Everyday my pc does about 70% of a WU, after a week i am at 0.
Everytime FaH starts when my pc as been turned off, it starts again from 0%, like it doesn't save its progress.
This seems not right to me. Any ideas?
I want to give you some computing power, but I don't want to think about it.
I had to register, when i register i have to do a captcha and describe a picture, then the picture doesn't show.
Everything around this project is so anoying to use, do you want to scare people away?
FaH seems to reset every day
Re: FaH seems to reset every day
Here's an update about the captcha issue : viewtopic.php?f=27&t=32211
You're probably running Windows and you probably didn't accept the default installation. As long as FAH is installed by the same user that is going to be logged on, FAH will write checkpoints and will resume from them. You can run 24x7, but if you must shut your computer off, click on PAUSE before shutting down Windows.
It's okay, i just de-installed it.
