Network Connection Drops/Extremely Slow when GPU Folding
OngOfSC
Post by OngOfSC »
Hi all,
This is a correction to a previous post, where I didn't follow the correct formatting for posting for technical information, that's my bad.
Basically, when I turn folding power to "full" or "medium"... or any time the GPU decides to kick in to work (e.g. when idle), my network connection drops like a rock. My typical connection just refuses to connect, and a secondary connection works VERY slowly. I'm not sure why this is the case, and any help is very much appreciated!
Specs: i7-9750H (6-Core Hyperthreaded), 16GB RAM, GTX 1650Ti Max-Q
Network Connection: Wireless on University Network
Operating System: Windows 10 Home
Overclocked: No (Undervolted stable with ThrottleStop)
Stable: Yes
Software: F@H 7.5.1, Cores 0xa7 and 0x21
WU Details (GPU): PRCG 11714(0,13172,95), Work/Collection Server: 140.163.4.241/128.252.203.4
*********************** Log Started 2020-03-05T18:56:07Z ***********************
18:56:07:************************* Folding@home Client *************************
18:56:07:        Website: https://foldingathome.org/
18:56:07:      Copyright: (c) 2009-2018 foldingathome.org
18:56:07:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:56:07:           Args:
18:56:07:         Config: C:\Users\victo\AppData\Roaming\FAHClient\config.xml
18:56:07:******************************** Build ********************************
18:56:07:        Version: 7.5.1
18:56:07:           Date: May 11 2018
18:56:07:           Time: 13:06:32
18:56:07:     Repository: Git
18:56:07:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:56:07:         Branch: master
18:56:07:       Compiler: Visual C++ 2008
18:56:07:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:56:07:       Platform: win32 10
18:56:07:           Bits: 32
18:56:07:           Mode: Release
18:56:07:******************************* System ********************************
18:56:07:            CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
18:56:07:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:56:07:           CPUs: 12
18:56:07:         Memory: 15.85GiB
18:56:07:    Free Memory: 12.00GiB
18:56:07:        Threads: WINDOWS_THREADS
18:56:07:     OS Version: 6.2
18:56:07:    Has Battery: true
18:56:07:     On Battery: false
18:56:07:     UTC Offset: -8
18:56:07:            PID: 15020
18:56:07:            CWD: C:\Users\victo\AppData\Roaming\FAHClient
18:56:07:             OS: Windows 10 Home
18:56:07:        OS Arch: AMD64
18:56:07:           GPUs: 1
18:56:07:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU117 [GeForce GTX 1650]
18:56:07:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
18:56:07:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.19
18:56:07:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
18:56:07:  Win32 Service: false
18:56:07:***********************************************************************
18:56:07:<config>
18:56:07:  <!-- Folding Core -->
18:56:07:  <checkpoint v='30'/>
18:56:07:
18:56:07:  <!-- Network -->
18:56:07:  <proxy v=':8080'/>
18:56:07:
18:56:07:  <!-- Slot Control -->
18:56:07:  <idle v='true'/>
18:56:07:
18:56:07:  <!-- User Information -->
18:56:07:  <team v='224497'/>
18:56:07:  <user v='OngOfSC_13BmKGi2Kxa8eDLiSRoVTGgMadG59cZvXi'/>
18:56:07:
18:56:07:  <!-- Folding Slots -->
18:56:07:  <slot id='0' type='CPU'>
18:56:07:    <idle v='false'/>
18:56:07:  </slot>
18:56:07:  <slot id='1' type='GPU'>
18:56:07:  </slot>
18:56:07:</config>
18:56:07:Trying to access database...
