Hi everybody,
recently I started folding (normally I only do RC5-72 or OGR and once a year a stampede with the Dutch Power Cows) but I came to a weird "bug", the gpu stays around 80% usage (currently it's hovering around 82%) and Task manager in windows 10 (compute_1) show 84%. If I run the dnet gpu client, the usage jumps directly to 98% and stays there until the wu is done then it jumps down and directly back up to 98%.
I tested an older card (HD7990) to and no problems there, the 2 core's jumping directly to 98%.
Its like something is holding it around 80% usage.
I've tried setting the core-priority to normal and high but no change also priority changed to normal and high but no change
Anybody knows what's going on here?
[s]*I've got some screenshots but can't post them yet[/s]
Edit: after approved topic
I've got the latest drivers for the gpu: Adrenalin 2020 Edition 20.2.2 Recommended
RX5700XT Usage stays around 84%
Re: RX5700XT Usaga stays around 84%
Some FAH work units are too small to fill all shaders of RX5700XT. So you just need to wait for other bigger work units.
task manager shows CPU utilization, not GPU. GPU-Z can show GPU utilization.
But, if you GPU is working, then one CPU core is reserved to help, so you would have 50% CPU plus whatever it took to help.
This thread should help you show us the log, so we can make better guesses than I just did.
viewtopic.php?f=24&t=26036
Jimbo: Taskman in windows 10 do show GPU compute/3d/encode/decode/... utilisation
https://i.imgur.com/zZlsIBd.png
Anyway the screenshots:
HD7990: https://i.imgur.com/YbjD9Dl.png
RX5700XT: https://i.imgur.com/vw1Mrt2.png
edit log file:
Edit 2: jeeej larger wu's now it goes to 90% pffff
edit log file:
*********************** Log Started 2020-03-10T17:14:47Z ***********************
17:14:47:************************* Folding@home Client *************************
17:14:47: Website: https://foldingathome.org/
17:14:47: Copyright: (c) 2009-2018 foldingathome.org
17:14:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:14:47: Args: --open-web-control
17:14:47: Config: e:\FAHClient\data\config.xml
17:14:47:******************************** Build ********************************
17:14:47: Version: 7.5.1
17:14:47: Date: May 11 2018
17:14:47: Time: 13:06:32
17:14:47: Repository: Git
17:14:47: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:14:47: Branch: master
17:14:47: Compiler: Visual C++ 2008
17:14:47: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:14:47: Platform: win32 10
17:14:47: Bits: 32
17:14:47: Mode: Release
17:14:47:******************************* System ********************************
17:14:47: CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
17:14:47: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
17:14:47: CPUs: 32
17:14:47: Memory: 15.88GiB
17:14:47: Free Memory: 11.69GiB
17:14:47: Threads: WINDOWS_THREADS
17:14:47: OS Version: 6.2
17:14:47: Has Battery: false
17:14:47: On Battery: false
17:14:47: UTC Offset: 1
17:14:47: PID: 4388
17:14:47: CWD: e:\FAHClient\data
17:14:47: OS: Windows 10 Enterprise
17:14:47: OS Arch: AMD64
17:14:47: GPUs: 1
17:14:47: GPU 0: Bus:68 Slot:0 Func:0 AMD:6 Navi 10 [Radeon RX 5600 OEM/5600 XT
17:14:47: / 5700/5700 XT]
17:14:47: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
17:14:47: specified module could not be found.
17:14:47:
17:14:47:OpenCL Device 0: Platform:0 Device:0 Bus:68 Slot:0 Compute:1.2 Driver:3004.8
17:14:47: Win32 Service: false
17:14:47:***********************************************************************
17:14:47:<config>
17:14:47: <!-- Folding Core -->
17:14:47: <checkpoint v='10'/>
17:14:47: <core-priority v='high'/>
17:14:47:
17:14:47: <!-- Network -->
17:14:47: <proxy v=':8080'/>
17:14:47:
17:14:47: <!-- Slot Control -->
17:14:47: <pause-on-battery v='false'/>
17:14:47: <power v='full'/>
17:14:47:
17:14:47: <!-- User Information -->
17:14:47: <passkey v='********************************'/>
17:14:47: <team v='92'/>
17:14:47: <user v='Damic'/>
17:14:47:
17:14:47: <!-- Folding Slots -->
17:14:47: <slot id='1' type='GPU'/>
17:14:47:</config>
17:14:47:Trying to access database...
