GPU not folding
Matt_Murdock_
GPU not folding
Post by Matt_Murdock_ »
I used to fold back on PS3 days. Now things have gotten a little more complex. I've built a computer and understand it mostly but folding seems a more complex here. On the Web client my CPU is doing most the work. I have a CPU monitoring program installed and i dont know if these are normal operating ranges for the Light setting. Average Load across all cores is 45% and CPU Temps floats at 60c-63c with occasional spikes to 71c. The GPU is not doing anything although it is recognized by the client. Here is the log, I suspect its not connected to the folding server for the GPU
*********************** Log Started 2020-03-14T07:09:22Z ***********************
07:09:22:************************* Folding@home Client *************************
07:09:22:        Website: https://foldingathome.org/
07:09:22:      Copyright: (c) 2009-2018 foldingathome.org
07:09:22:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:09:22:           Args: --open-web-control
07:09:22:         Config: <none>
07:09:22:******************************** Build ********************************
07:09:22:        Version: 7.5.1
07:09:22:           Date: May 11 2018
07:09:22:           Time: 13:06:32
07:09:22:     Repository: Git
07:09:22:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:09:22:         Branch: master
07:09:22:       Compiler: Visual C++ 2008
07:09:22:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:09:22:       Platform: win32 10
07:09:22:           Bits: 32
07:09:22:           Mode: Release
07:09:22:******************************* System ********************************
07:09:22:            CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:09:22:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:09:22:           CPUs: 16
07:09:22:         Memory: 15.93GiB
07:09:22:    Free Memory: 10.91GiB
07:09:22:        Threads: WINDOWS_THREADS
07:09:22:     OS Version: 6.2
07:09:22:    Has Battery: false
07:09:22:     On Battery: false
07:09:22:     UTC Offset: -7
07:09:22:            PID: 12652
07:09:22:            CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient
07:09:22:             OS: Windows 10 Home
07:09:22:        OS Arch: AMD64
07:09:22:           GPUs: 0
07:09:22:  CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:7.5 Driver:10.2
07:09:22:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:441.87
07:09:22:  Win32 Service: false
07:09:22:***********************************************************************
07:09:22:<config>
07:09:22:  <!-- Folding Slots -->
07:09:22:</config>
07:09:22:Connecting to assign1.foldingathome.org:8080
07:09:23:Updated GPUs.txt
07:09:23:Read GPUs.txt
07:09:23:Trying to access database...
07:09:23:Successfully acquired database lock
07:09:23:Enabled folding slot 00: PAUSED cpu:14 (not configured)
07:09:23:Enabled folding slot 01: PAUSED gpu:0:TU116 [GeForce GTX 1660 SUPER] (not configured)
07:09:26:10:127.0.0.1:New Web connection
07:10:24:Saving configuration to config.xml
07:10:24:<config>
07:10:24:  <!-- Folding Slots -->
07:10:24:  <slot id='0' type='CPU'/>
07:10:24:  <slot id='1' type='GPU'/>
07:10:24:</config>
07:10:24:Set client configured
07:10:24:WU00:FS00:Connecting to 65.254.110.245:8080
07:10:24:WU01:FS01:Connecting to 65.254.110.245:8080
07:10:24:WU00:FS00:Assigned to work server 128.252.203.9
07:10:24:WU00:FS00:Requesting new work unit for slot 00: READY cpu:14 from 128.252.203.9
07:10:24:WU00:FS00:Connecting to 128.252.203.9:8080
07:10:25:WU01:FS01:Assigned to work server 140.163.4.231
07:10:25:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.231
07:10:25:WU01:FS01:Connecting to 140.163.4.231:8080
07:10:26:WU00:FS00:Downloading 7.29MiB
07:10:26:WU00:FS00:Download complete
07:10:26:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14400 run:0 clone:3033 gen:92 core:0xa7 unit:0x0000006980fccb095dcad7c14ef6669f
