GTX 960m Failed Status
auride
Post by auride »
I installed F@H for the first time today on a Dell Inspiron 7559 which I've had for a few years. It has a broken screen but otherwise operates fine, so I thought I should use it for folding since it was otherwise gathering dust.
After installing F@H, CPU (i5 6300HQ) folding seems to work fine, but the GPU (Nvidia GTX 960m) folding displays a "Failed" status in both the web control client and FAHControl. It seems that when the client starts, it tries to download a project several times, but the download repeatedly stops, and eventually the client gives up.
Here's the log:
*********************** Log Started 2020-02-23T21:49:04Z ***********************
21:49:05:WU00:FS01:Connecting to 65.254.110.245:8080
21:49:06:WU00:FS01:Assigned to work server 155.247.166.220
21:49:06:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 155.247.166.220
21:49:06:WU00:FS01:Connecting to 155.247.166.220:8080
21:49:07:WU00:FS01:Downloading 15.86MiB
21:49:13:WU00:FS01:Download 84.74%
21:49:13:WU00:FS01:Download complete
21:49:14:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14180 run:4 clone:563 gen:23 core:0x21 unit:0x000000260002894c5d3b54e13cd08d9b
21:49:14:WU00:FS01:Starting
21:49:14:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:49:14:WU00:FS01:Started FahCore on PID 10048
21:49:14:WU00:FS01:Core PID:8188
21:49:14:WU00:FS01:FahCore 0x21 started
21:49:14:WU00:FS01:0x21:*********************** Log Started 2020-02-23T21:49:14Z ***********************
21:49:14:WU00:FS01:0x21:Project: 14180 (Run 4, Clone 563, Gen 23)
21:49:14:WU00:FS01:0x21:Unit: 0x000000260002894c5d3b54e13cd08d9b
21:49:14:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:49:14:WU00:FS01:0x21:Machine: 1
21:49:14:WU00:FS01:0x21:Reading tar file core.xml
21:49:14:WU00:FS01:0x21:Reading tar file integrator.xml
21:49:14:WU00:FS01:0x21:Reading tar file state.xml
21:49:14:WU00:FS01:0x21:Reading tar file system.xml
21:49:15:WU00:FS01:0x21:Digital signatures verified
21:49:15:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:49:15:WU00:FS01:0x21:Version 0.0.20
21:49:20:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:49:20:WU00:FS01:0x21:Saving result file logfile_01.txt
21:49:20:WU00:FS01:0x21:Saving result file log.txt
21:49:20:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
21:49:20:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:49:20:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14180 run:4 clone:563 gen:23 core:0x21 unit:0x000000260002894c5d3b54e13cd08d9b
21:49:20:WU00:FS01:Uploading 7.50KiB to 155.247.166.220
21:49:20:WU00:FS01:Connecting to 155.247.166.220:8080
21:49:20:WU00:FS01:Upload complete
21:49:20:WU00:FS01:Server responded WORK_ACK (400)
21:49:20:WU00:FS01:Cleaning up
21:49:20:WU00:FS01:Connecting to 65.254.110.245:8080
21:49:20:WU00:FS01:Assigned to work server 155.247.166.220
21:49:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 155.247.166.220
21:49:21:WU00:FS01:Downloading 15.62MiB
21:49:27:WU00:FS01:Download 77.62%
21:49:28:WU00:FS01:Download complete
21:49:28:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14180 run:0 clone:565 gen:23 core:0x21 unit:0x000000230002894c5d3b542c6db85630
21:49:28:WU00:FS01:Starting
21:49:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:49:28:WU00:FS01:Started FahCore on PID 11064
21:49:28:WU00:FS01:Core PID:11088
21:49:28:WU00:FS01:FahCore 0x21 started
21:49:28:WU00:FS01:0x21:*********************** Log Started 2020-02-23T21:49:28Z ***********************
21:49:28:WU00:FS01:0x21:Project: 14180 (Run 0, Clone 565, Gen 23)
21:49:28:WU00:FS01:0x21:Unit: 0x000000230002894c5d3b542c6db85630
21:49:28:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:49:28:WU00:FS01:0x21:Machine: 1
21:49:28:WU00:FS01:0x21:Reading tar file core.xml
21:49:28:WU00:FS01:0x21:Reading tar file integrator.xml
21:49:28:WU00:FS01:0x21:Reading tar file state.xml
21:49:28:WU00:FS01:0x21:Reading tar file system.xml
21:49:28:WU00:FS01:0x21:Digital signatures verified
21:49:28:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:49:28:WU00:FS01:0x21:Version 0.0.20
21:49:33:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:49:33:WU00:FS01:0x21:Saving result file logfile_01.txt
21:49:33:WU00:FS01:0x21:Saving result file log.txt
21:49:33:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
21:49:34:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:49:34:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14180 run:0 clone:565 gen:23 core:0x21 unit:0x000000230002894c5d3b542c6db85630