17:14:47:Successfully acquired database lock
17:14:47:Enabled folding slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
17:14:47:WU00:FS01:Starting
17:14:47:WU00:FS01:Running FahCore: e:\FAHClient/FAHCoreWrapper.exe e:\FAHClient\data\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 4388 -checkpoint 10 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:14:47:WU00:FS01:Started FahCore on PID 5688
17:14:47:WU00:FS01:Core PID:5868
17:14:47:WU00:FS01:FahCore 0x22 started
17:14:48:WU00:FS01:0x22:*********************** Log Started 2020-03-10T17:14:47Z ***********************
17:14:48:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:14:48:WU00:FS01:0x22: Type: 0x22
17:14:48:WU00:FS01:0x22: Core: Core22
17:14:48:WU00:FS01:0x22: Website: https://foldingathome.org/
17:14:48:WU00:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
17:14:48:WU00:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:14:48:WU00:FS01:0x22: <rafal.wiewiora@choderalab.org>
17:14:48:WU00:FS01:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 5688 -checkpoint 10
17:14:48:WU00:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
17:14:48:WU00:FS01:0x22: Config: <none>
17:14:48:WU00:FS01:0x22:************************************ Build *************************************
17:14:48:WU00:FS01:0x22: Version: 0.0.2
17:14:48:WU00:FS01:0x22: Date: Dec 6 2019
17:14:48:WU00:FS01:0x22: Time: 21:30:31
17:14:48:WU00:FS01:0x22: Repository: Git
17:14:48:WU00:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
17:14:48:WU00:FS01:0x22: Branch: HEAD
17:14:48:WU00:FS01:0x22: Compiler: Visual C++ 2008
17:14:48:WU00:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:14:48:WU00:FS01:0x22: Platform: win32 10
17:14:48:WU00:FS01:0x22: Bits: 64
17:14:48:WU00:FS01:0x22: Mode: Release
17:14:48:WU00:FS01:0x22:************************************ System ************************************
17:14:48:WU00:FS01:0x22: CPU: AMD Ryzen Threadripper 1950X 16-Core Processor
17:14:48:WU00:FS01:0x22: CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
17:14:48:WU00:FS01:0x22: CPUs: 32
17:14:48:WU00:FS01:0x22: Memory: 15.88GiB
17:14:48:WU00:FS01:0x22:Free Memory: 11.66GiB
17:14:48:WU00:FS01:0x22: Threads: WINDOWS_THREADS
17:14:48:WU00:FS01:0x22: OS Version: 6.2
17:14:48:WU00:FS01:0x22:Has Battery: false
17:14:48:WU00:FS01:0x22: On Battery: false
17:14:48:WU00:FS01:0x22: UTC Offset: 1
17:14:48:WU00:FS01:0x22: PID: 5868
17:14:48:WU00:FS01:0x22: CWD: e:\FAHClient\data\work
17:14:48:WU00:FS01:0x22: OS: Windows 10 Pro
17:14:48:WU00:FS01:0x22: OS Arch: AMD64
17:14:48:WU00:FS01:0x22:********************************************************************************
17:14:48:WU00:FS01:0x22:Project: 11737 (Run 0, Clone 1792, Gen 65)
17:14:48:WU00:FS01:0x22:Unit: 0x0000005c8ca304f15dfbe6d96205c086
17:14:48:WU00:FS01:0x22:Reading tar file core.xml
17:14:48:WU00:FS01:0x22:Reading tar file integrator.xml
17:14:48:WU00:FS01:0x22:Reading tar file state.xml
17:14:48:WU00:FS01:0x22:Reading tar file system.xml
17:14:48:WU00:FS01:0x22:Digital signatures verified
17:14:48:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:14:48:WU00:FS01:0x22:Version 0.0.2
17:14:51:15:127.0.0.1:New Web connection
17:15:00:WU00:FS01:0x22:Completed 0 out of 5000000 steps (0%)
17:15:00:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:16:18:WU00:FS01:0x22:Completed 50000 out of 5000000 steps (1%)-
Re: RX5700XT Usage stays around 84%
Yes, AMD GPUs are very sensitive to the number of atoms in projects. Bigger ones work way better and p11737 is quite small.
The assignment servers are not updated yet with new rules for AMD RX5700XT and similar high shader AMD GPUs.
As user your only option would be to run 2 work units on the same GPU to increase usage.
Ow ok, then we just need to wait until they are updated then.
Running two WU on GPU at the same time is often a bad idea on FAH ...
