Please add Radeon RX 580 2048SP
AlexHe
Post by AlexHe »
Name: AMD Radeon RX 580 2048SP
Device ID: 1002 6FDF-148C 2392
*********************** Log Started 2020-03-07T07:40:08Z ***********************
07:40:08:************************* Folding@home Client *************************
07:40:08:        Website: https://foldingathome.org/
07:40:08:      Copyright: (c) 2009-2018 foldingathome.org
07:40:08:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:40:08:           Args:
07:40:08:         Config: C:\Users\hrt20\AppData\Roaming\FAHClient\config.xml
07:40:08:******************************** Build ********************************
07:40:08:        Version: 7.5.1
07:40:08:           Date: May 11 2018
07:40:08:           Time: 13:06:32
07:40:08:     Repository: Git
07:40:08:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:40:08:         Branch: master
07:40:08:       Compiler: Visual C++ 2008
07:40:08:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:40:08:       Platform: win32 10
07:40:08:           Bits: 32
07:40:08:           Mode: Release
07:40:08:******************************* System ********************************
07:40:08:            CPU: AMD Ryzen 5 1600X Six-Core Processor
07:40:08:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
07:40:08:           CPUs: 12
07:40:08:         Memory: 15.93GiB
07:40:08:    Free Memory: 10.96GiB
07:40:08:        Threads: WINDOWS_THREADS
07:40:08:     OS Version: 6.2
07:40:08:    Has Battery: false
07:40:08:     On Battery: false
07:40:08:     UTC Offset: 8
07:40:08:            PID: 8748
07:40:08:            CWD: C:\Users\hrt20\AppData\Roaming\FAHClient
07:40:08:             OS: Windows 10 Enterprise
07:40:08:        OS Arch: AMD64
07:40:08:           GPUs: 0
07:40:08:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
07:40:08:                 找不到指定的模块。
07:40:08:
07:40:08:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
07:40:08:  Win32 Service: false
07:40:08:***********************************************************************
07:40:09:<config>
07:40:09:  <!-- Folding Core -->
07:40:09:  <checkpoint v='21'/>
07:40:09:
07:40:09:  <!-- Network -->
07:40:09:  <proxy v=':8080'/>
07:40:09:
07:40:09:  <!-- Slot Control -->
07:40:09:  <power v='light'/>
07:40:09:
07:40:09:  <!-- User Information -->
07:40:09:  <passkey v='********************************'/>
07:40:09:  <team v='3213'/>
07:40:09:  <user v='Alex'/>
07:40:09:
07:40:09:  <!-- Folding Slots -->
07:40:09:  <slot id='0' type='CPU'/>
07:40:09:</config>
07:40:09:Trying to access database...
07:40:09:Successfully acquired database lock
07:40:09:Enabled folding slot 00: READY cpu:5
07:40:09:WU00:FS00:Starting
07:40:09:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\hrt20\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8748 -checkpoint 21 -np 5
07:40:09:WU00:FS00:Started FahCore on PID 1736
07:40:09:WU00:FS00:Core PID:8976
07:40:09:WU00:FS00:FahCore 0xa7 started
07:40:09:WU00:FS00:0xa7:*********************** Log Started 2020-03-07T07:40:09Z ***********************
07:40:09:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:40:09:WU00:FS00:0xa7:       Type: 0xa7
07:40:09:WU00:FS00:0xa7:       Core: Gromacs
07:40:09:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1736 -checkpoint 21 -np 5
07:40:09:WU00:FS00:0xa7:************************************ CBang *************************************
07:40:09:WU00:FS00:0xa7:       Date: Oct 26 2019
07:40:09:WU00:FS00:0xa7:       Time: 01:38:25
07:40:09:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
07:40:09:WU00:FS00:0xa7:     Branch: master
07:40:09:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
07:40:09:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:40:09:WU00:FS00:0xa7:   Platform: win32 10
07:40:09:WU00:FS00:0xa7:       Bits: 64
07:40:09:WU00:FS00:0xa7:       Mode: Release
07:40:09:WU00:FS00:0xa7:************************************ System ************************************
07:40:09:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 1600X Six-Core Processor
07:40:09:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
07:40:09:WU00:FS00:0xa7:       CPUs: 12
07:40:09:WU00:FS00:0xa7:     Memory: 15.93GiB
07:40:09:WU00:FS00:0xa7:Free Memory: 10.97GiB
07:40:09:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
07:40:09:WU00:FS00:0xa7: OS Version: 6.2
07:40:09:WU00:FS00:0xa7:Has Battery: false
07:40:09:WU00:FS00:0xa7: On Battery: false
07:40:09:WU00:FS00:0xa7: UTC Offset: 8
07:40:09:WU00:FS00:0xa7:        PID: 8976
07:40:09:WU00:FS00:0xa7:        CWD: C:\Users\hrt20\AppData\Roaming\FAHClient\work
07:40:09:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
07:40:09:WU00:FS00:0xa7:    Version: 0.0.18
07:40:09:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:40:09:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
07:40:09:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
07:40:09:WU00:FS00:0xa7:       Time: 01:52:30
07:40:09:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
07:40:09:WU00:FS00:0xa7:************************************ Build *************************************
07:40:09:WU00:FS00:0xa7:       SIMD: avx_256
07:40:09:WU00:FS00:0xa7:********************************************************************************
07:40:09:WU00:FS00:0xa7:Project: 14182 (Run 4, Clone 452, Gen 2)
07:40:09:WU00:FS00:0xa7:Unit: 0x000000020002894b5dae08f218b78d10
07:40:09:WU00:FS00:0xa7:Digital signatures verified
07:40:09:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
07:40:09:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 21 -nt 4
07:40:09:WU00:FS00:0xa7:Steps: first=5000000 total=2500000
07:40:09:WU00:FS00:0xa7:Completed 640012 out of 2500000 steps (25%)
07:40:41:Saving configuration to config.xml
07:40:41:<config>
07:40:41:  <!-- Folding Core -->
07:40:41:  <checkpoint v='21'/>
07:40:41:
07:40:41:  <!-- Network -->
07:40:41:  <proxy v=':8080'/>
07:40:41:
07:40:41:  <!-- Slot Control -->
07:40:41:  <power v='light'/>
07:40:41:
07:40:41:  <!-- User Information -->
07:40:41:  <passkey v='********************************'/>
07:40:41:  <team v='3213'/>
07:40:41:  <user v='Alex'/>
07:40:41:
07:40:41:  <!-- Folding Slots -->
07:40:41:  <slot id='0' type='CPU'/>
07:40:41:</config>
07:42:59:WU00:FS00:0xa7:Completed 650000 out of 2500000 steps (26%)
07:50:12:WU00:FS00:0xa7:Completed 675000 out of 2500000 steps (27%)
07:57:29:WU00:FS00:0xa7:Completed 700000 out of 2500000 steps (28%)
08:04:45:WU00:FS00:0xa7:Completed 725000 out of 2500000 steps (29%)
Re: Please add Radeon RX 580 2048SP
Added 6fdf / Polaris 20 XL [Radeon RX 580 2048SP] to the list of supported devices.
AlexHe
Post by AlexHe »
Thank You.
