Error getting first install going Win 7
ACCR
Post by ACCR »
Errors are occurring that cause the yellow rather than the green Ready "light" to show in my Windows 7 Advanced Client Control window. It never appears to connect and start Folding. Folding Slots show as Ready and Work Que shows as downloading with progress as 0...
Any comments or suggestions from anyone??
Thanks in advance.
Alex
*********************** Log Started 2020-03-09T21:31:38Z ***********************
21:31:38:************************* Folding@home Client *************************
21:31:38:      Website: https://foldingathome.org/
21:31:38:    Copyright: (c) 2009-2018 foldingathome.org
21:31:38:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:31:38:         Args: --open-web-control
21:31:38:       Config: <none>
21:31:38:******************************** Build ********************************
21:31:38:      Version: 7.5.1
21:31:38:         Date: May 11 2018
21:31:38:         Time: 13:06:32
21:31:38:   Repository: Git
21:31:38:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:31:38:       Branch: master
21:31:38:     Compiler: Visual C++ 2008
21:31:38:      Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:31:38:     Platform: win32 10
21:31:38:         Bits: 32
21:31:38:         Mode: Release
21:31:38:******************************* System ********************************
21:31:38:          CPU: Intel(R) Core(TM)2 Duo CPU T6570 @ 2.10GHz
21:31:38:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
21:31:38:         CPUs: 2
21:31:38:       Memory: 2.84GiB
21:31:38:  Free Memory: 1.01GiB
21:31:38:      Threads: WINDOWS_THREADS
21:31:38:   OS Version: 6.1
21:31:38:  Has Battery: true
21:31:38:   On Battery: false
21:31:38:   UTC Offset: -5
21:31:38:          PID: 2888
21:31:38:          CWD: C:\Users\Weather\AppData\Roaming\FAHClient
21:31:38:           OS: Windows 7 Professional Service Pack 1
21:31:38:      OS Arch: X86
21:31:38:         GPUs: 0
21:31:38:         CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
21:31:38:               specified module could not be found.
21:31:38:
21:31:38:       OpenCL: Not detected: Failed to open dynamic library 'OpenCL.dll': The
21:31:38:
21:31:38:Win32 Service: false
21:31:38:***********************************************************************
21:31:38:<config>
21:31:38:  <!-- Folding Slots -->
21:31:38:</config>
21:31:38:Connecting to assign1.foldingathome.org:8080
21:31:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:31:59:Connecting to assign2.foldingathome.org:80
21:32:21:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
21:32:21:Trying to access database...
21:32:21:Successfully acquired database lock
21:32:21:Enabled folding slot 00: PAUSED cpu:0 (not configured)
21:32:24:12:127.0.0.1:New Web connection
21:32:25:33:127.0.0.1:New Web connection
21:32:56:Set client configured
21:32:56:WU00:FS00:Connecting to 65.254.110.245:8080
21:33:18:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:33:18:WU00:FS00:Connecting to 18.218.241.186:80
21:33:22:Saving configuration to config.xml
21:33:22:<config>
21:33:22:  <!-- Folding Slots -->
21:33:22:  <slot id='0' type='CPU'/>
21:33:22:</config>
21:33:39:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:33:39:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:33:40:WU00:FS00:Connecting to 65.254.110.245:8080
21:33:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:33:59:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:33:59:WU00:FS00:Connecting to 18.218.241.186:80
21:34:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:34:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:34:20:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:34:20:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:34:23:Saving configuration to config.xml
21:34:23:<config>
21:34:23:  <!-- Slot Control -->
21:34:23:  <power v='MEDIUM'/>
21:34:23:
21:34:23:  <!-- Folding Slots -->
21:34:23:  <slot id='0' type='CPU'/>
21:34:23:</config>
21:34:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:35:17:WU00:FS00:Connecting to 65.254.110.245:8080
21:35:38:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:35:38:WU00:FS00:Connecting to 18.218.241.186:80
21:35:46:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:36:00:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:36:00:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:36:38:Connecting to assign1.foldingathome.org:8080
21:36:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:36:59:Connecting to assign2.foldingathome.org:80
21:37:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
21:37:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:37:54:WU00:FS00:Connecting to 65.254.110.245:8080
21:38:15:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:38:15:WU00:FS00:Connecting to 18.218.241.186:80
21:38:37:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:38:37:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:41:38:Connecting to assign1.foldingathome.org:8080
21:41:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:41:59:Connecting to assign2.foldingathome.org:80
21:42:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
21:42:20:WU00:FS00:Connecting to 65.254.110.245:8080
21:42:21:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
21:42:22:ERROR:Send error: 10053: An established connection was aborted by the software in your host machine.
