ricpdx
Posts: 3 Joined: Sat Mar 07, 2020 9:25 pm
Post
by ricpdx » Sat Mar 07, 2020 9:39 pm
I have been running the F@H client on Win7 for a year or more, iirc, but just within the past month or so it has started crashing multiple times per day. Before that it ran without error for months and months.
I see the Windows EventLogs for the crashes, and I have the F@H log as well. I'll include both here. Tell me if there is more information I can provide.
Thanks in advance for any help you can provide.
Windows EventLog:
Log Name: Application
Source: Application Error
Date: 3/7/2020 12:57:44 PM
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: roseway
Description:
Faulting application name: FahCore_a7.exe, version: 0.0.0.0, time stamp: 0x5db40a96
Faulting module name: FahCore_a7.exe, version: 0.0.0.0, time stamp: 0x5db40a96
Exception code: 0xc0000417
Fault offset: 0x0000000000f155cd
Faulting process id: 0x1f38
Faulting application start time: 0x01d5f4c30b791ce0
Faulting application path: C:\Users\ric\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\v7\win\64bit\avx\Core_a7.fah\FahCore_a7.exe
Faulting module path: C:\Users\ric\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\v7\win\64bit\avx\Core_a7.fah\FahCore_a7.exe
Report Id: 4a7c24ad-60b6-11ea-8691-b8aeed74376b
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-03-07T20:57:44.000000000Z" />
<EventRecordID>85837</EventRecordID>
<Channel>Application</Channel>
<Computer>roseway</Computer>
<Security />
</System>
<EventData>
<Data>FahCore_a7.exe</Data>
<Data>0.0.0.0</Data>
<Data>5db40a96</Data>
<Data>c0000417</Data>
<Data>0000000000f155cd</Data>
<Data>1f38</Data>
<Data>01d5f4c30b791ce0</Data>
<Data>C:\Users\ric\AppData\Roaming\FAHClient\cores\cores.foldingathome.org\v7\win\64bit\avx\Core_a7.fah\FahCore_a7.exe</Data>
<Data>4a7c24ad-60b6-11ea-8691-b8aeed74376b</Data>
</EventData>
</Event>
F@H log:
*********************** Log Started 2020-03-07T18:52:21Z ***********************
18:52:21:************************* Folding@home Client *************************
18:52:21: Website: https://foldingathome.org/
18:52:21: Copyright: (c) 2009-2018 foldingathome.org
18:52:21: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:52:21: Args:
18:52:21: Config: C:\Users\ric\AppData\Roaming\FAHClient\config.xml
18:52:21:******************************** Build ********************************
18:52:21: Version: 7.5.1
18:52:21: Date: May 11 2018
18:52:21: Time: 13:06:32
18:52:21: Repository: Git
18:52:21: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:52:21: Branch: master
18:52:21: Compiler: Visual C++ 2008
18:52:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:52:21: Platform: win32 10
18:52:21: Bits: 32
18:52:21: Mode: Release
18:52:21:******************************* System ********************************
18:52:21: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
18:52:21: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
18:52:21: CPUs: 4
18:52:21: Memory: 15.89GiB
18:52:21: Free Memory: 13.82GiB
18:52:21: Threads: WINDOWS_THREADS
18:52:21: OS Version: 6.1
18:52:21: Has Battery: false
18:52:21: On Battery: false
18:52:21: UTC Offset: -8
18:52:21: PID: 4028
18:52:21: CWD: C:\Users\ric\AppData\Roaming\FAHClient
18:52:21: OS: Windows 7 Professional
18:52:21: OS Arch: AMD64
18:52:21: GPUs: 0
18:52:21: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:52:21: specified module could not be found.