21:49:34:WU00:FS01:Uploading 7.50KiB to 155.247.166.220
21:49:34:WU00:FS01:Connecting to 155.247.166.220:8080
21:49:34:WU00:FS01:Upload complete
21:49:34:WU00:FS01:Server responded WORK_ACK (400)
21:49:34:WU00:FS01:Cleaning up
21:49:34:WU01:FS01:Connecting to 65.254.110.245:8080
21:49:34:WU01:FS01:Assigned to work server 155.247.166.220
21:49:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 155.247.166.220
21:49:34:WU01:FS01:Connecting to 155.247.166.220:8080
21:49:34:WU01:FS01:Downloading 5.82MiB
21:49:40:WU01:FS01:Download 98.86%
21:49:40:WU01:FS01:Download complete
21:49:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14320 run:281 clone:2 gen:56 core:0x21 unit:0x0000005f0002894c5dfebaedc1a2fa2d
21:49:40:WU01:FS01:Starting
21:49:40:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:49:40:WU01:FS01:Started FahCore on PID 10592
21:49:40:WU01:FS01:Core PID:10612
21:49:40:WU01:FS01:FahCore 0x21 started
21:49:40:WU01:FS01:0x21:*********************** Log Started 2020-02-23T21:49:40Z ***********************
21:49:40:WU01:FS01:0x21:Project: 14320 (Run 281, Clone 2, Gen 56)
21:49:40:WU01:FS01:0x21:Unit: 0x0000005f0002894c5dfebaedc1a2fa2d
21:49:40:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:49:40:WU01:FS01:0x21:Machine: 1
21:49:40:WU01:FS01:0x21:Reading tar file core.xml
21:49:40:WU01:FS01:0x21:Reading tar file integrator.xml
21:49:40:WU01:FS01:0x21:Reading tar file state.xml
21:49:40:WU01:FS01:0x21:Reading tar file system.xml
21:49:40:WU01:FS01:0x21:Digital signatures verified
21:49:40:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:49:40:WU01:FS01:0x21:Version 0.0.20
21:49:43:WU01:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:49:43:WU01:FS01:0x21:Saving result file logfile_01.txt
21:49:43:WU01:FS01:0x21:Saving result file log.txt
21:49:43:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
21:49:43:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:49:43:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:14320 run:281 clone:2 gen:56 core:0x21 unit:0x0000005f0002894c5dfebaedc1a2fa2d
21:49:43:WU01:FS01:Uploading 7.50KiB to 155.247.166.220
21:49:43:WU01:FS01:Connecting to 155.247.166.220:8080
21:49:43:WU01:FS01:Upload complete
21:49:43:WU01:FS01:Server responded WORK_ACK (400)
21:49:43:WU01:FS01:Cleaning up
21:49:43:WU00:FS01:Connecting to 65.254.110.245:8080
21:49:44:WU00:FS01:Assigned to work server 155.247.166.220
21:49:44:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 155.247.166.220
21:49:44:WU00:FS01:Connecting to 155.247.166.220:8080
21:49:44:WU00:FS01:Downloading 5.82MiB
21:49:47:WU00:FS01:Download complete
21:49:47:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14320 run:70 clone:7 gen:35 core:0x21 unit:0x000000310002894c5dfebadb97fc2775
21:49:47:WU00:FS01:Starting
21:49:47:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:49:47:WU00:FS01:Started FahCore on PID 2176
21:49:47:WU00:FS01:Core PID:2580
21:49:47:WU00:FS01:FahCore 0x21 started
21:49:47:WU00:FS01:0x21:*********************** Log Started 2020-02-23T21:49:47Z ***********************
21:49:47:WU00:FS01:0x21:Project: 14320 (Run 70, Clone 7, Gen 35)
21:49:47:WU00:FS01:0x21:Unit: 0x000000310002894c5dfebadb97fc2775
21:49:47:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:49:47:WU00:FS01:0x21:Machine: 1
21:49:47:WU00:FS01:0x21:Reading tar file core.xml
21:49:47:WU00:FS01:0x21:Reading tar file integrator.xml
21:49:47:WU00:FS01:0x21:Reading tar file state.xml
21:49:47:WU00:FS01:0x21:Reading tar file system.xml
21:49:47:WU00:FS01:0x21:Digital signatures verified
21:49:47:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:49:47:WU00:FS01:0x21:Version 0.0.20
21:49:50:WU00:FS01:0x21:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:49:50:WU00:FS01:0x21:Saving result file logfile_01.txt
21:49:50:WU00:FS01:0x21:Saving result file log.txt
21:49:50:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
21:49:50:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:49:50:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:14320 run:70 clone:7 gen:35 core:0x21 unit:0x000000310002894c5dfebadb97fc2775
21:49:50:WU00:FS01:Uploading 7.50KiB to 155.247.166.220
21:49:50:WU00:FS01:Connecting to 155.247.166.220:8080
21:49:50:WU00:FS01:Upload complete
21:49:50:WU00:FS01:Server responded WORK_ACK (400)
21:49:50:WU00:FS01:Cleaning up
21:49:50:WU00:FS01:Connecting to 65.254.110.245:8080
21:49:51:WU00:FS01:Assigned to work server 140.163.4.241
