research groups are deploying new high-capacity servers and getting new projects into the queue. So I'd recommend just leaving everything there and it should fully engage relatively soon.
When FAH is installed and set to FULL, it will generally attempt to run one WU assignment on your i5 CPU and another on your R9 280 GPU. As has been stated above, you may have significant gaps in the productivity of your system due to the current server limitations.
John_Mc
- Hardware configuration: MacBook Pro (Retina, 15-inch, Mid 2015)
2.5 GHz Quad-Core Intel Core i7
GPU: AMD Radeon R9 M370X and Intel Iris Pro - Location: Monkton, Vermont
Started folding yesterday. The default startup settings were for a single CPU slot. It took about 15 ours to get my first WU.
When I saw that up and running, I added a slot for my GPU (Radeon HD 8800M series, according to the FAH client, AMD Radeon R9 M370X according to the system info on my computer), accepting the defaults for that. It has never been assigned a WU. However, in the mean time, my CPU lot finished one WU, was assigned and started another, and is almost done with that.
From reading the above, I'm guessing there are just not enough GPU WUs available at present? Is there any way to check that my client is setup correctly so that it will load at GPU WU when one is ready?
If you could post the first 200 or so lines of your log using the directions in the signature of Bruce's post, that would give us info about your system and its configuration to check over.
John_Mc
Here it is (Let me know if I cut off the log too soon)
Thanks for your help.
*********************** Log Started 2020-03-19T11:23:28Z ***********************
11:23:28:************************* Folding@home Client *************************
11:23:28: Website: https://foldingathome.org/
11:23:28: Copyright: (c) 2009-2018 foldingathome.org
11:23:28: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:23:28: Args:
11:23:28: Config: /Library/Application Support/FAHClient/config.xml
11:23:28:******************************** Build ********************************
11:23:28: Version: 7.5.1
11:23:28: Date: May 11 2018
11:23:28: Time: 12:57:01
11:23:28: Repository: Git
11:23:28: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
11:23:28: Branch: master
11:23:28: Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
11:23:28: Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
11:23:28: -Wno-unused-local-typedefs
11:23:28: Platform: darwin 15.6.0
11:23:28: Bits: 64
11:23:28: Mode: Release
11:23:28:******************************* System ********************************
11:23:28: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:23:28: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:23:28: CPUs: 8
11:23:28: Memory: 16.00GiB
11:23:28:Free Memory: 14.12GiB
11:23:28: Threads: POSIX_THREADS
11:23:28: OS Version: 10.15
11:23:28:Has Battery: true
11:23:28: On Battery: false
11:23:28: UTC Offset: -4
11:23:28: PID: 153
11:23:28: CWD: /Library/Application Support/FAHClient
11:23:28: OS: Darwin 19.3.0 x86_64
11:23:28: OS Arch: AMD64
11:23:28: GPUs: 1
11:23:28: GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon HD 8800M Series]
11:23:28: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
11:23:28: dlopen(libcuda.dylib, 1): image not found
11:23:28: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
11:23:28: dlopen(libOpenCL.dylib, 1): image not found
11:23:28:***********************************************************************
11:23:28:<config>
11:23:28: <!-- Slot Control -->
11:23:28: <power v='MEDIUM'/>
11:23:28:
11:23:28: <!-- User Information -->
11:23:28: <passkey v='********************************'/>
11:23:28: <user v='John_Mc'/>
11:23:28:
11:23:28: <!-- Folding Slots -->
11:23:28: <slot id='0' type='CPU'/>
11:23:28:</config>
11:23:28:Trying to access database...
