How to know if WU are sent back correctly
Caty
Post by Caty »
Hi,
sometimes when I power on the computer there is no internet connection. I connect it later to my mobile hotspot. However, if the WU is ready to be uploaded and there's no internet connection at that time, I can see the client tries several times to connect to the server but when the connection comes in, it says that it failed the upload. I'm posting some log lines to be clearer:
20:35:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:35:13:WU02:FS00:Connecting to 128.252.203.4:80
20:35:13:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:35:13:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:35:13:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:35:13:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:35:13:ERROR:WU00:FS00:Exception: Could not get an assignment
20:37:50:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:37:50:WU02:FS00:Connecting to 155.247.166.219:8080
20:37:50:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:37:50:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:37:50:WU02:FS00:Trying to send results to collection server
20:37:50:WU02:FS00:Connecting to 128.252.203.4:8080
20:37:50:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:37:50:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:37:50:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:37:50:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:37:50:ERROR:WU00:FS00:Exception: Could not get an assignment
20:42:04:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:42:04:WU02:FS00:Connecting to 155.247.166.219:8080
20:42:04:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:42:04:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:42:04:WU02:FS00:Trying to send results to collection server
20:42:04:WU02:FS00:Connecting to 128.252.203.4:8080
20:42:04:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:42:04:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:42:04:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:42:04:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:42:04:ERROR:WU00:FS00:Exception: Could not get an assignment
20:48:55:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:48:56:WU02:FS00:Connecting to 155.247.166.219:8080
20:48:56:WU00:FS00:Connecting to 65.254.110.245:8080
20:48:56:WU02:FS00:Server responded WORK_ACK (400)
20:48:56:WU02:FS00:Cleaning up
20:48:56:WU00:FS00:Assigned to work server 128.252.203.9
20:48:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 128.252.203.9
20:48:56:WU00:FS00:Connecting to 128.252.203.9:8080
20:48:57:WU00:FS00:Downloading 7.29MiB
20:49:03:WU00:FS00:Download 93.46%
20:49:03:WU00:FS00:Download complete
At 20:45 I connected my PC to internet and 3 minutes later FAH tried another connection but it says "state:SEND error:FAILED".
What happened to the WU? Was it thrown away? :|
Thank you in advance
Re: How to know if WU are sent back correctly
According to https://apps.foldingathome.org/wu a faulty WU was credited at Tue, 21 Jan 2020 11:00:02 GMT. The times shown in the log are GMT and you've posted things around 20:35 although the date is not clear. I'm not sure what happened in your case, in the past I've seen cases where a faulty WU was, in fact, uploaded but later somebody restored a backup which was later completed. The backup cannot be uploaded because the WU was already received. Is that what happened in your case?
You can find previous logs which have been backed up in the FAH data directory under /logs/.
Caty
Post by Caty »
I can't find the log directory. Where is it?
I have Windows 10
Follow the link in Bruce's signature, there are directions for finding and posting the logs for folders running all OS's.
Caty
Post by Caty »
This is the entire log file of that day:
*********************** Log Started 2020-01-20T20:31:32Z ***********************
20:31:32:************************* Folding@home Client *************************
20:31:32:        Website: https://foldingathome.org/
20:31:32:      Copyright: (c) 2009-2018 foldingathome.org
20:31:32:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:31:32:           Args:
20:31:32:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
20:31:32:******************************** Build ********************************
20:31:32:        Version: 7.5.1
20:31:32:           Date: May 11 2018
20:31:32:           Time: 13:06:32
20:31:32:     Repository: Git
20:31:32:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:31:32:         Branch: master
20:31:32:       Compiler: Visual C++ 2008
20:31:32:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:31:32:       Platform: win32 10
20:31:32:           Bits: 32
20:31:32:           Mode: Release
20:31:32:******************************* System ********************************
20:31:32:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:31:32:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:31:32:           CPUs: 8
20:31:32:         Memory: 15.84GiB
20:31:32:    Free Memory: 12.35GiB
20:31:32:        Threads: WINDOWS_THREADS
20:31:32:     OS Version: 6.2
20:31:32:    Has Battery: true
20:31:32:     On Battery: false
20:31:32:     UTC Offset: 1
20:31:32:            PID: 11868
20:31:32:            CWD: C:\Users\cathe\AppData\Roaming\FAHClient
20:31:32:             OS: Windows 10 Home
20:31:32:        OS Arch: AMD64
20:31:32:           GPUs: 1
20:31:32:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
20:31:32:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
20:31:32:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
20:31:32:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.36
20:31:32:  Win32 Service: false
20:31:32:***********************************************************************
20:31:32:<config>
20:31:32:  <!-- Network -->
20:31:32:  <proxy v=':8080'/>
20:31:32:
20:31:32:  <!-- Slot Control -->
20:31:32:  <pause-on-battery v='false'/>
20:31:32:
20:31:32:  <!-- User Information -->
20:31:32:  <passkey v='********************************'/>
20:31:32:  <team v='123'/>
20:31:32:  <user v='Caty'/>
20:31:32:
20:31:32:  <!-- Folding Slots -->
20:31:32:  <slot id='0' type='CPU'>
20:31:32:    <cpus v='4'/>
20:31:32:  </slot>
20:31:32:</config>
20:31:32:Trying to access database...
20:31:32:Successfully acquired database lock
20:31:32:Enabled folding slot 00: READY cpu:4
20:31:32:WU02:FS00:Starting
20:31:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11868 -checkpoint 15 -np 4
20:31:32:WU02:FS00:Started FahCore on PID 4744
20:31:32:WU02:FS00:Core PID:9896
20:31:32:WU02:FS00:FahCore 0xa7 started
20:31:33:WU02:FS00:0xa7:*********************** Log Started 2020-01-20T20:31:32Z ***********************
20:31:33:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:31:33:WU02:FS00:0xa7:       Type: 0xa7
20:31:33:WU02:FS00:0xa7:       Core: Gromacs
20:31:33:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 4744 -checkpoint 15 -np 4
20:31:33:WU02:FS00:0xa7:************************************ CBang *************************************
20:31:33:WU02:FS00:0xa7:       Date: Oct 26 2019
20:31:33:WU02:FS00:0xa7:       Time: 01:38:25
20:31:33:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:31:33:WU02:FS00:0xa7:     Branch: master
20:31:33:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:31:33:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:31:33:WU02:FS00:0xa7:   Platform: win32 10
20:31:33:WU02:FS00:0xa7:       Bits: 64
20:31:33:WU02:FS00:0xa7:       Mode: Release
20:31:33:WU02:FS00:0xa7:************************************ System ************************************
20:31:33:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:31:33:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:31:33:WU02:FS00:0xa7:       CPUs: 8
20:31:33:WU02:FS00:0xa7:     Memory: 15.84GiB
20:31:33:WU02:FS00:0xa7:Free Memory: 12.33GiB
20:31:33:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:31:33:WU02:FS00:0xa7: OS Version: 6.2
20:31:33:WU02:FS00:0xa7:Has Battery: true
20:31:33:WU02:FS00:0xa7: On Battery: false
20:31:33:WU02:FS00:0xa7: UTC Offset: 1
20:31:33:WU02:FS00:0xa7:        PID: 9896
20:31:33:WU02:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
20:31:33:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:31:33:WU02:FS00:0xa7:    Version: 0.0.18
20:31:33:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:31:33:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:31:33:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:31:33:WU02:FS00:0xa7:       Time: 01:52:30
20:31:33:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:31:33:WU02:FS00:0xa7:************************************ Build *************************************
20:31:33:WU02:FS00:0xa7:       SIMD: avx_256
20:31:33:WU02:FS00:0xa7:********************************************************************************
20:31:33:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
20:31:33:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
20:31:33:WU02:FS00:0xa7:Digital signatures verified
20:31:33:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 4
20:31:33:WU02:FS00:0xa7:ERROR:Guru Meditation #5faecae706d6a57a.12db9e054207a0a8 (3589152.4486440) '02/01/frame77.trr'
20:31:33:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:31:33:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:31:33:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:31:33:WU02:FS00:0xa7:Saving result file frame77.trr
20:31:33:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:31:33:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:31:34:WU02:FS00:Starting
20:31:34:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11868 -checkpoint 15 -np 4
20:31:34:WU02:FS00:Started FahCore on PID 2820
20:31:34:WU02:FS00:Core PID:5276
20:31:34:WU02:FS00:FahCore 0xa7 started
20:31:34:WU02:FS00:0xa7:*********************** Log Started 2020-01-20T20:31:34Z ***********************
20:31:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:31:34:WU02:FS00:0xa7:       Type: 0xa7
20:31:34:WU02:FS00:0xa7:       Core: Gromacs
20:31:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2820 -checkpoint 15 -np 4
20:31:34:WU02:FS00:0xa7:************************************ CBang *************************************
20:31:34:WU02:FS00:0xa7:       Date: Oct 26 2019
20:31:34:WU02:FS00:0xa7:       Time: 01:38:25
20:31:34:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:31:34:WU02:FS00:0xa7:     Branch: master
20:31:34:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:31:34:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:31:34:WU02:FS00:0xa7:   Platform: win32 10
20:31:34:WU02:FS00:0xa7:       Bits: 64
20:31:34:WU02:FS00:0xa7:       Mode: Release
20:31:34:WU02:FS00:0xa7:************************************ System ************************************
20:31:34:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:31:34:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:31:34:WU02:FS00:0xa7:       CPUs: 8
20:31:34:WU02:FS00:0xa7:     Memory: 15.84GiB
20:31:34:WU02:FS00:0xa7:Free Memory: 12.32GiB
20:31:34:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:31:34:WU02:FS00:0xa7: OS Version: 6.2
20:31:34:WU02:FS00:0xa7:Has Battery: true
20:31:34:WU02:FS00:0xa7: On Battery: false
20:31:34:WU02:FS00:0xa7: UTC Offset: 1
20:31:34:WU02:FS00:0xa7:        PID: 5276
20:31:34:WU02:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
20:31:34:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:31:34:WU02:FS00:0xa7:    Version: 0.0.18
20:31:34:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:31:34:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:31:34:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:31:34:WU02:FS00:0xa7:       Time: 01:52:30
20:31:34:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:31:34:WU02:FS00:0xa7:************************************ Build *************************************
20:31:34:WU02:FS00:0xa7:       SIMD: avx_256
