Error 0xC0000139 (STATUS_ENTRYPOINT_NOT_FOUND)
Ho letto tutti i post ma non ho capito come fare a superare l'errore che mi si presenta da questa mattina.
"FahCore_22.exe
Impossibile trovare il punto di ingresso clReleaseDevice della procedure nella libreria di collegamento dinamico OpenCL.dl."
Ho provato a chiudere e riattivare F@H ma l'errore si ripresenta sempre uguale.
Questo è il LOG relativo:
*********************** Log Started 2020-02-16T19:03:22Z ***********************
19:03:24:WU02:FS01:Starting
19:03:24:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 704 -lifeline 7068 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:03:24:WU02:FS01:Started FahCore on PID 1604
19:03:24:WU02:FS01:Core PID:2916
19:03:24:WU02:FS01:FahCore 0x22 started
19:03:50:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:03:50:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
19:03:50:WU02:FS01:Starting
19:03:50:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 704 -lifeline 7068 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:03:50:WU02:FS01:Started FahCore on PID 2236
19:03:50:WU02:FS01:Core PID:8724
19:03:50:WU02:FS01:FahCore 0x22 started
19:03:53:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:03:53:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
19:04:50:WU02:FS01:Starting
19:04:50:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 704 -lifeline 7068 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:04:50:WU02:FS01:Started FahCore on PID 5456
19:04:50:WU02:FS01:Core PID:7728
19:04:50:WU02:FS01:FahCore 0x22 started
19:04:54:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:04:54:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
19:04:54:WARNING:WU02:FS01:Too many errors, failing
19:04:54:WU02:FS01:Sending unit results: id:02 state:SEND error:FAILED project:11737 run:0 clone:3660 gen:30 core:0x22 unit:0x0000002d8ca304f15e34fa3fb9a4fd63
19:04:54:WU02:FS01:Connecting to 140.163.4.241:8080
19:04:54:WU02:FS01:Server responded WORK_ACK (400)
19:04:54:WU02:FS01:Cleaning up
19:12:55:WU02:FS01:Connecting to 65.254.110.245:80
19:12:56:WU02:FS01:Assigned to work server 140.163.4.241
19:12:56:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1306 from 140.163.4.241
19:12:56:WU02:FS01:Connecting to 140.163.4.241:8080
19:12:58:WU02:FS01:Downloading 11.67MiB
19:13:04:WU02:FS01:Download 13.93%
19:13:10:WU02:FS01:Download 20.89%
19:13:16:WU02:FS01:Download 26.25%
19:13:22:WU02:FS01:Download 31.07%
19:13:28:WU02:FS01:Download 41.79%
19:13:34:WU02:FS01:Download 78.22%
19:13:38:WU02:FS01:Download complete
19:13:38:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11737 run:0 clone:247 gen:291 core:0x22 unit:0x000001538ca304f15dead60f400ed28e
19:13:38:WU02:FS01:Starting
19:13:38:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 704 -lifeline 7068 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:13:38:WU02:FS01:Started FahCore on PID 7924
19:13:38:WU02:FS01:Core PID:2820
19:13:38:WU02:FS01:FahCore 0x22 started
19:13:41:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:13:41:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
19:13:41:WU02:FS01:Starting
19:13:41:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 704 -lifeline 7068 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:13:41:WU02:FS01:Started FahCore on PID 8452
19:13:41:WU02:FS01:Core PID:7556
19:13:41:WU02:FS01:FahCore 0x22 started
19:13:43:WARNING:WU02:FS01:FahCore returned an unknown error code which probably indicates that it crashed
19:13:43:WARNING:WU02:FS01:FahCore returned: UNKNOWN_ENUM (-1073741511 = 0xc0000139)
Processore: Intel(R) Core(T M) i7-4790 CPU @ 3.606Hz 3.60 GHz
RAM: 16 GB
Grafica: NVIDIA GeForce GTX 750 Ti
"FahCore_22.exe
RAM: 16 GB
Re: Error 0xC0000139 (STATUS_ENTRYPOINT_NOT_FOUND)
Non parlo italiano. Penso che sia necessario scaricare nuovamente il driver da Nvidia.
https://www.geforce.com/drivers/results/157137
Windows 10 64 Bit
Le prime 200 righe del file di registro ci diranno molto di più sul tuo computer.
Windows 10 64 Bit
Yes, this apparently means that the OpenCL drivers are not properly installed.
Mi sembra molto strano perché il mio PC (Windows 7 x64) sta eseguendo questi calcoli 24 ore al giorno dal 2016 e fino a ieri mattina non ho mai avuto problemi. La stessa cosa, però, mi è accaduta circa un mese fa sul mio Notebook (Windows 10 Home x64) anch'esso dotato di scheda NVIDIA e anch'esso acceso 24 ore al giorno e dopo aver chiuso F@H e poi riavviato ha ripreso a eseguire i calcoli senza ulteriori errori mentre sul PC desktop la stessa procedura non ha avuto effetto.
Dalla lettura dei post precedenti al mio mi sembra di capire che il problema sia legato al "progetto 11737" che è quello che anche a me segnala errore.
Ho provato a copiare le DLL direttamente nella cartella dell'Applicazione Client ma non è servito.
Ciò che mi lascia perplesso è il fatto che il mio PC non ha subito aggiornamenti né del Sistema Operativo (Windows Update disabilitato dopo l'installazione) né delle Applicazioni né dei Driver della Scheda Video e quindi essendo rimasto sempre uguale non riesco a spiegarmi l'errore e la necessità di dover aggiornare qualcosa che fino a ieri funzionava regolarmente.
In ogni caso grazie per le risposte e l'interessamento al mio problema.
https://www.geforce.com/drivers/results/157047
Non so perché OpenCL abbia fallito. Non ho i tuoi registri per essere sicuro di indovinare correttamente. So solo che è fallito e la risposta più semplice è reinstallare.
Non parlo italiano.
Non parlo italiano.
Ho sostituito 'FahCore_22.exe' con 'FahCore_21.exe' rinominandolo 'FahCore_22.exe' e poi ho tolto la sospensione alla GPU. Dopo qualche minuto, F@H, ha annullato il "progetto 11737" (sempre in attesa a 0,0 %) e ha caricato un altro "progetto 11714" che viene calcolato tramite 'FahCore_21.exe'. Sembra che il problema sia risolto almeno fino a quando non verrà scaricato un progetto che richiede 'FahCore_22.exe'.
Grazie ancora, comunque, per le risposte e 'buon lavoro' a tutti.
I am going to pretend that not doing anything I suggested is a language barrier.
Avevo capito bene il tuo suggerimento ma in questo momento non volevo aggiornare niente nel mio PC.JimboPalmer wrote:I am going to pretend that not doing anything I suggested is a language barrier.
Per risolvere il problema, almeno temporaneamente, mi era sufficiente un'opzione per abortire il progetto 11737 in questione, ma anche quelli simili, che usano appunto FahCore_22 e che evidentemente sono incompatibili con i driver della mia scheda video.
La soluzione da me adottata ha funzionato e non mi imperdirà in futuro di aggiornare i driver della mia Nvidia.
@famasoft - As earlier posts from this account were posted in English, I would suggest posting in English if you are looking for effective support. English is the primary language for this support forum for the F@h projects.
Joe_H wrote:@famasoft - As earlier posts from this account were posted in English, I would suggest posting in English if you are looking for effective support. English is the primary language for this support forum for the F@h projects.
I apologize but I didn't know about this rule. I will adjust for the future.
(by Google translate)
