It seems the project description for aforementioned projects are missing, it would be nice if this could be filled
thanks
project 14312 to 14319 missing desciption
Re: project 14312 to 14319 missing desciption
These projects are currently in beta, you should only be getting them if you are using the beta flag. That is only recommended for members of the beta test team.
If you are getting them with another setting, let us know and we will pass that on to the researcher running these.
Thanks for catching this. The project descriptions should be added by the end of the day.
They are the same as the 14086-14093 set though.
These projects just moved to Advanced recently.
Edit: Should be done now!