18:52:21:
18:52:21:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
18:52:21: Win32 Service: false
18:52:21:***********************************************************************
18:52:21:<config>
18:52:21: <!-- User Information -->
18:52:21: <team v='169927'/>
18:52:21: <user v='ricb'/>
18:52:21:
18:52:21: <!-- Folding Slots -->
18:52:21: <slot id='0' type='CPU'>
18:52:21: <idle v='true'/>
18:52:21: </slot>
18:52:21:</config>
18:52:21:Trying to access database...
18:52:21:Successfully acquired database lock
18:52:21:Enabled folding slot 00: PAUSED cpu:3 (waiting for idle)
19:29:27:WU01:FS00:Starting
19:29:27:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ric\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4028 -checkpoint 15 -np 3
19:29:27:WU01:FS00:Started FahCore on PID 2840
19:29:27:WU01:FS00:Core PID:8468
19:29:27:WU01:FS00:FahCore 0xa7 started
19:29:27:WU01:FS00:0xa7:*********************** Log Started 2020-03-07T19:29:27Z ***********************
19:29:27:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:29:27:WU01:FS00:0xa7: Type: 0xa7
19:29:27:WU01:FS00:0xa7: Core: Gromacs
19:29:27:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 2840 -checkpoint 15 -np 3
19:29:27:WU01:FS00:0xa7:************************************ CBang *************************************
19:29:27:WU01:FS00:0xa7: Date: Oct 26 2019
19:29:27:WU01:FS00:0xa7: Time: 01:38:25
19:29:27:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:29:27:WU01:FS00:0xa7: Branch: master
19:29:27:WU01:FS00:0xa7: Compiler: Visual C++ 2008
19:29:27:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:29:27:WU01:FS00:0xa7: Platform: win32 10
19:29:27:WU01:FS00:0xa7: Bits: 64
19:29:27:WU01:FS00:0xa7: Mode: Release
19:29:27:WU01:FS00:0xa7:************************************ System ************************************
19:29:27:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
19:29:27:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
19:29:27:WU01:FS00:0xa7: CPUs: 4
19:29:27:WU01:FS00:0xa7: Memory: 15.89GiB
19:29:27:WU01:FS00:0xa7:Free Memory: 9.58GiB
19:29:27:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
19:29:27:WU01:FS00:0xa7: OS Version: 6.1
19:29:27:WU01:FS00:0xa7:Has Battery: false
19:29:27:WU01:FS00:0xa7: On Battery: false
19:29:27:WU01:FS00:0xa7: UTC Offset: -8
19:29:27:WU01:FS00:0xa7: PID: 8468
19:29:27:WU01:FS00:0xa7: CWD: C:\Users\ric\AppData\Roaming\FAHClient\work
19:29:27:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
19:29:27:WU01:FS00:0xa7: Version: 0.0.18
19:29:27:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:29:27:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
19:29:27:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
19:29:27:WU01:FS00:0xa7: Time: 01:52:30
19:29:27:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:29:27:WU01:FS00:0xa7:************************************ Build *************************************
19:29:27:WU01:FS00:0xa7: SIMD: avx_256
19:29:27:WU01:FS00:0xa7:********************************************************************************
19:29:27:WU01:FS00:0xa7:Project: 14400 (Run 0, Clone 3444, Gen 99)
19:29:27:WU01:FS00:0xa7:Unit: 0x0000007280fccb095dcad78a19840631
19:29:27:WU01:FS00:0xa7:Digital signatures verified
19:29:27:WU01:FS00:0xa7:Calling: mdrun -s frame99.tpr -o frame99.trr -x frame99.xtc -cpi state.cpt -cpt 15 -nt 3
19:29:27:WU01:FS00:0xa7:ERROR:Guru Meditation #1d183a5aee13666e.959341f116ca44c0 (3891600.7783200) '01/01/frame99.trr'
19:29:27:WU01:FS00:0xa7:WARNING:Unexpected exit() call
19:29:27:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
19:29:27:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
19:29:27:WU01:FS00:0xa7:Saving result file frame99.trr
20:07:23:FS00:Shutting core down
