L0nerism
Posts: 3 Joined: Sat Nov 22, 2014 10:07 am
Post
by L0nerism » Thu Mar 12, 2020 2:45 am
Finally pulled the 11746 work unit today to find this error after the download. I'm on the latest driver 20.2.2 released on March 5th. The smaller COVID-19 work units run fine as it's working on P11745 as I type this (about to finish). Here's the log with the error it throws.
Hope this helps sort this out although maybe it's an AMD driver issue instead. If this is the wrong forum section feel free to move it.
*********************** Log Started 2020-03-12T01:07:47Z ***********************
01:08:27:FS01:Unpaused
01:08:28:WU01:FS01:Connecting to 65.254.110.245:8080
01:08:28:WU01:FS01:Assigned to work server 140.163.4.241
01:08:28:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Vega 10 XL/XT [Radeon RX Vega 56/64] from 140.163.4.241
01:08:28:WU01:FS01:Connecting to 140.163.4.241:8080
01:08:29:FS01:Finishing
01:08:30:WU01:FS01:Downloading 86.24MiB
01:08:36:WU01:FS01:Download 12.97%
01:08:42:WU01:FS01:Download 52.62%
01:08:48:WU01:FS01:Download 86.10%
01:08:50:WU01:FS01:Download complete
01:08:51:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11746 run:0 clone:1449 gen:6 core:0x22 unit:0x0000000a8ca304f15e67f8ab7d5e6a43
01:08:51:WU01:FS01:Starting
01:08:51:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Andrew\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 1708 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:08:51:WU01:FS01:Started FahCore on PID 11220
01:08:51:WU01:FS01:Core PID:7736
01:08:51:WU01:FS01:FahCore 0x22 started
01:08:51:WU01:FS01:0x22:*********************** Log Started 2020-03-12T01:08:51Z ***********************
01:08:51:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:08:51:WU01:FS01:0x22: Type: 0x22
01:08:51:WU01:FS01:0x22: Core: Core22
01:08:51:WU01:FS01:0x22: Website: https://foldingathome.org/
01:08:51:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
01:08:51:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
01:08:51:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
01:08:51:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 11220 -checkpoint 10
01:08:51:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:08:51:WU01:FS01:0x22: Config: <none>
01:08:51:WU01:FS01:0x22:************************************ Build *************************************
01:08:51:WU01:FS01:0x22: Version: 0.0.2
01:08:51:WU01:FS01:0x22: Date: Dec 6 2019
01:08:51:WU01:FS01:0x22: Time: 21:30:31
01:08:51:WU01:FS01:0x22: Repository: Git
01:08:51:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
01:08:51:WU01:FS01:0x22: Branch: HEAD
01:08:51:WU01:FS01:0x22: Compiler: Visual C++ 2008
01:08:51:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:08:51:WU01:FS01:0x22: Platform: win32 10
01:08:51:WU01:FS01:0x22: Bits: 64
01:08:51:WU01:FS01:0x22: Mode: Release
01:08:51:WU01:FS01:0x22:************************************ System ************************************
01:08:51:WU01:FS01:0x22: CPU: AMD Ryzen 7 1700 Eight-Core Processor
01:08:51:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
01:08:51:WU01:FS01:0x22: CPUs: 16
01:08:51:WU01:FS01:0x22: Memory: 15.94GiB
01:08:51:WU01:FS01:0x22:Free Memory: 12.07GiB
01:08:51:WU01:FS01:0x22: Threads: WINDOWS_THREADS