07:10:26:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
07:10:26:WU00:FS00:Connecting to cores.foldingathome.org:80
07:10:28:WU00:FS00:FahCore a7: Downloading 6.71MiB
07:10:28:WU00:FS00:FahCore a7: Download complete
07:10:29:WU00:FS00:Valid core signature
07:10:29:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
07:10:29:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
07:10:29:WU00:FS00:Starting
07:10:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 14
07:10:29:WU00:FS00:Started FahCore on PID 12756
07:10:29:WU00:FS00:Core PID:9028
07:10:29:WU00:FS00:FahCore 0xa7 started
07:10:30:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:10:29Z ***********************
07:10:30:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:10:30:WU00:FS00:0xa7:       Type: 0xa7
07:10:30:WU00:FS00:0xa7:       Core: Gromacs
07:10:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12756 -checkpoint 15 -np
07:10:30:WU00:FS00:0xa7:             14
07:10:30:WU00:FS00:0xa7:************************************ CBang *************************************
07:10:30:WU00:FS00:0xa7:       Date: Oct 26 2019
07:10:30:WU00:FS00:0xa7:       Time: 01:38:25
07:10:30:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:10:30:WU00:FS00:0xa7:     Branch: master
07:10:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:10:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:10:30:WU00:FS00:0xa7:   Platform: win32 10
07:10:30:WU00:FS00:0xa7:       Bits: 64
07:10:30:WU00:FS00:0xa7:       Mode: Release
07:10:30:WU00:FS00:0xa7:************************************ System ************************************
07:10:30:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:10:30:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:10:30:WU00:FS00:0xa7:       CPUs: 16
07:10:30:WU00:FS00:0xa7:     Memory: 15.93GiB
07:10:30:WU00:FS00:0xa7:Free Memory: 10.86GiB
07:10:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:10:30:WU00:FS00:0xa7: OS Version: 6.2
07:10:30:WU00:FS00:0xa7:Has Battery: false
07:10:30:WU00:FS00:0xa7: On Battery: false
07:10:30:WU00:FS00:0xa7: UTC Offset: -7
07:10:30:WU00:FS00:0xa7:        PID: 9028
07:10:30:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:10:30:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:10:30:WU00:FS00:0xa7:    Version: 0.0.18
07:10:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:10:30:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:10:30:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:10:30:WU00:FS00:0xa7:       Time: 01:52:30
07:10:30:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:10:30:WU00:FS00:0xa7:************************************ Build *************************************
07:10:30:WU00:FS00:0xa7:       SIMD: avx_256
07:10:30:WU00:FS00:0xa7:********************************************************************************
07:10:30:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:10:30:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:10:30:WU00:FS00:0xa7:Reading tar file core.xml
07:10:30:WU00:FS00:0xa7:Reading tar file frame92.tpr
07:10:30:WU00:FS00:0xa7:Digital signatures verified
07:10:30:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
07:10:30:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
07:10:30:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpt 15 -nt 12
07:10:30:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:10:32:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
07:10:46:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:10:46:WU01:FS01:Connecting to 140.163.4.231:80
07:11:07:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:11:07:FS00:Shutting core down
07:11:07:WU01:FS01:Connecting to 65.254.110.245:8080
07:11:07:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 9028
07:11:07:WU00:FS00:0xa7:Exiting, please wait. . .
