So with the announcement of the new Coronavirus Work Units and supporting the new 22 Core for 5700xts I wanted to try and get it setup on my computer.
Now I dual boot my computer and have no issues with GPU work units at all under Windows, however if I'm in windows I usually am gaming hence it not being the ideal thing to have running. However when I'm on linux I'm usually working with my GPU sitting doing nothing.
I seem to have errors of it working with my GPU and I'm not sure if it's a configuration issue or what. I've done the following:
- Re-installed the AMD GPU Drivers, I've used the pro drivers with pal opencl option.
- Tested another OpenCL Application, (Oclvanitygen crypto address generator) and this seems to work fine.
- Tried different indexes for the slot. With -1 I seem to get the error "OpenCL device matching slot 1 not found, try setting 'opencl-index' manually"
- Index at 0 I get the error "15:15:24:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)" Also with index of 1.
Computer Specs: 2700X, 16GB DDR4, 5700xt 50th Anniversary Edition
Network Connection: 350Mbps Cable
Operating System: Ubuntu 18.04 fully updated.
Overclocked?: N/A
Stable?: No unstability.
Software: 7.5.1 Client, Core 22 GPU
WU details: GPU Work Unit, WU 11743
Also, when appropriate, please post the contents of fahlog.txt (V6 and earlier] or log.txt {V7]: this tells loads of information and is vital in helping to diagnose/troubleshoot problems.
14:56:17:WU01:FS01:Connecting to 65.254.110.245:8080
14:56:17:WU01:FS01:Assigned to work server 140.163.4.241
14:56:17:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
14:56:17:WU01:FS01:Connecting to 140.163.4.241:8080
14:56:58:WU01:FS01:Downloading 29.59MiB
14:57:05:WU01:FS01:Download 1.06%
14:57:11:WU01:FS01:Download 3.17%
14:57:17:WU01:FS01:Download 8.45%
14:57:23:WU01:FS01:Download 22.39%
14:57:29:WU01:FS01:Download 39.92%
14:57:35:WU01:FS01:Download 74.14%
14:57:41:WU01:FS01:Download 99.07%
14:57:41:WU01:FS01:Download complete
14:57:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:3927 gen:3 core:0x22 unit:0x000000038ca304f15e69da31e47ddd03
14:57:41:WU01:FS01:Starting
14:57:41:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
14:58:41:WU01:FS01:Starting
14:58:41:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:00:18:WU01:FS01:Starting
15:00:18:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:02:56:WU01:FS01:Starting
15:02:56:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found, try setting 'opencl-index' manually
15:07:10:WU01:FS01:Starting
15:07:10:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 1 -gpu 1
15:07:10:WU01:FS01:Started FahCore on PID 15339
15:07:10:WU01:FS01:Core PID:15343
15:07:10:WU01:FS01:FahCore 0x22 started
15:07:10:WU01:FS01:0x22:*********************** Log Started 2020-03-12T15:07:10Z ***********************
15:07:10:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:07:10:WU01:FS01:0x22: Type: 0x22
15:07:10:WU01:FS01:0x22: Core: Core22
15:07:10:WU01:FS01:0x22: Website:
15:07:10:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:07:10:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:07:10:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:07:10:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 15339 -checkpoint 15
15:07:10:WU01:FS01:0x22: -gpu-vendor amd -opencl-device 1 -gpu 1
15:07:10:WU01:FS01:0x22: Config: <none>
15:07:10:WU01:FS01:0x22:************************************ Build *************************************
15:07:10:WU01:FS01:0x22: Version: 0.0.2
15:07:10:WU01:FS01:0x22: Date: Dec 6 2019
15:07:10:WU01:FS01:0x22: Time: 21:20:17
15:07:10:WU01:FS01:0x22: Repository: Git
15:07:10:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:07:10:WU01:FS01:0x22: Branch: core22
15:07:10:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:07:10:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:07:10:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:07:10:WU01:FS01:0x22: Bits: 64
15:07:10:WU01:FS01:0x22: Mode: Release
15:07:10:WU01:FS01:0x22:************************************ System ************************************
15:07:10:WU01:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:07:10:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:07:10:WU01:FS01:0x22: CPUs: 16
15:07:10:WU01:FS01:0x22: Memory: 15.68GiB
15:07:10:WU01:FS01:0x22:Free Memory: 7.00GiB
15:07:10:WU01:FS01:0x22: Threads: POSIX_THREADS
15:07:10:WU01:FS01:0x22: OS Version: 4.15
15:07:10:WU01:FS01:0x22:Has Battery: false
15:07:10:WU01:FS01:0x22: On Battery: false
15:07:10:WU01:FS01:0x22: UTC Offset: 0
15:07:10:WU01:FS01:0x22: PID: 15343
15:07:10:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
15:07:10:WU01:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:07:10:WU01:FS01:0x22: OS Arch: AMD64
15:07:10:WU01:FS01:0x22:********************************************************************************
15:07:10:WU01:FS01:0x22:Project: 11743 (Run 0, Clone 3927, Gen 3)
15:07:10:WU01:FS01:0x22:Unit: 0x000000038ca304f15e69da31e47ddd03
15:07:10:WU01:FS01:0x22:Reading tar file core.xml
15:07:10:WU01:FS01:0x22:Reading tar file integrator.xml
15:07:10:WU01:FS01:0x22:Reading tar file state.xml
15:07:10:WU01:FS01:0x22:Reading tar file system.xml
15:07:10:WU01:FS01:0x22:Digital signatures verified
15:07:10:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:07:10:WU01:FS01:0x22:Version 0.0.2
15:07:12:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:07:12:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:07:12:WU01:FS01:0x22:Saving result file science.log
