5700XT poor PPD?
apeman
5700XT poor PPD?
Post by apeman »
Newbie here and not finding much in my searching. My 5700 XT is reporting ~100 KPPD. I get the impression from other forums that this is pretty low, and I should expect in excess of 1 MPPD. Thoughts?
*********************** Log Started 2020-03-13T04:25:43Z ***********************
04:25:43:************************* Folding@home Client *************************
04:25:43:        Website: https://foldingathome.org/
04:25:43:      Copyright: (c) 2009-2018 foldingathome.org
04:25:43:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:25:43:           Args: --open-web-control
04:25:43:         Config: C:\Users\iamth\AppData\Roaming\FAHClient\config.xml
04:25:43:******************************** Build ********************************
04:25:43:        Version: 7.5.1
04:25:43:           Date: May 11 2018
04:25:43:           Time: 13:06:32
04:25:43:     Repository: Git
04:25:43:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:25:43:         Branch: master
04:25:43:       Compiler: Visual C++ 2008
04:25:43:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:25:43:       Platform: win32 10
04:25:43:           Bits: 32
04:25:43:           Mode: Release
04:25:43:******************************* System ********************************
04:25:43:            CPU: AMD Ryzen 9 3900X 12-Core Processor
04:25:43:         CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
04:25:43:           CPUs: 24
04:25:43:         Memory: 31.92GiB
04:25:43:    Free Memory: 17.62GiB
04:25:43:        Threads: WINDOWS_THREADS
04:25:43:     OS Version: 6.2
04:25:43:    Has Battery: false
04:25:43:     On Battery: false
04:25:43:     UTC Offset: -5
04:25:43:            PID: 27240
04:25:43:            CWD: C:\Users\iamth\AppData\Roaming\FAHClient
04:25:43:             OS: Windows 10 Enterprise
04:25:43:        OS Arch: AMD64
04:25:43:           GPUs: 1
04:25:43:          GPU 0: Bus:11 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
04:25:43:                 / 5700/5700 XT]
04:25:43:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
04:25:43:                 specified module could not be found.
04:25:43:
04:25:43:OpenCL Device 0: Platform:0 Device:0 Bus:11 Slot:0 Compute:1.2 Driver:3004.8
04:25:43:  Win32 Service: false
04:25:43:***********************************************************************
04:25:43:<config>
04:25:43:  <!-- Network -->
04:25:43:  <proxy v=':8080'/>
04:25:43:
04:25:43:  <!-- User Information -->
04:25:43:  <user v='apeman'/>
04:25:43:
04:25:43:  <!-- Folding Slots -->
04:25:43:  <slot id='1' type='GPU'>
04:25:43:    <client-type v='beta'/>
04:25:43:  </slot>
04:25:43:</config>
04:25:43:Trying to access database...
04:25:43:Successfully acquired database lock
04:25:43:Enabled folding slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
04:25:44:WU00:FS01:Starting
04:25:44:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\iamth\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 27240 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
04:25:44:WU00:FS01:Started FahCore on PID 27408
04:25:44:WU00:FS01:Core PID:27444
04:25:44:WU00:FS01:FahCore 0x22 started
04:25:44:WU00:FS01:0x22:*********************** Log Started 2020-03-13T04:25:44Z ***********************
04:25:44:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:25:44:WU00:FS01:0x22:       Type: 0x22
04:25:44:WU00:FS01:0x22:       Core: Core22
04:25:44:WU00:FS01:0x22:    Website: https://foldingathome.org/
04:25:44:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
04:25:44:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:25:44:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
04:25:44:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 27408 -checkpoint 15
04:25:44:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
04:25:44:WU00:FS01:0x22:     Config: <none>
04:25:44:WU00:FS01:0x22:************************************ Build *************************************
04:25:44:WU00:FS01:0x22:    Version: 0.0.2
04:25:44:WU00:FS01:0x22:       Date: Dec 6 2019
04:25:44:WU00:FS01:0x22:       Time: 21:30:31
04:25:44:WU00:FS01:0x22: Repository: Git
04:25:44:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:25:44:WU00:FS01:0x22:     Branch: HEAD
04:25:44:WU00:FS01:0x22:   Compiler: Visual C++ 2008
04:25:44:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:25:44:WU00:FS01:0x22:   Platform: win32 10
04:25:44:WU00:FS01:0x22:       Bits: 64
04:25:44:WU00:FS01:0x22:       Mode: Release
04:25:44:WU00:FS01:0x22:************************************ System ************************************
