RX 570 not folding
Oimel1987
RX 570 not folding
Post by Oimel1987 »
The Systeminfo says, that it can not recognize my gpu and nvcuda.dll is not found. How can I fix that? Nothing is overclocked or something else.
Thx for the help
*********************** Log Started 2020-03-03T10:08:21Z ***********************
10:08:21:************************* Folding@home Client *************************
10:08:21:        Website: https://foldingathome.org/
10:08:21:      Copyright: (c) 2009-2018 foldingathome.org
10:08:21:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:08:21:           Args: --open-web-control
10:08:21:         Config: <none>
10:08:21:******************************** Build ********************************
10:08:21:        Version: 7.5.1
10:08:21:           Date: May 11 2018
10:08:21:           Time: 13:06:32
10:08:21:     Repository: Git
10:08:21:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:08:21:         Branch: master
10:08:21:       Compiler: Visual C++ 2008
10:08:21:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:08:21:       Platform: win32 10
10:08:21:           Bits: 32
10:08:21:           Mode: Release
10:08:21:******************************* System ********************************
10:08:21:            CPU: AMD Ryzen 5 2600 Six-Core Processor
10:08:21:         CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:08:21:           CPUs: 12
10:08:21:         Memory: 15.95GiB
10:08:21:    Free Memory: 10.13GiB
10:08:21:        Threads: WINDOWS_THREADS
10:08:21:     OS Version: 6.2
10:08:21:    Has Battery: false
10:08:21:     On Battery: false
10:08:21:     UTC Offset: 1
10:08:21:            PID: 768
10:08:21:            CWD: C:\Users\pfeff\AppData\Roaming\FAHClient
10:08:21:             OS: Windows 10 Enterprise
10:08:21:        OS Arch: AMD64
10:08:21:           GPUs: 0
10:08:21:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
10:08:21:                 angegebene Modul wurde nicht gefunden.
10:08:21:
10:08:21:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
10:08:21:  Win32 Service: false
10:08:21:***********************************************************************
10:08:21:<config>
10:08:21:  <!-- Folding Slots -->
10:08:21:</config>
10:08:21:Connecting to assign1.foldingathome.org:8080
10:08:21:Updated GPUs.txt
10:08:21:Read GPUs.txt
10:08:21:Trying to access database...
10:08:22:Successfully acquired database lock
10:08:22:Enabled folding slot 00: PAUSED cpu:10 (not configured)
10:08:22:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] (not configured)
10:08:25:8:127.0.0.1:New Web connection
10:09:23:Saving configuration to config.xml
10:09:23:<config>
10:09:23:  <!-- Folding Slots -->
10:09:23:  <slot id='0' type='CPU'/>
10:09:23:  <slot id='1' type='GPU'/>
10:09:23:</config>
10:09:23:Set client configured
10:09:23:WU00:FS00:Connecting to 65.254.110.245:8080
10:09:23:WU01:FS01:Connecting to 65.254.110.245:8080
10:09:24:WU01:FS01:Connecting to 65.254.110.245:8080
10:09:24:WU00:FS00:Assigned to work server 155.247.166.219
10:09:24:WU00:FS00:Requesting new work unit for slot 00: READY cpu:10 from 155.247.166.219
10:09:24:WU00:FS00:Connecting to 155.247.166.219:8080
10:09:24:WU00:FS00:Downloading 1.72MiB
10:09:24:WU01:FS01:Assigned to work server 155.247.166.220
10:09:24:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 155.247.166.220
10:09:24:WU01:FS01:Connecting to 155.247.166.220:8080
10:09:25:WU01:FS01:Downloading 15.58MiB
10:09:26:WU00:FS00:Download complete
10:09:26:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14183 run:3 clone:40 gen:69 core:0xa7 unit:0x0000005a0002894b5cf936277ac68688
10:09:26:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
10:09:26:WU00:FS00:Connecting to cores.foldingathome.org:80
10:09:26:WU00:FS00:FahCore a7: Downloading 6.71MiB
10:09:29:WU00:FS00:FahCore a7: Download complete
10:09:29:WU00:FS00:Valid core signature
10:09:29:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
10:09:29:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
10:09:29:WU00:FS00:Starting
10:09:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 10
10:09:29:WU00:FS00:Started FahCore on PID 8464
10:09:30:WU01:FS01:Download complete
10:09:30:WU00:FS00:Core PID:10048
10:09:30:WU00:FS00:FahCore 0xa7 started
10:09:30:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T10:09:30Z ***********************