20:07:35:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:57:42:WU01:FS00:Starting
20:57:42:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ric\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 4028 -checkpoint 15 -np 3
20:57:42:WU01:FS00:Started FahCore on PID 7724
20:57:42:WU01:FS00:Core PID:7992
20:57:42:WU01:FS00:FahCore 0xa7 started
20:57:43:WU01:FS00:0xa7:*********************** Log Started 2020-03-07T20:57:42Z ***********************
20:57:43:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:57:43:WU01:FS00:0xa7: Type: 0xa7
20:57:43:WU01:FS00:0xa7: Core: Gromacs
20:57:43:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 7724 -checkpoint 15 -np 3
20:57:43:WU01:FS00:0xa7:************************************ CBang *************************************
20:57:43:WU01:FS00:0xa7: Date: Oct 26 2019
20:57:43:WU01:FS00:0xa7: Time: 01:38:25
20:57:43:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:57:43:WU01:FS00:0xa7: Branch: master
20:57:43:WU01:FS00:0xa7: Compiler: Visual C++ 2008
20:57:43:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:57:43:WU01:FS00:0xa7: Platform: win32 10
20:57:43:WU01:FS00:0xa7: Bits: 64
20:57:43:WU01:FS00:0xa7: Mode: Release
20:57:43:WU01:FS00:0xa7:************************************ System ************************************
20:57:43:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
20:57:43:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
20:57:43:WU01:FS00:0xa7: CPUs: 4
20:57:43:WU01:FS00:0xa7: Memory: 15.89GiB
20:57:43:WU01:FS00:0xa7:Free Memory: 9.44GiB
20:57:43:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
20:57:43:WU01:FS00:0xa7: OS Version: 6.1
20:57:43:WU01:FS00:0xa7:Has Battery: false
20:57:43:WU01:FS00:0xa7: On Battery: false
20:57:43:WU01:FS00:0xa7: UTC Offset: -8
20:57:43:WU01:FS00:0xa7: PID: 7992
20:57:43:WU01:FS00:0xa7: CWD: C:\Users\ric\AppData\Roaming\FAHClient\work
20:57:43:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
20:57:43:WU01:FS00:0xa7: Version: 0.0.18
20:57:43:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:57:43:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
20:57:43:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
20:57:43:WU01:FS00:0xa7: Time: 01:52:30
20:57:43:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:57:43:WU01:FS00:0xa7:************************************ Build *************************************
20:57:43:WU01:FS00:0xa7: SIMD: avx_256
20:57:43:WU01:FS00:0xa7:********************************************************************************
20:57:43:WU01:FS00:0xa7:Project: 14400 (Run 0, Clone 3444, Gen 99)
20:57:43:WU01:FS00:0xa7:Unit: 0x0000007280fccb095dcad78a19840631
20:57:43:WU01:FS00:0xa7:Digital signatures verified
20:57:43:WU01:FS00:0xa7:Calling: mdrun -s frame99.tpr -o frame99.trr -x frame99.xtc -cpi state.cpt -cpt 15 -nt 3
20:57:43:WU01:FS00:0xa7:ERROR:Guru Meditation #1d183a5aee13666e.959341f116ca44c0 (3891600.7783200) '01/01/frame99.trr'
20:57:43:WU01:FS00:0xa7:WARNING:Unexpected exit() call
20:57:43:WU01:FS00:0xa7:WARNING:Unexpected exit from science code
20:57:43:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
20:57:43:WU01:FS00:0xa7:Saving result file frame99.trr
21:18:35:FS00:Shutting core down
21:19:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Posts: 6501 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Sat Mar 07, 2020 11:24 pm
This sounds like a corrupted checkpoint ... let's try to eliminate this hypothesis first :
- pause your CPU slot (or exit the client)
- go to C:\Users\ric\AppData\Roaming\FAHClient\work
- delete 01 folder
- resume slot (or restart the client)
Does it help to get rid of the errors ?
ricpdx
Post
by ricpdx » Sun Mar 08, 2020 1:40 am
Thanks - carried out those instructions. I'll have to wait and see if crash re-occurs now. Will report back here if it does.
