Titan V PPD low
CommanderLake
Titan V PPD low
Post by CommanderLake »
I've got a watercooled Titan V thats cool as a cucumber at around 1980MHz core and 945MHz memory while running F@H and completely stable but I'm only getting around 230kPPD with project 11737 on core 0x22 with an estimated TPF of 28s, the utilization is 90%.
I got it second hand good as new to do some CUDA programming of my own and it performs stunningly with a peak of about 19 TFLOPS.
After looking around the forum it looks like I should be getting 10x more PPD than I am so why only ~230k?
Re: Titan V PPD low
The most common cause of low estimated PPD is not using a passkey. If you did not configure your client with a passkey, you can apply for and get a passkey to enter.
CommanderLake
Re: Titan V PPD low
I figured that out eventually, now I've seen over 3.4M PPD!
Re: Titan V PPD low
The more powerful the GPU, the more the Quick Return Bonus helps the Points Per Day!
CommanderLake
Re: Titan V PPD low
Over 4M PPD with 11739!
HaloJones
Re: Titan V PPD low
Post by HaloJones »
what does a Titan RTX get??!!
4070 super
Nathan_P
Not currently folding
Re: Titan V PPD low
Post by Nathan_P »
I would say nearly the same as a Titan V, less cores but higher clocks.
Re: Titan V PPD low
Nathan_P wrote:I would say nearly the same as a Titan V, less cores but higher clocks.
FAH performance is reasonably closely related to the GFLOPS numbers. GFLOPS are proportional to NCores*ClockRate.
Within a given generation, Watts/heat is sort of proportional to GFLOPS, but later generations (almost) always improve that relationship.
Duce H_K_
Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w
Re: Titan V PPD low
Post by Duce H_K_ »
CommanderLake wrote:Over 4M PPD with 11739!
Excellent, my congratulations ! :D