21:49:51:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:49:51:WU00:FS01:Connecting to 140.163.4.241:8080
21:49:51:WU00:FS01:Downloading 11.66MiB
21:49:55:WU00:FS01:Download complete
21:49:55:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:4983 gen:74 core:0x22 unit:0x000000628ca304f15e34fa4723192f47
21:49:55:WU00:FS01:Starting
21:49:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:49:55:WU00:FS01:Started FahCore on PID 5932
21:49:55:WU00:FS01:Core PID:2376
21:49:55:WU00:FS01:FahCore 0x22 started
21:49:56:WU00:FS01:0x22:*********************** Log Started 2020-02-23T21:49:56Z ***********************
21:49:56:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:49:56:WU00:FS01:0x22:       Type: 0x22
21:49:56:WU00:FS01:0x22:       Core: Core22
21:49:56:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:49:56:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:49:56:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:49:56:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:49:56:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5932 -checkpoint 15
21:49:56:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:49:56:WU00:FS01:0x22:             0 -gpu 0
21:49:56:WU00:FS01:0x22:     Config: <none>
21:49:56:WU00:FS01:0x22:************************************ Build *************************************
21:49:56:WU00:FS01:0x22:    Version: 0.0.2
21:49:56:WU00:FS01:0x22:       Date: Dec 6 2019
21:49:56:WU00:FS01:0x22:       Time: 21:30:31
21:49:56:WU00:FS01:0x22: Repository: Git
21:49:56:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:49:56:WU00:FS01:0x22:     Branch: HEAD
21:49:56:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:49:56:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:49:56:WU00:FS01:0x22:   Platform: win32 10
21:49:56:WU00:FS01:0x22:       Bits: 64
21:49:56:WU00:FS01:0x22:       Mode: Release
21:49:56:WU00:FS01:0x22:************************************ System ************************************
21:49:56:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:49:56:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:49:56:WU00:FS01:0x22:       CPUs: 4
21:49:56:WU00:FS01:0x22:     Memory: 7.88GiB
21:49:56:WU00:FS01:0x22:Free Memory: 5.28GiB
21:49:56:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:49:56:WU00:FS01:0x22: OS Version: 6.2
21:49:56:WU00:FS01:0x22:Has Battery: true
21:49:56:WU00:FS01:0x22: On Battery: false
21:49:56:WU00:FS01:0x22: UTC Offset: -8
21:49:56:WU00:FS01:0x22:        PID: 2376
21:49:56:WU00:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:49:56:WU00:FS01:0x22:         OS: Windows 10 Home
21:49:56:WU00:FS01:0x22:    OS Arch: AMD64
21:49:56:WU00:FS01:0x22:********************************************************************************
21:49:56:WU00:FS01:0x22:Project: 11737 (Run 0, Clone 4983, Gen 74)
21:49:56:WU00:FS01:0x22:Unit: 0x000000628ca304f15e34fa4723192f47
21:49:56:WU00:FS01:0x22:Reading tar file core.xml
21:49:56:WU00:FS01:0x22:Reading tar file integrator.xml
21:49:56:WU00:FS01:0x22:Reading tar file state.xml
21:49:56:WU00:FS01:0x22:Reading tar file system.xml
21:49:56:WU00:FS01:0x22:Digital signatures verified
21:49:56:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:49:56:WU00:FS01:0x22:Version 0.0.2
21:49:58:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:49:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11737 run:0 clone:4983 gen:74 core:0x22 unit:0x000000628ca304f15e34fa4723192f47
21:49:58:WU00:FS01:Uploading 8.00KiB to 140.163.4.241
21:49:58:WU00:FS01:Connecting to 140.163.4.241:8080
21:49:58:WU00:FS01:Upload complete
21:49:58:WU00:FS01:Server responded WORK_ACK (400)
21:49:58:WU00:FS01:Cleaning up
21:49:58:WU00:FS01:Connecting to 65.254.110.245:8080
21:49:59:WU00:FS01:Assigned to work server 140.163.4.241
21:49:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:49:59:WU00:FS01:Connecting to 140.163.4.241:8080
21:49:59:WU00:FS01:Downloading 11.65MiB
21:50:03:WU00:FS01:Download complete
21:50:03:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:3408 gen:58 core:0x22 unit:0x000000488ca304f15e34fa3e382d2e22
21:50:03:WU00:FS01:Starting
21:50:03:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:03:WU00:FS01:Started FahCore on PID 11036
21:50:03:WU00:FS01:Core PID:11060
21:50:03:WU00:FS01:FahCore 0x22 started
21:50:04:WU00:FS01:0x22:*********************** Log Started 2020-02-23T21:50:03Z ***********************
21:50:04:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:50:04:WU00:FS01:0x22:       Type: 0x22
21:50:04:WU00:FS01:0x22:       Core: Core22