20:31:34:WU02:FS00:0xa7:********************************************************************************
20:31:34:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
20:31:34:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
20:31:34:WU02:FS00:0xa7:Digital signatures verified
20:31:34:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 4
20:31:34:WU02:FS00:0xa7:ERROR:Guru Meditation #5faecae706d6a57a.12db9e054207a0a8 (3589152.4486440) '02/01/frame77.trr'
20:31:34:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:31:34:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:31:34:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:31:34:WU02:FS00:0xa7:Saving result file frame77.trr
20:31:34:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:31:34:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:32:34:WU02:FS00:Starting
20:32:34:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 11868 -checkpoint 15 -np 4
20:32:34:WU02:FS00:Started FahCore on PID 11908
20:32:34:WU02:FS00:Core PID:9852
20:32:34:WU02:FS00:FahCore 0xa7 started
20:32:34:WU02:FS00:0xa7:*********************** Log Started 2020-01-20T20:32:34Z ***********************
20:32:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:32:34:WU02:FS00:0xa7:       Type: 0xa7
20:32:34:WU02:FS00:0xa7:       Core: Gromacs
20:32:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 11908 -checkpoint 15 -np
20:32:34:WU02:FS00:0xa7:             4
20:32:34:WU02:FS00:0xa7:************************************ CBang *************************************
20:32:34:WU02:FS00:0xa7:       Date: Oct 26 2019
20:32:34:WU02:FS00:0xa7:       Time: 01:38:25
20:32:34:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:32:34:WU02:FS00:0xa7:     Branch: master
20:32:34:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:32:34:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:32:34:WU02:FS00:0xa7:   Platform: win32 10
20:32:34:WU02:FS00:0xa7:       Bits: 64
20:32:34:WU02:FS00:0xa7:       Mode: Release
20:32:34:WU02:FS00:0xa7:************************************ System ************************************
20:32:34:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:32:34:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:32:34:WU02:FS00:0xa7:       CPUs: 8
20:32:34:WU02:FS00:0xa7:     Memory: 15.84GiB
20:32:34:WU02:FS00:0xa7:Free Memory: 12.05GiB
20:32:34:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:32:34:WU02:FS00:0xa7: OS Version: 6.2
20:32:34:WU02:FS00:0xa7:Has Battery: true
20:32:34:WU02:FS00:0xa7: On Battery: false
20:32:34:WU02:FS00:0xa7: UTC Offset: 1
20:32:34:WU02:FS00:0xa7:        PID: 9852
20:32:34:WU02:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
20:32:34:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:32:34:WU02:FS00:0xa7:    Version: 0.0.18
20:32:34:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:32:34:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:32:34:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:32:34:WU02:FS00:0xa7:       Time: 01:52:30
20:32:34:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:32:34:WU02:FS00:0xa7:************************************ Build *************************************
20:32:34:WU02:FS00:0xa7:       SIMD: avx_256
20:32:34:WU02:FS00:0xa7:********************************************************************************
20:32:34:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
20:32:34:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
20:32:34:WU02:FS00:0xa7:Digital signatures verified
20:32:35:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 4
20:32:35:WU02:FS00:0xa7:ERROR:Guru Meditation #5faecae706d6a57a.12db9e054207a0a8 (3589152.4486440) '02/01/frame77.trr'
20:32:35:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:32:35:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:32:35:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:32:35:WU02:FS00:0xa7:Saving result file frame77.trr
20:32:35:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
20:32:35:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
20:32:35:WARNING:WU02:FS00:Too many errors, failing
20:32:35:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:32:35:WU02:FS00:Connecting to 155.247.166.219:8080
20:32:35:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:32:35:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:32:35:WU02:FS00:Trying to send results to collection server
20:32:35:WU02:FS00:Connecting to 128.252.203.4:8080
20:32:35:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:32:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:32:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:32:35:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:32:35:ERROR:WU00:FS00:Exception: Could not get an assignment
20:33:35:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:33:35:WU02:FS00:Connecting to 155.247.166.219:8080
20:33:35:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:33:35:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:33:35:WU02:FS00:Trying to send results to collection server
20:33:35:WU02:FS00:Connecting to 128.252.203.4:8080
20:33:35:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:33:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:33:35:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:33:35:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:33:35:ERROR:WU00:FS00:Exception: Could not get an assignment
20:35:12:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:35:12:WU02:FS00:Connecting to 155.247.166.219:8080
20:35:12:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:35:12:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:35:12:WU02:FS00:Trying to send results to collection server
20:35:13:WU02:FS00:Connecting to 128.252.203.4:8080
20:49:03:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14400 run:0 clone:2677 gen:49 core:0xa7 unit:0x0000003680fccb095dcad800ac5c31f0
20:49:03:WU00:FS00:Starting
20:49:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 11868 -checkpoint 15 -np 4
20:49:03:WU00:FS00:Started FahCore on PID 7356
20:49:03:WU00:FS00:Core PID:13796
20:49:03:WU00:FS00:FahCore 0xa7 started
20:49:04:WU00:FS00:0xa7:*********************** Log Started 2020-01-20T20:49:03Z ***********************
20:49:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:49:04:WU00:FS00:0xa7:       Type: 0xa7
20:49:04:WU00:FS00:0xa7:       Core: Gromacs
20:49:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 7356 -checkpoint 15 -np 4
20:49:04:WU00:FS00:0xa7:************************************ CBang *************************************
20:49:04:WU00:FS00:0xa7:       Date: Oct 26 2019
20:49:04:WU00:FS00:0xa7:       Time: 01:38:25
20:49:04:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:49:04:WU00:FS00:0xa7:     Branch: master
20:49:04:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
20:49:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:49:04:WU00:FS00:0xa7:   Platform: win32 10
20:49:04:WU00:FS00:0xa7:       Bits: 64
20:49:04:WU00:FS00:0xa7:       Mode: Release
20:49:04:WU00:FS00:0xa7:************************************ System ************************************
20:49:04:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
20:49:04:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
20:49:04:WU00:FS00:0xa7:       CPUs: 8
20:49:04:WU00:FS00:0xa7:     Memory: 15.84GiB
20:49:04:WU00:FS00:0xa7:Free Memory: 11.21GiB
20:49:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
20:49:04:WU00:FS00:0xa7: OS Version: 6.2
20:49:04:WU00:FS00:0xa7:Has Battery: true
20:49:04:WU00:FS00:0xa7: On Battery: false
20:49:04:WU00:FS00:0xa7: UTC Offset: 1
20:49:04:WU00:FS00:0xa7:        PID: 13796
20:49:04:WU00:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
20:49:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:49:04:WU00:FS00:0xa7:    Version: 0.0.18
20:49:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:49:04:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:49:04:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:49:04:WU00:FS00:0xa7:       Time: 01:52:30
20:49:04:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:49:04:WU00:FS00:0xa7:************************************ Build *************************************
20:49:04:WU00:FS00:0xa7:       SIMD: avx_256
20:49:04:WU00:FS00:0xa7:********************************************************************************
20:49:04:WU00:FS00:0xa7:Project: 14400 (Run 0, Clone 2677, Gen 49)
20:49:04:WU00:FS00:0xa7:Unit: 0x0000003680fccb095dcad800ac5c31f0
20:49:04:WU00:FS00:0xa7:Reading tar file core.xml
20:49:04:WU00:FS00:0xa7:Reading tar file frame49.tpr
20:49:04:WU00:FS00:0xa7:Digital signatures verified
20:49:04:WU00:FS00:0xa7:Calling: mdrun -s frame49.tpr -o frame49.trr -x frame49.xtc -cpt 15 -nt 4
20:49:04:WU00:FS00:0xa7:Steps: first=6125000 total=125000
20:49:07:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
20:52:00:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
20:55:01:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
I don't think so, Please post a list of the files in the FAH data directory under /logs/directory. A new file is created when you restart FAHClient and that file only covers part of the 20th hour. Also, I don't see the date reported.
Caty
Post by Caty »
Here are the log files around that date. I had to cut some chunks because of the amount of characters. Let me know if I have to post something more. Thank you for paying attention.
*********************** Log Started 2020-01-18T21:30:46Z ***********************
21:30:46:************************* Folding@home Client *************************
21:30:46:        Website: https://foldingathome.org/
21:30:46:      Copyright: (c) 2009-2018 foldingathome.org
21:30:46:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:30:46:           Args:
21:30:46:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
21:30:46:******************************** Build ********************************
21:30:46:        Version: 7.5.1
21:30:46:           Date: May 11 2018
21:30:46:           Time: 13:06:32
21:30:46:     Repository: Git
21:30:46:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:30:46:         Branch: master
21:30:46:       Compiler: Visual C++ 2008
21:30:46:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:30:46:       Platform: win32 10
21:30:46:           Bits: 32
21:30:46:           Mode: Release
21:30:46:******************************* System ********************************
21:30:46:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
21:30:46:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
21:30:46:           CPUs: 8
21:30:46:         Memory: 15.84GiB
21:30:46:    Free Memory: 12.10GiB
21:30:46:        Threads: WINDOWS_THREADS
21:30:46:     OS Version: 6.2
21:30:46:    Has Battery: true
21:30:46:     On Battery: false
21:30:46:     UTC Offset: 1
21:30:46:            PID: 3428
21:30:46:            CWD: C:\Users\cathe\AppData\Roaming\FAHClient
21:30:46:             OS: Windows 10 Home
21:30:46:        OS Arch: AMD64
21:30:46:           GPUs: 1
21:30:46:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
21:30:46:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
21:30:46:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
21:30:46:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.36
21:30:46:  Win32 Service: false
21:30:46:***********************************************************************
21:30:46:<config>
21:30:46:  <!-- Network -->
21:30:46:  <proxy v=':8080'/>
21:30:46:
21:30:46:  <!-- Slot Control -->
21:30:46:  <pause-on-battery v='false'/>
21:30:46:  <power v='medium'/>
21:30:46:
21:30:46:  <!-- User Information -->
21:30:46:  <passkey v='********************************'/>
21:30:46:  <user v='Caty'/>
21:30:46:
21:30:46:  <!-- Folding Slots -->
21:30:46:  <slot id='0' type='CPU'/>
21:30:46:  <slot id='1' type='GPU'/>
21:30:46:</config>
21:30:46:Trying to access database...
