attached logs if it helps developers.
*********************** Log Started 2020-03-14T03:19:35Z ***********************
03:19:35:************************* Folding@home Client *************************
03:19:35: Website: https://foldingathome.org/
03:19:35: Copyright: (c) 2009-2018 foldingathome.org
03:19:35: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:19:35: Args: --open-web-control
03:19:35: Config: <none>
03:19:35:******************************** Build ********************************
03:19:35: Version: 7.5.1
03:19:35: Date: May 11 2018
03:19:35: Time: 13:06:32
03:19:35: Repository: Git
03:19:35: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:19:35: Branch: master
03:19:35: Compiler: Visual C++ 2008
03:19:35: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:19:35: Platform: win32 10
03:19:35: Bits: 32
03:19:35: Mode: Release
03:19:35:******************************* System ********************************
03:19:35: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:19:35: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:19:35: CPUs: 8
03:19:35: Memory: 15.98GiB
03:19:35: Free Memory: 9.59GiB
03:19:35: Threads: WINDOWS_THREADS
03:19:35: OS Version: 6.2
03:19:35: Has Battery: false
03:19:35: On Battery: false
03:19:35: UTC Offset: 11
03:19:35: PID: 296280
03:19:35: CWD: C:\Users\Server\AppData\Roaming\FAHClient
03:19:35: OS: Windows 10 Enterprise
03:19:35: OS Arch: AMD64
03:19:35: GPUs: 0
03:19:35: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:10.1
03:19:35:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
03:19:35: Win32 Service: false
03:19:35:***********************************************************************
03:19:36:<config>
03:19:36: <!-- Folding Slots -->
03:19:36:</config>
03:19:36:Connecting to assign1.foldingathome.org:8080
03:19:37:Updated GPUs.txt
03:19:37:Read GPUs.txt
03:19:37:Trying to access database...
03:19:37:Successfully acquired database lock
03:19:37:Enabled folding slot 00: PAUSED cpu:6 (not configured)
03:19:37:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] 2308 (not configured)
03:19:40:8:127.0.0.1:New Web connection
03:19:48:Set client configured
03:19:49:WU00:FS00:Connecting to 65.254.110.245:8080
03:19:49:WU01:FS01:Connecting to 65.254.110.245:8080
03:19:50:WU00:FS00:Assigned to work server 128.252.203.10
03:19:50:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 128.252.203.10
03:19:50:WU00:FS00:Connecting to 128.252.203.10:8080
03:19:50:WU01:FS01:Assigned to work server 140.163.4.241
03:19:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:19:50:WU01:FS01:Connecting to 140.163.4.241:8080
03:19:51:WU00:FS00:Downloading 2.97MiB
03:19:58:WU00:FS00:Download 6.31%
03:20:07:WU00:FS00:Download 12.63%
03:20:15:WU00:FS00:Download 18.94%
03:20:21:WU00:FS00:Download 25.25%
03:20:30:WU00:FS00:Download 31.57%
03:20:36:WU00:FS00:Download 35.78%
03:20:38:Saving configuration to config.xml
03:20:38:<config>
03:20:38: <!-- Slot Control -->
03:20:38: <power v='MEDIUM'/>
03:20:38:
03:20:38: <!-- Folding Slots -->
03:20:38: <slot id='0' type='CPU'/>
03:20:38: <slot id='1' type='GPU'/>
03:20:38:</config>
03:20:38:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:20:38:WU01:FS01:Connecting to 65.254.110.245:8080
03:20:39:WU01:FS01:Assigned to work server 140.163.4.241
03:20:39:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:20:39:WU01:FS01:Connecting to 140.163.4.241:8080
03:20:44:WU00:FS00:Download 42.09%
03:20:53:WU00:FS00:Download 48.41%
03:21:00:WU00:FS00:Download 52.61%
03:21:00:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:21:00:WU01:FS01:Connecting to 140.163.4.241:80
03:21:08:WU00:FS00:Download 58.93%
03:21:15:WU00:FS00:Download 63.14%
03:21:22:WU00:FS00:Download 69.45%
03:21:29:WU00:FS00:Download 75.76%
03:21:37:WU00:FS00:Download 82.08%
03:21:43:WU00:FS00:Download 86.29%
03:21:44:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:21:51:WU00:FS00:Download 90.50%
03:21:58:WU00:FS00:Download 96.81%