21:50:04:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:50:04:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:50:04:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:50:04:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:50:04:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 11036 -checkpoint 15
21:50:04:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:50:04:WU00:FS01:0x22:             0 -gpu 0
21:50:04:WU00:FS01:0x22:     Config: <none>
21:50:04:WU00:FS01:0x22:************************************ Build *************************************
21:50:04:WU00:FS01:0x22:    Version: 0.0.2
21:50:04:WU00:FS01:0x22:       Date: Dec 6 2019
21:50:04:WU00:FS01:0x22:       Time: 21:30:31
21:50:04:WU00:FS01:0x22: Repository: Git
21:50:04:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:50:04:WU00:FS01:0x22:     Branch: HEAD
21:50:04:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:50:04:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:04:WU00:FS01:0x22:   Platform: win32 10
21:50:04:WU00:FS01:0x22:       Bits: 64
21:50:04:WU00:FS01:0x22:       Mode: Release
21:50:04:WU00:FS01:0x22:************************************ System ************************************
21:50:04:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:50:04:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:50:04:WU00:FS01:0x22:       CPUs: 4
21:50:04:WU00:FS01:0x22:     Memory: 7.88GiB
21:50:04:WU00:FS01:0x22:Free Memory: 5.33GiB
21:50:04:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:50:04:WU00:FS01:0x22: OS Version: 6.2
21:50:04:WU00:FS01:0x22:Has Battery: true
21:50:04:WU00:FS01:0x22: On Battery: false
21:50:04:WU00:FS01:0x22: UTC Offset: -8
21:50:04:WU00:FS01:0x22:        PID: 11060
21:50:04:WU00:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:50:04:WU00:FS01:0x22:         OS: Windows 10 Home
21:50:04:WU00:FS01:0x22:    OS Arch: AMD64
21:50:04:WU00:FS01:0x22:********************************************************************************
21:50:04:WU00:FS01:0x22:Project: 11737 (Run 0, Clone 3408, Gen 58)
21:50:04:WU00:FS01:0x22:Unit: 0x000000488ca304f15e34fa3e382d2e22
21:50:04:WU00:FS01:0x22:Reading tar file core.xml
21:50:04:WU00:FS01:0x22:Reading tar file integrator.xml
21:50:04:WU00:FS01:0x22:Reading tar file state.xml
21:50:04:WU00:FS01:0x22:Reading tar file system.xml
21:50:04:WU00:FS01:0x22:Digital signatures verified
21:50:04:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:50:04:WU00:FS01:0x22:Version 0.0.2
21:50:06:WU00:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:50:06:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
21:50:06:WU00:FS01:0x22:Saving result file science.log
21:50:06:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:06:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:06:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11737 run:0 clone:3408 gen:58 core:0x22 unit:0x000000488ca304f15e34fa3e382d2e22
21:50:06:WU00:FS01:Uploading 8.00KiB to 140.163.4.241
21:50:06:WU00:FS01:Connecting to 140.163.4.241:8080
21:50:06:WU00:FS01:Upload complete
21:50:07:WU00:FS01:Server responded WORK_ACK (400)
21:50:07:WU00:FS01:Cleaning up
21:50:07:WU01:FS01:Connecting to 65.254.110.245:8080
21:50:07:WU01:FS01:Assigned to work server 140.163.4.241
21:50:07:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:50:07:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:07:WU01:FS01:Downloading 11.66MiB
21:50:13:WU01:FS01:Download 39.14%
21:50:15:WU01:FS01:Download complete
21:50:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:280 gen:97 core:0x22 unit:0x0000007a8ca304f15df3d374e0ddf26b
21:50:16:WU01:FS01:Starting
21:50:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:16:WU01:FS01:Started FahCore on PID 704
21:50:16:WU01:FS01:Core PID:11092
21:50:16:WU01:FS01:FahCore 0x22 started
21:50:16:WU01:FS01:0x22:*********************** Log Started 2020-02-23T21:50:16Z ***********************
21:50:16:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:50:16:WU01:FS01:0x22:       Type: 0x22
21:50:16:WU01:FS01:0x22:       Core: Core22
21:50:16:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:50:16:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:50:16:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:50:16:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:50:16:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 704 -checkpoint 15
21:50:16:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:50:16:WU01:FS01:0x22:             0 -gpu 0
