GPU doing nothing
dmh.jpn
GPU doing nothing
Post by dmh.jpn »
Hi All, wanting to help contribute and although my CPU is working, my GPU is idle.
Here is my log:
*********************** Log Started 2020-03-14T02:46:26Z ***********************
02:46:26:************************* Folding@home Client *************************
02:46:26:        Website: https://foldingathome.org/
02:46:26:      Copyright: (c) 2009-2018 foldingathome.org
02:46:26:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:26:           Args: --open-web-control
02:46:26:         Config: <none>
02:46:26:******************************** Build ********************************
02:46:26:        Version: 7.5.1
02:46:26:           Date: May 11 2018
02:46:26:           Time: 13:06:32
02:46:26:     Repository: Git
02:46:26:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:46:26:         Branch: master
02:46:26:       Compiler: Visual C++ 2008
02:46:26:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:46:26:       Platform: win32 10
02:46:26:           Bits: 32
02:46:26:           Mode: Release
02:46:26:******************************* System ********************************
02:46:26:            CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
02:46:26:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
02:46:26:           CPUs: 4
02:46:26:         Memory: 15.93GiB
02:46:26:    Free Memory: 9.63GiB
02:46:26:        Threads: WINDOWS_THREADS
02:46:26:     OS Version: 6.2
02:46:26:    Has Battery: false
02:46:26:     On Battery: false
02:46:26:     UTC Offset: 9
02:46:26:            PID: 21112
02:46:26:            CWD: C:\Users\justp\AppData\Roaming\FAHClient
02:46:26:             OS: Windows 10 Enterprise
02:46:26:        OS Arch: AMD64
02:46:26:           GPUs: 0
02:46:26:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:10.1
02:46:26:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:432.0
02:46:26:  Win32 Service: false
02:46:26:***********************************************************************
02:46:27:<config>
02:46:27:  <!-- Folding Slots -->
02:46:27:</config>
02:46:27:Connecting to assign1.foldingathome.org:8080
02:46:27:Updated GPUs.txt
02:46:27:Read GPUs.txt
02:46:27:Trying to access database...
02:46:27:Successfully acquired database lock
02:46:27:Enabled folding slot 00: PAUSED cpu:2 (not configured)
02:46:27:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] 6463 (not configured)
02:46:33:10:127.0.0.1:New Web connection
02:47:28:Saving configuration to config.xml
02:47:28:<config>
02:47:28:  <!-- Folding Slots -->
02:47:28:  <slot id='0' type='CPU'/>
02:47:28:  <slot id='1' type='GPU'/>
02:47:28:</config>
02:47:28:Set client configured
02:47:28:WU00:FS00:Connecting to 65.254.110.245:8080
02:47:28:WU01:FS01:Connecting to 65.254.110.245:8080
02:47:29:WU01:FS01:Connecting to 65.254.110.245:8080
02:47:29:WU00:FS00:Assigned to work server 155.247.164.213
02:47:29:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 155.247.164.213
02:47:29:WU00:FS00:Connecting to 155.247.164.213:8080
02:47:29:WU01:FS01:Assigned to work server 140.163.4.231
02:47:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
02:47:29:WU01:FS01:Connecting to 140.163.4.231:8080
02:47:29:WU00:FS00:Downloading 1.23MiB
02:47:31:WU00:FS00:Download complete
02:47:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14304 run:7 clone:208 gen:9 core:0xa7 unit:0x000000099bf7a4d55e66c9fab1dc03d2
02:47:31:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
02:47:31:WU00:FS00:Connecting to cores.foldingathome.org:80
02:47:31:WU00:FS00:FahCore a7: Downloading 6.71MiB
02:47:33:WU00:FS00:FahCore a7: Download complete
02:47:33:WU00:FS00:Valid core signature
02:47:33:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
02:47:33:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
02:47:33:WU00:FS00:Starting
02:47:33:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\justp\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 21112 -checkpoint 15 -np 2
02:47:33:WU00:FS00:Started FahCore on PID 7488
02:47:33:WU00:FS00:Core PID:24060
02:47:33:WU00:FS00:FahCore 0xa7 started
02:47:34:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T02:47:33Z ***********************
02:47:34:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:47:34:WU00:FS00:0xa7:       Type: 0xa7
02:47:34:WU00:FS00:0xa7:       Core: Gromacs