10:09:30:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:09:30:WU00:FS00:0xa7:       Type: 0xa7
10:09:30:WU00:FS00:0xa7:       Core: Gromacs
10:09:30:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 8464 -checkpoint 15 -np
10:09:30:WU00:FS00:0xa7:             10
10:09:30:WU00:FS00:0xa7:************************************ CBang *************************************
10:09:30:WU00:FS00:0xa7:       Date: Oct 26 2019
10:09:30:WU00:FS00:0xa7:       Time: 01:38:25
10:09:30:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:09:30:WU00:FS00:0xa7:     Branch: master
10:09:30:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:09:30:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:09:30:WU00:FS00:0xa7:   Platform: win32 10
10:09:30:WU00:FS00:0xa7:       Bits: 64
10:09:30:WU00:FS00:0xa7:       Mode: Release
10:09:30:WU00:FS00:0xa7:************************************ System ************************************
10:09:30:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
10:09:30:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:09:30:WU00:FS00:0xa7:       CPUs: 12
10:09:30:WU00:FS00:0xa7:     Memory: 15.95GiB
10:09:30:WU00:FS00:0xa7:Free Memory: 9.68GiB
10:09:30:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:09:30:WU00:FS00:0xa7: OS Version: 6.2
10:09:30:WU00:FS00:0xa7:Has Battery: false
10:09:30:WU00:FS00:0xa7: On Battery: false
10:09:30:WU00:FS00:0xa7: UTC Offset: 1
10:09:30:WU00:FS00:0xa7:        PID: 10048
10:09:30:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
10:09:30:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:09:30:WU00:FS00:0xa7:    Version: 0.0.18
10:09:30:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:09:30:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:09:30:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:09:30:WU00:FS00:0xa7:       Time: 01:52:30
10:09:30:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:09:30:WU00:FS00:0xa7:************************************ Build *************************************
10:09:30:WU00:FS00:0xa7:       SIMD: avx_256
10:09:30:WU00:FS00:0xa7:********************************************************************************
10:09:30:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
10:09:30:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
10:09:30:WU00:FS00:0xa7:Reading tar file core.xml
10:09:30:WU00:FS00:0xa7:Reading tar file frame69.tpr
10:09:30:WU00:FS00:0xa7:Digital signatures verified
10:09:30:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpt 15 -nt 10
10:09:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14180 run:11 clone:366 gen:100 core:0x21 unit:0x000000a00002894c5d3b5625312dc7c1
10:09:31:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah
10:09:31:WU01:FS01:Connecting to cores.foldingathome.org:80
10:09:31:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
10:09:31:WU01:FS01:FahCore 21: Downloading 3.48MiB
10:09:32:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
10:09:33:WU01:FS01:FahCore 21: Download complete
10:09:33:WU01:FS01:Valid core signature
10:09:33:WU01:FS01:Unpacked 11.81MiB to cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe
10:09:33:WU01:FS01:Starting
10:09:33:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:09:33:WU01:FS01:Started FahCore on PID 16152
10:09:34:WU01:FS01:Core PID:14992
10:09:34:WU01:FS01:FahCore 0x21 started
10:09:34:WU01:FS01:0x21:*********************** Log Started 2020-03-03T10:09:34Z ***********************
10:09:34:WU01:FS01:0x21:Project: 14180 (Run 11, Clone 366, Gen 100)
10:09:34:WU01:FS01:0x21:Unit: 0x000000a00002894c5d3b5625312dc7c1
10:09:34:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
10:09:34:WU01:FS01:0x21:Machine: 1
10:09:34:WU01:FS01:0x21:Reading tar file core.xml
10:09:34:WU01:FS01:0x21:Reading tar file integrator.xml
10:09:34:WU01:FS01:0x21:Reading tar file state.xml
10:09:34:WU01:FS01:0x21:Reading tar file system.xml
10:09:34:WU01:FS01:0x21:Digital signatures verified
10:09:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
10:09:34:WU01:FS01:0x21:Version 0.0.20
10:09:45:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
10:09:45:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:10:53:FS00:Shutting core down
10:10:53:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 10048
10:10:53:WU00:FS00:0xa7:Exiting, please wait. . .