15:07:12:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:07:12:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:07:12:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11743 run:0 clone:3927 gen:3 core:0x22 unit:0x000000038ca304f15e69da31e47ddd03
15:09:33:WU01:FS01:0x22:*********************** Log Started 2020-03-12T15:09:32Z ***********************
15:09:33:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:09:33:WU01:FS01:0x22: Type: 0x22
15:09:33:WU01:FS01:0x22: Core: Core22
15:09:33:WU01:FS01:0x22: Website:
15:09:33:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:09:33:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:09:33:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:09:33:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 15772 -checkpoint 15
15:09:33:WU01:FS01:0x22: -gpu-vendor amd -opencl-device 1 -gpu 1
15:09:33:WU01:FS01:0x22: Config: <none>
15:09:33:WU01:FS01:0x22:************************************ Build *************************************
15:09:33:WU01:FS01:0x22: Version: 0.0.2
15:09:33:WU01:FS01:0x22: Date: Dec 6 2019
15:09:33:WU01:FS01:0x22: Time: 21:20:17
15:09:33:WU01:FS01:0x22: Repository: Git
15:09:33:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:09:33:WU01:FS01:0x22: Branch: core22
15:09:33:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:09:33:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:09:33:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:09:33:WU01:FS01:0x22: Bits: 64
15:09:33:WU01:FS01:0x22: Mode: Release
15:09:33:WU01:FS01:0x22:************************************ System ************************************
15:09:33:WU01:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:09:33:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:09:33:WU01:FS01:0x22: CPUs: 16
15:09:33:WU01:FS01:0x22: Memory: 15.68GiB
15:09:33:WU01:FS01:0x22:Free Memory: 7.11GiB
15:09:33:WU01:FS01:0x22: Threads: POSIX_THREADS
15:09:33:WU01:FS01:0x22: OS Version: 4.15
15:09:33:WU01:FS01:0x22:Has Battery: false
15:09:33:WU01:FS01:0x22: On Battery: false
15:09:33:WU01:FS01:0x22: UTC Offset: 0
15:09:33:WU01:FS01:0x22: PID: 15776
15:09:33:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
15:09:33:WU01:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:09:33:WU01:FS01:0x22: OS Arch: AMD64
15:09:33:WU01:FS01:0x22:********************************************************************************
15:09:33:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 23163, Gen 1)
15:09:33:WU01:FS01:0x22:Unit: 0x000000018ca304f15e63e382e819fd86
15:09:33:WU01:FS01:0x22:Reading tar file core.xml
15:09:33:WU01:FS01:0x22:Reading tar file integrator.xml
15:09:33:WU01:FS01:0x22:Reading tar file state.xml
15:09:33:WU01:FS01:0x22:Reading tar file system.xml
15:09:33:WU01:FS01:0x22:Digital signatures verified
15:09:33:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:09:33:WU01:FS01:0x22:Version 0.0.2
15:09:33:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:09:33:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:09:33:WU01:FS01:0x22:Saving result file science.log
15:09:33:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:09:34:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:09:34:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:23163 gen:1 core:0x22 unit:0x000000018ca304f15e63e382e819fd86
15:09:34:WU01:FS01:Uploading 7.50KiB to 140.163.4.241
15:09:34:WU01:FS01:Connecting to 140.163.4.241:8080
15:09:34:WU02:FS01:Connecting to 65.254.110.245:8080
15:09:34:WU02:FS01:Assigned to work server 140.163.4.241
15:09:34:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:09:34:WU02:FS01:Connecting to 140.163.4.241:8080
15:10:01:WU01:FS01:Upload complete
15:10:02:WU01:FS01:Server responded WORK_ACK (400)
15:10:02:WU01:FS01:Cleaning up
15:10:08:WU02:FS01:Downloading 79.12MiB
15:10:14:WU02:FS01:Download 0.87%
15:10:20:WU02:FS01:Download 4.42%
15:10:26:WU02:FS01:Download 7.98%
15:10:32:WU02:FS01:Download 12.09%
15:10:38:WU02:FS01:Download 15.56%
15:10:44:WU02:FS01:Download 18.17%
15:10:50:WU02:FS01:Download 31.52%
15:10:56:WU02:FS01:Download 39.26%
15:11:02:WU02:FS01:Download 46.05%
15:11:08:WU02:FS01:Download 53.32%
15:11:14:WU02:FS01:Download 63.51%
15:11:20:WU02:FS01:Download 79.55%
15:11:26:WU02:FS01:Download 93.53%
15:11:28:WU02:FS01:Download complete
15:11:29:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11741 run:0 clone:4233 gen:1 core:0x22 unit:0x000000018ca304f15e697627773fa48f
15:11:29:WU02:FS01:Starting
15:11:29:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 1 -gpu 1
15:11:29:WU02:FS01:Started FahCore on PID 16307
15:11:29:WU02:FS01:Core PID:16311
15:11:29:WU02:FS01:FahCore 0x22 started
15:11:29:WU02:FS01:0x22:*********************** Log Started 2020-03-12T15:11:29Z ***********************
15:11:29:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:11:29:WU02:FS01:0x22: Type: 0x22
15:11:29:WU02:FS01:0x22: Core: Core22
15:11:29:WU02:FS01:0x22: Website:
15:11:29:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:11:29:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:11:29:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:11:29:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 16307 -checkpoint 15
15:11:29:WU02:FS01:0x22: -gpu-vendor amd -opencl-device 1 -gpu 1
15:11:29:WU02:FS01:0x22: Config: <none>
15:11:29:WU02:FS01:0x22:************************************ Build *************************************
15:11:29:WU02:FS01:0x22: Version: 0.0.2
15:11:29:WU02:FS01:0x22: Date: Dec 6 2019
15:11:29:WU02:FS01:0x22: Time: 21:20:17
15:11:29:WU02:FS01:0x22: Repository: Git
15:11:29:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:11:29:WU02:FS01:0x22: Branch: core22