Post
by toTOW » Sun Mar 08, 2020 3:38 pm
If it's working fine after deleting the failing WU, I suggest that you stop using the "fold only when idle" option : using this option starts and stop the processing very often and increases the risk of corrupting a checkpoint.
I also suggest to exit the client manually (right click on icon> exit) before turning off or restating the machine.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Sun Mar 08, 2020 8:16 pm
0xc0000417 and the ERROR:Guru Meditation message indicate that your filesystem was corrupted. FAH discards the offending WU and downloads a new one so a validiation of the entire disk is probably not neede ... though that's up to you.
I have a theory this problem can be caused by FAHCore_a7, depending on what it was actually doing when you shut down/rebooted Windows. Until a new version of FAHCore_a7 is provided, it's fairly simple to follow toTOW's advice and pause the WU or otherwise exit FAH befoe restarting the machine. This will close the files properly.
ricpdx
Post
by ricpdx » Mon Mar 09, 2020 3:41 am
Thanks toTOW and bruce. So it hasn't crashed since I deleted the "01" folder, but computer was off in the morning -- weekdays will be a better test.
I just switched from on-idle to always-on. This disk (an SSD) is a bit low on space, fwiw: 30gb free out of 500gb. I don't think I'll validate the entire disk at this point.
I'll include the current log, in case that's of any interest. Anyway, so far, so good.
So "WU" = "work unit," I take it?
*********************** Log Started 2020-03-09T02:18:21Z ***********************
02:18:21:************************* Folding@home Client *************************
02:18:21: Website: https://foldingathome.org/
02:18:21: Copyright: (c) 2009-2018 foldingathome.org
02:18:21: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:18:21: Args:
02:18:21: Config: C:\Users\ric\AppData\Roaming\FAHClient\config.xml
02:18:21:******************************** Build ********************************
02:18:21: Version: 7.5.1
02:18:21: Date: May 11 2018
02:18:21: Time: 13:06:32
02:18:21: Repository: Git
02:18:21: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:18:21: Branch: master
02:18:21: Compiler: Visual C++ 2008
02:18:21: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:18:21: Platform: win32 10
02:18:21: Bits: 32
02:18:21: Mode: Release
02:18:21:******************************* System ********************************
02:18:21: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
02:18:21: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
02:18:21: CPUs: 4
02:18:21: Memory: 15.89GiB
02:18:21: Free Memory: 13.96GiB
02:18:21: Threads: WINDOWS_THREADS
02:18:21: OS Version: 6.1
02:18:21: Has Battery: false
02:18:21: On Battery: false
02:18:21: UTC Offset: -7
02:18:21: PID: 3904
02:18:21: CWD: C:\Users\ric\AppData\Roaming\FAHClient
02:18:21: OS: Windows 7 Professional
02:18:21: OS Arch: AMD64
02:18:21: GPUs: 0
02:18:21: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
02:18:21: specified module could not be found.
02:18:21:
02:18:21:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:20.19
02:18:21: Win32 Service: false
02:18:21:***********************************************************************
02:18:21:<config>
02:18:21: <!-- User Information -->
02:18:21: <team v='169927'/>
02:18:21: <user v='ricb'/>
02:18:21:
02:18:21: <!-- Folding Slots -->
02:18:21: <slot id='0' type='CPU'>
02:18:21: <idle v='true'/>
02:18:21: </slot>
02:18:21:</config>
02:18:21:Trying to access database...