04:25:44:WU00:FS01:0x22:        CPU: AMD Ryzen 9 3900X 12-Core Processor
04:25:44:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
04:25:44:WU00:FS01:0x22:       CPUs: 24
04:25:44:WU00:FS01:0x22:     Memory: 31.92GiB
04:25:44:WU00:FS01:0x22:Free Memory: 17.59GiB
04:25:44:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
04:25:44:WU00:FS01:0x22: OS Version: 6.2
04:25:44:WU00:FS01:0x22:Has Battery: false
04:25:44:WU00:FS01:0x22: On Battery: false
04:25:44:WU00:FS01:0x22: UTC Offset: -5
04:25:44:WU00:FS01:0x22:        PID: 27444
04:25:44:WU00:FS01:0x22:        CWD: C:\Users\iamth\AppData\Roaming\FAHClient\work
04:25:44:WU00:FS01:0x22:         OS: Windows 10 Pro
04:25:44:WU00:FS01:0x22:    OS Arch: AMD64
04:25:44:WU00:FS01:0x22:********************************************************************************
04:25:44:WU00:FS01:0x22:Project: 11745 (Run 0, Clone 1833, Gen 4)
04:25:44:WU00:FS01:0x22:Unit: 0x000000068ca304f15e67ef6d505d2de0
04:25:44:WU00:FS01:0x22:Digital signatures verified
04:25:44:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:25:44:WU00:FS01:0x22:Version 0.0.2
04:25:44:WU00:FS01:0x22:  Found a checkpoint file
04:26:19:WU00:FS01:0x22:Completed 500000 out of 1000000 steps (50%)
04:26:19:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
Re: 5700XT poor PPD?
From what is shown of your log, you have not entered a passkey to get bonus points. On a fast GPU those are the majority of the points coming from the Quick Return Bonus.
Welcome to Folding@Home!
Information on the Passkey
https://foldingathome.org/support/faq/points/passkey/
apeman
Post by apeman »
Ah, thanks. Done. Looks like now tho there's no work available for my card so I'll have to wait to verify performance is as expected.
apeman
Post by apeman »
PPD is up to 550K now. Does this sound right? I'm mainly concerned with ensuring my card is performing optimally.
That sounds in the right range. Exact performance will depend on the WU, those with more atoms will load your GPU more fully and also result in a higher PPD.
LumielGR
Post by LumielGR »
Joe_H wrote:That sounds in the right range. Exact performance will depend on the WU, those with more atoms will load your GPU more fully and also result in a higher PPD.
That doesn't sound right at all. I'm at 1.1M with a 5700xt nitro+ and I still think it's low.
On AMD GPUs, it depends on the project you got. Project with low number of atom will show 600-700k PPD while those with many atoms will be above 1M PPD.
DarkFoss
Hardware configuration: AMD 5800X3D Asus ROG Strix X570-E Gaming WiFi II bios 5031 G-Skill TridentZ Neo 3600mhz Asrock Tachi RX 7900XTX Corsair rm850x psu Asus PG32UQXR EK Elite 360 D-rgb aio Win 11pro/Kubuntu 2404.2 LTS Kernel 6.11.x HWE LowLatency UPS BX1500G
Post by DarkFoss »
@apeman Did you remember to change the gpu workload from gaming to compute in the global graphics settings? Hows the temps look? With these new Adrenaline2020 drivers I had to create a fan profile bumping up the minimum speed to get the temp below 60c on my FuryX. Not only had a bit of throttling at first I had a wu fail because my temp hit 63/64c.
apeman
Post by apeman »
On BOINC I never saw any benefit from Compute mode so didn't bother. Temps were <70. But I ended up returning the 5700XT. For three weeks I couldn't get it to stop crashing, even sometimes getting POST errors. The 5700XT is still having problems I've learned, as are the drivers. So I don't know to what degree folding might've been impacted. Running a 2060 Super now at 1.2M last I saw. Waiting for work now tho due to the server being overwhelmed again.
1) We're not BOINC, so there may be good reasons for the differences you see.
2) Maybe your 5700XT hardware is defective.
3) Maybe the paths in your case where cooling air circulates or a fah has been compromised.
If the problem was solved by installing a new GPU, I'm not going to worry about it.
DarkFoss
Post by DarkFoss »
Sounds like a lemon of a card good thing you returned it while you could. Enjoy your 2060!
apeman
Post by apeman »
I've actually learned that it remains a very common problem particularly affecting the XT. The regular 5700 doesn't seem to have the issue, except the ongoing problems with the drivers AMD has not been able to resolve. I'll have to revisit the card at a later time if only because it's aesthetically more pleasing in my new rig.
Burstaholic
Post by Burstaholic »
My non-XT 5700 has been consistently doing ~850k PPD. It does seem a bit low given the card's raw stats, but I guess that's just how it is. I have kept mine set to 'gaming' instead of 'compute' because I still play games on my PC regularly. Another datapoint for ya.