21:50:16:WU01:FS01:0x22:     Config: <none>
21:50:16:WU01:FS01:0x22:************************************ Build *************************************
21:50:16:WU01:FS01:0x22:    Version: 0.0.2
21:50:16:WU01:FS01:0x22:       Date: Dec 6 2019
21:50:16:WU01:FS01:0x22:       Time: 21:30:31
21:50:16:WU01:FS01:0x22: Repository: Git
21:50:16:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:50:16:WU01:FS01:0x22:     Branch: HEAD
21:50:16:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:50:16:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:16:WU01:FS01:0x22:   Platform: win32 10
21:50:16:WU01:FS01:0x22:       Bits: 64
21:50:16:WU01:FS01:0x22:       Mode: Release
21:50:16:WU01:FS01:0x22:************************************ System ************************************
21:50:16:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:50:16:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:50:16:WU01:FS01:0x22:       CPUs: 4
21:50:16:WU01:FS01:0x22:     Memory: 7.88GiB
21:50:16:WU01:FS01:0x22:Free Memory: 5.18GiB
21:50:16:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:50:16:WU01:FS01:0x22: OS Version: 6.2
21:50:16:WU01:FS01:0x22:Has Battery: true
21:50:16:WU01:FS01:0x22: On Battery: false
21:50:16:WU01:FS01:0x22: UTC Offset: -8
21:50:16:WU01:FS01:0x22:        PID: 11092
21:50:16:WU01:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:50:16:WU01:FS01:0x22:         OS: Windows 10 Home
21:50:16:WU01:FS01:0x22:    OS Arch: AMD64
21:50:16:WU01:FS01:0x22:********************************************************************************
21:50:16:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 280, Gen 97)
21:50:16:WU01:FS01:0x22:Unit: 0x0000007a8ca304f15df3d374e0ddf26b
21:50:16:WU01:FS01:0x22:Reading tar file core.xml
21:50:16:WU01:FS01:0x22:Reading tar file integrator.xml
21:50:16:WU01:FS01:0x22:Reading tar file state.xml
21:50:16:WU01:FS01:0x22:Reading tar file system.xml
21:50:16:WU01:FS01:0x22:Digital signatures verified
21:50:16:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:50:16:WU01:FS01:0x22:Version 0.0.2
21:50:18:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:50:18:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:50:18:WU01:FS01:0x22:Saving result file science.log
21:50:19:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:280 gen:97 core:0x22 unit:0x0000007a8ca304f15df3d374e0ddf26b
21:50:19:WU01:FS01:Uploading 8.00KiB to 140.163.4.241
21:50:19:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:19:WU02:FS01:Connecting to 65.254.110.245:8080
21:50:19:WU02:FS01:Assigned to work server 140.163.4.241
21:50:19:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:50:19:WU02:FS01:Connecting to 140.163.4.241:8080
21:50:20:WU01:FS01:Upload complete
21:50:20:WU01:FS01:Server responded WORK_ACK (400)
21:50:20:WU01:FS01:Cleaning up
21:50:20:WU02:FS01:Downloading 11.66MiB
21:50:26:WU02:FS01:Download 94.88%
21:50:26:WU02:FS01:Download complete
21:50:26:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:1423 gen:57 core:0x22 unit:0x0000005a8ca304f15dfbe6d6d12c1aac
21:50:26:WU02:FS01:Starting
21:50:26:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:26:WU02:FS01:Started FahCore on PID 1780
21:50:26:WU02:FS01:Core PID:1960
21:50:26:WU02:FS01:FahCore 0x22 started
21:50:26:WU02:FS01:0x22:*********************** Log Started 2020-02-23T21:50:26Z ***********************
21:50:26:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:50:26:WU02:FS01:0x22:       Type: 0x22
21:50:26:WU02:FS01:0x22:       Core: Core22
21:50:26:WU02:FS01:0x22:    Website: https://foldingathome.org/
21:50:26:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:50:26:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:50:26:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:50:26:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 1780 -checkpoint 15
21:50:26:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:50:26:WU02:FS01:0x22:             0 -gpu 0
21:50:26:WU02:FS01:0x22:     Config: <none>
21:50:26:WU02:FS01:0x22:************************************ Build *************************************
21:50:26:WU02:FS01:0x22:    Version: 0.0.2
21:50:26:WU02:FS01:0x22:       Date: Dec 6 2019
21:50:26:WU02:FS01:0x22:       Time: 21:30:31
21:50:26:WU02:FS01:0x22: Repository: Git
21:50:26:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:50:26:WU02:FS01:0x22:     Branch: HEAD
21:50:26:WU02:FS01:0x22:   Compiler: Visual C++ 2008
21:50:26:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:26:WU02:FS01:0x22:   Platform: win32 10