02:18:21:Successfully acquired database lock
02:18:21:Enabled folding slot 00: PAUSED cpu:3 (waiting for idle)
02:18:29:WU00:FS00:Starting
02:18:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ric\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3904 -checkpoint 15 -np 3
02:18:29:WU00:FS00:Started FahCore on PID 6652
02:18:29:WU00:FS00:Core PID:6696
02:18:29:WU00:FS00:FahCore 0xa7 started
02:18:33:WU00:FS00:0xa7:*********************** Log Started 2020-03-09T02:18:33Z ***********************
02:18:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:18:33:WU00:FS00:0xa7: Type: 0xa7
02:18:33:WU00:FS00:0xa7: Core: Gromacs
02:18:33:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6652 -checkpoint 15 -np 3
02:18:33:WU00:FS00:0xa7:************************************ CBang *************************************
02:18:33:WU00:FS00:0xa7: Date: Oct 26 2019
02:18:33:WU00:FS00:0xa7: Time: 01:38:25
02:18:33:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:18:33:WU00:FS00:0xa7: Branch: master
02:18:33:WU00:FS00:0xa7: Compiler: Visual C++ 2008
02:18:33:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:18:33:WU00:FS00:0xa7: Platform: win32 10
02:18:33:WU00:FS00:0xa7: Bits: 64
02:18:33:WU00:FS00:0xa7: Mode: Release
02:18:33:WU00:FS00:0xa7:************************************ System ************************************
02:18:33:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
02:18:33:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
02:18:33:WU00:FS00:0xa7: CPUs: 4
02:18:33:WU00:FS00:0xa7: Memory: 15.89GiB
02:18:33:WU00:FS00:0xa7:Free Memory: 12.98GiB
02:18:33:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
02:18:33:WU00:FS00:0xa7: OS Version: 6.1
02:18:33:WU00:FS00:0xa7:Has Battery: false
02:18:33:WU00:FS00:0xa7: On Battery: false
02:18:33:WU00:FS00:0xa7: UTC Offset: -7
02:18:33:WU00:FS00:0xa7: PID: 6696
02:18:33:WU00:FS00:0xa7: CWD: C:\Users\ric\AppData\Roaming\FAHClient\work
02:18:33:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:18:33:WU00:FS00:0xa7: Version: 0.0.18
02:18:33:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:18:33:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
02:18:33:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
02:18:33:WU00:FS00:0xa7: Time: 01:52:30
02:18:33:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:18:33:WU00:FS00:0xa7:************************************ Build *************************************
02:18:33:WU00:FS00:0xa7: SIMD: avx_256
02:18:33:WU00:FS00:0xa7:********************************************************************************
02:18:33:WU00:FS00:0xa7:Project: 14190 (Run 24, Clone 130, Gen 2)
02:18:33:WU00:FS00:0xa7:Unit: 0x000000050002894b5d5d2d140fa14d97
02:18:33:WU00:FS00:0xa7:Digital signatures verified
02:18:33:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 3
02:18:39:WU00:FS00:0xa7:Steps: first=2500000 total=1250000
02:18:54:WU00:FS00:0xa7:Completed 149927 out of 1250000 steps (11%)
02:19:19:WU00:FS00:0xa7:Completed 150000 out of 1250000 steps (12%)
02:19:22:Saving configuration to config.xml
02:19:22:<config>
02:19:22: <!-- User Information -->
02:19:22: <team v='169927'/>
02:19:22: <user v='ricb'/>
02:19:22:
02:19:22: <!-- Folding Slots -->
02:19:22: <slot id='0' type='CPU'/>
02:19:22:</config>
03:14:38:WU00:FS00:0xa7:Completed 162500 out of 1250000 steps (13%)
03:25:41:FS00:Shutting core down
03:25:41:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 6696
03:25:41:WU00:FS00:0xa7:Exiting, please wait. . .