03:22:01:WU00:FS00:Download complete
03:22:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14531 run:0 clone:976 gen:6 core:0xa7 unit:0x0000000680fccb0a5e6978d5313d00b0
03:22:01:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
03:22:01:WU00:FS00:Connecting to cores.foldingathome.org:80
03:22:01:WU00:FS00:FahCore a7: Downloading 6.71MiB
03:22:02:42:127.0.0.1:New Web connection
03:22:07:WU00:FS00:FahCore a7: 13.04%
03:22:11:WU00:FS00:FahCore a7: Download complete
03:22:11:WU00:FS00:Valid core signature
03:22:11:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
03:22:12:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
03:22:12:WU00:FS00:Starting
03:22:12:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Server\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 296280 -checkpoint 15 -np 6
03:22:12:WU00:FS00:Started FahCore on PID 285948
03:22:12:WU00:FS00:Core PID:291944
03:22:12:WU00:FS00:FahCore 0xa7 started
03:22:12:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T03:22:12Z ***********************
03:22:12:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:22:12:WU00:FS00:0xa7: Type: 0xa7
03:22:12:WU00:FS00:0xa7: Core: Gromacs
03:22:12:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 285948 -checkpoint 15 -np
03:22:12:WU00:FS00:0xa7: 6
03:22:13:WU00:FS00:0xa7:************************************ CBang *************************************
03:22:13:WU00:FS00:0xa7: Date: Oct 26 2019
03:22:13:WU00:FS00:0xa7: Time: 01:38:25
03:22:13:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:22:13:WU00:FS00:0xa7: Branch: master
03:22:13:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:22:13:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:22:13:WU00:FS00:0xa7: Platform: win32 10
03:22:13:WU00:FS00:0xa7: Bits: 64
03:22:13:WU00:FS00:0xa7: Mode: Release
03:22:13:WU00:FS00:0xa7:************************************ System ************************************
03:22:13:WU00:FS00:0xa7: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:22:13:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:22:13:WU00:FS00:0xa7: CPUs: 8
03:22:13:WU00:FS00:0xa7: Memory: 15.98GiB
03:22:13:WU00:FS00:0xa7:Free Memory: 9.42GiB
03:22:13:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:22:13:WU00:FS00:0xa7: OS Version: 6.2
03:22:13:WU00:FS00:0xa7:Has Battery: false
03:22:13:WU00:FS00:0xa7: On Battery: false
03:22:13:WU00:FS00:0xa7: UTC Offset: 11
03:22:13:WU00:FS00:0xa7: PID: 291944
03:22:13:WU00:FS00:0xa7: CWD: C:\Users\Server\AppData\Roaming\FAHClient\work
03:22:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:22:13:WU00:FS00:0xa7: Version: 0.0.18
03:22:13:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:22:13:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:22:13:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:22:13:WU00:FS00:0xa7: Time: 01:52:30
03:22:13:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:22:13:WU00:FS00:0xa7:************************************ Build *************************************
03:22:13:WU00:FS00:0xa7: SIMD: avx_256
03:22:13:WU00:FS00:0xa7:********************************************************************************
03:22:13:WU00:FS00:0xa7:Project: 14531 (Run 0, Clone 976, Gen 6)
03:22:13:WU00:FS00:0xa7:Unit: 0x0000000680fccb0a5e6978d5313d00b0
03:22:13:WU00:FS00:0xa7:Reading tar file core.xml
03:22:13:WU00:FS00:0xa7:Reading tar file frame6.tpr
03:22:13:WU00:FS00:0xa7:Digital signatures verified
03:22:13:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 6
03:22:13:WU00:FS00:0xa7:Steps: first=1500000 total=250000
03:22:15:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
03:22:15:WU01:FS01:Connecting to 65.254.110.245:8080
03:22:16:WU01:FS01:Assigned to work server 140.163.4.231
03:22:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:22:16:WU01:FS01:Connecting to 140.163.4.231:8080
03:22:19:FS00:Shutting core down
03:22:19:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 291944
03:22:19:WU00:FS00:0xa7:Exiting, please wait. . .