01:08:51:WU01:FS01:0x22: OS Version: 6.2
01:08:51:WU01:FS01:0x22:Has Battery: false
01:08:51:WU01:FS01:0x22: On Battery: false
01:08:51:WU01:FS01:0x22: UTC Offset: -4
01:08:51:WU01:FS01:0x22: PID: 7736
01:08:51:WU01:FS01:0x22: CWD: C:\Users\Andrew\AppData\Roaming\FAHClient\work
01:08:51:WU01:FS01:0x22: OS: Windows 10 Home
01:08:51:WU01:FS01:0x22: OS Arch: AMD64
01:08:51:WU01:FS01:0x22:********************************************************************************
01:08:51:WU01:FS01:0x22:Project: 11746 (Run 0, Clone 1449, Gen 6)
01:08:51:WU01:FS01:0x22:Unit: 0x0000000a8ca304f15e67f8ab7d5e6a43
01:08:51:WU01:FS01:0x22:Reading tar file core.xml
01:08:51:WU01:FS01:0x22:Reading tar file integrator.xml
01:08:51:WU01:FS01:0x22:Reading tar file state.xml
01:08:52:WU01:FS01:0x22:Reading tar file system.xml
01:08:53:WU01:FS01:0x22:Digital signatures verified
01:08:53:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:08:53:WU01:FS01:0x22:Version 0.0.2
01:09:10:WU01:FS01:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
01:09:10:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
01:09:10:WU01:FS01:0x22:Saving result file science.log
01:09:10:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
01:09:11:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:09:11:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11746 run:0 clone:1449 gen:6 core:0x22 unit:0x0000000a8ca304f15e67f8ab7d5e6a43
01:09:11:WU01:FS01:Uploading 8.00KiB to 140.163.4.241
01:09:11:WU01:FS01:Connecting to 140.163.4.241:8080
01:09:24:WU01:FS01:Upload complete
01:09:24:WU01:FS01:Server responded WORK_ACK (400)
01:09:24:WU01:FS01:Cleaning up
Posts: 6458 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Thu Mar 12, 2020 11:32 pm
Does it fail for every p11746 WUs ? If it fine with other Core 22 projects ?
L0nerism
Post
by L0nerism » Thu Mar 12, 2020 11:49 pm
I've completed four of the other Core22 projects successfully, 11737, 11741, 11745, and 11749.
JakeshiCZ
Posts: 1 Joined: Mon Mar 16, 2020 2:39 pm
Post
by JakeshiCZ » Mon Mar 16, 2020 2:42 pm
4 WU from p11746 downloaded yesterday and today, and everyone was ¨faulty. AMD FX-8350 and Radeon RX580 on Win 10.
14:34:00:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11746 run:0 clone:885 gen:9 core:0x22 unit:0x0000000e8ca304f15e67f3e3ea14fd2b
14:34:00:WU01:FS01:Starting
14:34:00:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\petrb\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12216 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:34:00:WU01:FS01:Started FahCore on PID 7636
14:34:00:WU01:FS01:Core PID:10828
14:34:00:WU01:FS01:FahCore 0x22 started
14:34:01:WU01:FS01:0x22:*********************** Log Started 2020-03-16T14:34:00Z ***********************
14:34:01:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
14:34:01:WU01:FS01:0x22: Type: 0x22
14:34:01:WU01:FS01:0x22: Core: Core22
14:34:01:WU01:FS01:0x22: Website: https://foldingathome.org/
14:34:01:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
14:34:01:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:34:01:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
14:34:01:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 7636 -checkpoint 15