21:30:46:Successfully acquired database lock
21:30:46:Enabled folding slot 00: READY cpu:6
21:30:46:Enabled folding slot 01: READY gpu:0:GP108 [GeForce MX150]
21:30:46:WU01:FS00:Starting
21:30:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 3428 -checkpoint 15 -np 6
21:30:46:WU01:FS00:Started FahCore on PID 8676
21:30:47:WU01:FS00:Core PID:4136
21:30:47:WU01:FS00:FahCore 0xa7 started
21:30:47:WU01:FS00:0xa7:*********************** Log Started 2020-01-18T21:30:47Z ***********************
21:30:47:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:30:47:WU01:FS00:0xa7:       Type: 0xa7
21:30:47:WU01:FS00:0xa7:       Core: Gromacs
21:30:47:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8676 -checkpoint 15 -np 6
21:30:47:WU01:FS00:0xa7:************************************ CBang *************************************
21:30:47:WU01:FS00:0xa7:       Date: Oct 26 2019
21:30:47:WU01:FS00:0xa7:       Time: 01:38:25
21:30:47:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
21:30:47:WU01:FS00:0xa7:     Branch: master
21:30:47:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
21:30:47:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:30:47:WU01:FS00:0xa7:   Platform: win32 10
21:30:47:WU01:FS00:0xa7:       Bits: 64
21:30:47:WU01:FS00:0xa7:       Mode: Release
21:30:47:WU01:FS00:0xa7:************************************ System ************************************
21:30:47:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
21:30:47:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
21:30:47:WU01:FS00:0xa7:       CPUs: 8
21:30:47:WU01:FS00:0xa7:     Memory: 15.84GiB
21:30:47:WU01:FS00:0xa7:Free Memory: 12.21GiB
21:30:47:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
21:30:47:WU01:FS00:0xa7: OS Version: 6.2
21:30:47:WU01:FS00:0xa7:Has Battery: true
21:30:47:WU01:FS00:0xa7: On Battery: false
21:30:47:WU01:FS00:0xa7: UTC Offset: 1
21:30:47:WU01:FS00:0xa7:        PID: 4136
21:30:47:WU01:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
21:30:47:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
21:30:47:WU01:FS00:0xa7:    Version: 0.0.18
21:30:47:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:30:47:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
21:30:47:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
21:30:47:WU01:FS00:0xa7:       Time: 01:52:30
21:30:47:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
21:30:47:WU01:FS00:0xa7:************************************ Build *************************************
21:30:47:WU01:FS00:0xa7:       SIMD: avx_256
21:30:47:WU01:FS00:0xa7:********************************************************************************
21:30:47:WU01:FS00:0xa7:Project: 14401 (Run 0, Clone 4841, Gen 1)
21:30:47:WU01:FS00:0xa7:Unit: 0x0000000180fccb095dcb2dbfa7563a8f
21:30:47:WU01:FS00:0xa7:Digital signatures verified
21:30:47:WU01:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -cpi state.cpt -cpt 15 -nt 6
21:30:47:WU00:FS01:Connecting to 65.254.110.245:8080
21:30:47:WU01:FS00:0xa7:Steps: first=125000 total=125000
21:30:53:WU01:FS00:0xa7:Completed 102291 out of 125000 steps (81%)
21:31:01:WU00:FS01:Assigned to work server 140.163.4.241
21:31:01:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GP108 [GeForce MX150] from 140.163.4.241
21:31:01:WU00:FS01:Connecting to 140.163.4.241:8080
21:31:02:WU00:FS01:Downloading 16.53MiB
21:31:08:WU00:FS01:Download 52.55%
21:31:14:WU00:FS01:Download 93.37%
21:31:15:WU00:FS01:Download complete
03:59:53:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
03:59:53:WU01:FS00:Connecting to 65.254.110.245:8080
03:59:54:WU01:FS00:Assigned to work server 155.247.166.219
03:59:54:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
03:59:54:WU01:FS00:Connecting to 155.247.166.219:8080
03:59:54:WU01:FS00:Downloading 1.24MiB
03:59:55:WU01:FS00:Download complete
03:59:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14307 run:5 clone:23 gen:14 core:0xa7 unit:0x000000110002894b5dd6cbf0bb0f12b6
04:02:07:WU00:FS01:0x21:Completed 1950000 out of 7500000 steps (26%)
04:03:23:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
04:03:35:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
04:03:35:WU02:FS00:0xa7:Saving result file frame3.trr
04:03:35:WU02:FS00:0xa7:Saving result file frame3.xtc
04:03:35:WU02:FS00:0xa7:Saving result file md.log
04:03:35:WU02:FS00:0xa7:Saving result file science.log
04:03:35:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:03:36:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:03:36:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:14402 run:0 clone:3126 gen:3 core:0xa7 unit:0x0000000480fccb095dcb2b6ae71b423e
04:03:36:WU02:FS00:Uploading 10.32MiB to 128.252.203.9
04:03:36:WU02:FS00:Connecting to 128.252.203.9:8080
04:03:36:WU01:FS00:Starting
04:03:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 3428 -checkpoint 15 -np 6
04:03:36:WU01:FS00:Started FahCore on PID 12196
04:03:36:WU01:FS00:Core PID:11444
04:03:36:WU01:FS00:FahCore 0xa7 started
04:03:36:WU01:FS00:0xa7:*********************** Log Started 2020-01-19T04:03:36Z ***********************
04:03:36:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:03:36:WU01:FS00:0xa7:       Type: 0xa7
04:03:36:WU01:FS00:0xa7:       Core: Gromacs
04:03:36:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 12196 -checkpoint 15 -np
04:03:36:WU01:FS00:0xa7:             6
04:03:36:WU01:FS00:0xa7:************************************ Build *************************************
04:03:36:WU01:FS00:0xa7:       SIMD: avx_256
04:03:36:WU01:FS00:0xa7:********************************************************************************
04:03:36:WU01:FS00:0xa7:Project: 14307 (Run 5, Clone 23, Gen 14)
04:03:36:WU01:FS00:0xa7:Unit: 0x000000110002894b5dd6cbf0bb0f12b6
04:03:36:WU01:FS00:0xa7:Reading tar file core.xml
04:03:36:WU01:FS00:0xa7:Reading tar file frame14.tpr
04:03:36:WU01:FS00:0xa7:Digital signatures verified
04:03:36:WU01:FS00:0xa7:Calling: mdrun -s frame14.tpr -o frame14.trr -cpt 15 -nt 6
04:03:36:WU01:FS00:0xa7:Steps: first=7000000 total=500000
04:03:37:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
04:03:42:WU02:FS00:Upload 73.87%
04:03:45:WU02:FS00:Upload complete
04:03:45:WU02:FS00:Server responded WORK_ACK (400)
04:03:45:WU02:FS00:Final credit estimate, 3681.00 points
04:03:45:WU02:FS00:Cleaning up
04:05:05:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
06:28:12:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
06:28:13:WU02:FS00:Connecting to 65.254.110.245:8080
06:28:14:WU02:FS00:Assigned to work server 155.247.166.219
06:28:14:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 155.247.166.219
06:28:14:WU02:FS00:Connecting to 155.247.166.219:8080
06:28:14:WU02:FS00:Downloading 1.72MiB
06:28:17:WU02:FS00:Download complete
06:28:17:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
06:29:40:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
06:29:42:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
06:29:42:WU01:FS00:0xa7:Saving result file frame14.trr
06:29:42:WU01:FS00:0xa7:Saving result file md.log
06:29:42:WU01:FS00:0xa7:Saving result file pullf.xvg
06:29:42:WU01:FS00:0xa7:Saving result file pullx.xvg
06:29:42:WU01:FS00:0xa7:Saving result file science.log
06:29:42:WU01:FS00:0xa7:Saving result file traj_comp.xtc
06:29:42:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
06:29:42:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:29:42:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14307 run:5 clone:23 gen:14 core:0xa7 unit:0x000000110002894b5dd6cbf0bb0f12b6
06:29:42:WU01:FS00:Uploading 2.63MiB to 155.247.166.219
06:29:42:WU01:FS00:Connecting to 155.247.166.219:8080
06:29:42:WU02:FS00:Starting
06:29:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 3428 -checkpoint 15 -np 6
06:29:42:WU02:FS00:Started FahCore on PID 12124
06:29:42:WU02:FS00:Core PID:10656
06:29:42:WU02:FS00:FahCore 0xa7 started
06:29:43:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T06:29:42Z ***********************
06:29:43:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:29:43:WU02:FS00:0xa7:       Type: 0xa7
06:29:43:WU02:FS00:0xa7:       Core: Gromacs
06:29:43:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 12124 -checkpoint 15 -np
06:29:43:WU02:FS00:0xa7:             6
06:29:43:WU02:FS00:0xa7:************************************ Build *************************************
06:29:43:WU02:FS00:0xa7:       SIMD: avx_256
06:29:43:WU02:FS00:0xa7:********************************************************************************
06:29:43:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
06:29:43:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
06:29:43:WU02:FS00:0xa7:Reading tar file core.xml
06:29:43:WU02:FS00:0xa7:Reading tar file frame77.tpr
06:29:43:WU02:FS00:0xa7:Digital signatures verified
06:29:43:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpt 15 -nt 6
06:29:43:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
06:29:44:WU02:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
06:29:46:WU01:FS00:Upload complete
06:29:46:WU01:FS00:Server responded WORK_ACK (400)
06:29:46:WU01:FS00:Final credit estimate, 1366.00 points
06:29:46:WU01:FS00:Cleaning up
06:34:12:WU00:FS01:0x21:Completed 2700000 out of 7500000 steps (36%)
12:56:52:WU02:FS00:0xa7:Completed 1025000 out of 2500000 steps (41%)
12:57:10:Removing old file 'configs/config-20200108-184735.xml'
12:57:10:Saving configuration to config.xml
12:57:10:<config>
12:57:10:  <!-- Network -->
12:57:10:  <proxy v=':8080'/>
12:57:10:
12:57:10:  <!-- Slot Control -->
12:57:10:  <pause-on-battery v='false'/>
12:57:10:  <power v='medium'/>
12:57:10:
12:57:10:  <!-- User Information -->
12:57:10:  <passkey v='********************************'/>
12:57:10:  <team v='123'/>
12:57:10:  <user v='Caty'/>
12:57:10:
12:57:10:  <!-- Folding Slots -->
12:57:10:  <slot id='0' type='CPU'/>
12:57:10:  <slot id='1' type='GPU'/>
12:57:10:</config>
12:57:58:Removing old file 'configs/config-20200108-185240.xml'
12:57:58:Saving configuration to config.xml
12:57:58:<config>
12:57:58:  <!-- Network -->
12:57:58:  <proxy v=':8080'/>
12:57:58:
12:57:58:  <!-- Slot Control -->
12:57:58:  <pause-on-battery v='false'/>
12:57:58:  <power v='medium'/>
12:57:58:
12:57:58:  <!-- User Information -->
12:57:58:  <passkey v='********************************'/>
12:57:58:  <team v='123'/>
12:57:58:  <user v='Caty'/>
12:57:58:
12:57:58:  <!-- Folding Slots -->
12:57:58:  <slot id='0' type='CPU'/>
12:57:58:  <slot id='1' type='GPU'/>
12:57:58:</config>
12:58:15:WU00:FS01:0x21:Completed 4575000 out of 7500000 steps (61%)
14:05:17:WU02:FS00:0xa7:Completed 1200000 out of 2500000 steps (48%)
14:15:07:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
14:15:08:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
14:15:08:WARNING:WU02:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
14:15:08:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
14:15:08:WU00:FS01:Starting
14:15:08:ERROR:WU00:FS01:Failed to start core: Failed to rename './work/00/logfile_01.txt' to './work/00/logfile_01-20200119-141508.txt': Impossibile accedere al file. Il file è utilizzato da un altro processo.
14:15:08:WU02:FS00:Starting
14:15:08:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 3428 -checkpoint 15 -np 6
14:15:08:WU02:FS00:Started FahCore on PID 13364
14:15:08:WU02:FS00:FahCore 0xa7 started
14:15:08:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:15:08:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
*********************** Log Started 2020-01-19T14:26:32Z ***********************
14:26:32:************************* Folding@home Client *************************
14:26:32:        Website: https://foldingathome.org/
14:26:32:      Copyright: (c) 2009-2018 foldingathome.org
14:26:32:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:26:32:           Args:
14:26:32:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
14:26:32:******************************** Build ********************************
14:26:32:        Version: 7.5.1
14:26:32:           Date: May 11 2018
14:26:32:           Time: 13:06:32
14:26:32:     Repository: Git
14:26:32:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:26:32:         Branch: master
14:26:32:       Compiler: Visual C++ 2008
14:26:32:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:26:32:       Platform: win32 10
14:26:32:           Bits: 32
14:26:32:           Mode: Release
14:26:32:******************************* System ********************************
14:26:32:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
14:26:32:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
14:26:32:           CPUs: 8
14:26:32:         Memory: 15.84GiB
14:26:32:    Free Memory: 12.91GiB
14:26:32:Trying to access database...