11:23:29:Successfully acquired database lock
11:23:29:Enabled folding slot 00: READY cpu:7
11:23:29:WU00:FS00:Starting
11:23:30:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 153 -checkpoint 15 -np 7
11:23:30:WU00:FS00:Started FahCore on PID 380
11:23:30:WU00:FS00:Core PID:381
11:23:30:WU00:FS00:FahCore 0xa7 started
11:23:36:WU00:FS00:0xa7:*********************** Log Started 2020-03-19T11:23:36Z ***********************
11:23:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:23:36:WU00:FS00:0xa7: Type: 0xa7
11:23:36:WU00:FS00:0xa7: Core: Gromacs
11:23:36:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 380 -checkpoint 15 -np 7
11:23:36:WU00:FS00:0xa7:************************************ CBang *************************************
11:23:36:WU00:FS00:0xa7: Date: Oct 26 2019
11:23:36:WU00:FS00:0xa7: Time: 03:00:53
11:23:36:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
11:23:36:WU00:FS00:0xa7: Branch: master
11:23:36:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:23:36:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:23:36:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:23:36:WU00:FS00:0xa7: Platform: darwin 19.0.0
11:23:36:WU00:FS00:0xa7: Bits: 64
11:23:36:WU00:FS00:0xa7: Mode: Release
11:23:36:WU00:FS00:0xa7:************************************ System ************************************
11:23:36:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:23:36:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:23:36:WU00:FS00:0xa7: CPUs: 8
11:23:36:WU00:FS00:0xa7: Memory: 16.00GiB
11:23:36:WU00:FS00:0xa7:Free Memory: 13.62GiB
11:23:36:WU00:FS00:0xa7: Threads: POSIX_THREADS
11:23:36:WU00:FS00:0xa7: OS Version: 10.15
11:23:36:WU00:FS00:0xa7:Has Battery: true
11:23:36:WU00:FS00:0xa7: On Battery: false
11:23:36:WU00:FS00:0xa7: UTC Offset: -4
11:23:36:WU00:FS00:0xa7: PID: 381
11:23:36:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
11:23:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:23:36:WU00:FS00:0xa7: Version: 0.0.18
11:23:36:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:23:36:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:23:36:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:23:36:WU00:FS00:0xa7: Time: 03:06:33
11:23:36:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
11:23:36:WU00:FS00:0xa7:************************************ Build *************************************
11:23:36:WU00:FS00:0xa7: SIMD: avx_256
11:23:36:WU00:FS00:0xa7:********************************************************************************
11:23:36:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 2, Gen 0)
11:23:36:WU00:FS00:0xa7:Unit: 0x0000000080fccb025e72eb4d167099b6
11:23:36:WU00:FS00:0xa7:Digital signatures verified
11:23:36:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
11:23:36:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 6
11:23:36:WU00:FS00:0xa7:Steps: first=0 total=500000
11:23:38:WU00:FS00:0xa7:Completed 19512 out of 500000 steps (3%)
11:23:44:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
11:25:08:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
11:26:19:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
11:27:31:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
11:28:42:FS00:Shutting core down
11:28:42:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
11:28:42:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 381
11:28:42:WU00:FS00:0xa7:Exiting, please wait. . .
11:28:43:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:28:43:WU00:FS00:Starting
11:28:43:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 153 -checkpoint 15 -np 7
11:28:43:WU00:FS00:Started FahCore on PID 651
11:28:43:WU00:FS00:Core PID:652
11:28:43:WU00:FS00:FahCore 0xa7 started
11:28:44:WU00:FS00:0xa7:*********************** Log Started 2020-03-19T11:28:43Z ***********************
11:28:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:28:44:WU00:FS00:0xa7: Type: 0xa7
11:28:44:WU00:FS00:0xa7: Core: Gromacs
11:28:44:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 651 -checkpoint 15 -np 7
11:28:44:WU00:FS00:0xa7:************************************ CBang *************************************
11:28:44:WU00:FS00:0xa7: Date: Oct 26 2019
11:28:44:WU00:FS00:0xa7: Time: 03:00:53
11:28:44:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
11:28:44:WU00:FS00:0xa7: Branch: master
11:28:44:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:28:44:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:28:44:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:28:44:WU00:FS00:0xa7: Platform: darwin 19.0.0
11:28:44:WU00:FS00:0xa7: Bits: 64
11:28:44:WU00:FS00:0xa7: Mode: Release
11:28:44:WU00:FS00:0xa7:************************************ System ************************************
11:28:44:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:28:44:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:28:44:WU00:FS00:0xa7: CPUs: 8
11:28:44:WU00:FS00:0xa7: Memory: 16.00GiB
11:28:44:WU00:FS00:0xa7:Free Memory: 9.62GiB
11:28:44:WU00:FS00:0xa7: Threads: POSIX_THREADS
11:28:44:WU00:FS00:0xa7: OS Version: 10.15
11:28:44:WU00:FS00:0xa7:Has Battery: true
11:28:44:WU00:FS00:0xa7: On Battery: false
11:28:44:WU00:FS00:0xa7: UTC Offset: -4
11:28:44:WU00:FS00:0xa7: PID: 652
11:28:44:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
11:28:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:28:44:WU00:FS00:0xa7: Version: 0.0.18
11:28:44:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:28:44:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:28:44:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:28:44:WU00:FS00:0xa7: Time: 03:06:33
11:28:44:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
11:28:44:WU00:FS00:0xa7:************************************ Build *************************************
11:28:44:WU00:FS00:0xa7: SIMD: avx_256
11:28:44:WU00:FS00:0xa7:********************************************************************************
11:28:44:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 2, Gen 0)
11:28:44:WU00:FS00:0xa7:Unit: 0x0000000080fccb025e72eb4d167099b6
11:28:44:WU00:FS00:0xa7:Digital signatures verified
11:28:44:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
11:28:44:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 6
11:28:44:WU00:FS00:0xa7:Steps: first=0 total=500000
11:28:44:WU00:FS00:0xa7:Completed 40012 out of 500000 steps (8%)
11:29:35:Saving configuration to config.xml
11:29:35:<config>
11:29:35: <!-- Slot Control -->
11:29:35: <power v='medium'/>
11:29:35:
11:29:35: <!-- User Information -->
11:29:35: <passkey v='********************************'/>
11:29:35: <user v='John_Mc'/>
11:29:35:
11:29:35: <!-- Folding Slots -->
11:29:35: <slot id='0' type='CPU'/>
11:29:35:</config>
11:29:53:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
11:30:33:FS00:Shutting core down
11:30:34:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 652
11:30:34:WU00:FS00:0xa7:Exiting, please wait. . .