10:10:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:10:54:WU00:FS00:Starting
10:10:54:WARNING:WU00:FS00:Changed SMP threads from 10 to 11 this can cause some work units to fail
10:10:54:WARNING:WU00:FS00:AS lowered CPUs from 11 to 10
10:10:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 10
10:10:54:WU00:FS00:Started FahCore on PID 5616
10:10:54:WU00:FS00:Core PID:14644
10:10:54:WU00:FS00:FahCore 0xa7 started
10:10:55:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T10:10:54Z ***********************
10:10:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:10:55:WU00:FS00:0xa7:       Type: 0xa7
10:10:55:WU00:FS00:0xa7:       Core: Gromacs
10:10:55:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5616 -checkpoint 15 -np
10:10:55:WU00:FS00:0xa7:             10
10:10:55:WU00:FS00:0xa7:************************************ CBang *************************************
10:10:55:WU00:FS00:0xa7:       Date: Oct 26 2019
10:10:55:WU00:FS00:0xa7:       Time: 01:38:25
10:10:55:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:10:55:WU00:FS00:0xa7:     Branch: master
10:10:55:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:10:55:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:10:55:WU00:FS00:0xa7:   Platform: win32 10
10:10:55:WU00:FS00:0xa7:       Bits: 64
10:10:55:WU00:FS00:0xa7:       Mode: Release
10:10:55:WU00:FS00:0xa7:************************************ System ************************************
10:10:55:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
10:10:55:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:10:55:WU00:FS00:0xa7:       CPUs: 12
10:10:55:WU00:FS00:0xa7:     Memory: 15.95GiB
10:10:55:WU00:FS00:0xa7:Free Memory: 9.18GiB
10:10:55:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:10:55:WU00:FS00:0xa7: OS Version: 6.2
10:10:55:WU00:FS00:0xa7:Has Battery: false
10:10:55:WU00:FS00:0xa7: On Battery: false
10:10:55:WU00:FS00:0xa7: UTC Offset: 1
10:10:55:WU00:FS00:0xa7:        PID: 14644
10:10:55:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
10:10:55:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:10:55:WU00:FS00:0xa7:    Version: 0.0.18
10:10:55:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:10:55:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:10:55:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:10:55:WU00:FS00:0xa7:       Time: 01:52:30
10:10:55:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:10:55:WU00:FS00:0xa7:************************************ Build *************************************
10:10:55:WU00:FS00:0xa7:       SIMD: avx_256
10:10:55:WU00:FS00:0xa7:********************************************************************************
10:10:55:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
10:10:55:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
10:10:55:WU00:FS00:0xa7:Digital signatures verified
10:10:55:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpi state.cpt -cpt 15 -nt 10
10:10:55:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
10:10:55:WU00:FS00:0xa7:Completed 6542 out of 2500000 steps (0%)
10:11:25:Saving configuration to config.xml
10:11:25:<config>
10:11:25:  <!-- Slot Control -->
10:11:25:  <power v='FULL'/>
10:11:25:
10:11:25:  <!-- User Information -->
10:11:25:  <passkey v='********************************'/>
10:11:25:  <user v='Timo_Pfeffer_2'/>
10:11:25:
10:11:25:  <!-- Folding Slots -->
10:11:25:  <slot id='0' type='CPU'/>
10:11:25:  <slot id='1' type='GPU'/>
10:11:25:</config>
10:13:28:FS00:Shutting core down
10:13:28:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 14644
10:13:28:WU00:FS00:0xa7:Exiting, please wait. . .
