Failed to connect to 192 dot 0 dot 2 dot 1
Oppie
Post by Oppie »
17:39:36:WU01:FS01:Connecting to 65.254.110.245:8080
17:39:36:WU01:FS01:Assigned to work server 192.0.2.1
17:39:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Wrestler [Radeon HD 7340] from 192.0.2.1
17:39:36:WU01:FS01:Connecting to 192.0.2.1:8080
17:39:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:39:58:WU01:FS01:Connecting to 192.0.2.1:80
17:40:19:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
traceroute to 192.0.2.1 (192.0.2.1), 30 hops max, 60 byte packets
 1  _gateway (192.168.0.1)  0.613 ms  1.142 ms  1.151 ms
 2  96.120.40.193 (96.120.40.193)  30.438 ms  30.466 ms  30.983 ms
 3  96.110.113.5 (96.110.113.5)  36.172 ms  36.190 ms  36.720 ms
 4  96.108.21.90 (96.108.21.90)  36.718 ms  36.690 ms  36.664 ms
 5  be-5-ar02.pontiac.mi.michigan.comcast.net (162.151.146.181)  36.654 ms  36.627 ms  38.782 ms
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
Re: Failed to connect to 192 dot 0 dot 2 dot 1
Attempted connections to 192.0.2.1 are poorly documented, but it probably indicates that FAH has not properly configured a GPU. Posting the first 200 lines of FAH's log will allow us to help you (see below).
That may not be necessary inasmuch as the Radeon HD 7340 is no longer supported. FAH uses mostly single-precision, but a relatively small percentage of double-precision operations are required. The Radeon HD 7340 does not support it.
When a GPU is assigned to 192.0.2.1, it means that it is not capable of running FAH. It is usually because it doesn't support Double Precision computation.
You can remove the GPU slot and contribute with a CPU slot.
Oppie
Post by Oppie »
Source Registry
ARIN
Net Range
192.0.2.0 - 192.0.2.255
CIDR
192.0.2.0/24
Name
TEST-NET-1
Handle
NET-192-0-2-0-1
Parent
NET-192-0-0-0-0
Net Type
not provided
Origin AS
not provided
Registration
Mon, 29 Jun 2009 15:15:30 GMT (Mon Jun 29 2009 local time)
Last Changed
Fri, 30 Aug 2013 17:09:21 GMT (Fri Aug 30 2013 local time)
Comments
Addresses starting with "192.0.2.", "198.51.100.", or "203.0.113." are reserved for use in documentation and sample configurations. They should never be used in a live network configuration. No one has permission to use these addresses on the Internet.
Network operators should add these address blocks to the list of non-routable address space, and if packet filters are deployed, then these address blocks should be added to packet filters. These blocks are not for local use, and the filters may be used in both local and public contexts.
These addresses are assigned by the IETF, the organization that develops Internet protocols, in the Informational document RFC 5737, which can be found at:
http://datatracker.ietf.org/doc/rfc5737
Self
https://rdap.arin.net/registry/ip/192.0.2.0
Alternate
https://whois.arin.net/rest/net/NET-192-0-2-0-1
Port 43 Whois
whois.arin.net