03:22:23:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
03:22:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:22:23:WU00:FS00:Starting
03:22:23:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
03:22:23:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
03:22:23:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Server\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 296280 -checkpoint 15 -np 6
03:22:24:WU00:FS00:Started FahCore on PID 296200
03:22:24:WU00:FS00:Core PID:297776
03:22:24:WU00:FS00:FahCore 0xa7 started
03:22:24:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T03:22:24Z ***********************
03:22:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:22:24:WU00:FS00:0xa7: Type: 0xa7
03:22:24:WU00:FS00:0xa7: Core: Gromacs
03:22:24:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 296200 -checkpoint 15 -np
03:22:24:WU00:FS00:0xa7: 6
03:22:24:WU00:FS00:0xa7:************************************ CBang *************************************
03:22:24:WU00:FS00:0xa7: Date: Oct 26 2019
03:22:24:WU00:FS00:0xa7: Time: 01:38:25
03:22:24:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:22:24:WU00:FS00:0xa7: Branch: master
03:22:24:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:22:24:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:22:24:WU00:FS00:0xa7: Platform: win32 10
03:22:24:WU00:FS00:0xa7: Bits: 64
03:22:24:WU00:FS00:0xa7: Mode: Release
03:22:24:WU00:FS00:0xa7:************************************ System ************************************
03:22:24:WU00:FS00:0xa7: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:22:24:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:22:24:WU00:FS00:0xa7: CPUs: 8
03:22:24:WU00:FS00:0xa7: Memory: 15.98GiB
03:22:24:WU00:FS00:0xa7:Free Memory: 9.43GiB
03:22:24:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:22:24:WU00:FS00:0xa7: OS Version: 6.2
03:22:24:WU00:FS00:0xa7:Has Battery: false
03:22:24:WU00:FS00:0xa7: On Battery: false
03:22:24:WU00:FS00:0xa7: UTC Offset: 11
03:22:24:WU00:FS00:0xa7: PID: 297776
03:22:24:WU00:FS00:0xa7: CWD: C:\Users\Server\AppData\Roaming\FAHClient\work
03:22:24:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:22:24:WU00:FS00:0xa7: Version: 0.0.18
03:22:24:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:22:24:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:22:24:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:22:24:WU00:FS00:0xa7: Time: 01:52:30
03:22:24:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:22:24:WU00:FS00:0xa7:************************************ Build *************************************
03:22:24:WU00:FS00:0xa7: SIMD: avx_256
03:22:24:WU00:FS00:0xa7:********************************************************************************
03:22:24:WU00:FS00:0xa7:Project: 14531 (Run 0, Clone 976, Gen 6)
03:22:24:WU00:FS00:0xa7:Unit: 0x0000000680fccb0a5e6978d5313d00b0
03:22:24:WU00:FS00:0xa7:Digital signatures verified
03:22:24:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 6
03:22:24:WU00:FS00:0xa7:Steps: first=1500000 total=250000
03:22:26:WU00:FS00:0xa7:Completed 52 out of 250000 steps (0%)
03:22:37:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:22:37:WU01:FS01:Connecting to 140.163.4.231:80
03:22:40:Saving configuration to config.xml
03:22:40:<config>
03:22:40: <!-- Slot Control -->
03:22:40: <power v='FULL'/>
03:22:40:
03:22:40: <!-- Folding Slots -->
03:22:40: <slot id='0' type='CPU'/>
03:22:40: <slot id='1' type='GPU'/>
03:22:40:</config>
03:22:59:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:23:15:WU01:FS01:Connecting to 65.254.110.245:8080
03:23:16:WU01:FS01:Assigned to work server 140.163.4.241
03:23:16:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:23:16:WU01:FS01:Connecting to 140.163.4.241:8080