14:26:32:Successfully acquired database lock
14:26:32:Enabled folding slot 00: READY cpu:6
14:26:32:Enabled folding slot 01: READY gpu:0:GP108 [GeForce MX150]
14:26:33:WU00:FS01:Starting
14:26:33:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
14:26:33:WU00:FS01:Started FahCore on PID 9608
14:26:33:WU00:FS01:Core PID:11272
14:26:33:WU00:FS01:FahCore 0x21 started
14:26:33:WU02:FS00:Starting
14:26:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -np 6
14:26:33:WU02:FS00:Started FahCore on PID 11324
14:26:33:WU02:FS00:Core PID:11336
14:26:33:WU02:FS00:FahCore 0xa7 started
14:26:34:WU00:FS01:0x21:*********************** Log Started 2020-01-19T14:26:33Z ***********************
14:26:34:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 7360, Gen 46)
14:26:34:WU00:FS01:0x21:Unit: 0x000000508ca304f15b21ad28d6356352
14:26:34:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
14:26:34:WU00:FS01:0x21:Machine: 1
14:26:34:WU00:FS01:0x21:Digital signatures verified
14:26:34:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
14:26:34:WU00:FS01:0x21:Version 0.0.20
14:26:34:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T14:26:33Z ***********************
14:26:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:26:34:WU02:FS00:0xa7:       Type: 0xa7
14:26:34:WU02:FS00:0xa7:       Core: Gromacs
14:26:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 11324 -checkpoint 15 -np
14:26:34:WU02:FS00:0xa7:             6
14:26:34:WU02:FS00:0xa7:************************************ Build *************************************
14:26:34:WU02:FS00:0xa7:       SIMD: avx_256
14:26:34:WU02:FS00:0xa7:********************************************************************************
14:26:34:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
14:26:34:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
14:26:34:WU02:FS00:0xa7:Digital signatures verified
14:26:34:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 6
14:26:34:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
14:26:34:WU00:FS01:0x21:  Found a checkpoint file
14:26:42:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:27:01:WU02:FS00:0xa7:Completed 1225000 out of 2500000 steps (49%)
15:39:52:WU02:FS00:0xa7:Completed 1400000 out of 2500000 steps (56%)
15:42:40:FS00:Shutting core down
15:42:40:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 11336
15:42:40:WU02:FS00:0xa7:Exiting, please wait. . .
15:42:41:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
15:42:42:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:42:42:WU02:FS00:Starting
15:42:42:WARNING:WU02:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
15:42:42:WARNING:WU02:FS00:AS lowered CPUs from 7 to 6
15:42:42:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -np 6
15:42:42:WU02:FS00:Started FahCore on PID 7224
15:42:42:WU02:FS00:Core PID:4916
15:42:42:WU02:FS00:FahCore 0xa7 started
15:42:42:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T15:42:42Z ***********************
15:42:42:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:42:42:WU02:FS00:0xa7:       Type: 0xa7
15:42:42:WU02:FS00:0xa7:       Core: Gromacs
15:42:42:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 7224 -checkpoint 15 -np 6
15:42:43:WU02:FS00:0xa7:************************************ Build *************************************
15:42:43:WU02:FS00:0xa7:       SIMD: avx_256
15:42:43:WU02:FS00:0xa7:********************************************************************************
15:42:43:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
15:42:43:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
15:42:43:WU02:FS00:0xa7:Digital signatures verified
15:42:43:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 6
15:42:43:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
15:42:44:WU02:FS00:0xa7:Completed 1406762 out of 2500000 steps (56%)
15:42:47:Removing old file 'configs/config-20200108-185543.xml'
15:42:47:Saving configuration to config.xml
15:42:47:<config>
15:42:47:  <!-- Network -->
15:42:47:  <proxy v=':8080'/>
15:42:47:
15:42:47:  <!-- Slot Control -->
15:42:47:  <pause-on-battery v='false'/>
15:42:47:  <power v='full'/>
15:42:47:
15:42:47:  <!-- User Information -->
15:42:47:  <passkey v='********************************'/>
15:42:47:  <team v='123'/>
15:42:47:  <user v='Caty'/>
15:42:47:
15:42:47:  <!-- Folding Slots -->
15:42:47:  <slot id='0' type='CPU'/>
15:42:47:  <slot id='1' type='GPU'/>
15:42:47:</config>
15:45:50:WU00:FS01:0x21:Completed 5025000 out of 7500000 steps (67%)
18:06:05:WU02:FS00:0xa7:Completed 1725000 out of 2500000 steps (69%)
18:08:29:FS00:Shutting core down
18:08:30:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 4916
18:08:30:WU02:FS00:0xa7:Exiting, please wait. . .
18:08:31:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
18:08:31:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:08:32:WU02:FS00:Starting
18:08:32:WARNING:WU02:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
18:08:32:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -np 6
18:08:32:WU02:FS00:Started FahCore on PID 14572
18:08:32:WU02:FS00:Core PID:14488
18:08:32:WU02:FS00:FahCore 0xa7 started
18:08:32:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T18:08:32Z ***********************
18:08:32:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:08:32:WU02:FS00:0xa7:       Type: 0xa7
18:08:32:WU02:FS00:0xa7:       Core: Gromacs
18:08:32:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 14572 -checkpoint 15 -np
18:08:32:WU02:FS00:0xa7:             6
18:08:32:WU02:FS00:0xa7:************************************ Build *************************************
18:08:32:WU02:FS00:0xa7:       SIMD: avx_256
18:08:32:WU02:FS00:0xa7:********************************************************************************
18:08:32:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
18:08:32:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
18:08:32:WU02:FS00:0xa7:Digital signatures verified
18:08:32:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 6
18:08:32:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
18:08:35:WU02:FS00:0xa7:Completed 1729512 out of 2500000 steps (69%)
18:09:11:Removing old file 'configs/config-20200108-193522.xml'
18:09:11:Saving configuration to config.xml
18:09:11:<config>
18:09:11:  <!-- Network -->
18:09:11:  <proxy v=':8080'/>
18:09:11:
18:09:11:  <!-- Slot Control -->
18:09:11:  <pause-on-battery v='false'/>
18:09:11:  <power v='medium'/>
18:09:11:
18:09:11:  <!-- User Information -->
18:09:11:  <passkey v='********************************'/>
18:09:11:  <team v='123'/>
18:09:11:  <user v='Caty'/>
18:09:11:
18:09:11:  <!-- Folding Slots -->
18:09:11:  <slot id='0' type='CPU'/>
18:09:11:  <slot id='1' type='GPU'/>
18:09:11:</config>
18:17:10:WU00:FS01:0x21:Completed 5550000 out of 7500000 steps (74%)
18:18:34:WU02:FS00:0xa7:Completed 1750000 out of 2500000 steps (70%)
18:20:16:WARNING:WU00:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
18:20:16:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
18:20:16:WARNING:WU02:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
18:20:16:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
18:20:16:WU00:FS01:Starting
18:20:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
18:20:16:WU00:FS01:Started FahCore on PID 7728
18:20:16:WU00:FS01:FahCore 0x21 started
18:20:17:WARNING:WU00:FS01:FahCore returned an unknown error code which probably indicates that it crashed
18:20:17:WARNING:WU00:FS01:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
18:20:17:WU02:FS00:Starting
18:20:17:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 5716 -checkpoint 15 -np 6
18:20:17:WU02:FS00:Started FahCore on PID 13700
18:20:17:WU02:FS00:FahCore 0xa7 started
18:20:17:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:20:17:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
*********************** Log Started 2020-01-19T21:38:56Z ***********************
21:38:56:************************* Folding@home Client *************************
21:38:56:        Website: https://foldingathome.org/
21:38:56:      Copyright: (c) 2009-2018 foldingathome.org
21:38:56:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:38:56:           Args:
21:38:56:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
21:38:56:******************************** Build ********************************
21:38:56:        Version: 7.5.1
21:38:56:           Date: May 11 2018
21:38:56:           Time: 13:06:32
21:38:56:     Repository: Git
21:38:56:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:38:56:         Branch: master
21:38:56:       Compiler: Visual C++ 2008
21:38:56:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:38:56:       Platform: win32 10
21:38:56:           Bits: 32
21:38:56:           Mode: Release
21:38:56:******************************* System ********************************
21:38:56:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
21:38:56:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
21:38:56:           CPUs: 8
21:38:56:         Memory: 15.84GiB
21:38:56:    Free Memory: 12.53GiB
21:38:56:        Threads: WINDOWS_THREADS
21:38:56:     OS Version: 6.2
21:38:56:    Has Battery: true
21:38:56:     On Battery: false
21:38:56:     UTC Offset: 1
21:38:56:            PID: 10628
21:38:56:            CWD: C:\Users\cathe\AppData\Roaming\FAHClient
21:38:56:             OS: Windows 10 Home
21:38:56:        OS Arch: AMD64
21:38:56:           GPUs: 1
21:38:56:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
21:38:56:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
21:38:56:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
21:38:56:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.36
21:38:56:  Win32 Service: false
21:38:56:***********************************************************************
21:38:56:<config>
21:38:56:  <!-- Network -->
21:38:56:  <proxy v=':8080'/>
21:38:56:
21:38:56:  <!-- Slot Control -->
21:38:56:  <pause-on-battery v='false'/>
21:38:56:  <power v='medium'/>
21:38:56:
21:38:56:  <!-- User Information -->
21:38:56:  <passkey v='********************************'/>
21:38:56:  <team v='123'/>
21:38:56:  <user v='Caty'/>
21:38:56:
21:38:56:  <!-- Folding Slots -->
21:38:56:  <slot id='0' type='CPU'/>
21:38:56:  <slot id='1' type='GPU'/>
21:38:56:</config>
21:38:56:Trying to access database...