07:11:07:WU01:FS01:Assigned to work server 140.163.4.231
07:11:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.231
07:11:07:WU01:FS01:Connecting to 140.163.4.231:8080
07:11:09:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:11:09:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:11:10:WU00:FS00:Starting
07:11:10:WARNING:WU00:FS00:Changed SMP threads from 14 to 15 this can cause some work units to fail
07:11:10:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
07:11:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 14
07:11:10:WU00:FS00:Started FahCore on PID 17884
07:11:10:WU00:FS00:Core PID:5344
07:11:10:WU00:FS00:FahCore 0xa7 started
07:11:10:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:11:10Z ***********************
07:11:10:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:11:10:WU00:FS00:0xa7:       Type: 0xa7
07:11:10:WU00:FS00:0xa7:       Core: Gromacs
07:11:10:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 17884 -checkpoint 15 -np
07:11:10:WU00:FS00:0xa7:             14
07:11:10:WU00:FS00:0xa7:************************************ CBang *************************************
07:11:10:WU00:FS00:0xa7:       Date: Oct 26 2019
07:11:10:WU00:FS00:0xa7:       Time: 01:38:25
07:11:10:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:11:10:WU00:FS00:0xa7:     Branch: master
07:11:10:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:11:10:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:11:10:WU00:FS00:0xa7:   Platform: win32 10
07:11:10:WU00:FS00:0xa7:       Bits: 64
07:11:10:WU00:FS00:0xa7:       Mode: Release
07:11:10:WU00:FS00:0xa7:************************************ System ************************************
07:11:10:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:11:10:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:11:10:WU00:FS00:0xa7:       CPUs: 16
07:11:10:WU00:FS00:0xa7:     Memory: 15.93GiB
07:11:10:WU00:FS00:0xa7:Free Memory: 10.90GiB
07:11:10:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:11:10:WU00:FS00:0xa7: OS Version: 6.2
07:11:10:WU00:FS00:0xa7:Has Battery: false
07:11:10:WU00:FS00:0xa7: On Battery: false
07:11:10:WU00:FS00:0xa7: UTC Offset: -7
07:11:10:WU00:FS00:0xa7:        PID: 5344
07:11:10:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:11:10:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:11:10:WU00:FS00:0xa7:    Version: 0.0.18
07:11:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:11:10:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:11:10:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:11:10:WU00:FS00:0xa7:       Time: 01:52:30
07:11:10:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:11:10:WU00:FS00:0xa7:************************************ Build *************************************
07:11:10:WU00:FS00:0xa7:       SIMD: avx_256
07:11:10:WU00:FS00:0xa7:********************************************************************************
07:11:10:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:11:10:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:11:10:WU00:FS00:0xa7:Digital signatures verified
07:11:10:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
07:11:10:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
07:11:10:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 12
07:11:10:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:11:12:WU00:FS00:0xa7:Completed 702 out of 125000 steps (0%)
07:11:25:Saving configuration to config.xml
07:11:25:<config>
07:11:25:  <!-- Slot Control -->
07:11:25:  <power v='FULL'/>
07:11:25:
07:11:25:  <!-- User Information -->
07:11:25:  <user v='Matt_Murdock'/>
07:11:25:
07:11:25:  <!-- Folding Slots -->
07:11:25:  <slot id='0' type='CPU'/>
07:11:25:  <slot id='1' type='GPU'/>
07:11:25:</config>
07:11:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:11:28:WU01:FS01:Connecting to 140.163.4.231:80
07:11:39:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
07:11:49:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:11:52:FS00:Paused
07:11:52:FS01:Paused
07:11:52:FS00:Shutting core down
07:11:52:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5344
07:11:52:WU00:FS00:0xa7:Exiting, please wait. . .
07:11:54:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:11:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:12:03:FS00:Unpaused
07:12:03:FS01:Unpaused
07:12:07:WU01:FS01:Connecting to 65.254.110.245:8080
07:12:07:WU01:FS01:Assigned to work server 140.163.4.231
07:12:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.231
07:12:07:WU01:FS01:Connecting to 140.163.4.231:8080
07:12:10:WU00:FS00:Starting
07:12:10:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
07:12:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 14
07:12:10:WU00:FS00:Started FahCore on PID 11404
07:12:10:WU00:FS00:Core PID:11676
07:12:10:WU00:FS00:FahCore 0xa7 started
07:12:10:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:12:10Z ***********************
07:12:10:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:12:10:WU00:FS00:0xa7:       Type: 0xa7
07:12:10:WU00:FS00:0xa7:       Core: Gromacs
07:12:10:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11404 -checkpoint 15 -np
07:12:10:WU00:FS00:0xa7:             14
07:12:10:WU00:FS00:0xa7:************************************ CBang *************************************
07:12:10:WU00:FS00:0xa7:       Date: Oct 26 2019
07:12:10:WU00:FS00:0xa7:       Time: 01:38:25
07:12:10:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:12:10:WU00:FS00:0xa7:     Branch: master
07:12:10:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:12:10:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:12:10:WU00:FS00:0xa7:   Platform: win32 10
07:12:10:WU00:FS00:0xa7:       Bits: 64
07:12:10:WU00:FS00:0xa7:       Mode: Release
07:12:10:WU00:FS00:0xa7:************************************ System ************************************