21:50:26:WU02:FS01:0x22:       Bits: 64
21:50:26:WU02:FS01:0x22:       Mode: Release
21:50:26:WU02:FS01:0x22:************************************ System ************************************
21:50:26:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:50:26:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:50:26:WU02:FS01:0x22:       CPUs: 4
21:50:26:WU02:FS01:0x22:     Memory: 7.88GiB
21:50:26:WU02:FS01:0x22:Free Memory: 5.15GiB
21:50:26:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
21:50:26:WU02:FS01:0x22: OS Version: 6.2
21:50:26:WU02:FS01:0x22:Has Battery: true
21:50:26:WU02:FS01:0x22: On Battery: false
21:50:26:WU02:FS01:0x22: UTC Offset: -8
21:50:26:WU02:FS01:0x22:        PID: 1960
21:50:26:WU02:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:50:26:WU02:FS01:0x22:         OS: Windows 10 Home
21:50:26:WU02:FS01:0x22:    OS Arch: AMD64
21:50:26:WU02:FS01:0x22:********************************************************************************
21:50:26:WU02:FS01:0x22:Project: 11737 (Run 0, Clone 1423, Gen 57)
21:50:26:WU02:FS01:0x22:Unit: 0x0000005a8ca304f15dfbe6d6d12c1aac
21:50:26:WU02:FS01:0x22:Reading tar file core.xml
21:50:26:WU02:FS01:0x22:Reading tar file integrator.xml
21:50:26:WU02:FS01:0x22:Reading tar file state.xml
21:50:26:WU02:FS01:0x22:Reading tar file system.xml
21:50:26:WU02:FS01:0x22:Digital signatures verified
21:50:26:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:50:26:WU02:FS01:0x22:Version 0.0.2
21:50:29:WU02:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:50:29:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
21:50:29:WU02:FS01:0x22:Saving result file science.log
21:50:29:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:30:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:30:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11737 run:0 clone:1423 gen:57 core:0x22 unit:0x0000005a8ca304f15dfbe6d6d12c1aac
21:50:30:WU02:FS01:Uploading 8.00KiB to 140.163.4.241
21:50:30:WU02:FS01:Connecting to 140.163.4.241:8080
21:50:30:WU02:FS01:Upload complete
21:50:30:WU02:FS01:Server responded WORK_ACK (400)
21:50:30:WU02:FS01:Cleaning up
21:50:30:WU01:FS01:Connecting to 65.254.110.245:8080
21:50:30:WU01:FS01:Assigned to work server 140.163.4.241
21:50:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:50:30:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:31:WU01:FS01:Downloading 11.65MiB
21:50:36:WU01:FS01:Download complete
21:50:36:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:4264 gen:46 core:0x22 unit:0x000000418ca304f15e34fa4263cf5eab
21:50:36:WU01:FS01:Starting
21:50:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:36:WU01:FS01:Started FahCore on PID 9220
21:50:36:WU01:FS01:Core PID:2672
21:50:36:WU01:FS01:FahCore 0x22 started
21:50:37:WU01:FS01:0x22:*********************** Log Started 2020-02-23T21:50:37Z ***********************
21:50:37:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:50:37:WU01:FS01:0x22:       Type: 0x22
21:50:37:WU01:FS01:0x22:       Core: Core22
21:50:37:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:50:37:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:50:37:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:50:37:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:50:37:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 9220 -checkpoint 15
21:50:37:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:50:37:WU01:FS01:0x22:             0 -gpu 0
21:50:37:WU01:FS01:0x22:     Config: <none>
21:50:37:WU01:FS01:0x22:************************************ Build *************************************
21:50:37:WU01:FS01:0x22:    Version: 0.0.2
21:50:37:WU01:FS01:0x22:       Date: Dec 6 2019
21:50:37:WU01:FS01:0x22:       Time: 21:30:31
21:50:37:WU01:FS01:0x22: Repository: Git
21:50:37:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:50:37:WU01:FS01:0x22:     Branch: HEAD
21:50:37:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:50:37:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:37:WU01:FS01:0x22:   Platform: win32 10
21:50:37:WU01:FS01:0x22:       Bits: 64
21:50:37:WU01:FS01:0x22:       Mode: Release
21:50:37:WU01:FS01:0x22:************************************ System ************************************
21:50:37:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:50:37:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:50:37:WU01:FS01:0x22:       CPUs: 4
21:50:37:WU01:FS01:0x22:     Memory: 7.88GiB
21:50:37:WU01:FS01:0x22:Free Memory: 5.16GiB