10:13:28:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:13:29:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:13:29:WU00:FS00:Starting
10:13:29:WARNING:WU00:FS00:Changed SMP threads from 11 to 10 this can cause some work units to fail
10:13:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 10
10:13:29:WU00:FS00:Started FahCore on PID 20000
10:13:29:WU00:FS00:Core PID:1384
10:13:29:WU00:FS00:FahCore 0xa7 started
10:13:29:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T10:13:29Z ***********************
10:13:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:13:29:WU00:FS00:0xa7:       Type: 0xa7
10:13:29:WU00:FS00:0xa7:       Core: Gromacs
10:13:29:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 20000 -checkpoint 15 -np
10:13:29:WU00:FS00:0xa7:             10
10:13:29:WU00:FS00:0xa7:************************************ CBang *************************************
10:13:29:WU00:FS00:0xa7:       Date: Oct 26 2019
10:13:29:WU00:FS00:0xa7:       Time: 01:38:25
10:13:29:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:13:29:WU00:FS00:0xa7:     Branch: master
10:13:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:13:29:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:13:29:WU00:FS00:0xa7:   Platform: win32 10
10:13:29:WU00:FS00:0xa7:       Bits: 64
10:13:29:WU00:FS00:0xa7:       Mode: Release
10:13:29:WU00:FS00:0xa7:************************************ System ************************************
10:13:29:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
10:13:29:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:13:29:WU00:FS00:0xa7:       CPUs: 12
10:13:29:WU00:FS00:0xa7:     Memory: 15.95GiB
10:13:29:WU00:FS00:0xa7:Free Memory: 9.24GiB
10:13:29:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:13:29:WU00:FS00:0xa7: OS Version: 6.2
10:13:29:WU00:FS00:0xa7:Has Battery: false
10:13:29:WU00:FS00:0xa7: On Battery: false
10:13:29:WU00:FS00:0xa7: UTC Offset: 1
10:13:29:WU00:FS00:0xa7:        PID: 1384
10:13:29:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
10:13:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:13:29:WU00:FS00:0xa7:    Version: 0.0.18
10:13:29:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:13:29:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:13:29:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:13:29:WU00:FS00:0xa7:       Time: 01:52:30
10:13:29:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:13:29:WU00:FS00:0xa7:************************************ Build *************************************
10:13:29:WU00:FS00:0xa7:       SIMD: avx_256
10:13:29:WU00:FS00:0xa7:********************************************************************************
10:13:29:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
10:13:29:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
10:13:29:WU00:FS00:0xa7:Digital signatures verified
10:13:29:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpi state.cpt -cpt 15 -nt 10
10:13:29:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
10:13:30:WU00:FS00:0xa7:Completed 23403 out of 2500000 steps (0%)
10:13:44:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
10:14:00:FS00:Shutting core down
10:14:00:FS01:Shutting core down
10:14:00:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 14992
10:14:00:WU01:FS01:0x21:Exiting, please wait. . .
10:14:00:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 1384
10:14:00:WU00:FS00:0xa7:Exiting, please wait. . .
