Not able to connect
zim799
Not able to connect
Post by zim799 »
Hi
I just downloaded Folding@home and I am not able to get it working. It launches, but it will not connect to the server. It says failure to connect and cant get assignment ID.
specs: i7-8700k, RTX 2070, 32gb RAM,
heres the log
*********************** Log Started 2020-03-12T18:01:47Z ***********************
18:01:47:************************* Folding@home Client *************************
18:01:47:        Website: https://foldingathome.org/
18:01:47:      Copyright: (c) 2009-2018 foldingathome.org
18:01:47:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:01:47:           Args: --open-web-control
18:01:47:         Config: C:\Users\Joey\AppData\Roaming\FAHClient\config.xml
18:01:47:******************************** Build ********************************
18:01:47:        Version: 7.5.1
18:01:47:           Date: May 11 2018
18:01:47:           Time: 13:06:32
18:01:47:     Repository: Git
18:01:47:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:01:47:         Branch: master
18:01:47:       Compiler: Visual C++ 2008
18:01:47:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:01:47:       Platform: win32 10
18:01:47:           Bits: 32
18:01:47:           Mode: Release
18:01:47:******************************* System ********************************
18:01:47:            CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
18:01:47:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:01:47:           CPUs: 12
18:01:47:         Memory: 31.93GiB
18:01:47:    Free Memory: 20.54GiB
18:01:47:        Threads: WINDOWS_THREADS
18:01:47:     OS Version: 6.2
18:01:47:    Has Battery: false
18:01:47:     On Battery: false
18:01:47:     UTC Offset: -5
18:01:47:            PID: 10872
18:01:47:            CWD: C:\Users\Joey\AppData\Roaming\FAHClient
18:01:47:             OS: Windows 10 Home
18:01:47:        OS Arch: AMD64
18:01:47:           GPUs: 0
18:01:47:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
18:01:47:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.59
18:01:47:  Win32 Service: false
18:01:47:***********************************************************************
18:01:47:<config>
18:01:47:  <!-- User Information -->
18:01:47:  <passkey v='********************************'/>
18:01:47:
18:01:47:  <!-- Folding Slots -->
18:01:47:  <slot id='0' type='CPU'/>
18:01:47:</config>
18:01:47:Connecting to assign1.foldingathome.org:8080
18:02:06:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
18:02:06:Connecting to assign2.foldingathome.org:80
18:02:26:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
18:02:26:Trying to access database...
18:02:26:Successfully acquired database lock
18:02:26:Enabled folding slot 00: READY cpu:11
18:02:26:WU00:FS00:Connecting to 65.254.110.245:8080
18:02:29:16:127.0.0.1:New Web connection
18:02:45:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
18:02:45:WU00:FS00:Connecting to 18.218.241.186:80
18:03:04:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
18:03:04:ERROR:WU00:FS00:Exception: Could not get an assignment ID
18:03:05:WU00:FS00:Connecting to 65.254.110.245:8080
18:03:24:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
18:03:24:WU00:FS00:Connecting to 18.218.241.186:80
18:03:43:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
18:03:43:ERROR:WU00:FS00:Exception: Could not get an assignment ID
18:04:05:WU00:FS00:Connecting to 65.254.110.245:8080
18:04:24:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
18:04:24:WU00:FS00:Connecting to 18.218.241.186:80
18:04:43:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
18:04:43:ERROR:WU00:FS00:Exception: Could not get an assignment ID
18:05:42:WU00:FS00:Connecting to 65.254.110.245:8080
18:06:01:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
18:06:01:WU00:FS00:Connecting to 18.218.241.186:80
18:06:20:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
18:06:20:ERROR:WU00:FS00:Exception: Could not get an assignment ID
18:06:47:Connecting to assign1.foldingathome.org:8080
18:07:06:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
18:07:06:Connecting to assign2.foldingathome.org:80
18:07:25:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
18:07:26:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: Not able to connect
OK, I am guessing your firewall is blocking your access to F@H servers.
You can check by turning off the Windows firewall for 10 minutes.
If that works, then you need to allow F@H client to access port 80 or 8080.
Once you've established that it's a firewall issue, you'll should configure a firewall exception that gives FAHClient the same internet permissions that are automatically configured for your browser.