15:11:29:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:11:29:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:11:29:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:11:29:WU02:FS01:0x22: Bits: 64
15:11:29:WU02:FS01:0x22: Mode: Release
15:11:29:WU02:FS01:0x22:************************************ System ************************************
15:11:29:WU02:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:11:29:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:11:29:WU02:FS01:0x22: CPUs: 16
15:11:29:WU02:FS01:0x22: Memory: 15.68GiB
15:11:29:WU02:FS01:0x22:Free Memory: 6.56GiB
15:11:29:WU02:FS01:0x22: Threads: POSIX_THREADS
15:11:29:WU02:FS01:0x22: OS Version: 4.15
15:11:29:WU02:FS01:0x22:Has Battery: false
15:11:29:WU02:FS01:0x22: On Battery: false
15:11:29:WU02:FS01:0x22: UTC Offset: 0
15:11:29:WU02:FS01:0x22: PID: 16311
15:11:29:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
15:11:29:WU02:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:11:29:WU02:FS01:0x22: OS Arch: AMD64
15:11:29:WU02:FS01:0x22:********************************************************************************
15:11:29:WU02:FS01:0x22:Project: 11741 (Run 0, Clone 4233, Gen 1)
15:11:29:WU02:FS01:0x22:Unit: 0x000000018ca304f15e697627773fa48f
15:11:29:WU02:FS01:0x22:Reading tar file core.xml
15:11:29:WU02:FS01:0x22:Reading tar file integrator.xml
15:11:29:WU02:FS01:0x22:Reading tar file state.xml
15:11:29:WU02:FS01:0x22:Reading tar file system.xml
15:11:29:WU02:FS01:0x22:Digital signatures verified
15:11:29:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:11:29:WU02:FS01:0x22:Version 0.0.2
15:11:34:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:11:34:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:11:34:WU02:FS01:0x22:Saving result file science.log
15:11:34:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:11:34:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:11:34:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11741 run:0 clone:4233 gen:1 core:0x22 unit:0x000000018ca304f15e697627773fa48f
15:11:34:WU02:FS01:Uploading 7.50KiB to 140.163.4.241
15:11:34:WU02:FS01:Connecting to 140.163.4.241:8080
15:11:35:WU01:FS01:Connecting to 65.254.110.245:8080
15:11:35:WU01:FS01:Assigned to work server 140.163.4.241
15:11:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:11:35:WU01:FS01:Connecting to 140.163.4.241:8080
15:11:44:WU02:FS01:Upload complete
15:11:44:WU02:FS01:Server responded WORK_ACK (400)
15:11:44:WU02:FS01:Cleaning up
15:11:45:WU01:FS01:Downloading 11.66MiB
15:11:51:WU01:FS01:Download 15.01%
15:11:57:WU01:FS01:Download 24.13%
15:12:03:WU01:FS01:Download 33.78%
15:12:09:WU01:FS01:Download 43.96%
15:12:15:WU01:FS01:Download 66.48%
15:12:21:WU01:FS01:Download 82.56%
15:12:22:WU01:FS01:Download complete
15:12:22:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:12224 gen:5 core:0x22 unit:0x0000000b8ca304f15e61c39546806777
15:12:22:WU01:FS01:Starting
15:12:22:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 1 -gpu 1
15:12:22:WU01:FS01:Started FahCore on PID 16434
15:12:22:WU01:FS01:Core PID:16438
15:12:22:WU01:FS01:FahCore 0x22 started
15:12:23:WU01:FS01:0x22:*********************** Log Started 2020-03-12T15:12:22Z ***********************
15:12:23:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:12:23:WU01:FS01:0x22: Type: 0x22
15:12:23:WU01:FS01:0x22: Core: Core22
15:12:23:WU01:FS01:0x22: Website:
15:12:23:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:12:23:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:12:23:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:12:23:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 16434 -checkpoint 15
15:12:23:WU01:FS01:0x22: -gpu-vendor amd -opencl-device 1 -gpu 1
15:12:23:WU01:FS01:0x22: Config: <none>
15:12:23:WU01:FS01:0x22:************************************ Build *************************************
15:12:23:WU01:FS01:0x22: Version: 0.0.2
15:12:23:WU01:FS01:0x22: Date: Dec 6 2019
15:12:23:WU01:FS01:0x22: Time: 21:20:17
15:12:23:WU01:FS01:0x22: Repository: Git
15:12:23:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:12:23:WU01:FS01:0x22: Branch: core22
15:12:23:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:12:23:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:12:23:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:12:23:WU01:FS01:0x22: Bits: 64
15:12:23:WU01:FS01:0x22: Mode: Release
15:12:23:WU01:FS01:0x22:************************************ System ************************************
15:12:23:WU01:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:12:23:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:12:23:WU01:FS01:0x22: CPUs: 16
15:12:23:WU01:FS01:0x22: Memory: 15.68GiB
15:12:23:WU01:FS01:0x22:Free Memory: 6.78GiB
15:12:23:WU01:FS01:0x22: Threads: POSIX_THREADS
15:12:23:WU01:FS01:0x22: OS Version: 4.15
15:12:23:WU01:FS01:0x22:Has Battery: false
15:12:23:WU01:FS01:0x22: On Battery: false
15:12:23:WU01:FS01:0x22: UTC Offset: 0
15:12:23:WU01:FS01:0x22: PID: 16438
15:12:23:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
15:12:23:WU01:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:12:23:WU01:FS01:0x22: OS Arch: AMD64
15:12:23:WU01:FS01:0x22:********************************************************************************
15:12:23:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 12224, Gen 5)
15:12:23:WU01:FS01:0x22:Unit: 0x0000000b8ca304f15e61c39546806777
15:12:23:WU01:FS01:0x22:Reading tar file core.xml
15:12:23:WU01:FS01:0x22:Reading tar file integrator.xml
15:12:23:WU01:FS01:0x22:Reading tar file state.xml
15:12:23:WU01:FS01:0x22:Reading tar file system.xml
15:12:23:WU01:FS01:0x22:Digital signatures verified