10:14:01:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:14:01:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:14:01:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:14:18:WU01:FS01:Starting
10:14:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/amd/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
10:14:18:WU01:FS01:Started FahCore on PID 4772
10:14:18:WU01:FS01:Core PID:12652
10:14:18:WU01:FS01:FahCore 0x21 started
10:14:18:WU01:FS01:0x21:*********************** Log Started 2020-03-03T10:14:18Z ***********************
10:14:18:WU01:FS01:0x21:Project: 14180 (Run 11, Clone 366, Gen 100)
10:14:18:WU01:FS01:0x21:Unit: 0x000000a00002894c5d3b5625312dc7c1
10:14:18:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
10:14:18:WU01:FS01:0x21:Machine: 1
10:14:18:WU01:FS01:0x21:Digital signatures verified
10:14:18:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
10:14:18:WU01:FS01:0x21:Version 0.0.20
10:14:25:WU01:FS01:0x21:Completed 0 out of 12500000 steps (0%)
10:14:25:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
10:14:28:Saving configuration to config.xml
10:14:28:<config>
10:14:28:  <!-- Slot Control -->
10:14:28:  <power v='MEDIUM'/>
10:14:28:
10:14:28:  <!-- User Information -->
10:14:28:  <passkey v='********************************'/>
10:14:28:  <user v='Timo_Pfeffer_2'/>
10:14:28:
10:14:28:  <!-- Folding Slots -->
10:14:28:  <slot id='0' type='CPU'/>
10:14:28:  <slot id='1' type='GPU'/>
10:14:28:</config>
10:14:29:WU00:FS00:Starting
10:14:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 10
10:14:29:WU00:FS00:Started FahCore on PID 12748
10:14:29:WU00:FS00:Core PID:18420
10:14:29:WU00:FS00:FahCore 0xa7 started
10:14:29:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T10:14:29Z ***********************
10:14:29:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:14:29:WU00:FS00:0xa7:       Type: 0xa7
10:14:29:WU00:FS00:0xa7:       Core: Gromacs
10:14:29:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12748 -checkpoint 15 -np
10:14:29:WU00:FS00:0xa7:             10
10:14:29:WU00:FS00:0xa7:************************************ CBang *************************************
10:14:29:WU00:FS00:0xa7:       Date: Oct 26 2019
10:14:29:WU00:FS00:0xa7:       Time: 01:38:25
10:14:29:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:14:29:WU00:FS00:0xa7:     Branch: master
10:14:29:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:14:29:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:14:29:WU00:FS00:0xa7:   Platform: win32 10
10:14:29:WU00:FS00:0xa7:       Bits: 64
10:14:29:WU00:FS00:0xa7:       Mode: Release
10:14:29:WU00:FS00:0xa7:************************************ System ************************************
10:14:29:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
10:14:29:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:14:29:WU00:FS00:0xa7:       CPUs: 12
10:14:29:WU00:FS00:0xa7:     Memory: 15.95GiB
10:14:29:WU00:FS00:0xa7:Free Memory: 9.23GiB
10:14:29:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:14:29:WU00:FS00:0xa7: OS Version: 6.2
10:14:29:WU00:FS00:0xa7:Has Battery: false
10:14:29:WU00:FS00:0xa7: On Battery: false
10:14:29:WU00:FS00:0xa7: UTC Offset: 1
10:14:29:WU00:FS00:0xa7:        PID: 18420
10:14:29:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
10:14:29:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:14:29:WU00:FS00:0xa7:    Version: 0.0.18
10:14:29:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:14:29:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:14:29:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:14:29:WU00:FS00:0xa7:       Time: 01:52:30
10:14:29:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:14:29:WU00:FS00:0xa7:************************************ Build *************************************
10:14:29:WU00:FS00:0xa7:       SIMD: avx_256
10:14:29:WU00:FS00:0xa7:********************************************************************************
10:14:29:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
10:14:29:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
10:14:29:WU00:FS00:0xa7:Digital signatures verified
10:14:29:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpi state.cpt -cpt 15 -nt 10
10:14:29:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
10:14:30:WU00:FS00:0xa7:Completed 26942 out of 2500000 steps (1%)
10:15:47:FS00:Shutting core down
10:15:47:FS01:Shutting core down
10:15:48:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 12652
10:15:48:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 18420
10:15:48:WU01:FS01:0x21:Exiting, please wait. . .
10:15:48:WU00:FS00:0xa7:Exiting, please wait. . .