21:38:56:Successfully acquired database lock
21:38:56:Enabled folding slot 00: READY cpu:6
21:38:56:Enabled folding slot 01: READY gpu:0:GP108 [GeForce MX150]
21:38:56:WU00:FS01:Starting
21:38:56:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 10628 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
21:38:57:WU00:FS01:Started FahCore on PID 13864
21:38:57:WU00:FS01:Core PID:13896
21:38:57:WU00:FS01:FahCore 0x21 started
21:38:57:WU02:FS00:Starting
21:38:57:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10628 -checkpoint 15 -np 6
21:38:57:WU02:FS00:Started FahCore on PID 13956
21:38:58:WU02:FS00:Core PID:13976
21:38:58:WU02:FS00:FahCore 0xa7 started
21:38:58:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T21:38:58Z ***********************
21:38:58:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:38:58:WU02:FS00:0xa7:       Type: 0xa7
21:38:58:WU02:FS00:0xa7:       Core: Gromacs
21:38:58:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 13956 -checkpoint 15 -np
21:38:58:WU02:FS00:0xa7:             6
21:38:59:WU02:FS00:0xa7:************************************ Build *************************************
21:38:59:WU02:FS00:0xa7:       SIMD: avx_256
21:38:59:WU02:FS00:0xa7:********************************************************************************
21:38:59:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
21:38:59:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
21:38:59:WU02:FS00:0xa7:Digital signatures verified
21:38:59:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 6
21:38:59:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
21:39:00:WU00:FS01:0x21:*********************** Log Started 2020-01-19T21:39:00Z ***********************
21:39:00:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 7360, Gen 46)
21:39:00:WU00:FS01:0x21:Unit: 0x000000508ca304f15b21ad28d6356352
21:39:00:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:39:00:WU00:FS01:0x21:Machine: 1
21:39:00:WU00:FS01:0x21:Digital signatures verified
21:39:00:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:39:00:WU00:FS01:0x21:Version 0.0.20
21:39:01:WU02:FS00:0xa7:Completed 1729512 out of 2500000 steps (69%)
21:39:02:WU00:FS01:0x21:  Found a checkpoint file
21:39:17:WU00:FS01:0x21:Completed 5500000 out of 7500000 steps (73%)
21:39:17:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:42:08:FS00:Shutting core down
21:42:08:FS01:Shutting core down
21:42:08:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 13976
21:42:08:WU02:FS00:0xa7:Exiting, please wait. . .
21:42:08:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 13896
21:42:08:WU00:FS01:0x21:Exiting, please wait. . .
21:42:09:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
21:42:09:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
21:42:10:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:42:10:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:42:10:WU02:FS00:Starting
21:42:10:WARNING:WU02:FS00:Changed SMP threads from 6 to 3 this can cause some work units to fail
21:42:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10628 -checkpoint 15 -np 3
21:42:11:WU02:FS00:Started FahCore on PID 2424
21:42:11:WU02:FS00:Core PID:3568
21:42:11:WU02:FS00:FahCore 0xa7 started
21:42:11:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T21:42:11Z ***********************
21:42:11:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:42:11:WU02:FS00:0xa7:       Type: 0xa7
21:42:11:WU02:FS00:0xa7:       Core: Gromacs
21:42:11:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 2424 -checkpoint 15 -np 3
21:42:11:WU02:FS00:0xa7:************************************ Build *************************************
21:42:11:WU02:FS00:0xa7:       SIMD: avx_256
21:42:11:WU02:FS00:0xa7:********************************************************************************
21:42:11:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
21:42:11:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
21:42:11:WU02:FS00:0xa7:Digital signatures verified
21:42:11:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 3
21:42:11:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
21:42:12:WU02:FS00:0xa7:Completed 1732822 out of 2500000 steps (69%)
21:42:23:Removing old file 'configs/config-20200108-214126.xml'
21:42:23:Saving configuration to config.xml
21:42:23:<config>
21:42:23:  <!-- Network -->
21:42:23:  <proxy v=':8080'/>
21:42:23:
21:42:23:  <!-- Slot Control -->
21:42:23:  <pause-on-battery v='false'/>
21:42:23:
21:42:23:  <!-- User Information -->
21:42:23:  <passkey v='********************************'/>
21:42:23:  <team v='123'/>
21:42:23:  <user v='Caty'/>
21:42:23:
21:42:23:  <!-- Folding Slots -->
21:42:23:  <slot id='0' type='CPU'/>
21:42:23:</config>
21:42:23:WARNING:WU00:Slot ID 1 no longer exists and there are no other matching slots, dumping
21:42:23:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:11714 run:0 clone:7360 gen:46 core:0x21 unit:0x000000508ca304f15b21ad28d6356352
21:42:23:WU00:Connecting to 140.163.4.241:8080
21:42:24:WU00:Server responded WORK_ACK (400)
21:42:24:WU00:Cleaning up
21:42:45:Removing old file 'configs/config-20200108-214934.xml'
21:42:45:Saving configuration to config.xml
21:42:45:<config>
21:42:45:  <!-- Network -->
21:42:45:  <proxy v=':8080'/>
21:42:45:
21:42:45:  <!-- Slot Control -->
21:42:45:  <pause-on-battery v='false'/>
21:42:45:
21:42:45:  <!-- User Information -->
21:42:45:  <passkey v='********************************'/>
21:42:45:  <team v='123'/>
21:42:45:  <user v='Caty'/>
21:42:45:
21:42:45:  <!-- Folding Slots -->
21:42:45:  <slot id='0' type='CPU'>
21:42:45:    <cpus v='4'/>
21:42:45:  </slot>
21:42:45:</config>
21:42:45:FS00:Shutting core down
21:42:45:WU02:FS00:0xa7:WARNING:Console control signal 1 on PID 3568
21:42:45:WU02:FS00:0xa7:Exiting, please wait. . .
21:42:46:WU02:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:42:46:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:43:00:Removing old file 'configs/config-20200108-224029.xml'
21:43:00:Saving configuration to config.xml
21:43:00:<config>
21:43:00:  <!-- Network -->
21:43:00:  <proxy v=':8080'/>
21:43:00:
21:43:00:  <!-- Slot Control -->
21:43:00:  <pause-on-battery v='false'/>
21:43:00:
21:43:00:  <!-- User Information -->
21:43:00:  <passkey v='********************************'/>
21:43:00:  <team v='123'/>
21:43:00:  <user v='Caty'/>
21:43:00:
21:43:00:  <!-- Folding Slots -->
21:43:00:  <slot id='0' type='CPU'>
21:43:00:    <cpus v='4'/>
21:43:00:  </slot>
21:43:00:</config>
21:43:10:WU02:FS00:Starting
21:43:10:WARNING:WU02:FS00:Changed SMP threads from 3 to 4 this can cause some work units to fail
21:43:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10628 -checkpoint 15 -np 4
21:43:11:WU02:FS00:Started FahCore on PID 5500
21:43:11:WU02:FS00:Core PID:9276
21:43:11:WU02:FS00:FahCore 0xa7 started
21:43:11:WU02:FS00:0xa7:*********************** Log Started 2020-01-19T21:43:11Z ***********************
21:43:11:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:43:11:WU02:FS00:0xa7:       Type: 0xa7
21:43:11:WU02:FS00:0xa7:       Core: Gromacs
21:43:11:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 5500 -checkpoint 15 -np 4
21:43:11:WU02:FS00:0xa7:************************************ Build *************************************
21:43:11:WU02:FS00:0xa7:       SIMD: avx_256
21:43:11:WU02:FS00:0xa7:********************************************************************************
21:43:11:WU02:FS00:0xa7:Project: 14182 (Run 4, Clone 1, Gen 77)
21:43:11:WU02:FS00:0xa7:Unit: 0x0000005d0002894b5cf684d66a21a40b
21:43:11:WU02:FS00:0xa7:Digital signatures verified
21:43:11:WU02:FS00:0xa7:Calling: mdrun -s frame77.tpr -o frame77.trr -cpi state.cpt -cpt 15 -nt 4
21:43:11:WU02:FS00:0xa7:Steps: first=192500000 total=2500000
21:43:12:WU02:FS00:0xa7:Completed 1734282 out of 2500000 steps (69%)
21:46:40:WARNING:WU02:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
21:46:40:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
21:46:40:WU02:FS00:Starting
21:46:41:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 10628 -checkpoint 15 -np 4
21:46:41:WU02:FS00:Started FahCore on PID 13548
21:46:41:WU02:FS00:FahCore 0xa7 started
21:46:41:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:46:41:WARNING:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
20:31:32:           Args:
20:31:32:           Bits: 32
20:31:32:           CPUs: 8
20:31:32:           GPUs: 1
20:31:32:<config>
20:31:32:
20:31:32:
20:31:32:
20:31:32:  </slot>
20:31:32:</config>
20:37:50:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:37:50:ERROR:WU00:FS00:Exception: Could not get an assignment
20:42:04:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:42:04:WU02:FS00:Connecting to 155.247.166.219:8080
20:42:04:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:42:04:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:42:04:WU02:FS00:Trying to send results to collection server
20:42:04:WU02:FS00:Connecting to 128.252.203.4:8080
20:42:04:ERROR:WU02:FS00:Exception: Failed to connect to 128.252.203.4:80: Tentativo di operazione del socket verso un host non raggiungibile.
20:42:04:ERROR:WU00:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
20:42:04:ERROR:WU00:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
20:42:04:WARNING:WU00:FS00:Exception: Failed to find any IP addresses for assignment servers
20:42:04:ERROR:WU00:FS00:Exception: Could not get an assignment
20:48:55:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:14182 run:4 clone:1 gen:77 core:0xa7 unit:0x0000005d0002894b5cf684d66a21a40b
20:48:56:WU02:FS00:Connecting to 155.247.166.219:8080
20:48:56:WU00:FS00:Connecting to 65.254.110.245:8080
20:48:56:WU02:FS00:Server responded WORK_ACK (400)
20:48:56:WU02:FS00:Cleaning up
20:48:56:WU00:FS00:Assigned to work server 128.252.203.9
20:48:56:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 128.252.203.9
20:48:56:WU00:FS00:Connecting to 128.252.203.9:8080
20:48:57:WU00:FS00:Downloading 7.29MiB
20:49:03:WU00:FS00:Download complete
21:35:17:WU00:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
21:36:36:Removing old file 'configs/config-20200108-224130.xml'
21:36:36:Saving configuration to config.xml
21:36:36:<config>
21:36:36:  <!-- Network -->
21:36:36:  <proxy v=':8080'/>
21:36:36:
21:36:36:  <!-- Slot Control -->
21:36:36:  <pause-on-battery v='false'/>
21:36:36:  <power v='full'/>
21:36:36:
21:36:36:  <!-- User Information -->
21:36:36:  <passkey v='********************************'/>
21:36:36:  <team v='123'/>
21:36:36:  <user v='Caty'/>
21:36:36:
21:36:36:  <!-- Folding Slots -->
21:36:36:  <slot id='0' type='CPU'>
21:36:36:    <cpus v='4'/>
21:36:36:  </slot>
21:36:36:</config>
21:39:26:WU00:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
01:16:35:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
01:16:36:WU01:FS00:Connecting to 65.254.110.245:8080
01:16:37:WU01:FS00:Assigned to work server 128.252.203.9
01:16:37:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
01:16:37:WU01:FS00:Connecting to 128.252.203.9:8080
01:16:38:WU01:FS00:Downloading 7.72MiB
01:16:47:WU01:FS00:Download complete
01:16:47:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14401 run:0 clone:4560 gen:6 core:0xa7 unit:0x0000000880fccb095dcb2defe201f147
01:18:52:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
01:18:57:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
01:18:57:WU00:FS00:0xa7:Saving result file frame49.trr
01:18:57:WU00:FS00:0xa7:Saving result file frame49.xtc
01:18:57:WU00:FS00:0xa7:Saving result file md.log
01:18:57:WU00:FS00:0xa7:Saving result file science.log
01:18:57:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:18:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:18:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14400 run:0 clone:2677 gen:49 core:0xa7 unit:0x0000003680fccb095dcad800ac5c31f0
01:18:57:WU00:FS00:Uploading 9.80MiB to 128.252.203.9
01:18:57:WU00:FS00:Connecting to 128.252.203.9:8080
01:18:58:WU01:FS00:Starting
01:18:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 11868 -checkpoint 15 -np 4
01:18:58:WU01:FS00:Started FahCore on PID 2728
01:18:58:WU01:FS00:Core PID:8908
01:18:58:WU01:FS00:FahCore 0xa7 started
01:18:58:WU01:FS00:0xa7:*********************** Log Started 2020-01-21T01:18:58Z ***********************
01:18:58:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:18:58:WU01:FS00:0xa7:       Type: 0xa7
01:18:58:WU01:FS00:0xa7:       Core: Gromacs
01:18:58:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 2728 -checkpoint 15 -np 4
01:18:58:WU01:FS00:0xa7:************************************ Build *************************************
01:18:58:WU01:FS00:0xa7:       SIMD: avx_256
01:18:58:WU01:FS00:0xa7:********************************************************************************
01:18:58:WU01:FS00:0xa7:Project: 14401 (Run 0, Clone 4560, Gen 6)
01:18:58:WU01:FS00:0xa7:Unit: 0x0000000880fccb095dcb2defe201f147
01:18:58:WU01:FS00:0xa7:Reading tar file core.xml
01:18:58:WU01:FS00:0xa7:Reading tar file frame6.tpr
01:18:58:WU01:FS00:0xa7:Digital signatures verified
01:18:58:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpt 15 -nt 4
01:18:58:WU01:FS00:0xa7:Steps: first=750000 total=125000
01:19:03:WU00:FS00:Upload 1.28%
01:19:03:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
01:19:13:WU00:FS00:Upload 2.55%
01:31:02:WU00:FS00:Upload 100.00%
01:31:07:WU00:FS00:Upload complete
01:31:07:WU00:FS00:Server responded WORK_ACK (400)
01:31:07:WU00:FS00:Final credit estimate, 3623.00 points
01:31:07:WU00:FS00:Cleaning up
01:31:26:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
05:24:13:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
05:24:14:WU00:FS00:Connecting to 65.254.110.245:8080
05:45:42:WU00:FS00:0xa7:Completed 75000 out of 2500000 steps (3%)
06:36:37:WU00:FS00:0xa7:Completed 275000 out of 2500000 steps (11%)
06:36:53:WARNING:WU00:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
06:36:53:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
06:36:54:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
Re: How to know if WU are sent back correctly
We are looking for a log that starts at mabe Tue, 21 Jan 2020 10:00:00 GMT or earlier and extends to 11:00:00
All times in the log are GMT.