15:12:23:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:12:23:WU01:FS01:0x22:Version 0.0.2
15:12:23:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:12:23:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:12:23:WU01:FS01:0x22:Saving result file science.log
15:12:23:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:12:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:12:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:12224 gen:5 core:0x22 unit:0x0000000b8ca304f15e61c39546806777
15:12:24:WU01:FS01:Uploading 7.50KiB to 140.163.4.241
15:12:24:WU01:FS01:Connecting to 140.163.4.241:8080
15:12:24:WU02:FS01:Connecting to 65.254.110.245:8080
15:12:24:WU02:FS01:Assigned to work server 140.163.4.241
15:12:24:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:12:24:WU02:FS01:Connecting to 140.163.4.241:8080
15:12:35:WU01:FS01:Upload complete
15:12:35:WU01:FS01:Server responded WORK_ACK (400)
15:12:35:WU01:FS01:Cleaning up
15:12:36:WU02:FS01:Downloading 11.66MiB
15:12:42:WU02:FS01:Download 7.51%
15:12:48:WU02:FS01:Download 21.98%
15:12:54:WU02:FS01:Download 63.79%
15:13:00:WU02:FS01:Download 99.17%
15:13:00:WU02:FS01:Download complete
15:13:00:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:8244 gen:11 core:0x22 unit:0x000000148ca304f15e406546acd3b6e1
15:13:00:WU02:FS01:Starting
15:13:00:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
15:13:00:WU02:FS01:Started FahCore on PID 16486
15:13:00:WU02:FS01:Core PID:16490
15:13:00:WU02:FS01:FahCore 0x22 started
15:13:00:WU02:FS01:0x22:*********************** Log Started 2020-03-12T15:13:00Z ***********************
15:13:00:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:13:00:WU02:FS01:0x22: Type: 0x22
15:13:00:WU02:FS01:0x22: Core: Core22
15:13:00:WU02:FS01:0x22: Website:
15:13:00:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:13:00:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:13:00:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:13:00:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 16486 -checkpoint 15
15:13:00:WU02:FS01:0x22: -gpu-vendor amd -opencl-device 0 -gpu 0
15:13:00:WU02:FS01:0x22: Config: <none>
15:13:00:WU02:FS01:0x22:************************************ Build *************************************
15:13:00:WU02:FS01:0x22: Version: 0.0.2
15:13:00:WU02:FS01:0x22: Date: Dec 6 2019
15:13:00:WU02:FS01:0x22: Time: 21:20:17
15:13:00:WU02:FS01:0x22: Repository: Git
15:13:00:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:13:00:WU02:FS01:0x22: Branch: core22
15:13:00:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:13:00:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:13:00:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:13:00:WU02:FS01:0x22: Bits: 64
15:13:00:WU02:FS01:0x22: Mode: Release
15:13:00:WU02:FS01:0x22:************************************ System ************************************
15:13:00:WU02:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:13:00:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:13:00:WU02:FS01:0x22: CPUs: 16
15:13:00:WU02:FS01:0x22: Memory: 15.68GiB
15:13:00:WU02:FS01:0x22:Free Memory: 6.80GiB
15:13:00:WU02:FS01:0x22: Threads: POSIX_THREADS
15:13:00:WU02:FS01:0x22: OS Version: 4.15
15:13:00:WU02:FS01:0x22:Has Battery: false
15:13:00:WU02:FS01:0x22: On Battery: false
15:13:00:WU02:FS01:0x22: UTC Offset: 0
15:13:00:WU02:FS01:0x22: PID: 16490
15:13:00:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
15:13:00:WU02:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:13:00:WU02:FS01:0x22: OS Arch: AMD64
15:13:00:WU02:FS01:0x22:********************************************************************************
15:13:00:WU02:FS01:0x22:Project: 11737 (Run 0, Clone 8244, Gen 11)
15:13:00:WU02:FS01:0x22:Unit: 0x000000148ca304f15e406546acd3b6e1
15:13:00:WU02:FS01:0x22:Reading tar file core.xml
15:13:00:WU02:FS01:0x22:Reading tar file integrator.xml
15:13:00:WU02:FS01:0x22:Reading tar file state.xml
15:13:00:WU02:FS01:0x22:Reading tar file system.xml
15:13:00:WU02:FS01:0x22:Digital signatures verified
15:13:00:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:13:00:WU02:FS01:0x22:Version 0.0.2
15:13:01:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:13:01:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:13:01:WU02:FS01:0x22:Saving result file science.log
15:13:01:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:13:01:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:13:01:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11737 run:0 clone:8244 gen:11 core:0x22 unit:0x000000148ca304f15e406546acd3b6e1
15:13:01:WU02:FS01:Uploading 7.50KiB to 140.163.4.241
15:13:01:WU02:FS01:Connecting to 140.163.4.241:8080
15:13:01:WU01:FS01:Connecting to 65.254.110.245:8080
15:13:02:WU01:FS01:Assigned to work server 140.163.4.241
15:13:02:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:13:02:WU01:FS01:Connecting to 140.163.4.241:8080
15:13:04:WU02:FS01:Upload complete
15:13:04:WU02:FS01:Server responded WORK_ACK (400)
15:13:04:WU02:FS01:Cleaning up
15:13:06:ERROR:WU01:FS01:Exception: Server did not assign work unit
15:13:06:WU01:FS01:Connecting to 65.254.110.245:8080
15:13:06:WU01:FS01:Assigned to work server 140.163.4.241
15:13:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:13:06:WU01:FS01:Connecting to 140.163.4.241:8080
15:13:16:WU01:FS01:Downloading 11.65MiB
15:13:22:WU01:FS01:Download 11.26%
15:13:28:WU01:FS01:Download 24.67%
15:13:35:WU01:FS01:Download 42.91%
15:13:41:WU01:FS01:Download 56.86%
15:13:47:WU01:FS01:Download 77.24%
15:13:55:WU01:FS01:Download 97.08%
15:13:56:WU01:FS01:Download complete
15:13:56:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:6990 gen:43 core:0x22 unit:0x0000003c8ca304f15e40652fedc8040f
