Hi
I am a newbie, registered and started folding yesterday. I have an issue with the web control page which keeps reloading every second or so. I can see on the FAH control app things are running and several WU were completed. and should complete a couple more this morning.
Also because the web control is not loading properly i cant change the setting to only when idle. This is causing issues because the machine is working at full speed.
Can you suggested how to fix this. I cant see any way to uninstall where is this to be found.
I have tried various web browsers and they all have the same problem
regards
lapman
Web Control not loading correctly and resets immediately
Re: Web Control not loading correctly and resets immediately
Update
this is the log
12:54:14:WU00:FS00:0xa7:Completed 325000 out of 2500000 steps (13%)
12:54:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
12:54:20:WU01:FS01:0x22:Completed 3700000 out of 5000000 steps (74%)
Running Firefox and Web Control seems to be OK at the moment
FAH working as normal
any comments ?
lapman
this is the log
any comments ?
lapman
Don't worry about ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host", it's not a fatal error. I think it caused when you close Webcontrol or the Viewer ...
If Webcontrol is not working well, first workaround is to try to open it with another browser. Second workaround is to use FAHControl instead (Advance Control from contextual menu after a right click on icon in Task Bar).
The setting "only when idle" might cause other issues, like checkpoint corruptions because of the multiple pause/resume it causes ... use at own risk.
...toTOW wrote:Don't worry about ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host", it's not a fatal error. I think it caused when you close Webcontrol or the Viewer ...
or several other things.
I have the same issue when using Opera to run the Web Control Client. Try using another browser. (Using Edge fixed it for me)