07:12:10:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:12:10:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:12:10:WU00:FS00:0xa7:       CPUs: 16
07:12:10:WU00:FS00:0xa7:     Memory: 15.93GiB
07:12:10:WU00:FS00:0xa7:Free Memory: 10.95GiB
07:12:10:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:12:10:WU00:FS00:0xa7: OS Version: 6.2
07:12:10:WU00:FS00:0xa7:Has Battery: false
07:12:10:WU00:FS00:0xa7: On Battery: false
07:12:10:WU00:FS00:0xa7: UTC Offset: -7
07:12:10:WU00:FS00:0xa7:        PID: 11676
07:12:10:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:12:10:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:12:10:WU00:FS00:0xa7:    Version: 0.0.18
07:12:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:12:10:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:12:10:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:12:10:WU00:FS00:0xa7:       Time: 01:52:30
07:12:10:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:12:10:WU00:FS00:0xa7:************************************ Build *************************************
07:12:10:WU00:FS00:0xa7:       SIMD: avx_256
07:12:10:WU00:FS00:0xa7:********************************************************************************
07:12:10:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:12:10:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:12:10:WU00:FS00:0xa7:Digital signatures verified
07:12:10:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
07:12:10:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
07:12:10:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 12
07:12:10:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:12:12:WU00:FS00:0xa7:Completed 1532 out of 125000 steps (1%)
07:12:28:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:12:28:WU01:FS01:Connecting to 140.163.4.231:80
07:12:32:FS00:Shutting core down
07:12:32:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11676
07:12:32:WU00:FS00:0xa7:Exiting, please wait. . .
07:12:34:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:12:34:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:13:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
07:13:10:WU00:FS00:Starting
07:13:10:WARNING:WU00:FS00:Changed SMP threads from 15 to 7 this can cause some work units to fail
07:13:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 7
07:13:10:WU00:FS00:Started FahCore on PID 13724
07:13:10:WU00:FS00:Core PID:6396
07:13:10:WU00:FS00:FahCore 0xa7 started
07:13:10:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:13:10Z ***********************
07:13:10:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:13:10:WU00:FS00:0xa7:       Type: 0xa7
07:13:10:WU00:FS00:0xa7:       Core: Gromacs
07:13:10:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 13724 -checkpoint 15 -np
07:13:10:WU00:FS00:0xa7:             7
07:13:10:WU00:FS00:0xa7:************************************ CBang *************************************
07:13:10:WU00:FS00:0xa7:       Date: Oct 26 2019
07:13:10:WU00:FS00:0xa7:       Time: 01:38:25
07:13:10:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:13:10:WU00:FS00:0xa7:     Branch: master
07:13:10:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:13:10:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:13:10:WU00:FS00:0xa7:   Platform: win32 10
07:13:10:WU00:FS00:0xa7:       Bits: 64
07:13:10:WU00:FS00:0xa7:       Mode: Release
07:13:10:WU00:FS00:0xa7:************************************ System ************************************
07:13:10:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:13:10:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:13:10:WU00:FS00:0xa7:       CPUs: 16
07:13:10:WU00:FS00:0xa7:     Memory: 15.93GiB
07:13:10:WU00:FS00:0xa7:Free Memory: 11.09GiB
07:13:10:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:13:10:WU00:FS00:0xa7: OS Version: 6.2
07:13:10:WU00:FS00:0xa7:Has Battery: false
07:13:10:WU00:FS00:0xa7: On Battery: false
07:13:10:WU00:FS00:0xa7: UTC Offset: -7
07:13:10:WU00:FS00:0xa7:        PID: 6396
07:13:10:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:13:10:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:13:10:WU00:FS00:0xa7:    Version: 0.0.18
07:13:10:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:13:10:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:13:10:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:13:10:WU00:FS00:0xa7:       Time: 01:52:30
07:13:10:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:13:10:WU00:FS00:0xa7:************************************ Build *************************************
07:13:10:WU00:FS00:0xa7:       SIMD: avx_256
07:13:10:WU00:FS00:0xa7:********************************************************************************
07:13:10:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:13:10:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:13:10:WU00:FS00:0xa7:Digital signatures verified
07:13:10:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
07:13:10:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 6
07:13:10:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:13:12:WU00:FS00:0xa7:Completed 1952 out of 125000 steps (1%)
07:13:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
07:13:27:Saving configuration to config.xml
07:13:27:<config>
07:13:27:  <!-- Slot Control -->
07:13:27:  <power v='LIGHT'/>
07:13:27:
07:13:27:  <!-- User Information -->
07:13:27:  <user v='Matt_Murdock'/>
07:13:27:
07:13:27:  <!-- Folding Slots -->
07:13:27:  <slot id='0' type='CPU'/>
07:13:27:  <slot id='1' type='GPU'/>
07:13:27:</config>
07:13:37:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
07:13:45:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
07:14:59:WU00:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
07:15:58:FS00:Shutting core down
07:15:58:WU01:FS01:Connecting to 65.254.110.245:8080
07:15:58:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6396
07:15:58:WU00:FS00:0xa7:Exiting, please wait. . .