15:13:56:WU01:FS01:Starting
15:13:56:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
15:13:56:WU01:FS01:Started FahCore on PID 16837
15:13:56:WU01:FS01:Core PID:16841
15:13:56:WU01:FS01:FahCore 0x22 started
15:13:56:WU01:FS01:0x22:*********************** Log Started 2020-03-12T15:13:56Z ***********************
15:13:56:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:13:56:WU01:FS01:0x22: Type: 0x22
15:13:56:WU01:FS01:0x22: Core: Core22
15:13:56:WU01:FS01:0x22: Website:
15:13:56:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:13:56:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:13:56:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:13:56:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 16837 -checkpoint 15
15:13:56:WU01:FS01:0x22: -gpu-vendor amd -opencl-device 0 -gpu 0
15:13:56:WU01:FS01:0x22: Config: <none>
15:13:56:WU01:FS01:0x22:************************************ Build *************************************
15:13:56:WU01:FS01:0x22: Version: 0.0.2
15:13:56:WU01:FS01:0x22: Date: Dec 6 2019
15:13:56:WU01:FS01:0x22: Time: 21:20:17
15:13:56:WU01:FS01:0x22: Repository: Git
15:13:56:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:13:56:WU01:FS01:0x22: Branch: core22
15:13:56:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:13:56:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:13:56:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:13:56:WU01:FS01:0x22: Bits: 64
15:13:56:WU01:FS01:0x22: Mode: Release
15:13:56:WU01:FS01:0x22:************************************ System ************************************
15:13:56:WU01:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:13:56:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:13:56:WU01:FS01:0x22: CPUs: 16
15:13:56:WU01:FS01:0x22: Memory: 15.68GiB
15:13:56:WU01:FS01:0x22:Free Memory: 6.34GiB
15:13:56:WU01:FS01:0x22: Threads: POSIX_THREADS
15:13:56:WU01:FS01:0x22: OS Version: 4.15
15:13:56:WU01:FS01:0x22:Has Battery: false
15:13:56:WU01:FS01:0x22: On Battery: false
15:13:56:WU01:FS01:0x22: UTC Offset: 0
15:13:56:WU01:FS01:0x22: PID: 16841
15:13:56:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
15:13:56:WU01:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:13:56:WU01:FS01:0x22: OS Arch: AMD64
15:13:56:WU01:FS01:0x22:********************************************************************************
15:13:56:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 6990, Gen 43)
15:13:56:WU01:FS01:0x22:Unit: 0x0000003c8ca304f15e40652fedc8040f
15:13:56:WU01:FS01:0x22:Reading tar file core.xml
15:13:56:WU01:FS01:0x22:Reading tar file integrator.xml
15:13:56:WU01:FS01:0x22:Reading tar file state.xml
15:13:56:WU01:FS01:0x22:Reading tar file system.xml
15:13:56:WU01:FS01:0x22:Digital signatures verified
15:13:56:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:13:56:WU01:FS01:0x22:Version 0.0.2
15:13:57:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:13:57:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:13:57:WU01:FS01:0x22:Saving result file science.log
15:13:57:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:13:57:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:13:57:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:6990 gen:43 core:0x22 unit:0x0000003c8ca304f15e40652fedc8040f
15:13:57:WU01:FS01:Uploading 7.50KiB to 140.163.4.241
15:13:57:WU01:FS01:Connecting to 140.163.4.241:8080
15:13:57:WU02:FS01:Connecting to 65.254.110.245:8080
15:13:58:WU02:FS01:Assigned to work server 140.163.4.241
15:13:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:13:58:WU02:FS01:Connecting to 140.163.4.241:8080
15:14:01:WU01:FS01:Upload complete
15:14:01:WU01:FS01:Server responded WORK_ACK (400)
15:14:01:WU01:FS01:Cleaning up
15:14:01:WU02:FS01:Downloading 11.65MiB
15:14:07:WU02:FS01:Download 6.97%
15:14:13:WU02:FS01:Download 14.49%
15:14:19:WU02:FS01:Download 23.61%
15:14:25:WU02:FS01:Download 38.63%
15:14:31:WU02:FS01:Download 53.65%
15:14:36:WU02:FS01:Download complete
15:14:36:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:14261 gen:1 core:0x22 unit:0x000000048ca304f15e61c3ff7554bc4b
15:14:36:WU02:FS01:Starting
15:14:36:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
15:14:36:WU02:FS01:Started FahCore on PID 17230
15:14:36:WU02:FS01:Core PID:17234
15:14:36:WU02:FS01:FahCore 0x22 started
15:14:37:WU02:FS01:0x22:*********************** Log Started 2020-03-12T15:14:36Z ***********************
15:14:37:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:14:37:WU02:FS01:0x22: Type: 0x22
15:14:37:WU02:FS01:0x22: Core: Core22
15:14:37:WU02:FS01:0x22: Website:
15:14:37:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:14:37:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:14:37:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:14:37:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 17230 -checkpoint 15
15:14:37:WU02:FS01:0x22: -gpu-vendor amd -opencl-device 0 -gpu 0
15:14:37:WU02:FS01:0x22: Config: <none>
15:14:37:WU02:FS01:0x22:************************************ Build *************************************
15:14:37:WU02:FS01:0x22: Version: 0.0.2
15:14:37:WU02:FS01:0x22: Date: Dec 6 2019
15:14:37:WU02:FS01:0x22: Time: 21:20:17
15:14:37:WU02:FS01:0x22: Repository: Git
15:14:37:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:14:37:WU02:FS01:0x22: Branch: core22
15:14:37:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:14:37:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:14:37:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:14:37:WU02:FS01:0x22: Bits: 64
15:14:37:WU02:FS01:0x22: Mode: Release