10:15:48:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
10:15:48:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
10:15:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:15:48:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
10:15:48:WU00:FS00:Starting
10:15:48:WARNING:WU00:FS00:Changed SMP threads from 10 to 5 this can cause some work units to fail
10:15:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 5
10:15:48:WU00:FS00:Started FahCore on PID 13000
10:15:48:WU00:FS00:Core PID:11768
10:15:48:WU00:FS00:FahCore 0xa7 started
10:15:49:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T10:15:48Z ***********************
10:15:49:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:15:49:WU00:FS00:0xa7:       Type: 0xa7
10:15:49:WU00:FS00:0xa7:       Core: Gromacs
10:15:49:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 13000 -checkpoint 15 -np
10:15:49:WU00:FS00:0xa7:             5
10:15:49:WU00:FS00:0xa7:************************************ CBang *************************************
10:15:49:WU00:FS00:0xa7:       Date: Oct 26 2019
10:15:49:WU00:FS00:0xa7:       Time: 01:38:25
10:15:49:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:15:49:WU00:FS00:0xa7:     Branch: master
10:15:49:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
10:15:49:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:15:49:WU00:FS00:0xa7:   Platform: win32 10
10:15:49:WU00:FS00:0xa7:       Bits: 64
10:15:49:WU00:FS00:0xa7:       Mode: Release
10:15:49:WU00:FS00:0xa7:************************************ System ************************************
10:15:49:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
10:15:49:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:15:49:WU00:FS00:0xa7:       CPUs: 12
10:15:49:WU00:FS00:0xa7:     Memory: 15.95GiB
10:15:49:WU00:FS00:0xa7:Free Memory: 9.37GiB
10:15:49:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:15:49:WU00:FS00:0xa7: OS Version: 6.2
10:15:49:WU00:FS00:0xa7:Has Battery: false
10:15:49:WU00:FS00:0xa7: On Battery: false
10:15:49:WU00:FS00:0xa7: UTC Offset: 1
10:15:49:WU00:FS00:0xa7:        PID: 11768
10:15:49:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
10:15:49:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
10:15:49:WU00:FS00:0xa7:    Version: 0.0.18
10:15:49:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:15:49:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:15:49:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
10:15:49:WU00:FS00:0xa7:       Time: 01:52:30
10:15:49:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:15:49:WU00:FS00:0xa7:************************************ Build *************************************
10:15:49:WU00:FS00:0xa7:       SIMD: avx_256
10:15:49:WU00:FS00:0xa7:********************************************************************************
10:15:49:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
10:15:49:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
10:15:49:WU00:FS00:0xa7:Digital signatures verified
10:15:49:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
10:15:49:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpi state.cpt -cpt 15 -nt 4
10:15:49:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
10:15:49:WU00:FS00:0xa7:Completed 35842 out of 2500000 steps (1%)
10:16:30:Saving configuration to config.xml
10:16:30:<config>
10:16:30:  <!-- Slot Control -->
10:16:30:  <power v='LIGHT'/>
10:16:30:
10:16:30:  <!-- User Information -->
10:16:30:  <passkey v='********************************'/>
10:16:30:  <user v='Timo_Pfeffer_2'/>
10:16:30:
10:16:30:  <!-- Folding Slots -->
10:16:30:  <slot id='0' type='CPU'/>
10:16:30:  <slot id='1' type='GPU'/>
10:16:30:</config>
10:19:54:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
10:26:45:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
10:34:08:WU00:FS00:0xa7:Completed 100000 out of 2500000 steps (4%)
Oimel1987
RX 570 not folding
Post by Oimel1987 »
my RX 570 is not detected. It always says in SystemInfo that nvcuda.dll is not found
11:16:02:FS00:Unpaused
11:16:02:FS01:Unpaused
11:16:29:Saving configuration to config.xml
11:16:29:<config>
11:16:29:  <!-- Slot Control -->
11:16:29:  <power v='LIGHT'/>
11:16:29:
11:16:29:  <!-- User Information -->
11:16:29:  <passkey v='********************************'/>
11:16:29:  <user v='Timo_Pfeffer_2'/>
11:16:29:
11:16:29:  <!-- Folding Slots -->
11:16:29:  <slot id='0' type='CPU'/>
11:16:29:  <slot id='1' type='GPU'/>
11:16:29:</config>
11:16:47:WU00:FS00:Starting