21:50:37:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:50:37:WU01:FS01:0x22: OS Version: 6.2
21:50:37:WU01:FS01:0x22:Has Battery: true
21:50:37:WU01:FS01:0x22: On Battery: false
21:50:37:WU01:FS01:0x22: UTC Offset: -8
21:50:37:WU01:FS01:0x22:        PID: 2672
21:50:37:WU01:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:50:37:WU01:FS01:0x22:         OS: Windows 10 Home
21:50:37:WU01:FS01:0x22:    OS Arch: AMD64
21:50:37:WU01:FS01:0x22:********************************************************************************
21:50:37:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 4264, Gen 46)
21:50:37:WU01:FS01:0x22:Unit: 0x000000418ca304f15e34fa4263cf5eab
21:50:37:WU01:FS01:0x22:Reading tar file core.xml
21:50:37:WU01:FS01:0x22:Reading tar file integrator.xml
21:50:37:WU01:FS01:0x22:Reading tar file state.xml
21:50:37:WU01:FS01:0x22:Reading tar file system.xml
21:50:37:WU01:FS01:0x22:Digital signatures verified
21:50:37:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:50:37:WU01:FS01:0x22:Version 0.0.2
21:50:41:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:50:41:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:50:41:WU01:FS01:0x22:Saving result file science.log
21:50:41:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:41:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:41:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:4264 gen:46 core:0x22 unit:0x000000418ca304f15e34fa4263cf5eab
21:50:41:WU01:FS01:Uploading 8.00KiB to 140.163.4.241
21:50:41:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:41:WU01:FS01:Upload complete
21:50:41:WU01:FS01:Server responded WORK_ACK (400)
21:50:41:WU01:FS01:Cleaning up
21:50:41:WU01:FS01:Connecting to 65.254.110.245:8080
21:50:42:WU01:FS01:Assigned to work server 140.163.4.241
21:50:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 960M] from 140.163.4.241
21:50:42:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:42:WU01:FS01:Downloading 11.66MiB
21:50:47:WU01:FS01:Download complete
21:50:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:2573 gen:35 core:0x22 unit:0x000000388ca304f15e04388f8abc8229
21:50:47:WU01:FS01:Starting
21:50:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Vladimir\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9008 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
21:50:47:WU01:FS01:Started FahCore on PID 932
21:50:47:WU01:FS01:Core PID:6416
21:50:47:WU01:FS01:FahCore 0x22 started
21:50:48:WU01:FS01:0x22:*********************** Log Started 2020-02-23T21:50:47Z ***********************
21:50:48:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:50:48:WU01:FS01:0x22:       Type: 0x22
21:50:48:WU01:FS01:0x22:       Core: Core22
21:50:48:WU01:FS01:0x22:    Website: https://foldingathome.org/
21:50:48:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:50:48:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:50:48:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:50:48:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 932 -checkpoint 15
21:50:48:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
21:50:48:WU01:FS01:0x22:             0 -gpu 0
21:50:48:WU01:FS01:0x22:     Config: <none>
21:50:48:WU01:FS01:0x22:************************************ Build *************************************
21:50:48:WU01:FS01:0x22:    Version: 0.0.2
21:50:48:WU01:FS01:0x22:       Date: Dec 6 2019
21:50:48:WU01:FS01:0x22:       Time: 21:30:31
21:50:48:WU01:FS01:0x22: Repository: Git
21:50:48:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:50:48:WU01:FS01:0x22:     Branch: HEAD
21:50:48:WU01:FS01:0x22:   Compiler: Visual C++ 2008
21:50:48:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:50:48:WU01:FS01:0x22:   Platform: win32 10
21:50:48:WU01:FS01:0x22:       Bits: 64
21:50:48:WU01:FS01:0x22:       Mode: Release
21:50:48:WU01:FS01:0x22:************************************ System ************************************
21:50:48:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-6300HQ CPU @ 2.30GHz
21:50:48:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
21:50:48:WU01:FS01:0x22:       CPUs: 4
21:50:48:WU01:FS01:0x22:     Memory: 7.88GiB
21:50:48:WU01:FS01:0x22:Free Memory: 5.07GiB
21:50:48:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
21:50:48:WU01:FS01:0x22: OS Version: 6.2
21:50:48:WU01:FS01:0x22:Has Battery: true
21:50:48:WU01:FS01:0x22: On Battery: false
21:50:48:WU01:FS01:0x22: UTC Offset: -8
21:50:48:WU01:FS01:0x22:        PID: 6416
21:50:48:WU01:FS01:0x22:        CWD: C:\Users\Vladimir\AppData\Roaming\FAHClient\work