15:14:37:WU02:FS01:0x22:************************************ System ************************************
15:14:37:WU02:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:14:37:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:14:37:WU02:FS01:0x22: CPUs: 16
15:14:37:WU02:FS01:0x22: Memory: 15.68GiB
15:14:37:WU02:FS01:0x22:Free Memory: 4.96GiB
15:14:37:WU02:FS01:0x22: Threads: POSIX_THREADS
15:14:37:WU02:FS01:0x22: OS Version: 4.15
15:14:37:WU02:FS01:0x22:Has Battery: false
15:14:37:WU02:FS01:0x22: On Battery: false
15:14:37:WU02:FS01:0x22: UTC Offset: 0
15:14:37:WU02:FS01:0x22: PID: 17234
15:14:37:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
15:14:37:WU02:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:14:37:WU02:FS01:0x22: OS Arch: AMD64
15:14:37:WU02:FS01:0x22:********************************************************************************
15:14:37:WU02:FS01:0x22:Project: 11737 (Run 0, Clone 14261, Gen 1)
15:14:37:WU02:FS01:0x22:Unit: 0x000000048ca304f15e61c3ff7554bc4b
15:14:37:WU02:FS01:0x22:Reading tar file core.xml
15:14:37:WU02:FS01:0x22:Reading tar file integrator.xml
15:14:37:WU02:FS01:0x22:Reading tar file state.xml
15:14:37:WU02:FS01:0x22:Reading tar file system.xml
15:14:37:WU02:FS01:0x22:Digital signatures verified
15:14:37:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:14:37:WU02:FS01:0x22:Version 0.0.2
15:14:37:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:14:37:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:14:37:WU02:FS01:0x22:Saving result file science.log
15:14:37:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:14:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:14:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11737 run:0 clone:14261 gen:1 core:0x22 unit:0x000000048ca304f15e61c3ff7554bc4b
15:14:38:WU02:FS01:Uploading 7.50KiB to 140.163.4.241
15:14:38:WU02:FS01:Connecting to 140.163.4.241:8080
15:14:38:WU01:FS01:Connecting to 65.254.110.245:8080
15:14:38:WU01:FS01:Assigned to work server 140.163.4.241
15:14:38:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:14:38:WU01:FS01:Connecting to 140.163.4.241:8080
15:14:50:WU02:FS01:Upload complete
15:14:50:WU02:FS01:Server responded WORK_ACK (400)
15:14:50:WU02:FS01:Cleaning up
15:14:50:ERROR:WU01:FS01:Exception: Server did not assign work unit
15:14:50:WU01:FS01:Connecting to 65.254.110.245:8080
15:14:51:WU01:FS01:Assigned to work server 140.163.4.241
15:14:51:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:14:51:WU01:FS01:Connecting to 140.163.4.241:8080
15:14:52:WU01:FS01:Downloading 11.66MiB
15:14:58:WU01:FS01:Download 11.80%
15:15:04:WU01:FS01:Download 20.38%
15:15:10:WU01:FS01:Download 39.14%
15:15:16:WU01:FS01:Download 60.05%
15:15:22:WU01:FS01:Download 89.01%
15:15:23:WU01:FS01:Download complete
15:15:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:13082 gen:3 core:0x22 unit:0x000000068ca304f15e61c3c3ed6e761b
15:15:23:WU01:FS01:Starting
15:15:23:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 01 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
15:15:23:WU01:FS01:Started FahCore on PID 17281
15:15:23:WU01:FS01:Core PID:17285
15:15:23:WU01:FS01:FahCore 0x22 started
15:15:23:WU01:FS01:0x22:*********************** Log Started 2020-03-12T15:15:23Z ***********************
15:15:23:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:15:23:WU01:FS01:0x22: Type: 0x22
15:15:23:WU01:FS01:0x22: Core: Core22
15:15:23:WU01:FS01:0x22: Website:
15:15:23:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:15:23:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:15:23:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:15:23:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 17281 -checkpoint 15
15:15:23:WU01:FS01:0x22: -gpu-vendor amd -opencl-device 0 -gpu 0
15:15:23:WU01:FS01:0x22: Config: <none>
15:15:23:WU01:FS01:0x22:************************************ Build *************************************
15:15:23:WU01:FS01:0x22: Version: 0.0.2
15:15:23:WU01:FS01:0x22: Date: Dec 6 2019
15:15:23:WU01:FS01:0x22: Time: 21:20:17
15:15:23:WU01:FS01:0x22: Repository: Git
15:15:23:WU01:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:15:23:WU01:FS01:0x22: Branch: core22
15:15:23:WU01:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:15:23:WU01:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:15:23:WU01:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:15:23:WU01:FS01:0x22: Bits: 64
15:15:23:WU01:FS01:0x22: Mode: Release
15:15:23:WU01:FS01:0x22:************************************ System ************************************
15:15:23:WU01:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:15:23:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:15:23:WU01:FS01:0x22: CPUs: 16
15:15:23:WU01:FS01:0x22: Memory: 15.68GiB
15:15:23:WU01:FS01:0x22:Free Memory: 5.04GiB
15:15:23:WU01:FS01:0x22: Threads: POSIX_THREADS
15:15:23:WU01:FS01:0x22: OS Version: 4.15
15:15:23:WU01:FS01:0x22:Has Battery: false
15:15:23:WU01:FS01:0x22: On Battery: false
15:15:23:WU01:FS01:0x22: UTC Offset: 0
15:15:23:WU01:FS01:0x22: PID: 17285
15:15:23:WU01:FS01:0x22: CWD: /var/lib/fahclient/work
15:15:23:WU01:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:15:23:WU01:FS01:0x22: OS Arch: AMD64
15:15:23:WU01:FS01:0x22:********************************************************************************
15:15:23:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 13082, Gen 3)
15:15:23:WU01:FS01:0x22:Unit: 0x000000068ca304f15e61c3c3ed6e761b
15:15:23:WU01:FS01:0x22:Reading tar file core.xml
15:15:23:WU01:FS01:0x22:Reading tar file integrator.xml
15:15:23:WU01:FS01:0x22:Reading tar file state.xml
15:15:23:WU01:FS01:0x22:Reading tar file system.xml