11:30:35:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:30:35:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:30:35:WU00:FS00:Starting
11:30:35:WARNING:WU00:FS00:Changed SMP threads from 7 to 8 this can cause some work units to fail
11:30:35:WARNING:WU00:FS00:AS lowered CPUs from 8 to 7
11:30:35:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 153 -checkpoint 15 -np 7
11:30:35:WU00:FS00:Started FahCore on PID 662
11:30:35:WU00:FS00:Core PID:663
11:30:35:WU00:FS00:FahCore 0xa7 started
11:30:36:Saving configuration to config.xml
11:30:36:<config>
11:30:36: <!-- Slot Control -->
11:30:36: <power v='full'/>
11:30:36:
11:30:36: <!-- User Information -->
11:30:36: <passkey v='********************************'/>
11:30:36: <user v='John_Mc'/>
11:30:36:
11:30:36: <!-- Folding Slots -->
11:30:36: <slot id='0' type='CPU'/>
11:30:36:</config>
11:30:36:WU00:FS00:0xa7:*********************** Log Started 2020-03-19T11:30:35Z ***********************
11:30:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:30:36:WU00:FS00:0xa7: Type: 0xa7
11:30:36:WU00:FS00:0xa7: Core: Gromacs
11:30:36:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 662 -checkpoint 15 -np 7
11:30:36:WU00:FS00:0xa7:************************************ CBang *************************************
11:30:36:WU00:FS00:0xa7: Date: Oct 26 2019
11:30:36:WU00:FS00:0xa7: Time: 03:00:53
11:30:36:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
11:30:36:WU00:FS00:0xa7: Branch: master
11:30:36:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:30:36:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:30:36:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:30:36:WU00:FS00:0xa7: Platform: darwin 19.0.0
11:30:36:WU00:FS00:0xa7: Bits: 64
11:30:36:WU00:FS00:0xa7: Mode: Release
11:30:36:WU00:FS00:0xa7:************************************ System ************************************
11:30:36:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:30:36:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:30:36:WU00:FS00:0xa7: CPUs: 8
11:30:36:WU00:FS00:0xa7: Memory: 16.00GiB
11:30:36:WU00:FS00:0xa7:Free Memory: 9.34GiB
11:30:36:WU00:FS00:0xa7: Threads: POSIX_THREADS
11:30:36:WU00:FS00:0xa7: OS Version: 10.15
11:30:36:WU00:FS00:0xa7:Has Battery: true
11:30:36:WU00:FS00:0xa7: On Battery: false
11:30:36:WU00:FS00:0xa7: UTC Offset: -4
11:30:36:WU00:FS00:0xa7: PID: 663
11:30:36:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
11:30:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:30:36:WU00:FS00:0xa7: Version: 0.0.18
11:30:36:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:30:36:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:30:36:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:30:36:WU00:FS00:0xa7: Time: 03:06:33
11:30:36:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
11:30:36:WU00:FS00:0xa7:************************************ Build *************************************
11:30:36:WU00:FS00:0xa7: SIMD: avx_256
11:30:36:WU00:FS00:0xa7:********************************************************************************
11:30:36:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 2, Gen 0)
11:30:36:WU00:FS00:0xa7:Unit: 0x0000000080fccb025e72eb4d167099b6
11:30:36:WU00:FS00:0xa7:Digital signatures verified
11:30:36:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
11:30:36:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 6
11:30:36:WU00:FS00:0xa7:Steps: first=0 total=500000
11:30:36:WU00:FS00:0xa7:Completed 47902 out of 500000 steps (9%)
11:31:04:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
11:32:14:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
11:33:23:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:34:33:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:35:43:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
11:36:53:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
11:38:02:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
11:39:13:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
11:40:23:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
11:41:33:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
11:42:43:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
11:43:52:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
11:45:02:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
11:46:13:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
11:47:23:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
11:48:33:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
11:49:43:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
11:50:13:FS00:Shutting core down
11:50:13:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 663
11:50:13:WU00:FS00:0xa7:Exiting, please wait. . .