03:23:59:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:24:42:Saving configuration to config.xml
03:24:42:<config>
03:24:42: <!-- Slot Control -->
03:24:42: <power v='FULL'/>
03:24:42:
03:24:42: <!-- User Information -->
03:24:42: <user v='Zeal0usD'/>
03:24:42:
03:24:42: <!-- Folding Slots -->
03:24:42: <slot id='0' type='CPU'/>
03:24:42: <slot id='1' type='GPU'/>
03:24:42:</config>
03:24:53:WU01:FS01:Connecting to 65.254.110.245:8080
03:24:53:WU01:FS01:Assigned to work server 140.163.4.231
03:24:53:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:24:53:WU01:FS01:Connecting to 140.163.4.231:8080
03:25:15:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:25:15:WU01:FS01:Connecting to 140.163.4.231:80
03:25:36:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:26:46:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
03:27:30:WU01:FS01:Connecting to 65.254.110.245:8080
03:27:31:WU01:FS01:Assigned to work server 140.163.4.231
03:27:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:27:31:WU01:FS01:Connecting to 140.163.4.231:8080
03:27:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:27:52:WU01:FS01:Connecting to 140.163.4.231:80
03:28:13:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:31:01:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
03:31:44:WU01:FS01:Connecting to 65.254.110.245:8080
03:31:45:WU01:FS01:Assigned to work server 140.163.4.231
03:31:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:31:45:WU01:FS01:Connecting to 140.163.4.231:8080
03:32:06:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:32:06:WU01:FS01:Connecting to 140.163.4.231:80
03:32:28:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:34:27:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
03:37:28:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
03:38:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:38:36:WU01:FS01:Connecting to 65.254.110.245:8080
03:38:36:WU01:FS01:Assigned to work server 140.163.4.231
03:38:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:38:36:WU01:FS01:Connecting to 140.163.4.231:8080
03:38:42:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:39:07:FS00:Paused
03:39:07:FS01:Paused
03:39:07:FS00:Shutting core down
03:39:07:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 297776
03:39:07:WU00:FS00:0xa7:Exiting, please wait. . .
03:39:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:39:13:FS00:Unpaused
03:39:13:FS01:Unpaused
03:39:13:WU00:FS00:Starting
03:39:13:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
03:39:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Server\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 296280 -checkpoint 15 -np 6
03:39:13:WU00:FS00:Started FahCore on PID 297992
03:39:13:WU00:FS00:Core PID:298180
03:39:13:WU00:FS00:FahCore 0xa7 started
03:39:14:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T03:39:13Z ***********************
03:39:14:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:39:14:WU00:FS00:0xa7: Type: 0xa7
03:39:14:WU00:FS00:0xa7: Core: Gromacs
03:39:14:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 297992 -checkpoint 15 -np
03:39:14:WU00:FS00:0xa7: 6
03:39:14:WU00:FS00:0xa7:************************************ CBang *************************************
03:39:14:WU00:FS00:0xa7: Date: Oct 26 2019
03:39:14:WU00:FS00:0xa7: Time: 01:38:25
03:39:14:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:39:14:WU00:FS00:0xa7: Branch: master
03:39:14:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:39:14:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:39:14:WU00:FS00:0xa7: Platform: win32 10
03:39:14:WU00:FS00:0xa7: Bits: 64
03:39:14:WU00:FS00:0xa7: Mode: Release
03:39:14:WU00:FS00:0xa7:************************************ System ************************************