02:47:34:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7488 -checkpoint 15 -np 2
02:47:34:WU00:FS00:0xa7:************************************ CBang *************************************
02:47:34:WU00:FS00:0xa7:       Date: Oct 26 2019
02:47:34:WU00:FS00:0xa7:       Time: 01:38:25
02:47:34:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:47:34:WU00:FS00:0xa7:     Branch: master
02:47:34:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
02:47:34:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:47:34:WU00:FS00:0xa7:   Platform: win32 10
02:47:34:WU00:FS00:0xa7:       Bits: 64
02:47:34:WU00:FS00:0xa7:       Mode: Release
02:47:34:WU00:FS00:0xa7:************************************ System ************************************
02:47:34:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
02:47:34:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
02:47:34:WU00:FS00:0xa7:       CPUs: 4
02:47:34:WU00:FS00:0xa7:     Memory: 15.93GiB
02:47:34:WU00:FS00:0xa7:Free Memory: 10.41GiB
02:47:34:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:47:34:WU00:FS00:0xa7: OS Version: 6.2
02:47:34:WU00:FS00:0xa7:Has Battery: false
02:47:34:WU00:FS00:0xa7: On Battery: false
02:47:34:WU00:FS00:0xa7: UTC Offset: 9
02:47:34:WU00:FS00:0xa7:        PID: 24060
02:47:34:WU00:FS00:0xa7:        CWD: C:\Users\justp\AppData\Roaming\FAHClient\work
02:47:34:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:47:34:WU00:FS00:0xa7:    Version: 0.0.18
02:47:34:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:47:34:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:47:34:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
02:47:34:WU00:FS00:0xa7:       Time: 01:52:30
02:47:34:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:47:34:WU00:FS00:0xa7:************************************ Build *************************************
02:47:34:WU00:FS00:0xa7:       SIMD: avx_256
02:47:34:WU00:FS00:0xa7:********************************************************************************
02:47:34:WU00:FS00:0xa7:Project: 14304 (Run 7, Clone 208, Gen 9)
02:47:34:WU00:FS00:0xa7:Unit: 0x000000099bf7a4d55e66c9fab1dc03d2
02:47:34:WU00:FS00:0xa7:Reading tar file core.xml
02:47:34:WU00:FS00:0xa7:Reading tar file frame9.tpr
02:47:34:WU00:FS00:0xa7:Digital signatures verified
02:47:34:WU00:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -cpt 15 -nt 2
02:47:34:WU00:FS00:0xa7:Steps: first=4500000 total=500000
02:47:35:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
02:47:50:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:47:50:WU01:FS01:Connecting to 140.163.4.231:80
02:48:12:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:48:12:WU01:FS01:Connecting to 65.254.110.245:8080
02:48:12:WU01:FS01:Assigned to work server 140.163.4.231
02:48:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
02:48:12:WU01:FS01:Connecting to 140.163.4.231:8080
02:48:33:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:48:33:WU01:FS01:Connecting to 140.163.4.231:80
02:48:55:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:49:12:WU01:FS01:Connecting to 65.254.110.245:8080
02:49:12:WU01:FS01:Assigned to work server 140.163.4.241
02:49:12:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.241
02:49:12:WU01:FS01:Connecting to 140.163.4.241:8080
02:49:56:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
02:50:29:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:50:31:Saving configuration to config.xml
02:50:31:<config>
02:50:31:  <!-- User Information -->
02:50:31:  <passkey v='********************************'/>
02:50:31:  <user v='dmh.jpn'/>
02:50:31:
02:50:31:  <!-- Folding Slots -->
02:50:31:  <slot id='0' type='CPU'/>
02:50:31:  <slot id='1' type='GPU'/>
02:50:31:</config>
02:50:49:WU01:FS01:Connecting to 65.254.110.245:8080
02:50:49:WU01:FS01:Assigned to work server 140.163.4.241
02:50:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.241
02:50:50:WU01:FS01:Connecting to 140.163.4.241:8080
02:51:11:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:51:11:WU01:FS01:Connecting to 140.163.4.241:80
02:51:32:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:51:47:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
02:52:12:FS00:Shutting core down
02:52:12:WU01:FS01:Connecting to 65.254.110.245:8080
02:52:12:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 24060
02:52:12:WU00:FS00:0xa7:Exiting, please wait. . .