21:50:48:WU01:FS01:0x22:         OS: Windows 10 Home
21:50:48:WU01:FS01:0x22:    OS Arch: AMD64
21:50:48:WU01:FS01:0x22:********************************************************************************
21:50:48:WU01:FS01:0x22:Project: 11737 (Run 0, Clone 2573, Gen 35)
21:50:48:WU01:FS01:0x22:Unit: 0x000000388ca304f15e04388f8abc8229
21:50:48:WU01:FS01:0x22:Reading tar file core.xml
21:50:48:WU01:FS01:0x22:Reading tar file integrator.xml
21:50:48:WU01:FS01:0x22:Reading tar file state.xml
21:50:48:WU01:FS01:0x22:Reading tar file system.xml
21:50:48:WU01:FS01:0x22:Digital signatures verified
21:50:48:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:50:48:WU01:FS01:0x22:Version 0.0.2
21:50:50:WU01:FS01:0x22:ERROR:exception: Error initializing context: clGetDeviceInfo (-5)
21:50:50:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:50:50:WU01:FS01:0x22:Saving result file science.log
21:50:50:WU01:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
21:50:51:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
21:50:51:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11737 run:0 clone:2573 gen:35 core:0x22 unit:0x000000388ca304f15e04388f8abc8229
21:50:51:WU01:FS01:Uploading 8.00KiB to 140.163.4.241
21:50:51:WU01:FS01:Connecting to 140.163.4.241:8080
21:50:51:WU01:FS01:Upload complete
21:50:51:WU01:FS01:Server responded WORK_ACK (400)
21:50:51:WU01:FS01:Cleaning up
I figure a 960m should be pretty effective at this, so I want to get it working. I tried looking up solutions, and found a few threads with a search query similar to this post's title.
All of these seem similar to my problem, but the solutions offered don't seem to work, or I don't really understand them (I am not the most technically proficient...). One with the title "FahCore returned: BAD_WORK_UNIT (114 = 0x72) with 960M" might be the most relevant, but the OP uses Linux, and I have Windows 10 Home. A lot of these threads recommend installing drivers from NVidia's site, however, the driver this site provides for 9m series graphics seems years old, and the installer gave an error when I downloaded and ran it.
I've tried updating and restarting my computer several times, as well as going to FAHControl > Configure > Slots and deleting then recreating the GPU slot with default values.
Please let me know if I need to provide any other information. I'll try my best to get this working, as I believe in the cause.
Re: GTX 960m Failed Status
Which version of the video drivers do you have installed? If they were installed by Windows Update they may not include the necessary support for OpenCL. Drivers downloaded direct from nVidia should include that support.
It would be helpful to see the first page of FAH's log, but I suspect the GPU problem might be lack of support for OpenCL. If you upgrade your drivers from the NVidia.com website, it will install OpenCL drivers at the same time.
The GTX 960m is supported.
Your Dell is a laptop with two video cards.
Integrated Intel HD Graphics 530
Discrete NVIDIA GeForce GTX 960M
https://www.geforce.com/hardware/techno ... technology
F@H does not support Intel video.
I suspect it is running the Intel card when F@H starts and so fails. You want to disable the Intel Video and run the Nvidia all the time.
There may be BIOS setting for that, there may be driver settings, etc.
"As far as I know, you cannot actually disable the Intel GPU however, you can force everything to use the Nvidia card by going to the Nvidia control panel, then under global 3D settings you'll see the option to set all applications to use the Nvidia GPU." http://forum.notebookreview.com/threads ... us.788462/
"Uninstall the Intel & NVIDIA GPU Drivers that came with Dell; then go get the latest ones from Intel and NVIDIA sites for your model of GPU and OS. After they both installed and you've rebooted, set NVIDIA GPU as default in NVIDIA Control Panel." https://steamcommunity.com/discussions/ ... 057776162/
"Your best bet to never having to deal with Optimus, is what I do. I leave my notebook plugged into AC power, with the battery removed, whenever I am gaming or doing anything graphically intense. Doing this has made it so Optimus never screws around with what GPU launches what, and every game opens with the Nvidia GPU. I have two notebooks, both with Optimus and Nvidia GPUs, and they both just always work."
https://www.nvidia.com/en-us/geforce/fo ... -forever-/
These are three different 'solutions' offered by users. i hope one works for you!