03:39:14:WU00:FS00:0xa7: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:39:14:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:39:14:WU00:FS00:0xa7: CPUs: 8
03:39:14:WU00:FS00:0xa7: Memory: 15.98GiB
03:39:14:WU00:FS00:0xa7:Free Memory: 9.32GiB
03:39:14:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:39:14:WU00:FS00:0xa7: OS Version: 6.2
03:39:14:WU00:FS00:0xa7:Has Battery: false
03:39:14:WU00:FS00:0xa7: On Battery: false
03:39:14:WU00:FS00:0xa7: UTC Offset: 11
03:39:14:WU00:FS00:0xa7: PID: 298180
03:39:14:WU00:FS00:0xa7: CWD: C:\Users\Server\AppData\Roaming\FAHClient\work
03:39:14:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:39:14:WU00:FS00:0xa7: Version: 0.0.18
03:39:14:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:39:14:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:39:14:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:39:14:WU00:FS00:0xa7: Time: 01:52:30
03:39:14:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:39:14:WU00:FS00:0xa7:************************************ Build *************************************
03:39:14:WU00:FS00:0xa7: SIMD: avx_256
03:39:14:WU00:FS00:0xa7:********************************************************************************
03:39:14:WU00:FS00:0xa7:Project: 14531 (Run 0, Clone 976, Gen 6)
03:39:14:WU00:FS00:0xa7:Unit: 0x0000000680fccb0a5e6978d5313d00b0
03:39:14:WU00:FS00:0xa7:Digital signatures verified
03:39:14:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 6
03:39:14:WU00:FS00:0xa7:Steps: first=1500000 total=250000
03:39:15:WU00:FS00:0xa7:Completed 11222 out of 250000 steps (4%)
03:39:56:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:39:56:WU01:FS01:Connecting to 65.254.110.245:8080
03:39:57:WU01:FS01:Assigned to work server 140.163.4.241
03:39:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:39:57:WU01:FS01:Connecting to 140.163.4.241:8080
03:40:18:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:40:18:WU01:FS01:Connecting to 140.163.4.241:80
03:40:40:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:41:12:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
03:41:34:WU01:FS01:Connecting to 65.254.110.245:8080
03:41:34:WU01:FS01:Assigned to work server 140.163.4.231
03:41:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:41:34:WU01:FS01:Connecting to 140.163.4.231:8080
03:43:13:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:44:11:WU01:FS01:Connecting to 65.254.110.245:8080
03:44:12:WU01:FS01:Assigned to work server 140.163.4.241
03:44:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:44:12:WU01:FS01:Connecting to 140.163.4.241:8080
03:44:33:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:44:33:WU01:FS01:Connecting to 140.163.4.241:80
03:44:51:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
03:45:43:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
03:48:25:WU01:FS01:Connecting to 65.254.110.245:8080
03:48:26:WU01:FS01:Assigned to work server 140.163.4.241
03:48:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.241
03:48:26:WU01:FS01:Connecting to 140.163.4.241:8080
03:48:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:48:47:WU01:FS01:Connecting to 140.163.4.241:80
03:49:00:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
03:49:09:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:53:25:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
03:55:17:WU01:FS01:Connecting to 65.254.110.245:8080
03:55:17:WU01:FS01:Assigned to work server 140.163.4.231
03:55:17:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] 2308 from 140.163.4.231
03:55:17:WU01:FS01:Connecting to 140.163.4.231:8080
03:55:39:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:55:39:WU01:FS01:Connecting to 140.163.4.231:80
03:56:02:FS00:Shutting core down
03:56:02:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 298180
03:56:02:WU00:FS00:0xa7:Exiting, please wait. . .