14:34:01:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
14:34:01:WU01:FS01:0x22: Config: <none>
14:34:01:WU01:FS01:0x22:************************************ Build *************************************
14:34:01:WU01:FS01:0x22: Version: 0.0.2
14:34:01:WU01:FS01:0x22: Date: Dec 6 2019
14:34:01:WU01:FS01:0x22: Time: 21:30:31
14:34:01:WU01:FS01:0x22: Repository: Git
14:34:01:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
14:34:01:WU01:FS01:0x22: Branch: HEAD
14:34:01:WU01:FS01:0x22: Compiler: Visual C++ 2008
14:34:01:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:34:01:WU01:FS01:0x22: Platform: win32 10
14:34:01:WU01:FS01:0x22: Bits: 64
14:34:01:WU01:FS01:0x22: Mode: Release
14:34:01:WU01:FS01:0x22:************************************ System ************************************
14:34:01:WU01:FS01:0x22: CPU: AMD FX(tm)-8350 Eight-Core Processor
14:34:01:WU01:FS01:0x22: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
14:34:01:WU01:FS01:0x22: CPUs: 8
14:34:01:WU01:FS01:0x22: Memory: 15.90GiB
14:34:01:WU01:FS01:0x22:Free Memory: 9.42GiB
14:34:01:WU01:FS01:0x22: Threads: WINDOWS_THREADS
14:34:01:WU01:FS01:0x22: OS Version: 6.2
14:34:01:WU01:FS01:0x22:Has Battery: false
14:34:01:WU01:FS01:0x22: On Battery: false
14:34:01:WU01:FS01:0x22: UTC Offset: 1
14:34:01:WU01:FS01:0x22: PID: 10828
14:34:01:WU01:FS01:0x22: CWD: C:\Users\petrb\AppData\Roaming\FAHClient\work
14:34:01:WU01:FS01:0x22: OS: Windows 10 Pro
14:34:01:WU01:FS01:0x22: OS Arch: AMD64
14:34:01:WU01:FS01:0x22:********************************************************************************
14:34:01:WU01:FS01:0x22:Project: 11746 (Run 0, Clone 885, Gen 9)
14:34:01:WU01:FS01:0x22:Unit: 0x0000000e8ca304f15e67f3e3ea14fd2b
14:34:01:WU01:FS01:0x22:Reading tar file core.xml
14:34:01:WU01:FS01:0x22:Reading tar file integrator.xml
14:34:01:WU01:FS01:0x22:Reading tar file state.xml
14:34:01:WU01:FS01:0x22:Reading tar file system.xml
14:34:02:WU01:FS01:0x22:Digital signatures verified
14:34:02:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
14:34:02:WU01:FS01:0x22:Version 0.0.2
14:34:21:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
14:34:33:WU01:FS01:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
14:34:33:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
14:34:33:WU01:FS01:0x22:Saving result file science.log
14:34:33:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
14:34:33:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:34:33:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11746 run:0 clone:885 gen:9 core:0x22 unit:0x0000000e8ca304f15e67f3e3ea14fd2b
somata
Posts: 10 Joined: Mon Jun 16, 2008 2:13 am
Post
by somata » Sat Mar 21, 2020 2:00 am
Same exact issue here on RX 480 8GB and Ryzen 5 1600X. Just updated from Adrenaline 20.2.2 to 20.3.1; issue persists.
Jertzuu
Posts: 31 Joined: Wed Mar 25, 2020 6:25 pm
Hardware configuration: Ryzen 5 2600 @ 4,1GHz G.Skill Trident Z RGB 3200mHz CL14 32Gb Asus Prime X470-PRO Zotac AMP! Extreme 1080 Ti Samsung Evo 970 250Gb NVMe M.2 Samsung Evo 860 500Gb SSD WD Black 1Tb 7200RPM HDD
Post
by Jertzuu » Wed Mar 25, 2020 6:35 pm
I have the same problem with my Ryzen 5 2600 and GTX 1080 Ti. Any fix to this?
CPU projects work fine, but GPU projects don't.