Caty
Post by Caty »
The next log files I have are these ones:
*********************** Log Started 2020-01-21T22:51:20Z ***********************
22:51:20:************************* Folding@home Client *************************
22:51:20:        Website: https://foldingathome.org/
22:51:20:      Copyright: (c) 2009-2018 foldingathome.org
22:51:20:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:51:20:           Args:
22:51:20:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
22:51:20:******************************** Build ********************************
22:51:20:        Version: 7.5.1
22:51:20:           Date: May 11 2018
22:51:20:           Time: 13:06:32
22:51:20:     Repository: Git
22:51:20:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:51:20:         Branch: master
22:51:20:       Compiler: Visual C++ 2008
22:51:20:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:51:20:       Platform: win32 10
22:51:20:           Bits: 32
22:51:20:           Mode: Release
22:51:20:******************************* System ********************************
22:51:20:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
22:51:20:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
22:51:20:           CPUs: 8
22:51:20:         Memory: 15.84GiB
22:51:20:    Free Memory: 11.86GiB
22:51:20:        Threads: WINDOWS_THREADS
22:51:20:     OS Version: 6.2
22:51:20:    Has Battery: true
22:51:20:     On Battery: false
22:51:20:     UTC Offset: 1
22:51:20:            PID: 12372
22:51:20:            CWD: C:\Users\cathe\AppData\Roaming\FAHClient
22:51:20:             OS: Windows 10 Home
22:51:20:        OS Arch: AMD64
22:51:20:           GPUs: 1
22:51:20:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
22:51:20:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
22:51:20:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
22:51:20:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.36
22:51:20:  Win32 Service: false
22:51:20:***********************************************************************
22:51:20:<config>
22:51:20:  <!-- Network -->
22:51:20:  <proxy v=':8080'/>
22:51:20:
22:51:20:  <!-- Slot Control -->
22:51:20:  <pause-on-battery v='false'/>
22:51:20:  <power v='full'/>
22:51:20:
22:51:20:  <!-- User Information -->
22:51:20:  <passkey v='********************************'/>
22:51:20:  <team v='123'/>
22:51:20:  <user v='Caty'/>
22:51:20:
22:51:20:  <!-- Folding Slots -->
22:51:20:  <slot id='0' type='CPU'>
22:51:20:    <cpus v='4'/>
22:51:20:  </slot>
22:51:20:</config>
22:51:20:Trying to access database...
22:51:20:Successfully acquired database lock
22:51:20:Enabled folding slot 00: READY cpu:4
22:51:20:WU00:FS00:Starting
22:51:20:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 12372 -checkpoint 15 -np 4
22:51:20:WU00:FS00:Started FahCore on PID 4304
22:51:20:WU00:FS00:Core PID:1920
22:51:20:WU00:FS00:FahCore 0xa7 started
22:51:20:WU00:FS00:0xa7:*********************** Log Started 2020-01-21T22:51:20Z ***********************
22:51:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:51:20:WU00:FS00:0xa7:       Type: 0xa7
22:51:20:WU00:FS00:0xa7:       Core: Gromacs
22:51:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4304 -checkpoint 15 -np 4
22:51:20:WU00:FS00:0xa7:************************************ CBang *************************************
22:51:20:WU00:FS00:0xa7:       Date: Oct 26 2019
22:51:20:WU00:FS00:0xa7:       Time: 01:38:25
22:51:20:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:51:20:WU00:FS00:0xa7:     Branch: master
22:51:20:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:51:20:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:51:20:WU00:FS00:0xa7:   Platform: win32 10
22:51:20:WU00:FS00:0xa7:       Bits: 64
22:51:20:WU00:FS00:0xa7:       Mode: Release
22:51:20:WU00:FS00:0xa7:************************************ System ************************************
22:51:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
22:51:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
22:51:20:WU00:FS00:0xa7:       CPUs: 8
22:51:20:WU00:FS00:0xa7:     Memory: 15.84GiB
22:51:20:WU00:FS00:0xa7:Free Memory: 11.78GiB
22:51:20:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:51:20:WU00:FS00:0xa7: OS Version: 6.2
22:51:20:WU00:FS00:0xa7:Has Battery: true
22:51:20:WU00:FS00:0xa7: On Battery: false
22:51:20:WU00:FS00:0xa7: UTC Offset: 1
22:51:20:WU00:FS00:0xa7:        PID: 1920
22:51:20:WU00:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
22:51:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:51:20:WU00:FS00:0xa7:    Version: 0.0.18
22:51:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:51:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:51:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:51:20:WU00:FS00:0xa7:       Time: 01:52:30
22:51:20:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:51:20:WU00:FS00:0xa7:************************************ Build *************************************
22:51:20:WU00:FS00:0xa7:       SIMD: avx_256
22:51:20:WU00:FS00:0xa7:********************************************************************************
22:51:20:WU00:FS00:0xa7:Project: 14053 (Run 1, Clone 85, Gen 63)
22:51:20:WU00:FS00:0xa7:Unit: 0x000000580002894b5b2a58dfa92867b5
22:51:20:WU00:FS00:0xa7:Digital signatures verified
22:51:20:WU00:FS00:0xa7:Calling: mdrun -s frame63.tpr -o frame63.trr -cpi state.cpt -cpt 15 -nt 4
22:51:20:WU00:FS00:0xa7:Steps: first=157500000 total=2500000
22:51:21:WU00:FS00:0xa7:Completed 238161 out of 2500000 steps (9%)
08:27:40:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
08:27:41:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:27:41:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:27:41:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:27:41:ERROR:WU01:FS00:Exception: Could not get an assignment
08:28:41:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:28:41:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:28:41:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:28:41:ERROR:WU01:FS00:Exception: Could not get an assignment
08:30:19:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:30:19:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:30:19:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:30:19:ERROR:WU01:FS00:Exception: Could not get an assignment
08:32:56:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:32:56:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:32:56:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:32:56:ERROR:WU01:FS00:Exception: Could not get an assignment
08:33:45:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
08:33:46:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:33:46:WU00:FS00:0xa7:Saving result file ener.edr
08:33:46:WU00:FS00:0xa7:Saving result file frame63.trr
08:33:46:WU00:FS00:0xa7:Saving result file md.log
08:33:46:WU00:FS00:0xa7:Saving result file science.log
08:33:46:WU00:FS00:0xa7:Saving result file traj_comp.xtc
08:33:46:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:33:47:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:33:47:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:33:47:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:33:47:WU00:FS00:Connecting to 155.247.166.219:8080
08:33:47:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:33:47:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:33:47:WU00:FS00:Trying to send results to collection server
08:33:47:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:33:47:WU00:FS00:Connecting to 155.247.166.220:8080
08:33:47:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:34:48:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:34:48:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:34:48:WU00:FS00:Connecting to 155.247.166.219:8080
08:34:48:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:34:48:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:34:48:WU00:FS00:Trying to send results to collection server
08:34:48:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:34:48:WU00:FS00:Connecting to 155.247.166.220:8080
08:34:48:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:36:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:36:25:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:36:25:WU00:FS00:Connecting to 155.247.166.219:8080
08:36:25:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:36:25:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:36:25:WU00:FS00:Trying to send results to collection server
08:36:25:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:36:25:WU00:FS00:Connecting to 155.247.166.220:8080
08:36:25:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:37:10:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:37:10:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:37:10:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:37:10:ERROR:WU01:FS00:Exception: Could not get an assignment
08:39:02:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:39:02:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:39:02:WU00:FS00:Connecting to 155.247.166.219:8080
08:39:02:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:39:02:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:39:02:WU00:FS00:Trying to send results to collection server
08:39:02:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:39:02:WU00:FS00:Connecting to 155.247.166.220:8080
08:39:02:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:43:16:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:43:16:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:43:16:WU00:FS00:Connecting to 155.247.166.219:8080
08:43:16:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:43:16:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:43:16:WU00:FS00:Trying to send results to collection server
08:43:16:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:43:16:WU00:FS00:Connecting to 155.247.166.220:8080
08:43:16:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:44:01:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:44:01:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:44:01:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:44:01:ERROR:WU01:FS00:Exception: Could not get an assignment
08:50:08:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
08:50:08:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
08:50:08:WU00:FS00:Connecting to 155.247.166.219:8080
08:50:08:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:50:08:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:50:08:WU00:FS00:Trying to send results to collection server
08:50:08:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
08:50:08:WU00:FS00:Connecting to 155.247.166.220:8080
08:50:08:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
08:55:07:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
08:55:07:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
08:55:07:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
08:55:07:ERROR:WU01:FS00:Exception: Could not get an assignment
09:01:13:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
09:01:13:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
09:01:13:WU00:FS00:Connecting to 155.247.166.219:8080
09:01:13:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:01:13:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
09:01:13:WU00:FS00:Trying to send results to collection server
09:01:13:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
09:01:13:WU00:FS00:Connecting to 155.247.166.220:8080
09:01:13:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
09:13:03:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
09:13:03:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
09:13:03:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
09:13:03:ERROR:WU01:FS00:Exception: Could not get an assignment
09:19:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
09:19:10:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
09:19:10:WU00:FS00:Connecting to 155.247.166.219:8080
09:19:10:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:19:10:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
09:19:10:WU00:FS00:Trying to send results to collection server
09:19:10:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
09:19:10:WU00:FS00:Connecting to 155.247.166.220:8080
09:19:10:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
09:42:06:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
09:42:06:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
09:42:06:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
09:42:06:ERROR:WU01:FS00:Exception: Could not get an assignment
09:48:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
09:48:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
09:48:12:WU00:FS00:Connecting to 155.247.166.219:8080
09:48:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
09:48:12:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
09:48:12:WU00:FS00:Trying to send results to collection server
09:48:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
09:48:12:WU00:FS00:Connecting to 155.247.166.220:8080
09:48:12:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
10:29:04:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
10:29:04:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
10:29:04:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
10:29:04:ERROR:WU01:FS00:Exception: Could not get an assignment
10:35:11:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
10:35:11:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
10:35:11:WU00:FS00:Connecting to 155.247.166.219:8080
10:35:11:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:35:11:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
10:35:11:WU00:FS00:Trying to send results to collection server
10:35:11:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
10:35:11:WU00:FS00:Connecting to 155.247.166.220:8080
10:35:11:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
******************************* Date: 2020-01-22 *******************************
11:45:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
11:45:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
11:45:05:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
11:45:05:ERROR:WU01:FS00:Exception: Could not get an assignment
11:51:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
11:51:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
11:51:12:WU00:FS00:Connecting to 155.247.166.219:8080
11:51:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
11:51:12:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
11:51:12:WU00:FS00:Trying to send results to collection server
11:51:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
11:51:12:WU00:FS00:Connecting to 155.247.166.220:8080
11:51:12:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
13:48:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
13:48:05:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
13:48:05:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
13:48:05:ERROR:WU01:FS00:Exception: Could not get an assignment
13:54:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
13:54:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
13:54:12:WU00:FS00:Connecting to 155.247.166.219:8080
13:54:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
13:54:12:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
13:54:12:WU00:FS00:Trying to send results to collection server
13:54:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
13:54:12:WU00:FS00:Connecting to 155.247.166.220:8080
13:54:12:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
17:07:06:ERROR:WU01:FS00:Exception: Could not get IP address for assign1.foldingathome.org: Host sconosciuto.