07:15:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:15:58:WU01:FS01:Connecting to 18.218.241.186:80
07:15:59:WU01:FS01:Assigned to work server 140.163.4.241
07:15:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.241
07:15:59:WU01:FS01:Connecting to 140.163.4.241:8080
07:16:00:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:16:00:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:16:00:WU00:FS00:Starting
07:16:00:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 7
07:16:00:WU00:FS00:Started FahCore on PID 1964
07:16:00:WU00:FS00:Core PID:15232
07:16:00:WU00:FS00:FahCore 0xa7 started
07:16:01:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:16:00Z ***********************
07:16:01:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:16:01:WU00:FS00:0xa7:       Type: 0xa7
07:16:01:WU00:FS00:0xa7:       Core: Gromacs
07:16:01:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1964 -checkpoint 15 -np 7
07:16:01:WU00:FS00:0xa7:************************************ CBang *************************************
07:16:01:WU00:FS00:0xa7:       Date: Oct 26 2019
07:16:01:WU00:FS00:0xa7:       Time: 01:38:25
07:16:01:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:16:01:WU00:FS00:0xa7:     Branch: master
07:16:01:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:16:01:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:16:01:WU00:FS00:0xa7:   Platform: win32 10
07:16:01:WU00:FS00:0xa7:       Bits: 64
07:16:01:WU00:FS00:0xa7:       Mode: Release
07:16:01:WU00:FS00:0xa7:************************************ System ************************************
07:16:01:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:16:01:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:16:01:WU00:FS00:0xa7:       CPUs: 16
07:16:01:WU00:FS00:0xa7:     Memory: 15.93GiB
07:16:01:WU00:FS00:0xa7:Free Memory: 11.10GiB
07:16:01:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:16:01:WU00:FS00:0xa7: OS Version: 6.2
07:16:01:WU00:FS00:0xa7:Has Battery: false
07:16:01:WU00:FS00:0xa7: On Battery: false
07:16:01:WU00:FS00:0xa7: UTC Offset: -7
07:16:01:WU00:FS00:0xa7:        PID: 15232
07:16:01:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:16:01:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:16:01:WU00:FS00:0xa7:    Version: 0.0.18
07:16:01:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:16:01:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:16:01:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:16:01:WU00:FS00:0xa7:       Time: 01:52:30
07:16:01:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:16:01:WU00:FS00:0xa7:************************************ Build *************************************
07:16:01:WU00:FS00:0xa7:       SIMD: avx_256
07:16:01:WU00:FS00:0xa7:********************************************************************************
07:16:01:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:16:01:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:16:01:WU00:FS00:0xa7:Digital signatures verified
07:16:01:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
07:16:01:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 6
07:16:01:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:16:03:WU00:FS00:0xa7:Completed 4732 out of 125000 steps (3%)
07:16:18:WU00:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
07:16:30:Saving configuration to config.xml
07:16:30:<config>
07:16:30:  <!-- Slot Control -->
07:16:30:  <power v='light'/>
07:16:30:
07:16:30:  <!-- User Information -->
07:16:30:  <user v='Matt_Murdock'/>
07:16:30:
07:16:30:  <!-- Folding Slots -->
07:16:30:  <slot id='0' type='CPU'/>
07:16:30:  <slot id='1' type='GPU'/>
07:16:30:</config>
07:17:08:FS00:Shutting core down
07:17:08:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 15232
07:17:08:WU00:FS00:0xa7:Exiting, please wait. . .
