Hi!
My name is Joe, I live in germany and I installed folding@home on 2 machines:
- Win 10 PC
- macBook Air
1) At the registration I ordered a Passkey. Is this key linked with my Identity? What if I change my ID-Name - will it linked automatically to the passkey?
2) Is there a synchronization in the folding@home account to the machines I run? On the webpage I can't see any stat which machines I use...
3) Where can I find a list of teams ? At the website "Stats report - teams monthly" is nothing, only the message "Bad Gateway".
I hope you can help me at these starting steps...
Thanks...
Joe
Questions from a newbie
Re: Questions from a newbie
1 - The passkey is linked to the username and email address you supplied when applying for it. If you lost it, applying again with the same username and email will get you the same passkey sent back.
For WU's sent back, the database stores the username and passkey information, that then never gets changed in the database. However you can use your passkey with more than one username, the stats will be recorded under each username separately. At one time you could search the database by just your passkey, but that was removed in one of the revisions.
2 - It depends on what exactly you mean by synchronization. No, the website will not show current progress, but once WU's have been returned they do show up, usually within a couple hours.
3 - there are a number of updates and changes going on for the website, hopefully they will all get sorted out in a short time.
Watsyerproblem
Are there any requirements for getting a passkey? I tried to get one yesterday and I wasn't sent an email.
Okay, thanks for this help!
rwh202
3x GTX 1080 Ti
3x GTX 1060
With regards to 1), it is possible to use the same passkey with multiple user identities.
It is therefore possible to view points accumulated by a single passkey, across multiple user accounts if you so desire.
However, each user identity will need to 'qualify' by returning 10 successful WUs before it receives the bonus points
No special requirements that I know of. You just need to enter a username and a valid email address. I just did a test from hereWatsyerproblem wrote:Are there any requirements for getting a passkey? I tried to get one yesterday and I wasn't sent an email.
https://apps.foldingathome.org/getpasskey
and was sent a passkey from a F@h account on gmail. Could you check your spam folder and see if an email ended up there?