11:50:14:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:50:15:WU00:FS00:Starting
11:50:15:WARNING:WU00:FS00:Changed SMP threads from 8 to 7 this can cause some work units to fail
11:50:15:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 153 -checkpoint 15 -np 7
11:50:15:WU00:FS00:Started FahCore on PID 675
11:50:15:WU00:FS00:Core PID:676
11:50:15:WU00:FS00:FahCore 0xa7 started
11:50:15:WU00:FS00:0xa7:*********************** Log Started 2020-03-19T11:50:15Z ***********************
11:50:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:50:15:WU00:FS00:0xa7: Type: 0xa7
11:50:15:WU00:FS00:0xa7: Core: Gromacs
11:50:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 675 -checkpoint 15 -np 7
11:50:15:WU00:FS00:0xa7:************************************ CBang *************************************
11:50:15:WU00:FS00:0xa7: Date: Oct 26 2019
11:50:15:WU00:FS00:0xa7: Time: 03:00:53
11:50:15:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
11:50:15:WU00:FS00:0xa7: Branch: master
11:50:15:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:50:15:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:50:15:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:50:15:WU00:FS00:0xa7: Platform: darwin 19.0.0
11:50:15:WU00:FS00:0xa7: Bits: 64
11:50:15:WU00:FS00:0xa7: Mode: Release
11:50:15:WU00:FS00:0xa7:************************************ System ************************************
11:50:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:50:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:50:15:WU00:FS00:0xa7: CPUs: 8
11:50:15:WU00:FS00:0xa7: Memory: 16.00GiB
11:50:15:WU00:FS00:0xa7:Free Memory: 9.08GiB
11:50:15:WU00:FS00:0xa7: Threads: POSIX_THREADS
11:50:15:WU00:FS00:0xa7: OS Version: 10.15
11:50:15:WU00:FS00:0xa7:Has Battery: true
11:50:15:WU00:FS00:0xa7: On Battery: false
11:50:15:WU00:FS00:0xa7: UTC Offset: -4
11:50:15:WU00:FS00:0xa7: PID: 676
11:50:15:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
11:50:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:50:15:WU00:FS00:0xa7: Version: 0.0.18
11:50:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:50:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:50:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:50:15:WU00:FS00:0xa7: Time: 03:06:33
11:50:15:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
11:50:15:WU00:FS00:0xa7:************************************ Build *************************************
11:50:15:WU00:FS00:0xa7: SIMD: avx_256
11:50:15:WU00:FS00:0xa7:********************************************************************************
11:50:15:WU00:FS00:0xa7:Project: 14576 (Run 0, Clone 2, Gen 0)
11:50:15:WU00:FS00:0xa7:Unit: 0x0000000080fccb025e72eb4d167099b6
11:50:15:WU00:FS00:0xa7:Digital signatures verified
11:50:15:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
11:50:15:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpi state.cpt -cpt 15 -nt 6
11:50:15:WU00:FS00:0xa7:Steps: first=0 total=500000
11:50:15:WU00:FS00:0xa7:Completed 132082 out of 500000 steps (26%)
11:50:18:FS00:Shutting core down
11:50:18:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 676
11:50:18:WU00:FS00:0xa7:Exiting, please wait. . .