07:17:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:17:10:WU00:FS00:Starting
07:17:10:WARNING:WU00:FS00:Changed SMP threads from 7 to 15 this can cause some work units to fail
07:17:10:WARNING:WU00:FS00:AS lowered CPUs from 15 to 14
07:17:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 14
07:17:10:WU00:FS00:Started FahCore on PID 11800
07:17:10:WU00:FS00:Core PID:16012
07:17:10:WU00:FS00:FahCore 0xa7 started
07:17:11:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:17:10Z ***********************
07:17:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:17:11:WU00:FS00:0xa7:       Type: 0xa7
07:17:11:WU00:FS00:0xa7:       Core: Gromacs
07:17:11:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11800 -checkpoint 15 -np
07:17:11:WU00:FS00:0xa7:             14
07:17:11:WU00:FS00:0xa7:************************************ CBang *************************************
07:17:11:WU00:FS00:0xa7:       Date: Oct 26 2019
07:17:11:WU00:FS00:0xa7:       Time: 01:38:25
07:17:11:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:17:11:WU00:FS00:0xa7:     Branch: master
07:17:11:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:17:11:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:17:11:WU00:FS00:0xa7:   Platform: win32 10
07:17:11:WU00:FS00:0xa7:       Bits: 64
07:17:11:WU00:FS00:0xa7:       Mode: Release
07:17:11:WU00:FS00:0xa7:************************************ System ************************************
07:17:11:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:17:11:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:17:11:WU00:FS00:0xa7:       CPUs: 16
07:17:11:WU00:FS00:0xa7:     Memory: 15.93GiB
07:17:11:WU00:FS00:0xa7:Free Memory: 11.11GiB
07:17:11:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:17:11:WU00:FS00:0xa7: OS Version: 6.2
07:17:11:WU00:FS00:0xa7:Has Battery: false
07:17:11:WU00:FS00:0xa7: On Battery: false
07:17:11:WU00:FS00:0xa7: UTC Offset: -7
07:17:11:WU00:FS00:0xa7:        PID: 16012
07:17:11:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:17:11:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:17:11:WU00:FS00:0xa7:    Version: 0.0.18
07:17:11:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:17:11:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:17:11:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:17:11:WU00:FS00:0xa7:       Time: 01:52:30
07:17:11:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:17:11:WU00:FS00:0xa7:************************************ Build *************************************
07:17:11:WU00:FS00:0xa7:       SIMD: avx_256
07:17:11:WU00:FS00:0xa7:********************************************************************************
07:17:11:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:17:11:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:17:11:WU00:FS00:0xa7:Digital signatures verified
07:17:11:WU00:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
07:17:11:WU00:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
07:17:11:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 12
07:17:11:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:17:12:WU00:FS00:0xa7:Completed 5862 out of 125000 steps (4%)
07:17:12:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
07:17:13:WU01:FS01:Connecting to 65.254.110.245:8080
07:17:13:WU01:FS01:Assigned to work server 140.163.4.241
07:17:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.241
07:17:13:WU01:FS01:Connecting to 140.163.4.241:8080
07:17:31:Saving configuration to config.xml
07:17:31:<config>
07:17:31:  <!-- Slot Control -->
07:17:31:  <power v='full'/>
07:17:31:
07:17:31:  <!-- User Information -->
07:17:31:  <user v='Matt_Murdock'/>
07:17:31:
07:17:31:  <!-- Folding Slots -->
07:17:31:  <slot id='0' type='CPU'/>
07:17:31:  <slot id='1' type='GPU'/>
07:17:31:</config>
07:17:31:WU00:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
07:17:35:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:17:35:WU01:FS01:Connecting to 140.163.4.241:80
07:17:36:FS00:Shutting core down
07:17:36:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 16012
07:17:36:WU00:FS00:0xa7:Exiting, please wait. . .