03:56:02:WU01:FS01:Downloading 29.75MiB
03:56:04:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:56:08:WU01:FS01:Download 38.02%
03:56:12:WU01:FS01:Download complete
03:56:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:7932 gen:0 core:0x22 unit:0x000000008ca304e75e6bb20b77e07082
03:56:13:Saving configuration to config.xml
03:56:13:<config>
03:56:13: <!-- Slot Control -->
03:56:13: <power v='FULL'/>
03:56:13:
03:56:13: <!-- User Information -->
03:56:13: <user v='Zeal0usD'/>
03:56:13:
03:56:13: <!-- Folding Slots -->
03:56:13: <slot id='0' type='CPU'>
03:56:13: <idle v='true'/>
03:56:13: </slot>
03:56:13: <slot id='1' type='GPU'>
03:56:13: </slot>
03:56:13:</config>
03:56:55:WU00:FS00:Starting
03:56:55:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
03:56:55:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Server\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 296280 -checkpoint 15 -np 6
03:56:55:WU00:FS00:Started FahCore on PID 298228
03:56:55:WU00:FS00:Core PID:298968
03:56:55:WU00:FS00:FahCore 0xa7 started
03:56:55:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
03:56:55:WU01:FS01:Connecting to cores.foldingathome.org:80
03:56:55:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T03:56:55Z ***********************
03:56:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:56:55:WU00:FS00:0xa7: Type: 0xa7
03:56:55:WU00:FS00:0xa7: Core: Gromacs
03:56:55:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 298228 -checkpoint 15 -np
03:56:55:WU00:FS00:0xa7: 6
03:56:55:WU00:FS00:0xa7:************************************ CBang *************************************
03:56:55:WU00:FS00:0xa7: Date: Oct 26 2019
03:56:55:WU00:FS00:0xa7: Time: 01:38:25
03:56:55:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:56:55:WU00:FS00:0xa7: Branch: master
03:56:55:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:56:55:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:56:55:WU00:FS00:0xa7: Platform: win32 10
03:56:55:WU00:FS00:0xa7: Bits: 64
03:56:56:WU00:FS00:0xa7: Mode: Release
03:56:56:WU00:FS00:0xa7:************************************ System ************************************
03:56:56:WU00:FS00:0xa7: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:56:56:WU00:FS00:0xa7: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:56:56:WU00:FS00:0xa7: CPUs: 8
03:56:56:WU00:FS00:0xa7: Memory: 15.98GiB
03:56:56:WU00:FS00:0xa7:Free Memory: 9.06GiB
03:56:56:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:56:56:WU00:FS00:0xa7: OS Version: 6.2
03:56:56:WU00:FS00:0xa7:Has Battery: false
03:56:56:WU00:FS00:0xa7: On Battery: false
03:56:56:WU00:FS00:0xa7: UTC Offset: 11
03:56:56:WU00:FS00:0xa7: PID: 298968
03:56:56:WU00:FS00:0xa7: CWD: C:\Users\Server\AppData\Roaming\FAHClient\work
03:56:56:WU01:FS01:FahCore 22: Downloading 4.04MiB
03:56:56:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:56:56:WU00:FS00:0xa7: Version: 0.0.18
03:56:56:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:56:56:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:56:56:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:56:56:WU00:FS00:0xa7: Date: Oct 26 2019
03:56:56:WU00:FS00:0xa7: Time: 01:52:30
03:56:56:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:56:56:WU00:FS00:0xa7: Branch: master
03:56:56:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:56:56:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:56:56:WU00:FS00:0xa7: Platform: win32 10
03:56:56:WU00:FS00:0xa7: Bits: 64
03:56:56:WU00:FS00:0xa7:************************************ Build *************************************
03:56:56:WU00:FS00:0xa7: SIMD: avx_256
03:56:56:WU00:FS00:0xa7:********************************************************************************
03:56:56:WU00:FS00:0xa7:Project: 14531 (Run 0, Clone 976, Gen 6)
03:56:56:WU00:FS00:0xa7:Unit: 0x0000000680fccb0a5e6978d5313d00b0
03:56:56:WU00:FS00:0xa7:Digital signatures verified
03:56:56:WU00:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpi state.cpt -cpt 15 -nt 6