8:31:21:WU03:FS01:0x22:************************************ System ************************************
18:31:21:WU03:FS01:0x22: CPU: AMD Ryzen 5 2600 Six-Core Processor
18:31:21:WU03:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
18:31:21:WU03:FS01:0x22: CPUs: 12
18:31:21:WU03:FS01:0x22: Memory: 31.92GiB
18:31:21:WU03:FS01:0x22:Free Memory: 26.33GiB
18:31:21:WU03:FS01:0x22: Threads: WINDOWS_THREADS
18:31:21:WU03:FS01:0x22: OS Version: 6.2
18:31:21:WU03:FS01:0x22:Has Battery: false
18:31:21:WU03:FS01:0x22: On Battery: false
18:31:21:WU03:FS01:0x22: UTC Offset: 2
18:31:21:WU03:FS01:0x22: PID: 9028
18:31:21:WU03:FS01:0x22: CWD: C:\Users\jeret\AppData\Roaming\FAHClient\work
18:31:21:WU03:FS01:0x22: OS: Windows 10 Pro
18:31:21:WU03:FS01:0x22: OS Arch: AMD64
18:31:21:WU03:FS01:0x22:********************************************************************************
18:31:21:WU03:FS01:0x22:Project: 11751 (Run 0, Clone 1657, Gen 15)
18:31:21:WU03:FS01:0x22:Unit: 0x000000188ca304e75e6a8042a056d388
18:31:21:WU03:FS01:0x22:Reading tar file core.xml
18:31:21:WU03:FS01:0x22:Reading tar file integrator.xml
18:31:21:WU03:FS01:0x22:Reading tar file state.xml
18:31:22:WU03:FS01:0x22:Reading tar file system.xml
18:31:23:WU03:FS01:0x22:Digital signatures verified
18:31:23:WU03:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:31:23:WU03:FS01:0x22:Version 0.0.2
18:31:36:WU03:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:31:36:WU03:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:31:50:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:31:50:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
18:32:02:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:32:02:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
18:32:13:WU03:FS01:0x22:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
18:32:13:WU03:FS01:0x22:Following exception occured: Particle coordinate is nan
18:32:13:WU03:FS01:0x22:ERROR:114: Max Retries Reached
18:32:13:WU03:FS01:0x22:Saving result file ..\logfile_01.txt
18:32:13:WU03:FS01:0x22:Saving result file badstate-0.xml
18:32:16:WU03:FS01:0x22:Saving result file badstate-1.xml
18:32:18:WU03:FS01:0x22:Saving result file badstate-2.xml
18:32:20:WU03:FS01:0x22:Saving result file checkpt.crc
18:32:20:WU03:FS01:0x22:Saving result file science.log
18:32:20:WU03:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
18:32:21:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:32:21:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11751 run:0 clone:1657 gen:15 core:0x22 unit:0x000000188ca304e75e6a8042a056d388
18:32:21:WU03:FS01:Uploading 56.35KiB to 140.163.4.231
dfgirl12
Posts: 38 Joined: Fri Aug 21, 2009 8:34 am
Post
by dfgirl12 » Wed Mar 25, 2020 11:19 pm
For the AMD GPU: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5) issue:
viewtopic.php?f=81&t=32771
viewtopic.php?f=74&t=32991 (This one mentions: "Researchers are looking into disabling those projects on AMD GPUs until fix has been found.")
kwerboom
Posts: 62 Joined: Mon Dec 12, 2011 7:31 pm
Post
by kwerboom » Thu Mar 26, 2020 8:44 am
Came to report I'm having the same problem with my Vega 56.
07:51:38:WU01:FS00:Downloading 13.15MiB
07:51:44:WU01:FS00:Download 49.92%
07:51:50:WU01:FS00:Download 98.42%
07:51:50:WU01:FS00:Download complete
07:51:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11746 run:0 clone:2422 gen:7 core:0x22 unit:0x000000108ca304f15e67ffa330afa5f6
07:51:50:WU01:FS00:Starting
07:51:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keith\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10628 -checkpoint 9 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:51:50:WU01:FS00:Started FahCore on PID 16092
07:51:50:WU01:FS00:Core PID:20964
07:51:50:WU01:FS00:FahCore 0x22 started
07:51:50:WU01:FS00:0x22:*********************** Log Started 2020-03-26T07:51:50Z ***********************
07:51:50:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
