Configuring FAHClient to use my AMD RX 580 on Ubuntu 18.04
LavaDrop
Post by LavaDrop »
Hi!
I've been scratching my head for several days trying to figure out the Linux client and it's configuration. :e?:
I've tried several suggestions:
  • Add FAHClient to video group
    Verify I've a correct installation of drivers (AMDGPUPRO) and OpenCL (clinfo)
    Correct expert flag setup script put incorrectly because the installer is expecting the client to be properly configured (gpu=false flag)
    Change opencl index from -1 to 0
However, the client still states it can't find my OpenCL device and produces Bad Work Units (it does detect the actual GPU, though).
This is the log:
*********************** Log Started 2020-03-14T01:28:59Z ***********************
01:28:59:************************* Folding@home Client *************************
01:28:59:    Website: https://foldingathome.org/
01:28:59:  Copyright: (c) 2009-2018 foldingathome.org
01:28:59:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:28:59:       Args: --child --lifeline 6467 /etc/fahclient/config.xml --run-as
01:28:59:             fahclient --pid-file=/var/run/fahclient.pid --daemon
01:28:59:     Config: /etc/fahclient/config.xml
01:28:59:******************************** Build ********************************
01:28:59:    Version: 7.5.1
01:28:59:       Date: May 11 2018
01:28:59:       Time: 19:59:04
01:28:59: Repository: Git
01:28:59:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
01:28:59:     Branch: master
01:28:59:   Compiler: GNU 6.3.0 20170516
01:28:59:    Options: -std=gnu++98 -O3 -funroll-loops
01:28:59:   Platform: linux2 4.14.0-3-amd64
01:28:59:       Bits: 64
01:28:59:       Mode: Release
01:28:59:******************************* System ********************************
01:28:59:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
01:28:59:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
01:28:59:       CPUs: 16
01:28:59:     Memory: 15.67GiB
01:28:59:Free Memory: 7.53GiB
01:28:59:    Threads: POSIX_THREADS
01:28:59: OS Version: 5.0
01:28:59:Has Battery: false
01:28:59: On Battery: false
01:28:59: UTC Offset: -6
01:28:59:        PID: 6495
01:28:59:        CWD: /var/lib/fahclient
01:28:59:         OS: Linux 5.0.0-23-generic x86_64
01:28:59:    OS Arch: AMD64
01:28:59:       GPUs: 1
01:28:59:      GPU 0: Bus:28 Slot:0 Func:0 AMD:5 Ellesmere XT [Radeon RX 470/480/570/580]
01:28:59:       CUDA: Not detected: cuInit() returned 100
01:28:59:     OpenCL: Not detected: clGetDeviceIDs() returned -1
01:28:59:***********************************************************************
01:28:59:<config>
01:28:59:  <!-- Network -->
01:28:59:  <proxy v=':8080'/>
01:28:59:
01:28:59:  <!-- User Information -->
01:28:59:  <passkey v='********************************'/>
01:28:59:  <team v='75655'/>
01:28:59:  <user v='LavaDrop'/>
01:28:59:
01:28:59:  <!-- Folding Slots -->
01:28:59:  <slot id='0' type='CPU'/>
01:28:59:  <slot id='1' type='GPU'>
01:28:59:    <opencl-index v='0'/>
01:28:59:  </slot>
01:28:59:</config>
01:28:59:Switching to user fahclient
01:28:59:Trying to access database...
01:29:16:Successfully acquired database lock
01:29:16:Enabled folding slot 00: READY cpu:14
01:29:16:Enabled folding slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
01:29:16:ERROR:No compute devices matched GPU #0 AMD:5 Ellesmere XT [Radeon RX 470/480/570/580].  You may need to update your graphics drivers.
