Hi.
My username s macmsb and from what I can tell I haven’t been active long enough to show up on leaderboard yet.
With that said I was wondering if I can still go straight to my donor stat page like: http stats foldingathome org / donor / #####
Except I don’t have my donor number. Where can I find it?
Thanks
How do I find my user/donor number?
Re: How do I find my user/donor number?
That number will show up once you have completed enough WU's or the periodic update picks up your name and a Donor search on the stats returns data for your username. But that number is subject to change, it is not permanently assigned and can change if/when the database is reorganized.
However a search using https://stats.foldingathome.org/donor/macmsb does work when I tried it now. That is the form used by the link from the Webb Control.
At this point you can also search on your username through some of the links provided at apps.foldinathome.org.