17:07:06:ERROR:WU01:FS00:Exception: Could not get IP address for assign2.foldingathome.org: Host sconosciuto.
17:07:06:WARNING:WU01:FS00:Exception: Failed to find any IP addresses for assignment servers
17:07:06:ERROR:WU01:FS00:Exception: Could not get an assignment
17:13:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
17:13:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
17:13:12:WU00:FS00:Connecting to 155.247.166.219:8080
17:13:12:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
17:13:12:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 155.247.166.219:80: Tentativo di operazione del socket verso un host non raggiungibile.
17:13:12:WU00:FS00:Trying to send results to collection server
17:13:12:WU00:FS00:Uploading 7.17MiB to 155.247.166.220
17:13:12:WU00:FS00:Connecting to 155.247.166.220:8080
17:13:12:ERROR:WU00:FS00:Exception: Failed to connect to 155.247.166.220:80: Tentativo di operazione del socket verso un host non raggiungibile.
18:30:08:12:127.0.0.1:New Web connection
18:31:21:ERROR:Receive error: 10054: Connessione in corso interrotta forzatamente dall'host remoto.
18:31:37:ERROR:Receive error: 10053: Connessione interrotta dal software del computer host.
18:33:07:Clean exit
*********************** Log Started 2020-01-22T18:33:34Z ***********************
18:33:34:************************* Folding@home Client *************************
18:33:34:        Website: https://foldingathome.org/
18:33:34:      Copyright: (c) 2009-2018 foldingathome.org
18:33:34:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:33:34:           Args: --open-web-control
18:33:34:         Config: C:\Users\cathe\AppData\Roaming\FAHClient\config.xml
18:33:34:******************************** Build ********************************
18:33:34:        Version: 7.5.1
18:33:34:           Date: May 11 2018
18:33:34:           Time: 13:06:32
18:33:34:     Repository: Git
18:33:34:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:33:34:         Branch: master
18:33:34:       Compiler: Visual C++ 2008
18:33:34:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:33:34:       Platform: win32 10
18:33:34:           Bits: 32
18:33:34:           Mode: Release
18:33:34:******************************* System ********************************
18:33:34:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
18:33:34:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
18:33:34:           CPUs: 8
18:33:34:         Memory: 15.84GiB
18:33:34:    Free Memory: 9.86GiB
18:33:34:        Threads: WINDOWS_THREADS
18:33:34:     OS Version: 6.2
18:33:34:    Has Battery: true
18:33:34:     On Battery: false
18:33:34:     UTC Offset: 1
18:33:34:            PID: 15528
18:33:34:            CWD: C:\Users\cathe\AppData\Roaming\FAHClient
18:33:34:             OS: Windows 10 Home
18:33:34:        OS Arch: AMD64
18:33:34:           GPUs: 1
18:33:34:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP108 [GeForce MX150]
18:33:34:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.2
18:33:34:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
18:33:34:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:398.36
18:33:34:  Win32 Service: false
18:33:34:***********************************************************************
18:33:34:<config>
18:33:34:  <!-- Network -->
18:33:34:  <proxy v=':8080'/>
18:33:34:
18:33:34:  <!-- Slot Control -->
18:33:34:  <pause-on-battery v='false'/>
18:33:34:  <power v='full'/>
18:33:34:
18:33:34:  <!-- User Information -->
18:33:34:  <passkey v='********************************'/>
18:33:34:  <team v='123'/>
18:33:34:  <user v='Caty'/>
18:33:34:
18:33:34:  <!-- Folding Slots -->
18:33:34:  <slot id='0' type='CPU'>
18:33:34:    <cpus v='4'/>
18:33:34:  </slot>
18:33:34:</config>
18:33:34:Trying to access database...
18:33:34:Successfully acquired database lock
18:33:34:Enabled folding slot 00: READY cpu:4
18:33:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14053 run:1 clone:85 gen:63 core:0xa7 unit:0x000000580002894b5b2a58dfa92867b5
18:33:34:WU00:FS00:Uploading 7.17MiB to 155.247.166.219
18:33:34:WU00:FS00:Connecting to 155.247.166.219:8080
18:33:34:WU01:FS00:Connecting to 65.254.110.245:8080
18:33:35:WU01:FS00:Assigned to work server 128.252.203.9
18:33:35:WU01:FS00:Requesting new work unit for slot 00: READY cpu:4 from 128.252.203.9
18:33:35:WU01:FS00:Connecting to 128.252.203.9:8080
18:33:35:WU01:FS00:Downloading 7.72MiB
18:33:37:11:127.0.0.1:New Web connection
18:33:41:WU01:FS00:Download 12.95%
18:33:43:WU00:FS00:Upload 46.17%
18:33:46:WU01:FS00:Download complete
18:33:46:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14401 run:0 clone:4402 gen:11 core:0xa7 unit:0x0000000c80fccb095dcb2e091701fa95
18:33:46:WU01:FS00:Starting
18:33:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15528 -checkpoint 15 -np 4
18:33:47:WU01:FS00:Started FahCore on PID 16560
18:33:47:WU01:FS00:Core PID:15464
18:33:47:WU01:FS00:FahCore 0xa7 started
18:33:48:WU01:FS00:0xa7:*********************** Log Started 2020-01-22T18:33:47Z ***********************
18:33:48:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:33:48:WU01:FS00:0xa7:       Type: 0xa7
18:33:48:WU01:FS00:0xa7:       Core: Gromacs
18:33:48:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16560 -checkpoint 15 -np
18:33:48:WU01:FS00:0xa7:             4
18:33:48:WU01:FS00:0xa7:************************************ CBang *************************************
18:33:48:WU01:FS00:0xa7:       Date: Oct 26 2019
18:33:48:WU01:FS00:0xa7:       Time: 01:38:25
18:33:48:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
18:33:48:WU01:FS00:0xa7:     Branch: master
18:33:48:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
18:33:48:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:33:48:WU01:FS00:0xa7:   Platform: win32 10
18:33:48:WU01:FS00:0xa7:       Bits: 64
18:33:48:WU01:FS00:0xa7:       Mode: Release
18:33:48:WU01:FS00:0xa7:************************************ System ************************************
18:33:48:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
18:33:48:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
18:33:48:WU01:FS00:0xa7:       CPUs: 8
18:33:48:WU01:FS00:0xa7:     Memory: 15.84GiB
18:33:48:WU01:FS00:0xa7:Free Memory: 9.58GiB
18:33:48:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
18:33:48:WU01:FS00:0xa7: OS Version: 6.2
18:33:48:WU01:FS00:0xa7:Has Battery: true
18:33:48:WU01:FS00:0xa7: On Battery: false
18:33:48:WU01:FS00:0xa7: UTC Offset: 1
18:33:48:WU01:FS00:0xa7:        PID: 15464
18:33:48:WU01:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
18:33:48:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
18:33:48:WU01:FS00:0xa7:    Version: 0.0.18
18:33:48:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:33:48:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
18:33:48:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
18:33:48:WU01:FS00:0xa7:       Time: 01:52:30
18:33:48:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
18:33:48:WU01:FS00:0xa7:************************************ Build *************************************
18:33:48:WU01:FS00:0xa7:       SIMD: avx_256
18:33:48:WU01:FS00:0xa7:********************************************************************************
18:33:48:WU01:FS00:0xa7:Project: 14401 (Run 0, Clone 4402, Gen 11)
18:33:48:WU01:FS00:0xa7:Unit: 0x0000000c80fccb095dcb2e091701fa95
18:33:48:WU01:FS00:0xa7:Reading tar file core.xml
18:33:48:WU01:FS00:0xa7:Reading tar file frame11.tpr
18:33:48:WU01:FS00:0xa7:Digital signatures verified
18:33:48:WU01:FS00:0xa7:Calling: mdrun -s frame11.tpr -o frame11.trr -x frame11.xtc -cpt 15 -nt 4
18:33:48:WU01:FS00:0xa7:Steps: first=1375000 total=125000
18:33:53:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
18:33:58:WU00:FS00:Upload 97.57%
18:34:51:WU00:FS00:Upload complete
18:34:51:WU00:FS00:Server responded WORK_ACK (400)
18:34:51:WU00:FS00:Final credit estimate, 6746.00 points
18:34:51:WU00:FS00:Cleaning up
18:36:29:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
18:39:11:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
22:56:00:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
22:56:00:WU00:FS00:Connecting to 65.254.110.245:8080
22:56:01:WU00:FS00:Assigned to work server 128.252.203.9
22:56:01:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
22:56:01:WU00:FS00:Connecting to 128.252.203.9:8080
22:56:03:WU00:FS00:Downloading 7.64MiB
22:56:09:WU00:FS00:Download 54.82%
22:56:12:WU00:FS00:Download complete
22:56:12:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14402 run:0 clone:2235 gen:10 core:0xa7 unit:0x0000000c80fccb095dcb2bfaff1a68df
22:58:37:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
22:58:43:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
22:58:43:WU01:FS00:0xa7:Saving result file frame11.trr
22:58:43:WU01:FS00:0xa7:Saving result file frame11.xtc
22:58:43:WU01:FS00:0xa7:Saving result file md.log
22:58:43:WU01:FS00:0xa7:Saving result file science.log
22:58:43:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
22:58:44:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:58:44:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14401 run:0 clone:4402 gen:11 core:0xa7 unit:0x0000000c80fccb095dcb2e091701fa95
22:58:44:WU01:FS00:Uploading 10.51MiB to 128.252.203.9
22:58:44:WU00:FS00:Starting
22:58:44:WU01:FS00:Connecting to 128.252.203.9:8080
22:58:44:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15528 -checkpoint 15 -np 4
22:58:44:WU00:FS00:Started FahCore on PID 15664
22:58:44:WU00:FS00:Core PID:10740
22:58:44:WU00:FS00:FahCore 0xa7 started
22:58:44:WU00:FS00:0xa7:*********************** Log Started 2020-01-22T22:58:44Z ***********************
22:58:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:58:44:WU00:FS00:0xa7:       Type: 0xa7
22:58:44:WU00:FS00:0xa7:       Core: Gromacs
