Nvidia GTX 1060 won't get used by FAH
therium
Post by therium »
Windows 10 running FAH 7.5.1. I'm using the Nvidia studio drivers as they seem to work better with FAH I read. Nvidea GTX 1060 has 3GB of RAM.
My CPU is doing all the folding right now, the client is set at Medium. The GPU on FAH says "GTX 1060" and "Ready" but is not folding. See screenshot. Right side of screenshot is cut off by the forum, so make your browser wider to see it all. Why the forum cuts off images and doesn't shrink them I don't know.
How do I get my GPU to be used by FAH?
Here is my whole log file, which does not appear to use local time. My local time is about 10am. Well if the time in the log is Zulu time that would make sense as I Zulu time is 5 hours ahead of me.
15:00:01:Removing old file 'configs/config-20200125-104059.xml'
15:00:01:Saving configuration to config.xml
15:00:01:<config>
15:00:01:  <!-- Network -->
15:00:01:  <proxy v=':8080'/>
15:00:01:
15:00:01:  <!-- Slot Control -->
15:00:01:  <power v='MEDIUM'/>
15:00:01:
15:00:01:  <!-- User Information -->
15:00:01:  <passkey v='********************************'/>
15:00:01:  <team v='40965'/>
15:00:01:  <user v='Therium'/>
15:00:01:
15:00:01:  <!-- Folding Slots -->
15:00:01:  <slot id='0' type='CPU'/>
15:00:01:  <slot id='1' type='GPU'/>
15:00:01:</config>
15:00:47:Removing old file 'configs/config-20200125-104118.xml'
15:00:47:Saving configuration to config.xml
15:00:47:<config>
15:00:47:  <!-- Network -->
15:00:47:  <proxy v=':8080'/>
15:00:47:
15:00:47:  <!-- Slot Control -->
15:00:47:  <power v='MEDIUM'/>
15:00:47:
15:00:47:  <!-- User Information -->
15:00:47:  <passkey v='********************************'/>
15:00:47:  <team v='40965'/>
15:00:47:  <user v='Therium'/>
15:00:47:
15:00:47:  <!-- Folding Slots -->
15:00:47:  <slot id='0' type='CPU'/>
15:00:47:  <slot id='1' type='GPU'/>
15:00:47:</config>
15:01:12:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
15:01:13:WU02:FS00:Connecting to 65.254.110.245:8080
15:01:13:WU02:FS00:Assigned to work server 155.247.166.219
15:01:13:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.166.219
15:01:13:WU02:FS00:Connecting to 155.247.166.219:8080
15:01:13:WU02:FS00:Downloading 6.67MiB
15:01:17:WU02:FS00:Download complete
15:01:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14300 run:18 clone:81 gen:11 core:0xa7 unit:0x000000130002894b5e56c0415fcf6c48
15:03:42:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
15:03:43:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
15:03:43:WU01:FS00:0xa7:Saving result file dhdl.xvg
15:03:43:WU01:FS00:0xa7:Saving result file frame17.trr
15:03:43:WU01:FS00:0xa7:Saving result file md.log
15:03:43:WU01:FS00:0xa7:Saving result file science.log
15:03:43:WU01:FS00:0xa7:Saving result file traj_comp.xtc
15:03:43:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
15:03:44:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:03:44:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14316 run:1 clone:49 gen:17 core:0xa7 unit:0x000000160002894b5df7b4f7d67fa234
15:03:44:WU01:FS00:Uploading 12.58MiB to 155.247.166.219
15:03:44:WU01:FS00:Connecting to 155.247.166.219:8080
15:03:44:WU02:FS00:Starting
15:03:44:WU02:FS00:Running FahCore: e:\Apps\FAHClient/FAHCoreWrapper.exe C:\Users\PC\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10408 -checkpoint 15 -np 2
15:03:44:WU02:FS00:Started FahCore on PID 12452
15:03:44:WU02:FS00:Core PID:3740
15:03:44:WU02:FS00:FahCore 0xa7 started
15:03:45:WU02:FS00:0xa7:*********************** Log Started 2020-03-07T15:03:44Z ***********************
15:03:45:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:03:45:WU02:FS00:0xa7:       Type: 0xa7
15:03:45:WU02:FS00:0xa7:       Core: Gromacs
15:03:45:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 12452 -checkpoint 15 -np
15:03:45:WU02:FS00:0xa7:             2
15:03:45:WU02:FS00:0xa7:************************************ CBang *************************************
15:03:45:WU02:FS00:0xa7:       Date: Oct 26 2019
15:03:45:WU02:FS00:0xa7:       Time: 01:38:25
15:03:45:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
15:03:45:WU02:FS00:0xa7:     Branch: master
15:03:45:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
15:03:45:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:03:45:WU02:FS00:0xa7:   Platform: win32 10
15:03:45:WU02:FS00:0xa7:       Bits: 64
15:03:45:WU02:FS00:0xa7:       Mode: Release
15:03:45:WU02:FS00:0xa7:************************************ System ************************************
15:03:45:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
15:03:45:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:03:45:WU02:FS00:0xa7:       CPUs: 4
15:03:45:WU02:FS00:0xa7:     Memory: 15.97GiB
15:03:45:WU02:FS00:0xa7:Free Memory: 11.65GiB