15:15:23:WU01:FS01:0x22:Digital signatures verified
15:15:23:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:15:23:WU01:FS01:0x22:Version 0.0.2
15:15:24:WU01:FS01:0x22:Saving result file ../logfile_01.txt
15:15:24:WU01:FS01:0x22:Saving result file science.log
15:15:24:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:15:24:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:15:24:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:13082 gen:3 core:0x22 unit:0x000000068ca304f15e61c3c3ed6e761b
15:15:24:WU01:FS01:Uploading 7.50KiB to 140.163.4.241
15:15:24:WU01:FS01:Connecting to 140.163.4.241:8080
15:15:24:WU02:FS01:Connecting to 65.254.110.245:8080
15:15:25:WU02:FS01:Assigned to work server 140.163.4.241
15:15:25:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:15:25:WU02:FS01:Connecting to 140.163.4.241:8080
15:15:27:WU01:FS01:Upload complete
15:15:27:WU01:FS01:Server responded WORK_ACK (400)
15:15:27:WU01:FS01:Cleaning up
15:15:29:WU02:FS01:Downloading 51.29MiB
15:15:35:WU02:FS01:Download 1.46%
15:15:41:WU02:FS01:Download 4.39%
15:15:47:WU02:FS01:Download 7.55%
15:15:53:WU02:FS01:Download 12.18%
15:15:59:WU02:FS01:Download 16.21%
15:16:05:WU02:FS01:Download 19.37%
15:16:11:WU02:FS01:Download 22.79%
15:16:17:WU02:FS01:Download 27.05%
15:16:23:WU02:FS01:Download 31.68%
15:16:29:WU02:FS01:Download 36.31%
15:16:35:WU02:FS01:Download 41.67%
15:16:41:WU02:FS01:Download 45.33%
15:16:47:WU02:FS01:Download 49.71%
15:16:53:WU02:FS01:Download 55.07%
15:16:59:WU02:FS01:Download 59.46%
15:17:05:WU02:FS01:Download 65.80%
15:17:11:WU02:FS01:Download 70.79%
15:17:17:WU02:FS01:Download 78.10%
15:17:23:WU02:FS01:Download 83.83%
15:17:29:WU02:FS01:Download 90.41%
15:17:35:WU02:FS01:Download 99.79%
15:17:35:WU02:FS01:Download complete
15:17:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11745 run:0 clone:3574 gen:0 core:0x22 unit:0x000000008ca304f15e6a526658eb39aa
15:17:35:WU02:FS01:Starting
15:17:35:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 14221 -checkpoint 15 -gpu-vendor amd -opencl-device 0 -gpu 0
15:17:35:WU02:FS01:Started FahCore on PID 17509
15:17:35:WU02:FS01:Core PID:17513
15:17:35:WU02:FS01:FahCore 0x22 started
15:17:35:WU02:FS01:0x22:*********************** Log Started 2020-03-12T15:17:35Z ***********************
15:17:35:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:17:35:WU02:FS01:0x22: Type: 0x22
15:17:35:WU02:FS01:0x22: Core: Core22
15:17:35:WU02:FS01:0x22: Website
15:17:35:WU02:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:17:35:WU02:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:17:35:WU02:FS01:0x22: <rafal.wiewiora@choderalab.org>
15:17:35:WU02:FS01:0x22: Args: -dir 02 -suffix 01 -version 705 -lifeline 17509 -checkpoint 15
15:17:35:WU02:FS01:0x22: -gpu-vendor amd -opencl-device 0 -gpu 0
15:17:35:WU02:FS01:0x22: Config: <none>
15:17:35:WU02:FS01:0x22:************************************ Build *************************************
15:17:35:WU02:FS01:0x22: Version: 0.0.2
15:17:35:WU02:FS01:0x22: Date: Dec 6 2019
15:17:35:WU02:FS01:0x22: Time: 21:20:17
15:17:35:WU02:FS01:0x22: Repository: Git
15:17:35:WU02:FS01:0x22: Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:17:35:WU02:FS01:0x22: Branch: core22
15:17:35:WU02:FS01:0x22: Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:17:35:WU02:FS01:0x22: Options: -std=gnu++98 -O3 -funroll-loops
15:17:35:WU02:FS01:0x22: Platform: linux2 4.9.87-linuxkit-aufs
15:17:35:WU02:FS01:0x22: Bits: 64
15:17:35:WU02:FS01:0x22: Mode: Release
15:17:35:WU02:FS01:0x22:************************************ System ************************************
15:17:35:WU02:FS01:0x22: CPU: AMD Ryzen 7 2700X Eight-Core Processor
15:17:35:WU02:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
15:17:35:WU02:FS01:0x22: CPUs: 16
15:17:35:WU02:FS01:0x22: Memory: 15.68GiB
15:17:35:WU02:FS01:0x22:Free Memory: 2.09GiB
15:17:35:WU02:FS01:0x22: Threads: POSIX_THREADS
15:17:35:WU02:FS01:0x22: OS Version: 4.15
15:17:35:WU02:FS01:0x22:Has Battery: false
15:17:35:WU02:FS01:0x22: On Battery: false
15:17:35:WU02:FS01:0x22: UTC Offset: 0
15:17:35:WU02:FS01:0x22: PID: 17513
15:17:35:WU02:FS01:0x22: CWD: /var/lib/fahclient/work
15:17:35:WU02:FS01:0x22: OS: Linux 4.15.0-88-generic x86_64
15:17:35:WU02:FS01:0x22: OS Arch: AMD64
15:17:35:WU02:FS01:0x22:********************************************************************************
15:17:35:WU02:FS01:0x22:Project: 11745 (Run 0, Clone 3574, Gen 0)
15:17:35:WU02:FS01:0x22:Unit: 0x000000008ca304f15e6a526658eb39aa
15:17:35:WU02:FS01:0x22:Reading tar file core.xml
15:17:35:WU02:FS01:0x22:Reading tar file integrator.xml
15:17:35:WU02:FS01:0x22:Reading tar file state.xml
15:17:35:WU02:FS01:0x22:Reading tar file system.xml
15:17:35:WU02:FS01:0x22:Digital signatures verified
15:17:35:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:17:35:WU02:FS01:0x22:Version 0.0.2
15:17:39:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceIDs (-1)
15:17:39:WU02:FS01:0x22:Saving result file ../logfile_01.txt
15:17:39:WU02:FS01:0x22:Saving result file science.log
15:17:39:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
15:17:39:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:17:39:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11745 run:0 clone:3574 gen:0 core:0x22 unit:0x000000008ca304f15e6a526658eb39aa
15:17:39:WU02:FS01:Uploading 7.50KiB to 140.163.4.241
15:17:39:WU02:FS01:Connecting to 140.163.4.241:8080
15:17:49:WU02:FS01:Upload complete
15:17:49:WU02:FS01:Server responded WORK_ACK (400)
15:17:49:WU02:FS01:Cleaning upCL Info log:
Number of platforms 1
Platform Name AMD Accelerated Parallel Processing
Platform Vendor Advanced Micro Devices, Inc.