11:50:19:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
11:50:19:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
11:51:15:WU00:FS00:Starting
11:51:15:WARNING:WU00:FS00:Changed SMP threads from 7 to 8 this can cause some work units to fail
11:51:15:WARNING:WU00:FS00:AS lowered CPUs from 8 to 7
11:51:15:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 153 -checkpoint 15 -np 7
11:51:15:WU00:FS00:Started FahCore on PID 713
11:51:15:WU00:FS00:Core PID:714
11:51:15:WU00:FS00:FahCore 0xa7 started
11:51:15:WU00:FS00:0xa7:*********************** Log Started 2020-03-19T11:51:15Z ***********************
11:51:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:51:15:WU00:FS00:0xa7: Type: 0xa7
11:51:15:WU00:FS00:0xa7: Core: Gromacs
11:51:15:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 713 -checkpoint 15 -np 7
11:51:15:WU00:FS00:0xa7:************************************ CBang *************************************
11:51:15:WU00:FS00:0xa7: Date: Oct 26 2019
11:51:15:WU00:FS00:0xa7: Time: 03:00:53
11:51:15:WU00:FS00:0xa7: Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
11:51:15:WU00:FS00:0xa7: Branch: master
11:51:15:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
11:51:15:WU00:FS00:0xa7: Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
11:51:15:WU00:FS00:0xa7: -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
11:51:15:WU00:FS00:0xa7: Platform: darwin 19.0.0
11:51:15:WU00:FS00:0xa7: Bits: 64
11:51:15:WU00:FS00:0xa7: Mode: Release
11:51:15:WU00:FS00:0xa7:************************************ System ************************************
11:51:15:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
11:51:15:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 70 Stepping 1
11:51:15:WU00:FS00:0xa7: CPUs: 8
11:51:15:WU00:FS00:0xa7: Memory: 16.00GiB
11:51:15:WU00:FS00:0xa7:Free Memory: 8.76GiB
11:51:15:WU00:FS00:0xa7: Threads: POSIX_THREADS
11:51:15:WU00:FS00:0xa7: OS Version: 10.15
11:51:15:WU00:FS00:0xa7:Has Battery: true
11:51:15:WU00:FS00:0xa7: On Battery: false
11:51:15:WU00:FS00:0xa7: UTC Offset: -4
11:51:15:WU00:FS00:0xa7: PID: 714
11:51:15:WU00:FS00:0xa7: CWD: /Library/Application Support/FAHClient/work
11:51:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:51:15:WU00:FS00:0xa7: Version: 0.0.18
11:51:15:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:51:15:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
11:51:15:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
11:51:15:WU00:FS00:0xa7: Time: 03:06:33
11:51:15:WU00:FS00:0xa7: Revision: fcc08f30b8997509aaba3a213354c363f474e056
John_Mc
OK. Thanks. Guess I'll turn that one off. (I added my system info to my profile. Thought I had mentioned it in my previous post, but I see now that I did not.)
Hi there - I've installed the software (yesterday) and have been waiting all day to see if a work unit appears: I don't understand any of the technical stuff but this is a fairly new Lenovo laptop. Is it just (as they say on the telephone helplines) "we are experiencing a high volume of calls, please hold"?
Jesse_V
CPU: i7-6700k
Yes, it's quite likely that you got everything set up correctly, but there are just so many new users that there's not enough work available for everyone at this moment. The research teams are getting more projects into the queue and setting up more servers so hopefully that resolves itself soon.Viv_Brown wrote:Hi there - I've installed the software (yesterday) and have been waiting all day to see if a work unit appears: I don't understand any of the technical stuff but this is a fairly new Lenovo laptop. Is it just (as they say on the telephone helplines) "we are experiencing a high volume of calls, please hold"?
Thanks - I guess (like the rest of life) I just have to be patient!
John_Mc
Do you know if there are plans to add support for GPU folding on the Mac in the future? If so, how can I be sure to hear about it, and will I need to do anything special to get it to start happening?bruce wrote:Oh, you didn't mention that you were running MacOS and I' didn't guess that. Unfortunately GPU folding is not supported on the Mac. The configuration created by original install was correct: You have a CPU slot. Manually adding a GPU was a useless step.
If you don't get an answer to this at the moment it might be worth asking it again once the current surge/overload of issues is managed - think at the moment most resource is focused on keeping stuff going for today/tomorrow and maybe the next week or so ... There may be discussions on this in previous thread that might enlighten you - feel free to root around with the search tool ... One of the Mods or Site Admins may get a chance to give you an answer if they get a chance.
As I understand it, there currently are no plans to reopen the development of a folding core for the macOS. The F@h team may reevaluate that at some point in the future as the Apple hardware and software changes. That would be if they saw expending some part of the limited software development resources on that would get them more science than using it on another resource.John_Mc wrote:Do you know if there are plans to add support for GPU folding on the Mac in the future? If so, how can I be sure to hear about it, and will I need to do anything special to get it to start happening?
