I got one error while folding this morning, first time seeing this error, wonder anyone can explain what's going on? (ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.)
Also, it has been over 6 months that my web control have stopped working, it never loads my identity, score and progress bar. Last but not least, the link to the project description stopped working this morning. When I clicked the project number in my advance control nothing happened. Does anyone know what's going on? I try to reinstall everything but it didn't work.
3 possible error
Re: 3 possible error
Don't worry about ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host", it's not a fatal error. I think it caused when you close Webcontrol or the Viewer ...
If Webcontrol is not working well, first workaround is to try to open it with another browser. Second workaround is to use FAHControl instead (Advance Control from contextual menu after a right click on icon in Task Bar).
Yes, for some reason, project numbers appear like a link in FAHControl, but it doesn't work. You can still look of the project number in this list and click on it to get detailed description : https://apps.foldingathome.org/psummary?visibility=ALL
I got more error ever since I reinstall Folding@home
05:50:55:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:52:04:ERROR:WU00:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
Wonder what did I do wrong when I reinstall Folding@home? Never see those kinds of error before
We could use a little bit more of the log : How to provide enough info to get helpful support.
I am guessing, but I'm pretty sure that what you're seeing is the saturation of servers hosting the GPU COVID-19 related projects.