03:25:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:25:47:WU00:FS00:Starting
03:25:47:WARNING:WU00:FS00:Changed SMP threads from 3 to 1 this can cause some work units to fail
03:25:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\ric\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3904 -checkpoint 15 -np 1
03:25:47:WU00:FS00:Started FahCore on PID 560
03:25:47:WU00:FS00:Core PID:7728
03:25:47:WU00:FS00:FahCore 0xa7 started
03:25:48:WU00:FS00:0xa7:*********************** Log Started 2020-03-09T03:25:47Z ***********************
03:25:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:25:48:WU00:FS00:0xa7: Type: 0xa7
03:25:48:WU00:FS00:0xa7: Core: Gromacs
03:25:48:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 560 -checkpoint 15 -np 1
03:25:48:WU00:FS00:0xa7:************************************ CBang *************************************
03:25:48:WU00:FS00:0xa7: Date: Oct 26 2019
03:25:48:WU00:FS00:0xa7: Time: 01:38:25
03:25:48:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:25:48:WU00:FS00:0xa7: Branch: master
03:25:48:WU00:FS00:0xa7: Compiler: Visual C++ 2008
03:25:48:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:25:48:WU00:FS00:0xa7: Platform: win32 10
03:25:48:WU00:FS00:0xa7: Bits: 64
03:25:48:WU00:FS00:0xa7: Mode: Release
03:25:48:WU00:FS00:0xa7:************************************ System ************************************
03:25:48:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
03:25:48:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 61 Stepping 4
03:25:48:WU00:FS00:0xa7: CPUs: 4
03:25:48:WU00:FS00:0xa7: Memory: 15.89GiB
03:25:48:WU00:FS00:0xa7:Free Memory: 11.73GiB
03:25:48:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
03:25:48:WU00:FS00:0xa7: OS Version: 6.1
03:25:48:WU00:FS00:0xa7:Has Battery: false
03:25:48:WU00:FS00:0xa7: On Battery: false
03:25:48:WU00:FS00:0xa7: UTC Offset: -7
03:25:48:WU00:FS00:0xa7: PID: 7728
03:25:48:WU00:FS00:0xa7: CWD: C:\Users\ric\AppData\Roaming\FAHClient\work
03:25:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:25:48:WU00:FS00:0xa7: Version: 0.0.18
03:25:48:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:25:48:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
03:25:48:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
03:25:48:WU00:FS00:0xa7: Time: 01:52:30
03:25:48:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:25:48:WU00:FS00:0xa7:************************************ Build *************************************
03:25:48:WU00:FS00:0xa7: SIMD: avx_256
03:25:48:WU00:FS00:0xa7:********************************************************************************
03:25:48:WU00:FS00:0xa7:Project: 14190 (Run 24, Clone 130, Gen 2)
03:25:48:WU00:FS00:0xa7:Unit: 0x000000050002894b5d5d2d140fa14d97
03:25:48:WU00:FS00:0xa7:Digital signatures verified
03:25:48:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 1
03:25:48:WU00:FS00:0xa7:Steps: first=2500000 total=1250000
03:25:50:WU00:FS00:0xa7:Completed 166627 out of 1250000 steps (13%)
03:26:28:Saving configuration to config.xml
03:26:28:<config>
03:26:28: <!-- Slot Control -->
03:26:28: <power v='light'/>
03:26:28:
03:26:28: <!-- User Information -->
03:26:28: <team v='169927'/>
03:26:28: <user v='ricb'/>
03:26:28:
03:26:28: <!-- Folding Slots -->
03:26:28: <slot id='0' type='CPU'/>
03:26:28:</config>
Post
by bruce » Mon Mar 09, 2020 5:31 am
Yes, WU = Work Unit and each WU is uniquely identified by 4 numbers PRCG which stands for Project/Run/Clone/Gen.
The log looks normal for an Intel i5 with no supported GPU.
Depending on the cooling capability of your system (is it a laptop?) you can adjust the number of threads allocated to folding to 1 or 2 or 3 or 4. FAHCore_a7 runs at a very low priority so I doubt you'll see any foreground performance degradation no matter what you choose. Everything you'd want to use your computer for would take priority, very briefly interrupting the folding calculations. That's a lot better than the "idle" setting.