07:51:50:WU01:FS00:0x22: Type: 0x22
07:51:50:WU01:FS00:0x22: Core: Core22
07:51:50:WU01:FS00:0x22: Website: https://foldingathome.org/
07:51:50:WU01:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
07:51:50:WU01:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:51:50:WU01:FS00:0x22: <rafal.wiewiora@choderalab.org>
07:51:50:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 16092 -checkpoint 9
07:51:50:WU01:FS00:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
07:51:50:WU01:FS00:0x22: Config: <none>
07:51:50:WU01:FS00:0x22:************************************ Build *************************************
07:51:50:WU01:FS00:0x22: Version: 0.0.2
07:51:50:WU01:FS00:0x22: Date: Dec 6 2019
07:51:50:WU01:FS00:0x22: Time: 21:30:31
07:51:50:WU01:FS00:0x22: Repository: Git
07:51:50:WU01:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
07:51:50:WU01:FS00:0x22: Branch: HEAD
07:51:50:WU01:FS00:0x22: Compiler: Visual C++ 2008
07:51:50:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:51:50:WU01:FS00:0x22: Platform: win32 10
07:51:50:WU01:FS00:0x22: Bits: 64
07:51:50:WU01:FS00:0x22: Mode: Release
07:51:50:WU01:FS00:0x22:************************************ System ************************************
07:51:50:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
07:51:50:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:51:50:WU01:FS00:0x22: CPUs: 8
07:51:50:WU01:FS00:0x22: Memory: 15.94GiB
07:51:50:WU01:FS00:0x22:Free Memory: 7.72GiB
07:51:50:WU01:FS00:0x22: Threads: WINDOWS_THREADS
07:51:50:WU01:FS00:0x22: OS Version: 6.2
07:51:50:WU01:FS00:0x22:Has Battery: false
07:51:50:WU01:FS00:0x22: On Battery: false
07:51:50:WU01:FS00:0x22: UTC Offset: -5
07:51:50:WU01:FS00:0x22: PID: 20964
07:51:50:WU01:FS00:0x22: CWD: C:\Users\Keith\AppData\Roaming\FAHClient\work
07:51:50:WU01:FS00:0x22: OS: Windows 10 Pro
07:51:50:WU01:FS00:0x22: OS Arch: AMD64
07:51:50:WU01:FS00:0x22:********************************************************************************
07:51:50:WU01:FS00:0x22:Project: 11746 (Run 0, Clone 2422, Gen 7)
07:51:50:WU01:FS00:0x22:Unit: 0x000000108ca304f15e67ffa330afa5f6
07:51:50:WU01:FS00:0x22:Reading tar file core.xml
07:51:50:WU01:FS00:0x22:Reading tar file integrator.xml
07:51:50:WU01:FS00:0x22:Reading tar file state.xml
07:51:52:WU01:FS00:0x22:Reading tar file system.xml
07:51:52:WU01:FS00:0x22:Digital signatures verified
07:51:52:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
07:51:52:WU01:FS00:0x22:Version 0.0.2
07:52:05:WU01:FS00:0x22:ERROR:exception: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5)
07:52:05:WU01:FS00:0x22:Saving result file ..\logfile_01.txt
07:52:05:WU01:FS00:0x22:Saving result file science.log
07:52:05:WU01:FS00:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
07:52:06:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:52:06:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:11746 run:0 clone:2422 gen:7 core:0x22 unit:0x000000108ca304f15e67ffa330afa5f6
07:52:06:WU01:FS00:Uploading 2.60KiB to 140.163.4.241
lars766
Posts: 1 Joined: Thu Mar 26, 2020 1:19 pm
Post
by lars766 » Thu Mar 26, 2020 1:22 pm
Same here Vega 56 is either idle or will instantly stop because of BAD_WORK_UNIT
MrFrizzy
Posts: 123 Joined: Fri Feb 14, 2020 4:48 am
Post
by MrFrizzy » Thu Mar 26, 2020 8:23 pm
dfgirl12 wrote: For the AMD GPU: Error invoking kernel sortShortList: clEnqueueNDRangeKernel (-5) issue:
To comment specifically on these linked posts, Navi based cards (RX 5500 to 5700 XT) don't appear to be running into the kernel sortShortList message and are folding these projects just fine.
This seems to be happening a bunch on GCN based cards. I have seen as old as the R290 to the Vega cards exhibiting this issue.
Thus far, I haven not seen any reports on a nVidia card with the kernel message. Jertzuu's report with the 1080ti shows a different error message than the kernel sortShortList message and I think should be looked into separately.