11:16:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\pfeff\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 768 -checkpoint 15 -np 5
11:16:47:WU00:FS00:Started FahCore on PID 9480
11:16:47:WU00:FS00:Core PID:9504
11:16:47:WU00:FS00:FahCore 0xa7 started
11:16:48:WU00:FS00:0xa7:*********************** Log Started 2020-03-03T11:16:47Z ***********************
11:16:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:16:48:WU00:FS00:0xa7:       Type: 0xa7
11:16:48:WU00:FS00:0xa7:       Core: Gromacs
11:16:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9480 -checkpoint 15 -np 5
11:16:48:WU00:FS00:0xa7:************************************ CBang *************************************
11:16:48:WU00:FS00:0xa7:       Date: Oct 26 2019
11:16:48:WU00:FS00:0xa7:       Time: 01:38:25
11:16:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:16:48:WU00:FS00:0xa7:     Branch: master
11:16:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:16:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:16:48:WU00:FS00:0xa7:   Platform: win32 10
11:16:48:WU00:FS00:0xa7:       Bits: 64
11:16:48:WU00:FS00:0xa7:       Mode: Release
11:16:48:WU00:FS00:0xa7:************************************ System ************************************
11:16:48:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 2600 Six-Core Processor
11:16:48:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
11:16:48:WU00:FS00:0xa7:       CPUs: 12
11:16:48:WU00:FS00:0xa7:     Memory: 15.95GiB
11:16:48:WU00:FS00:0xa7:Free Memory: 10.05GiB
11:16:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:16:48:WU00:FS00:0xa7: OS Version: 6.2
11:16:48:WU00:FS00:0xa7:Has Battery: false
11:16:48:WU00:FS00:0xa7: On Battery: false
11:16:48:WU00:FS00:0xa7: UTC Offset: 1
11:16:48:WU00:FS00:0xa7:        PID: 9504
11:16:48:WU00:FS00:0xa7:        CWD: C:\Users\pfeff\AppData\Roaming\FAHClient\work
11:16:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:16:48:WU00:FS00:0xa7:    Version: 0.0.18
11:16:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:16:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:16:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:16:48:WU00:FS00:0xa7:       Time: 01:52:30
11:16:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:16:48:WU00:FS00:0xa7:************************************ Build *************************************
11:16:48:WU00:FS00:0xa7:       SIMD: avx_256
11:16:48:WU00:FS00:0xa7:********************************************************************************
11:16:48:WU00:FS00:0xa7:Project: 14183 (Run 3, Clone 40, Gen 69)
11:16:48:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5cf936277ac68688
11:16:48:WU00:FS00:0xa7:Digital signatures verified
11:16:48:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
11:16:48:WU00:FS00:0xa7:Calling: mdrun -s frame69.tpr -o frame69.trr -cpi state.cpt -cpt 15 -nt 4
11:16:48:WU00:FS00:0xa7:Steps: first=172500000 total=2500000
11:16:48:WU00:FS00:0xa7:Completed 237142 out of 2500000 steps (9%)
Re: RX 570 not folding
Actually the client does recognize that you have a Radeon GPU later in the log after initialization and setup has completed. You can ignore the message about the nvcuda.dll not being found, that only applies if you have a nVidia GPU in your system.
At this point the client downloaded an updated GPUs.txt file and creates a folding slot for your GPU:
Later on at 10:09:24 WU's for a CPU slot and the slot created for your GPU are downloaded and started. That includes folding cores being downloaded for both slots to handle the processing of the WU's. What shows in the log after that are multiple restart connected with the power slider position being changed. On the last start shown in the log the GPU is not started because on the Light setting its slot only runs when the PC interactive use is detected as inactive.
Just merged your second post into this topic, same condition of the client on the Light setting not seeing your system as inactive for interactive use. On windows the client is waiting for the OS to indicate inactivity, no keyboard or mouse usage for a period of time. If after a few minutes of not using either, the client still does not start the GPU slot, let us know. We can do further trouble shooting or suggest configuration changes to get you going.
Oimel1987
Post by Oimel1987 »
thx so far :-) I have set it now to "while I'm working" and "medium". The GPU is now really folding :-) The thing which is now interesting me is: why is the setting "medium" uses "100%" of my Ryzen 2600 ?