02:52:13:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
02:52:13:WU01:FS01:Assigned to work server 140.163.4.231
02:52:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
02:52:13:WU01:FS01:Connecting to 140.163.4.231:8080
02:52:13:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:52:13:WU00:FS00:Starting
02:52:13:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
02:52:13:WARNING:WU00:FS00:AS lowered CPUs from 3 to 2
02:52:13:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\justp\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 21112 -checkpoint 15 -np 2
02:52:13:WU00:FS00:Started FahCore on PID 20740
02:52:13:WU00:FS00:Core PID:3536
02:52:13:WU00:FS00:FahCore 0xa7 started
02:52:13:WU00:FS00:0xa7:*********************** Log Started 2020-03-14T02:52:13Z ***********************
02:52:13:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:52:13:WU00:FS00:0xa7:       Type: 0xa7
02:52:13:WU00:FS00:0xa7:       Core: Gromacs
02:52:13:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 20740 -checkpoint 15 -np
02:52:13:WU00:FS00:0xa7:             2
02:52:13:WU00:FS00:0xa7:************************************ CBang *************************************
02:52:13:WU00:FS00:0xa7:       Date: Oct 26 2019
02:52:13:WU00:FS00:0xa7:       Time: 01:38:25
02:52:13:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:52:13:WU00:FS00:0xa7:     Branch: master
02:52:13:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
02:52:13:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:52:13:WU00:FS00:0xa7:   Platform: win32 10
02:52:13:WU00:FS00:0xa7:       Bits: 64
02:52:13:WU00:FS00:0xa7:       Mode: Release
02:52:13:WU00:FS00:0xa7:************************************ System ************************************
02:52:13:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
02:52:13:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
02:52:13:WU00:FS00:0xa7:       CPUs: 4
02:52:13:WU00:FS00:0xa7:     Memory: 15.93GiB
02:52:13:WU00:FS00:0xa7:Free Memory: 10.34GiB
02:52:13:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:52:13:WU00:FS00:0xa7: OS Version: 6.2
02:52:13:WU00:FS00:0xa7:Has Battery: false
02:52:13:WU00:FS00:0xa7: On Battery: false
02:52:13:WU00:FS00:0xa7: UTC Offset: 9
02:52:13:WU00:FS00:0xa7:        PID: 3536
02:52:13:WU00:FS00:0xa7:        CWD: C:\Users\justp\AppData\Roaming\FAHClient\work
02:52:13:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:52:13:WU00:FS00:0xa7:    Version: 0.0.18
02:52:13:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:52:13:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:52:13:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
02:52:13:WU00:FS00:0xa7:       Time: 01:52:30
02:52:13:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:52:13:WU00:FS00:0xa7:************************************ Build *************************************
02:52:13:WU00:FS00:0xa7:       SIMD: avx_256
02:52:13:WU00:FS00:0xa7:********************************************************************************
02:52:13:WU00:FS00:0xa7:Project: 14304 (Run 7, Clone 208, Gen 9)
02:52:13:WU00:FS00:0xa7:Unit: 0x000000099bf7a4d55e66c9fab1dc03d2
02:52:13:WU00:FS00:0xa7:Digital signatures verified
02:52:13:WU00:FS00:0xa7:Calling: mdrun -s frame9.tpr -o frame9.trr -cpi state.cpt -cpt 15 -nt 2
02:52:13:WU00:FS00:0xa7:Steps: first=4500000 total=500000
02:52:14:WU00:FS00:0xa7:Completed 11402 out of 500000 steps (2%)
02:52:33:Saving configuration to config.xml
02:52:33:<config>
02:52:33:  <!-- Slot Control -->
02:52:33:  <power v='FULL'/>
02:52:33:
02:52:33:  <!-- User Information -->
02:52:33:  <passkey v='********************************'/>
02:52:33:  <user v='dmh.jpn'/>
02:52:33:
02:52:33:  <!-- Folding Slots -->
02:52:33:  <slot id='0' type='CPU'/>
02:52:33:  <slot id='1' type='GPU'/>
02:52:33:</config>