18:56:07:Successfully acquired database lock
18:56:07:Enabled folding slot 00: READY cpu:5
18:56:07:Enabled folding slot 01: PAUSED gpu:0:TU117 [GeForce GTX 1650] (waiting for idle)
18:56:07:WU02:FS00:Starting
18:56:07:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\victo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 15020 -checkpoint 30 -np 5
18:56:08:WU02:FS00:Started FahCore on PID 1052
18:56:08:WU02:FS00:Core PID:6088
18:56:08:WU02:FS00:FahCore 0xa7 started
18:56:08:WU02:FS00:0xa7:*********************** Log Started 2020-03-05T18:56:08Z ***********************
18:56:08:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:56:08:WU02:FS00:0xa7:       Type: 0xa7
18:56:08:WU02:FS00:0xa7:       Core: Gromacs
18:56:08:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 1052 -checkpoint 30 -np 5
18:56:08:WU02:FS00:0xa7:************************************ CBang *************************************
18:56:08:WU02:FS00:0xa7:       Date: Oct 26 2019
18:56:08:WU02:FS00:0xa7:       Time: 01:38:25
18:56:08:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:56:08:WU02:FS00:0xa7:     Branch: master
18:56:08:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
18:56:08:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:56:08:WU02:FS00:0xa7:   Platform: win32 10
18:56:08:WU02:FS00:0xa7:       Bits: 64
18:56:08:WU02:FS00:0xa7:       Mode: Release
18:56:08:WU02:FS00:0xa7:************************************ System ************************************
18:56:08:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
18:56:08:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
18:56:08:WU02:FS00:0xa7:       CPUs: 12
18:56:08:WU02:FS00:0xa7:     Memory: 15.85GiB
18:56:08:WU02:FS00:0xa7:Free Memory: 11.42GiB
18:56:08:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
18:56:08:WU02:FS00:0xa7: OS Version: 6.2
18:56:08:WU02:FS00:0xa7:Has Battery: true
18:56:08:WU02:FS00:0xa7: On Battery: false
18:56:08:WU02:FS00:0xa7: UTC Offset: -8
18:56:08:WU02:FS00:0xa7:        PID: 6088
18:56:08:WU02:FS00:0xa7:        CWD: C:\Users\victo\AppData\Roaming\FAHClient\work
18:56:08:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
18:56:08:WU02:FS00:0xa7:    Version: 0.0.18
18:56:08:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:56:08:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:56:08:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
18:56:08:WU02:FS00:0xa7:       Time: 01:52:30
18:56:08:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:56:08:WU02:FS00:0xa7:************************************ Build *************************************
18:56:08:WU02:FS00:0xa7:       SIMD: avx_256
18:56:08:WU02:FS00:0xa7:********************************************************************************
18:56:08:WU02:FS00:0xa7:Project: 14175 (Run 0, Clone 47, Gen 129)
18:56:08:WU02:FS00:0xa7:Unit: 0x0000009c0002894b5cabee8229c96af1
18:56:08:WU02:FS00:0xa7:Digital signatures verified
18:56:08:WU02:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
18:56:08:WU02:FS00:0xa7:Calling: mdrun -s frame129.tpr -o frame129.trr -cpi state.cpt -cpt 30 -nt 4
18:56:09:WU02:FS00:0xa7:Steps: first=32250000 total=250000
18:56:12:WU02:FS00:0xa7:Completed 58701 out of 250000 steps (23%)
19:00:51:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
19:05:13:15:127.0.0.1:New Web connection
19:08:29:42:127.0.0.1:New Web connection
19:09:26:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
19:18:23:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
19:23:24:FS00:Shutting core down
19:23:24:WU03:FS01:Starting
19:23:24:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\victo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 705 -lifeline 15020 -checkpoint 30 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:23:24:WU03:FS01:Started FahCore on PID 7480
19:23:24:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 6088
19:23:24:WU02:FS00:0xa7:Exiting, please wait. . .
19:23:24:WU03:FS01:Core PID:13572
19:23:24:WU03:FS01:FahCore 0x21 started
19:23:24:WU03:FS01:0x21:*********************** Log Started 2020-03-05T19:23:24Z ***********************
19:23:24:WU03:FS01:0x21:Project: 11714 (Run 0, Clone 13172, Gen 95)
19:23:24:WU03:FS01:0x21:Unit: 0x000000a48ca304f15de0497e7db7c0f8
19:23:24:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:23:24:WU03:FS01:0x21:Machine: 1
19:23:24:WU03:FS01:0x21:Digital signatures verified
19:23:24:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:23:24:WU03:FS01:0x21:Version 0.0.20
19:23:25:WU03:FS01:0x21:  Found a checkpoint file
19:23:30:WU03:FS01:0x21:Completed 1750000 out of 7500000 steps (23%)
19:23:30:WU03:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:23:30:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
19:23:30:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:23:31:WU02:FS00:Starting
19:23:31:WARNING:WU02:FS00:Changed SMP threads from 5 to 11 this can cause some work units to fail
19:23:31:WARNING:WU02:FS00:AS lowered CPUs from 11 to 5
19:23:31:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\victo\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 15020 -checkpoint 30 -np 5
19:23:31:WU02:FS00:Started FahCore on PID 17336
19:23:31:WU02:FS00:Core PID:18260