03:56:56:WU00:FS00:0xa7:Steps: first=1500000 total=250000
03:56:57:WU00:FS00:0xa7:Completed 21422 out of 250000 steps (8%)
03:57:02:WU01:FS01:FahCore 22: 72.72%
03:57:04:WU01:FS01:FahCore 22: Download complete
03:57:04:WU01:FS01:Valid core signature
03:57:04:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
03:57:04:WU01:FS01:Starting
03:57:04:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Server\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 296280 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:57:04:WU01:FS01:Started FahCore on PID 294684
03:57:04:WU01:FS01:Core PID:295788
03:57:04:WU01:FS01:FahCore 0x22 started
03:57:05:WU01:FS01:0x22:*********************** Log Started 2020-03-14T03:57:04Z ***********************
03:57:05:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:57:05:WU01:FS01:0x22: Type: 0x22
03:57:05:WU01:FS01:0x22: Core: Core22
03:57:05:WU01:FS01:0x22: Website: https://foldingathome.org/
03:57:05:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
03:57:05:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:57:05:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
03:57:05:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 294684 -checkpoint 15
03:57:05:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
03:57:05:WU01:FS01:0x22: 0 -gpu 0
03:57:05:WU01:FS01:0x22: Config: <none>
03:57:05:WU01:FS01:0x22:************************************ Build *************************************
03:57:05:WU01:FS01:0x22: Version: 0.0.2
03:57:05:WU01:FS01:0x22: Date: Dec 6 2019
03:57:05:WU01:FS01:0x22: Time: 21:30:31
03:57:05:WU01:FS01:0x22: Repository: Git
03:57:05:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:57:05:WU01:FS01:0x22: Branch: HEAD
03:57:05:WU01:FS01:0x22: Compiler: Visual C++ 2008
03:57:05:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:57:05:WU01:FS01:0x22: Platform: win32 10
03:57:05:WU01:FS01:0x22: Bits: 64
03:57:05:WU01:FS01:0x22: Mode: Release
03:57:05:WU01:FS01:0x22:************************************ System ************************************
03:57:05:WU01:FS01:0x22: CPU: AMD FX(tm)-8320 Eight-Core Processor
03:57:05:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
03:57:05:WU01:FS01:0x22: CPUs: 8
03:57:05:WU01:FS01:0x22: Memory: 15.98GiB
03:57:05:WU01:FS01:0x22:Free Memory: 8.95GiB
03:57:05:WU01:FS01:0x22: Threads: WINDOWS_THREADS
03:57:05:WU01:FS01:0x22: OS Version: 6.2
03:57:05:WU01:FS01:0x22:Has Battery: false
03:57:05:WU01:FS01:0x22: On Battery: false
03:57:05:WU01:FS01:0x22: UTC Offset: 11
03:57:05:WU01:FS01:0x22: PID: 295788
03:57:05:WU01:FS01:0x22: CWD: C:\Users\Server\AppData\Roaming\FAHClient\work
03:57:05:WU01:FS01:0x22: OS: Windows 10 Pro
03:57:05:WU01:FS01:0x22: OS Arch: AMD64
03:57:05:WU01:FS01:0x22:********************************************************************************
03:57:05:WU01:FS01:0x22:Project: 11748 (Run 0, Clone 7932, Gen 0)
03:57:05:WU01:FS01:0x22:Unit: 0x000000008ca304e75e6bb20b77e07082
03:57:05:WU01:FS01:0x22:Reading tar file core.xml
03:57:05:WU01:FS01:0x22:Reading tar file integrator.xml
03:57:05:WU01:FS01:0x22:Reading tar file state.xml
03:57:06:WU01:FS01:0x22:Reading tar file system.xml
03:57:06:WU01:FS01:0x22:Digital signatures verified
03:57:06:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
03:57:06:WU01:FS01:0x22:Version 0.0.2
03:57:14:Saving configuration to config.xml
03:57:14:<config>
03:57:14: <!-- Slot Control -->
03:57:14: <power v='FULL'/>
03:57:14:
03:57:14: <!-- User Information -->
03:57:14: <user v='Zeal0usD'/>
03:57:14:
03:57:14: <!-- Folding Slots -->
03:57:14: <slot id='0' type='CPU'/>
03:57:14: <slot id='1' type='GPU'/>
03:57:14:</config>
03:57:51:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
03:57:51:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:59:11:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
04:01:40:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
04:02:38:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
04:05:26:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
