GTX 1660Ti not running
Hrakuun
Post by Hrakuun »
Hi,
I just installed the F@H and my GPU isnt doing anything.
CPU works just fine.
This is the log for GPU:
*********************** Log Started 2020-03-14T09:49:24Z ***********************
09:49:24:ERROR:FS01:OpenCL GPU not found for 'opencl-index' = 4 with vendor ID = 0x10de, please correct this by removing the manually configured 'opencl-index' option.
09:49:52:FS01:Unpaused
09:49:53:WU01:FS01:Connecting to 65.254.110.245:8080
09:49:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:49:53:WU01:FS01:Connecting to 18.218.241.186:80
09:49:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:49:54:ERROR:WU01:FS01:Exception: Could not get an assignment
09:49:54:WU01:FS01:Connecting to 65.254.110.245:8080
09:49:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:49:54:WU01:FS01:Connecting to 18.218.241.186:80
09:50:54:WU01:FS01:Connecting to 65.254.110.245:8080
09:50:54:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:50:54:WU01:FS01:Connecting to 18.218.241.186:80
09:50:54:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:50:54:ERROR:WU01:FS01:Exception: Could not get an assignment
09:52:31:WU01:FS01:Connecting to 65.254.110.245:8080
09:52:32:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:52:32:WU01:FS01:Connecting to 18.218.241.186:80
09:52:32:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:52:32:ERROR:WU01:FS01:Exception: Could not get an assignment
09:55:08:WU01:FS01:Connecting to 65.254.110.245:8080
09:55:09:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:55:09:WU01:FS01:Connecting to 18.218.241.186:80
09:55:09:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:55:09:ERROR:WU01:FS01:Exception: Could not get an assignment
09:59:23:WU01:FS01:Connecting to 65.254.110.245:8080
09:59:23:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:59:23:WU01:FS01:Connecting to 18.218.241.186:80
09:59:24:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:59:24:ERROR:WU01:FS01:Exception: Could not get an assignment
10:01:46:WU01:FS01:Connecting to 65.254.110.245:8080
10:01:46:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:01:46:WU01:FS01:Connecting to 18.218.241.186:80
10:01:47:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:01:47:ERROR:WU01:FS01:Exception: Could not get an assignment
10:03:23:WU01:FS01:Connecting to 65.254.110.245:8080
10:03:24:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:03:24:WU01:FS01:Connecting to 18.218.241.186:80
10:03:24:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:03:24:ERROR:WU01:FS01:Exception: Could not get an assignment
10:06:00:WU01:FS01:Connecting to 65.254.110.245:8080
10:06:01:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:06:01:WU01:FS01:Connecting to 18.218.241.186:80
10:06:01:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:06:01:ERROR:WU01:FS01:Exception: Could not get an assignment
10:07:24:FS01:Paused
10:07:27:FS01:Unpaused
10:07:27:WU01:FS01:Connecting to 65.254.110.245:8080
10:07:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:07:28:WU01:FS01:Connecting to 18.218.241.186:80
10:07:28:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:07:28:ERROR:WU01:FS01:Exception: Could not get an assignment
Anyone knows how to fix it? Thanks!
Reason: added code tags
Re: GTX 1660Ti not running
Are you sure that you didn't mess with the opencl-index settings ? If so, please remove it.
Else, see announcement : Temporary server outages
Hrakuun
Post by Hrakuun »
I did not mess wit hit manually, but when i changed it to "-1" it works :) Now my CPU doesnt have work. Thanks anyway!
The error message is exceedingly confusing. Your GPU is not properly install. Post the first couple of pages of FAH's log per the instructions below.
Have you manually installed the proprietary drivers from AMD or NVidia's website?
The NVidia drivers also install OpenCL's runtime. You have to install OpenCL separately for AMD ... depending on whether you're on Window or Linux
Unfortunately GPUs are not supported on MacOS-X.
Hrakuun
Post by Hrakuun »
I updated the Drivers via Gforce Xperience. I have WinX, sometimes the GPU does receive a job, but most of the time its idle.
Nathan_P
Not currently folding
Post by Nathan_P »
yeah, the servers are struggling to keep up with demand. Please be patient