21:42:39:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:42:39:WU00:FS00:Connecting to 18.218.241.186:80
21:42:58:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:42:58:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:46:38:Connecting to assign1.foldingathome.org:8080
21:46:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:46:59:Connecting to assign2.foldingathome.org:80
21:47:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
21:49:12:WU00:FS00:Connecting to 65.254.110.245:8080
21:49:33:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
21:49:33:WU00:FS00:Connecting to 18.218.241.186:80
21:49:54:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
21:49:54:ERROR:WU00:FS00:Exception: Could not get an assignment ID
21:51:38:Connecting to assign1.foldingathome.org:8080
21:51:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:51:59:Connecting to assign2.foldingathome.org:80
21:52:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
21:56:38:Connecting to assign1.foldingathome.org:8080
21:56:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
21:56:59:Connecting to assign2.foldingathome.org:80
21:57:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:00:17:WU00:FS00:Connecting to 65.254.110.245:8080
22:00:39:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
22:00:39:WU00:FS00:Connecting to 18.218.241.186:80
22:01:00:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
22:01:00:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:01:38:Connecting to assign1.foldingathome.org:8080
22:01:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:01:59:Connecting to assign2.foldingathome.org:80
22:02:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:06:38:Connecting to assign1.foldingathome.org:8080
22:06:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:06:59:Connecting to assign2.foldingathome.org:80
22:07:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:11:38:Connecting to assign1.foldingathome.org:8080
22:11:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:11:59:Connecting to assign2.foldingathome.org:80
22:12:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:16:38:Connecting to assign1.foldingathome.org:8080
22:16:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:16:59:Connecting to assign2.foldingathome.org:80
22:17:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:18:14:WU00:FS00:Connecting to 65.254.110.245:8080
22:18:35:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
22:18:35:WU00:FS00:Connecting to 18.218.241.186:80
22:18:57:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
22:18:57:ERROR:WU00:FS00:Exception: Could not get an assignment ID
22:21:38:Connecting to assign1.foldingathome.org:8080
22:21:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:21:59:Connecting to assign2.foldingathome.org:80
22:22:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:26:38:Connecting to assign1.foldingathome.org:8080
22:26:59:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
22:26:59:Connecting to assign2.foldingathome.org:80
22:27:20:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
22:27:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: Error getting first install going Win 7
Something (proxy, firewall, security software, ...) between you and the FAH servers is interfering with your connection. How do connect to the Internet ?
ACCR
Post by ACCR »
Thanks for the response
I connect through a SonicWall firewall.
FAHClient needs to connect to the internet with the same security settings used by browsers. Traditional browsers are recognized by default but you'll probably have to enable a firewall exception for FAHClient.
ACCR
Post by ACCR »
What ports do I need to add as exceptions to my router?? Is the FAHClient using port 80??
FAHClient is using port 8080 by preference and falls back to using port 80. The client uses http for transfers just like a web browser.
ACCR
Post by ACCR »
Based on it using port 80 as a fallback, it should work, yet it doesn't.... Web browsers work just fine.
Did you disable your firewall to test if it helps ?
Some firewall/proxies don't like software that attempt connections directly to IP instead of using DNS.
simonk1969
Post by simonk1969 »
I've just had the same issue on Windows 10, I've just added exceptions to the Windows firewall for the program FAHClient. Instantly resolved the issue, that's probably all you need to do in your sonic firewall.