15:03:45:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
15:03:45:WU02:FS00:0xa7: OS Version: 6.2
15:03:45:WU02:FS00:0xa7:Has Battery: false
15:03:45:WU02:FS00:0xa7: On Battery: false
15:03:45:WU02:FS00:0xa7: UTC Offset: -5
15:03:45:WU02:FS00:0xa7:        PID: 3740
15:03:45:WU02:FS00:0xa7:        CWD: C:\Users\PC\AppData\Roaming\FAHClient\work
15:03:45:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
15:03:45:WU02:FS00:0xa7:    Version: 0.0.18
15:03:45:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:03:45:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:03:45:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
15:03:45:WU02:FS00:0xa7:       Time: 01:52:30
15:03:45:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
15:03:45:WU02:FS00:0xa7:************************************ Build *************************************
15:03:45:WU02:FS00:0xa7:       SIMD: avx_256
15:03:45:WU02:FS00:0xa7:********************************************************************************
15:03:45:WU02:FS00:0xa7:Project: 14300 (Run 18, Clone 81, Gen 11)
15:03:45:WU02:FS00:0xa7:Unit: 0x000000130002894b5e56c0415fcf6c48
15:03:45:WU02:FS00:0xa7:Reading tar file core.xml
15:03:45:WU02:FS00:0xa7:Reading tar file frame11.tpr
15:03:45:WU02:FS00:0xa7:Digital signatures verified
15:03:45:WU02:FS00:0xa7:Calling: mdrun -s frame11.tpr -o frame11.trr -cpt 15 -nt 2
15:03:45:WU02:FS00:0xa7:Steps: first=5500000 total=500000
15:03:47:WU02:FS00:0xa7:Completed 1 out of 500000 steps (0%)
15:03:50:WU01:FS00:Upload 45.72%
15:03:52:WU02:FS00:0xa7:ERROR:
15:03:52:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
15:03:52:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
15:03:52:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec_top.c, line: 394
15:03:52:WU02:FS00:0xa7:ERROR:Fatal error:
15:03:52:WU02:FS00:0xa7:ERROR:1 of the 251792 bonded interactions could not be calculated because some atoms involved moved further apart than the multi-body cut-off distance (1.036 nm) or the two-body cut-off distance (1.036 nm), see option -rdd, for pairs and tabulated bonds also see option -ddcheck
15:03:52:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
15:03:52:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
15:03:56:WU01:FS00:Upload 99.89%
15:03:56:WU01:FS00:Upload complete
15:03:56:WU01:FS00:Server responded WORK_ACK (400)
15:03:56:WU01:FS00:Final credit estimate, 955.00 points
15:03:56:WU01:FS00:Cleaning up
15:04:02:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
15:04:02:WU02:FS00:0xa7:Saving result file dhdl.xvg
15:04:02:WU02:FS00:0xa7:Saving result file frame11.trr
15:04:02:WU02:FS00:0xa7:Saving result file md.log
15:04:02:WU02:FS00:0xa7:Saving result file science.log
15:04:02:WU02:FS00:0xa7:Saving result file traj_comp.xtc
15:04:02:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
15:04:03:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:04:03:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:14300 run:18 clone:81 gen:11 core:0xa7 unit:0x000000130002894b5e56c0415fcf6c48
15:04:03:WU02:FS00:Uploading 5.90MiB to 155.247.166.219
15:04:03:WU02:FS00:Connecting to 155.247.166.219:8080
15:04:04:WU01:FS00:Connecting to 65.254.110.245:8080
15:04:04:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:04:04:WU01:FS00:Connecting to 18.218.241.186:80
15:04:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:04:05:ERROR:WU01:FS00:Exception: Could not get an assignment
15:04:05:WU01:FS00:Connecting to 65.254.110.245:8080
15:04:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:04:05:WU01:FS00:Connecting to 18.218.241.186:80
15:04:09:WU02:FS00:Upload 70.96%
15:04:10:WU02:FS00:Upload complete
15:04:10:WU02:FS00:Server responded WORK_ACK (400)
15:04:10:WU02:FS00:Cleaning up
15:05:05:WU01:FS00:Connecting to 65.254.110.245:8080
15:05:05:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:05:05:WU01:FS00:Connecting to 18.218.241.186:80
15:05:05:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:05:05:ERROR:WU01:FS00:Exception: Could not get an assignment
15:06:04:WU00:FS01:Connecting to 65.254.110.245:8080
15:06:04:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:06:04:WU00:FS01:Connecting to 18.218.241.186:80
15:06:04:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:06:04:ERROR:WU00:FS01:Exception: Could not get an assignment
15:06:42:WU01:FS00:Connecting to 65.254.110.245:8080
15:06:42:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:06:42:WU01:FS00:Connecting to 18.218.241.186:80
15:06:43:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:06:43:ERROR:WU01:FS00:Exception: Could not get an assignment
Thank you.
Re: Nvidia GTX 1060 won't get used by FAH
See my answer in your other thread : viewtopic.php?p=311797#p311797
