Gpu clocks
MuFF
Gpu clocks
Post by MuFF »
Does folding use GPU core or GPU memory? or does it utilize both? I would like to underclock/undervolt either or to save power if it's not utilizing one or the other.
Re: Gpu clocks
Post by foldy »
GPU core is doing all the work, GPU memory clock makes no difference.
MuFF
Re: Gpu clocks
Post by MuFF »
ok thank you
Re: Gpu clocks
A GPU with fast/large memory is unnecessary for FAH. A GPU with a lot of shaders (i.e.-lots of GFLOPS) is the primary criteria ... plus one CPU thread to move data.
Be especially careful with overclocking.