02:52:34:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:52:34:WU01:FS01:Connecting to 140.163.4.231:80
02:52:55:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:53:02:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
02:53:49:WU01:FS01:Connecting to 65.254.110.245:8080
02:53:50:WU01:FS01:Assigned to work server 140.163.4.231
02:53:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
02:53:50:WU01:FS01:Connecting to 140.163.4.231:8080
02:54:07:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
02:54:11:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:54:11:WU01:FS01:Connecting to 140.163.4.231:80
02:54:32:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:55:11:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
02:56:16:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
02:56:27:WU01:FS01:Connecting to 65.254.110.245:8080
02:56:27:WU01:FS01:Assigned to work server 140.163.4.231
02:56:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
02:56:27:WU01:FS01:Connecting to 140.163.4.231:8080
02:56:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
02:56:48:WU01:FS01:Connecting to 140.163.4.231:80
02:57:21:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
02:58:09:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
02:58:35:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
02:59:49:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
03:00:41:Saving configuration to config.xml
03:00:41:<config>
03:00:41:  <!-- Slot Control -->
03:00:41:  <power v='FULL'/>
03:00:41:
03:00:41:  <!-- User Information -->
03:00:41:  <passkey v='********************************'/>
03:00:41:  <team v='225605'/>
03:00:41:  <user v='dmh.jpn'/>
03:00:41:
03:00:41:  <!-- Folding Slots -->
03:00:41:  <slot id='0' type='CPU'/>
03:00:41:  <slot id='1' type='GPU'/>
03:00:41:</config>
03:00:41:WU01:FS01:Connecting to 65.254.110.245:8080
03:00:41:WU01:FS01:Assigned to work server 140.163.4.241
03:00:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.241
03:00:41:WU01:FS01:Connecting to 140.163.4.241:8080
03:01:02:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:01:02:WU01:FS01:Connecting to 140.163.4.241:80
03:01:05:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
03:01:24:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:02:10:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
03:03:15:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
03:04:25:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
03:05:35:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
03:06:02:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:06:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:06:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:06:42:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
03:07:32:WU01:FS01:Connecting to 65.254.110.245:8080
03:07:33:WU01:FS01:Assigned to work server 140.163.4.231
03:07:33:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 140.163.4.231
03:07:33:WU01:FS01:Connecting to 140.163.4.231:8080
03:07:48:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
03:07:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:07:54:WU01:FS01:Connecting to 140.163.4.231:80
03:08:15:ERROR:WU01:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:08:18:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:08:34:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
jonault
Re: GPU doing nothing
Post by jonault »
Your log shows you're having problems connecting to 140.163.4.231. Others are reporting problems with that server also. Since you're able to get work units for your CPU, I don't think there's necessarily any problem on your end. I suggest just letting it run overnight to see if you eventually manage to get through. One of my PCs took about an hour to download a WU earlier this evening, but it did eventually start folding again.