22:58:44:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 15664 -checkpoint 15 -np
22:58:44:WU00:FS00:0xa7:             4
22:58:44:WU00:FS00:0xa7:************************************ CBang *************************************
22:58:44:WU00:FS00:0xa7:       Date: Oct 26 2019
22:58:44:WU00:FS00:0xa7:       Time: 01:38:25
22:58:44:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:58:44:WU00:FS00:0xa7:     Branch: master
22:58:44:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:58:44:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:58:44:WU00:FS00:0xa7:   Platform: win32 10
22:58:44:WU00:FS00:0xa7:       Bits: 64
22:58:44:WU00:FS00:0xa7:       Mode: Release
22:58:44:WU00:FS00:0xa7:************************************ System ************************************
22:58:44:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
22:58:44:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
22:58:44:WU00:FS00:0xa7:       CPUs: 8
22:58:44:WU00:FS00:0xa7:     Memory: 15.84GiB
22:58:44:WU00:FS00:0xa7:Free Memory: 9.36GiB
22:58:44:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:58:44:WU00:FS00:0xa7: OS Version: 6.2
22:58:44:WU00:FS00:0xa7:Has Battery: true
22:58:44:WU00:FS00:0xa7: On Battery: false
22:58:44:WU00:FS00:0xa7: UTC Offset: 1
22:58:44:WU00:FS00:0xa7:        PID: 10740
22:58:44:WU00:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
22:58:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:58:44:WU00:FS00:0xa7:    Version: 0.0.18
22:58:44:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:58:44:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:58:44:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:58:44:WU00:FS00:0xa7:       Time: 01:52:30
22:58:44:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:58:44:WU00:FS00:0xa7:************************************ Build *************************************
22:58:44:WU00:FS00:0xa7:       SIMD: avx_256
22:58:44:WU00:FS00:0xa7:********************************************************************************
22:58:44:WU00:FS00:0xa7:Project: 14402 (Run 0, Clone 2235, Gen 10)
22:58:44:WU00:FS00:0xa7:Unit: 0x0000000c80fccb095dcb2bfaff1a68df
22:58:44:WU00:FS00:0xa7:Reading tar file core.xml
22:58:44:WU00:FS00:0xa7:Reading tar file frame10.tpr
22:58:44:WU00:FS00:0xa7:Digital signatures verified
22:58:44:WU00:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -x frame10.xtc -cpt 15 -nt 4
22:58:44:WU00:FS00:0xa7:Steps: first=1250000 total=125000
22:58:50:WU01:FS00:Upload 71.39%
22:58:50:WU00:FS00:0xa7:Completed 1 out of 125000 steps (0%)
22:58:56:WU01:FS00:Upload complete
22:58:56:WU01:FS00:Server responded WORK_ACK (400)
22:58:56:WU01:FS00:Final credit estimate, 4323.00 points
22:58:56:WU01:FS00:Cleaning up
23:01:31:WU00:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
03:23:25:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
03:23:26:WU01:FS00:Connecting to 65.254.110.245:8080
03:23:27:WU01:FS00:Assigned to work server 128.252.203.9
03:23:27:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
03:23:27:WU01:FS00:Connecting to 128.252.203.9:8080
03:23:27:WU01:FS00:Downloading 7.29MiB
03:23:33:WU01:FS00:Download 75.45%
03:23:33:WU01:FS00:Download complete
03:23:33:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14400 run:0 clone:4069 gen:62 core:0xa7 unit:0x0000004180fccb095dcad7437854f8db
03:26:09:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
03:26:15:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
03:26:15:WU00:FS00:0xa7:Saving result file frame10.trr
03:26:15:WU00:FS00:0xa7:Saving result file frame10.xtc
03:26:15:WU00:FS00:0xa7:Saving result file md.log
03:26:15:WU00:FS00:0xa7:Saving result file science.log
03:26:15:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:26:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:26:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14402 run:0 clone:2235 gen:10 core:0xa7 unit:0x0000000c80fccb095dcb2bfaff1a68df
03:26:15:WU00:FS00:Uploading 10.32MiB to 128.252.203.9
03:26:15:WU00:FS00:Connecting to 128.252.203.9:8080
03:26:15:WU01:FS00:Starting
03:26:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15528 -checkpoint 15 -np 4
03:26:15:WU01:FS00:Started FahCore on PID 15716
03:26:15:WU01:FS00:Core PID:5540
03:26:15:WU01:FS00:FahCore 0xa7 started
03:26:16:WU01:FS00:0xa7:*********************** Log Started 2020-01-23T03:26:16Z ***********************
03:26:16:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:26:16:WU01:FS00:0xa7:       Type: 0xa7
03:26:16:WU01:FS00:0xa7:       Core: Gromacs
03:26:16:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 15716 -checkpoint 15 -np
03:26:16:WU01:FS00:0xa7:             4
03:26:16:WU01:FS00:0xa7:************************************ CBang *************************************
03:26:16:WU01:FS00:0xa7:       Date: Oct 26 2019
03:26:16:WU01:FS00:0xa7:       Time: 01:38:25
03:26:16:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:26:16:WU01:FS00:0xa7:     Branch: master
03:26:16:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:26:16:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:26:16:WU01:FS00:0xa7:   Platform: win32 10
03:26:16:WU01:FS00:0xa7:       Bits: 64
03:26:16:WU01:FS00:0xa7:       Mode: Release
03:26:16:WU01:FS00:0xa7:************************************ System ************************************
03:26:16:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
03:26:16:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
03:26:16:WU01:FS00:0xa7:       CPUs: 8
03:26:16:WU01:FS00:0xa7:     Memory: 15.84GiB
03:26:16:WU01:FS00:0xa7:Free Memory: 10.25GiB
03:26:16:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:26:16:WU01:FS00:0xa7: OS Version: 6.2
03:26:16:WU01:FS00:0xa7:Has Battery: true
03:26:16:WU01:FS00:0xa7: On Battery: false
03:26:16:WU01:FS00:0xa7: UTC Offset: 1
03:26:16:WU01:FS00:0xa7:        PID: 5540
03:26:16:WU01:FS00:0xa7:        CWD: C:\Users\cathe\AppData\Roaming\FAHClient\work
03:26:16:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:26:16:WU01:FS00:0xa7:    Version: 0.0.18
03:26:16:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:26:16:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:26:16:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:26:16:WU01:FS00:0xa7:       Time: 01:52:30
03:26:16:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:26:16:WU01:FS00:0xa7:************************************ Build *************************************
03:26:16:WU01:FS00:0xa7:       SIMD: avx_256
03:26:16:WU01:FS00:0xa7:********************************************************************************
03:26:16:WU01:FS00:0xa7:Project: 14400 (Run 0, Clone 4069, Gen 62)
03:26:16:WU01:FS00:0xa7:Unit: 0x0000004180fccb095dcad7437854f8db
03:26:16:WU01:FS00:0xa7:Reading tar file core.xml
03:26:16:WU01:FS00:0xa7:Reading tar file frame62.tpr
03:26:16:WU01:FS00:0xa7:Digital signatures verified
03:26:16:WU01:FS00:0xa7:Calling: mdrun -s frame62.tpr -o frame62.trr -x frame62.xtc -cpt 15 -nt 4
03:26:16:WU01:FS00:0xa7:Steps: first=7750000 total=125000
03:26:19:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
03:26:21:WU00:FS00:Upload 51.46%
03:26:26:WU00:FS00:Upload complete
03:26:26:WU00:FS00:Server responded WORK_ACK (400)
03:26:26:WU00:FS00:Final credit estimate, 4124.00 points
03:26:26:WU00:FS00:Cleaning up
03:28:48:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
07:16:58:WU01:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
07:18:03:WARNING:WU01:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
07:18:03:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
07:18:03:WU01:FS00:Starting
07:18:03:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\cathe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15528 -checkpoint 15 -np 4
07:18:04:WU01:FS00:Started FahCore on PID 3568
07:18:04:WU01:FS00:FahCore 0xa7 started
07:18:04:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
07:18:04:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741205 = 0xc000026b)
After the failed upload of that evening, the computer run until 6:36 a.m. of the morning and then has resumed at 22 p.m.
Well, I can't find the necessariy information in any of the logs you've posted. The one fact I can provided is that https://apps.foldingathome.org/wu#proje ... e=1&gen=77 shows that the WU as returned at 2020-01-20 21:04:47 with a status Faulty 2. That means that at some time before that, the WU was processed and the calculation ended with an error. That result was returned so that the project can gather statistics on what kind of errors are being experienced by the project as well as to initiate a re-assignment of the WU for someone else to attempt to complete it. As you can see, someone called Anonymous successfully completed it some 5.5 hours later.
The explanation of the error you experienced should be somewhere in your log when the WU was processed and the WU was deleted from your system. You did receive a partial credit of 372.28 for the error report.
I'm not sure how or why you were able to re-process the WU but apparently you restored a backup. That is never successful because you can only get credit for a WU one time -- even if it's a partial credit. The server will not let you upload another result for the same WU.
I notice you're having a few communications OTHER THAN the inability to return this WU. Those don't seem to be related. After a reboot, if your internet is slow to connect, FAH doesn't wait for the connection. It just tried to connect and if it can't make a connection, it waits a bit and then just re-tries.
Caty
Post by Caty »
Yes I do see some problems other that this one.
The solution for all of this is exiting FAH (stopping to fold), connecting the computer to internet and then start folding again. Don't know if this makes sense but hope helps other people.
Thank you very much for your patience