01:29:16:WU01:FS00:Starting
01:29:16:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 6495 -checkpoint 15 -np 14
01:29:16:WU01:FS00:Started FahCore on PID 6557
01:29:16:WU01:FS00:Core PID:6561
01:29:16:WU01:FS00:FahCore 0xa7 started
01:29:17:WU00:FS01:Connecting to 65.254.110.245:8080
01:29:17:WU01:FS00:0xa7:*********************** Log Started 2020-03-14T01:29:16Z ***********************
01:29:17:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:29:17:WU01:FS00:0xa7:       Type: 0xa7
01:29:17:WU01:FS00:0xa7:       Core: Gromacs
01:29:17:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 6557 -checkpoint 15 -np
01:29:17:WU01:FS00:0xa7:             14
01:29:17:WU01:FS00:0xa7:************************************ CBang *************************************
01:29:17:WU01:FS00:0xa7:       Date: Nov 5 2019
01:29:17:WU01:FS00:0xa7:       Time: 06:06:57
01:29:17:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
01:29:17:WU01:FS00:0xa7:     Branch: master
01:29:17:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
01:29:17:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
01:29:17:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
01:29:17:WU01:FS00:0xa7:       Bits: 64
01:29:17:WU01:FS00:0xa7:       Mode: Release
01:29:17:WU01:FS00:0xa7:************************************ System ************************************
01:29:17:WU01:FS00:0xa7:        CPU: AMD Ryzen 7 2700X Eight-Core Processor
01:29:17:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
01:29:17:WU01:FS00:0xa7:       CPUs: 16
01:29:17:WU01:FS00:0xa7:     Memory: 15.67GiB
01:29:17:WU01:FS00:0xa7:Free Memory: 8.00GiB
01:29:17:WU01:FS00:0xa7:    Threads: POSIX_THREADS
01:29:17:WU01:FS00:0xa7: OS Version: 5.0
01:29:17:WU01:FS00:0xa7:Has Battery: false
01:29:17:WU01:FS00:0xa7: On Battery: false
01:29:17:WU01:FS00:0xa7: UTC Offset: -6
01:29:17:WU01:FS00:0xa7:        PID: 6561
01:29:17:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
01:29:17:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:29:17:WU01:FS00:0xa7:    Version: 0.0.18
01:29:17:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:29:17:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:29:17:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
01:29:17:WU01:FS00:0xa7:       Time: 06:13:26
01:29:17:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
01:29:17:WU01:FS00:0xa7:************************************ Build *************************************
01:29:17:WU01:FS00:0xa7:       SIMD: avx_256
01:29:17:WU01:FS00:0xa7:********************************************************************************
01:29:17:WU01:FS00:0xa7:Project: 13831 (Run 874, Clone 2, Gen 103)
01:29:17:WU01:FS00:0xa7:Unit: 0x0000007680fccb095d693a481c2d4be8
01:29:17:WU01:FS00:0xa7:Digital signatures verified
01:29:17:WU01:FS00:0xa7:Reducing thread count from 14 to 13 to avoid domain decomposition with large prime factor 7
01:29:17:WU01:FS00:0xa7:Reducing thread count from 13 to 12 to avoid domain decomposition by a prime number > 3
01:29:17:WU01:FS00:0xa7:Calling: mdrun -s frame103.tpr -o frame103.trr -x frame103.xtc -cpi state.cpt -cpt 15 -nt 12
01:29:17:WU01:FS00:0xa7:Steps: first=12875000 total=12875000
01:29:17:WU00:FS01:Assigned to work server 140.163.4.231
01:29:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.231
01:29:17:WU00:FS01:Connecting to 140.163.4.231:8080
01:29:19:WU01:FS00:0xa7:Completed 53022 out of 12875000 steps (0%)
I can run GPU work units on BOINC.
Re: Configuring FAHClient to use my AMD RX 580 on Ubuntu 18.
Post by foldy »
Try that first:
sudo apt-get install ocl-icd-libopencl1
sudo apt-get install ocl-icd-opencl-dev
LavaDrop
Post by LavaDrop »
foldy wrote:Try that first:
Thank you, however it made no change at all. GPU still stuck on Ready.
16:13:05:ERROR:No compute devices matched GPU #0 AMD:5 Ellesmere XT [Radeon RX 470/480/570/580].  You may need to update your graphics drivers.
Burstaholic
Post by Burstaholic »
You need the AMD proprietary OpenCL driver: https://www.amd.com/en/support/kb/relea ... fied-linux
LavaDrop
Post by LavaDrop »
Burstaholic wrote:You need the AMD proprietary OpenCL driver: https://www.amd.com/en/support/kb/relea ... fied-linux
I have the proprietary driver installed and properly configured.
BOINC detects and works with my GPU.
John_D
Post by John_D »
Since the client looks set up ok, try this:
set the client to medium in FAHControl.
Are you running two clients, one for your CPU and one for your graphics card.
LavaDrop
Post by LavaDrop »
FAHControl is set to medium.
BOINC is only running CPU tasks because Rosetta doesn't use GPUs. I was running SETI and then they announced they were putting the program on hibernation, so I paused SETI. I set it up to use 8 threads at 50% CPU time.
Paragon
Hardware configuration: Rig1 (Dedicated SMP): AMD Phenom II X6 1100T, Gigabyte GA-880GMA-USB3 board, 8 GB Kingston 1333 DDR3 Ram, Seasonic S12 II 380 Watt PSU, Noctua CPU Cooler
Rig2 (Part-Time GPU): Intel Q6600, Gigabyte 965P-S3 Board, EVGA 460 GTX Graphics, 8 GB Kingston 800 DDR2 Ram, Seasonic Gold X-650 PSU, Artic Cooling Freezer 7 CPU Cooler
Post by Paragon »
I've run into this with my RX 480s and RX580s. You've probably done everything right. There's a weird permissions issue, where the FAH Client just can't access the open CL libraries.
See this thread...it's a long read.
viewtopic.php?f=81&t=31293&start=15
In summary, the key bit is a workaround based on this other thread
viewtopic.php?f=74&t=31096
Basically you need to tweak the startup script for the client (/etc/init.d/FAHClient), changing the username from "fahclient" to "root". The client can then see Open CL devices and fold correctly. This seems like a problem unique to AMD GPUs on Linux, since Nvidia GPUs work fine (once open CL is installed).
For some Linux distros you may need to add the fahclient username to be part of the video group. I recall coming across that posted at one time. I personally have not needed to do that, the newest Linux setup I have currently is running on Ubuntu 16.04.