07:17:37:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:17:38:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:17:56:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:18:10:WU00:FS00:Starting
07:18:10:WARNING:WU00:FS00:Changed SMP threads from 15 to 7 this can cause some work units to fail
07:18:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\That Chris Guy\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 12652 -checkpoint 15 -np 7
07:18:10:WU00:FS00:Started FahCore on PID 18440
07:18:10:WU00:FS00:Core PID:9932
07:18:10:WU00:FS00:FahCore 0xa7 started
07:18:11:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T07:18:10Z ***********************
07:18:11:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:18:11:WU00:FS00:0xa7:       Type: 0xa7
07:18:11:WU00:FS00:0xa7:       Core: Gromacs
07:18:11:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 18440 -checkpoint 15 -np
07:18:11:WU00:FS00:0xa7:             7
07:18:11:WU00:FS00:0xa7:************************************ CBang *************************************
07:18:11:WU00:FS00:0xa7:       Date: Oct 26 2019
07:18:11:WU00:FS00:0xa7:       Time: 01:38:25
07:18:11:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:18:11:WU00:FS00:0xa7:     Branch: master
07:18:11:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:18:11:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:18:11:WU00:FS00:0xa7:   Platform: win32 10
07:18:11:WU00:FS00:0xa7:       Bits: 64
07:18:11:WU00:FS00:0xa7:       Mode: Release
07:18:11:WU00:FS00:0xa7:************************************ System ************************************
07:18:11:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
07:18:11:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
07:18:11:WU00:FS00:0xa7:       CPUs: 16
07:18:11:WU00:FS00:0xa7:     Memory: 15.93GiB
07:18:11:WU00:FS00:0xa7:Free Memory: 11.14GiB
07:18:11:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:18:11:WU00:FS00:0xa7: OS Version: 6.2
07:18:11:WU00:FS00:0xa7:Has Battery: false
07:18:11:WU00:FS00:0xa7: On Battery: false
07:18:11:WU00:FS00:0xa7: UTC Offset: -7
07:18:11:WU00:FS00:0xa7:        PID: 9932
07:18:11:WU00:FS00:0xa7:        CWD: C:\Users\That Chris Guy\AppData\Roaming\FAHClient\work
07:18:11:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:18:11:WU00:FS00:0xa7:    Version: 0.0.18
07:18:11:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:18:11:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:18:11:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:18:11:WU00:FS00:0xa7:       Time: 01:52:30
07:18:11:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:18:11:WU00:FS00:0xa7:************************************ Build *************************************
07:18:11:WU00:FS00:0xa7:       SIMD: avx_256
07:18:11:WU00:FS00:0xa7:********************************************************************************
07:18:11:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 3033, Gen 92)
07:18:11:WU00:FS00:0xa7:Unit: 0x0000006980fccb095dcad7c14ef6669f
07:18:11:WU00:FS00:0xa7:Digital signatures verified
07:18:11:WU00:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
07:18:11:WU00:FS00:0xa7:Calling: mdrun -s frame92.tpr -o frame92.trr -x frame92.xtc -cpi state.cpt -cpt 15 -nt 6
07:18:11:WU00:FS00:0xa7:Steps: first=11500000 total=125000
07:18:12:WU00:FS00:0xa7:Completed 6342 out of 125000 steps (5%)
07:18:32:Saving configuration to config.xml
07:18:32:<config>
07:18:32:  <!-- Slot Control -->
07:18:32:  <power v='light'/>
07:18:32:
07:18:32:  <!-- User Information -->
07:18:32:  <user v='Matt_Murdock'/>
07:18:32:
07:18:32:  <!-- Folding Slots -->
07:18:32:  <slot id='0' type='CPU'/>
07:18:32:  <slot id='1' type='GPU'/>
07:18:32:</config>
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Re: GPU not folding
Post by v00d00 »
You have an issue with the GPU. Maybe a driver issue. i havent folded on windows in a long time so can't really help beyond that.
BlueRotkev
Hardware configuration: Zotac Twin Fan 1660Ti (442.59GRD)
240GB WD Green M2
2TB WD Black 7200
i5 7400
16GB Loki of Asgard 2400MHz RAM
Re: GPU not folding
Post by BlueRotkev »
I can't see which GPU youre using, as I'm seeing driver 441.xx
Latest Nvidia drivers are 442.59. might be worth a mention
i5-7400
Nvidia 1660Ti
AVG PPD 572000
Here to fight COVID-19
Re: GPU not folding
I'm going to guess that this is the problem: Subject: Temporary server outages
The servers are being reloaded one-at-a-time.