19:23:31:WU02:FS00:FahCore 0xa7 started
19:23:31:WU02:FS00:0xa7:*********************** Log Started 2020-03-05T19:23:31Z ***********************
19:23:31:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:23:31:WU02:FS00:0xa7:       Type: 0xa7
19:23:31:WU02:FS00:0xa7:       Core: Gromacs
19:23:31:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 17336 -checkpoint 30 -np
19:23:31:WU02:FS00:0xa7:             5
19:23:31:WU02:FS00:0xa7:************************************ CBang *************************************
19:23:31:WU02:FS00:0xa7:       Date: Oct 26 2019
19:23:31:WU02:FS00:0xa7:       Time: 01:38:25
19:23:31:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:23:31:WU02:FS00:0xa7:     Branch: master
19:23:31:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
19:23:31:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:23:31:WU02:FS00:0xa7:   Platform: win32 10
19:23:31:WU02:FS00:0xa7:       Bits: 64
19:23:31:WU02:FS00:0xa7:       Mode: Release
19:23:31:WU02:FS00:0xa7:************************************ System ************************************
19:23:31:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
19:23:31:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
19:23:31:WU02:FS00:0xa7:       CPUs: 12
19:23:31:WU02:FS00:0xa7:     Memory: 15.85GiB
19:23:31:WU02:FS00:0xa7:Free Memory: 7.05GiB
19:23:31:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
19:23:31:WU02:FS00:0xa7: OS Version: 6.2
19:23:31:WU02:FS00:0xa7:Has Battery: true
19:23:31:WU02:FS00:0xa7: On Battery: false
19:23:31:WU02:FS00:0xa7: UTC Offset: -8
19:23:31:WU02:FS00:0xa7:        PID: 18260
19:23:31:WU02:FS00:0xa7:        CWD: C:\Users\victo\AppData\Roaming\FAHClient\work
19:23:31:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
19:23:31:WU02:FS00:0xa7:    Version: 0.0.18
19:23:31:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:23:31:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:23:31:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
19:23:31:WU02:FS00:0xa7:       Time: 01:52:30
19:23:31:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:23:31:WU02:FS00:0xa7:************************************ Build *************************************
19:23:31:WU02:FS00:0xa7:       SIMD: avx_256
19:23:31:WU02:FS00:0xa7:********************************************************************************
19:23:31:WU02:FS00:0xa7:Project: 14175 (Run 0, Clone 47, Gen 129)
19:23:31:WU02:FS00:0xa7:Unit: 0x0000009c0002894b5cabee8229c96af1
19:23:31:WU02:FS00:0xa7:Digital signatures verified
19:23:31:WU02:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
19:23:31:WU02:FS00:0xa7:Calling: mdrun -s frame129.tpr -o frame129.trr -cpi state.cpt -cpt 30 -nt 4
19:23:32:WU02:FS00:0xa7:Steps: first=32250000 total=250000
19:23:34:Removing old file 'configs/config-20200304-191240.xml'
19:23:34:Saving configuration to config.xml
19:23:34:<config>
19:23:34:  <!-- Folding Core -->
19:23:34:  <checkpoint v='30'/>
19:23:34:
19:23:34:  <!-- Network -->
19:23:34:  <proxy v=':8080'/>
19:23:34:
19:23:34:  <!-- Slot Control -->
19:23:34:  <idle v='true'/>
19:23:34:  <power v='full'/>
19:23:34:
19:23:34:  <!-- User Information -->
19:23:34:  <team v='224497'/>
19:23:34:  <user v='OngOfSC_13BmKGi2Kxa8eDLiSRoVTGgMadG59cZvXi'/>
19:23:34:
19:23:34:  <!-- Folding Slots -->
19:23:34:  <slot id='0' type='CPU'>
19:23:34:    <idle v='false'/>
19:23:34:  </slot>
19:23:34:  <slot id='1' type='GPU'>
19:23:34:  </slot>
19:23:34:</config>
19:23:35:WU02:FS00:0xa7:Completed 66442 out of 250000 steps (26%)
19:26:52:WU03:FS01:0x21:Completed 1800000 out of 7500000 steps (24%)
Thanks in advance!
Re: Network Connection Drops/Extremely Slow when GPU Folding
I would suspect one of two things.
First, your PS might not be up to supplying sufficient power when the CPU and GPU are fully engaged, and insufficient power is getting to your wireless adapter.
Second would be something not properly shielded, and that is interfering with your Wifi connection.
Can you move something closer and try using an Ethernet wire rather than the WiFi? That would eliminate one of those possibilities.
OngOfSC
Post by OngOfSC »
I'll try the ethernet troubleshoot when I get home later tonight. As for the power draw/requirements... I'm not sure if that's something that can be fixed on a laptop (it works when running a demanding game, though it might not be to the same requirements at F@H?)
It also could be a limitation in your laptop's cooling. Laptops are typically designed with insufficient cooling and FAH pushes against those limits. Adjusting the fan can help. So can propping it up on bottle-caps (or a professional laptop stand). Never run you laptop on a bed inasmuch a large percentage of the heat goes out the back.
OngOfSC
Post by OngOfSC »
Sorry for the delay! I actually have been super busy recently and haven't gotten the chance to try the ethernet option.
Cooling doesn't seem to be the issue- running my fans at full speed keeps temperatures around 60 degrees for both my CPU and GPU.
Running my GPU without the CPU leads to the same issues- not sure if it's power limiting in that case. Could something in the hardware actually be configured strangely?