Platform Version OpenCL 2.1 AMD-APP (3004.6)
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
Platform Host timer resolution 1ns
Platform Extensions function suffix AMD
Number of devices 1
Device Name gfx1010
Device Vendor Advanced Micro Devices, Inc.
Device Vendor ID 0x1002
Device Version OpenCL 2.0 AMD-APP (3004.6)
Driver Version 3004.6 (PAL,LC)
Device OpenCL C Version OpenCL C 2.0
Device Type GPU
Device Board Name (AMD) AMD Radeon RX 5700 XT 50th Anniversary
Device Topology (AMD) PCI-E, 08:00.0
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 20
SIMD per compute unit (AMD) 2
SIMD width (AMD) 32
SIMD instruction width (AMD) 1
Max clock frequency 2100MHz
Graphics IP (AMD) 10.10
Device Partition (core)
Max number of sub-devices 20
Supported partition types None
Max work item dimensions 3
Max work item sizes 1024x1024x1024
Max work group size 256
Preferred work group size (AMD) 256
Max work group size (AMD) 1024
Preferred work group size multiple 32
Wavefront width (AMD) 32
char 4 / 4
short 2 / 2
int 1 / 1
long 1 / 1
half 1 / 1 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Correctly-rounded divide and sqrt operations Yes
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Address bits 64, Little-Endian
Global memory size 8573157376 (7.984GiB)
Global free memory (AMD) 8306688 (7.922GiB)
Global memory channels (AMD) 8
Global memory banks per channel (AMD) 4
Global memory bank width (AMD) 256 bytes
Error Correction support No
Max memory allocation 4244635648 (3.953GiB)
Unified memory for Host and Device No
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing Yes
Fine-grained system sharing No
Atomics No
Minimum alignment for any data type 128 bytes
Alignment of base address 2048 bits (256 bytes)
Preferred alignment for atomics
SVM 0 bytes
Global 0 bytes
Local 0 bytes
Max size for global variable 3820172032 (3.558GiB)
Preferred total size of global vars 8573157376 (7.984GiB)
Global Memory cache type Read/Write
Global Memory cache size 16384 (16KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 134217728 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 256 bytes
Pitch alignment for 2D image buffers 256 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 128
Max number of write image args 64
Max number of read/write image args 64
Max number of pipe args 16
Max active pipe reservations 16
Max pipe packet size 4244635648 (3.953GiB)
Local memory type Local
Local memory size 65536 (64KiB)
Local memory syze per CU (AMD) 65536 (64KiB)
Local memory banks (AMD) 32
Max number of constant args 8
Max constant buffer size 4244635648 (3.953GiB)
Preferred constant buffer size (AMD) 16384 (16KiB)
Max size of kernel argument 1024
Queue properties (on host)
Out-of-order execution No
Profiling Yes
Queue properties (on device)
Out-of-order execution Yes
Profiling Yes
Preferred size 262144 (256KiB)
Max size 8388608 (8MiB)
Max queues on device 1
Max events on device 1024
Prefer user sync for interop Yes
Number of P2P devices (AMD) 0
P2P devices (AMD) <printDeviceInfo:144: get number of CL_DEVICE_P2P_DEVICES_AMD : error -30>
Profiling timer resolution 1ns
Profiling timer offset since Epoch (AMD) 1584024351514805324ns (Thu Mar 12 14:45:51 2020)
Execution capabilities
Run OpenCL kernels Yes
Run native kernels No
Thread trace supported (AMD) Yes
Number of async queues (AMD) 4
Max real-time compute queues (AMD) 0
Max real-time compute units (AMD) 0
printf() buffer size 4194304 (4MiB)
Built-in kernels
Device Extensions cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_fp16 cl_khr_gl_sharing cl_khr_gl_depth_images cl_amd_device_attribute_query cl_amd_media_ops cl_amd_media_ops2 cl_khr_image2d_from_buffer cl_khr_subgroups cl_khr_gl_event cl_khr_depth_images cl_khr_mipmap_image cl_khr_mipmap_image_writes cl_amd_copy_buffer_p2p
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [AMD]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
Device Name gfx1010
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) Success (1)
Device Name gfx1010
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
Device Name gfx1010Code: Select all
Vendor: Advanced Micro Devices, Inc. (1002)
Driver: 3004.6 (PAL,LC)
Profile: FULL_PROFILE
Version: OpenCL 2.0 AMD-APP (3004.6)
Max compute units: 20
Max workgroup size: 256
Global memory: 8573157376
Max allocation: 4244635648
OpenCL compiler flags: -DDEEP_PREPROC_UNROLL -DVERY_EXPENSIVE_BRANCHES -DDEEP_VLIW
Loading kernel binary f8a888b62c1baed45f0e6f867c20d99b.oclbin
Grid size: 2560x4096
Modular inverse: 5120 threads, 2048 ops each
Using OpenCL prefix matcher
