How to check correct completes of wu?
gravitonian
Post by gravitonian »
My statistics are not updated and credits are not received after one WU and I am worried that its are being executed with an error due to a small overclock of the video card.
Log file:
*********************** Log Started 2020-01-10T15:37:59Z ***********************
15:37:59:************************* Folding@home Client *************************
15:37:59:        Website: https://foldingathome.org/
15:37:59:      Copyright: (c) 2009-2018 foldingathome.org
15:37:59:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:37:59:           Args:
15:37:59:         Config: C:\ProgramData\FAHClient\config.xml
15:37:59:******************************** Build ********************************
15:37:59:        Version: 7.5.1
15:37:59:           Date: May 11 2018
15:37:59:           Time: 13:06:32
15:37:59:     Repository: Git
15:37:59:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:37:59:         Branch: master
15:37:59:       Compiler: Visual C++ 2008
15:37:59:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:37:59:       Platform: win32 10
15:37:59:           Bits: 32
15:37:59:           Mode: Release
15:37:59:******************************* System ********************************
15:37:59:            CPU: Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz
15:37:59:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
15:37:59:           CPUs: 4
15:37:59:         Memory: 7.95GiB
15:37:59:    Free Memory: 6.03GiB
15:37:59:        Threads: WINDOWS_THREADS
15:37:59:     OS Version: 6.1
15:37:59:    Has Battery: false
15:37:59:     On Battery: false
15:37:59:     UTC Offset: 4
15:37:59:            PID: 4120
15:37:59:            CWD: C:\ProgramData\FAHClient
15:37:59:             OS: Windows 7 Ultimate
15:37:59:        OS Arch: AMD64
15:37:59:           GPUs: 1
15:37:59:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU116 [GeForce GTX 1660 SUPER]
15:37:59:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
15:37:59:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.87
15:37:59:  Win32 Service: false
15:37:59:***********************************************************************
15:37:59:<config>
15:37:59:  <!-- Network -->
15:37:59:  <proxy v=':8080'/>
15:37:59:
15:37:59:  <!-- Slot Control -->
15:37:59:  <power v='FULL'/>
15:37:59:
15:37:59:  <!-- User Information -->
15:37:59:  <passkey v='********************************'/>
15:37:59:  <user v='gravitonian'/>
15:37:59:
15:37:59:  <!-- Folding Slots -->
15:37:59:  <slot id='0' type='CPU'>
15:37:59:    <cpus v='1'/>
15:37:59:    <paused v='true'/>
15:37:59:  </slot>
15:37:59:  <slot id='1' type='GPU'>
15:37:59:  </slot>
15:37:59:</config>
15:37:59:Trying to access database...
15:37:59:Successfully acquired database lock
15:37:59:Enabled folding slot 00: PAUSED cpu:1 (by user)
15:37:59:Enabled folding slot 01: PAUSED gpu:0:TU116 [GeForce GTX 1660 SUPER] (by user)
16:16:33:FS00:Unpaused
16:16:33:FS01:Unpaused
16:16:33:WU01:FS01:Starting
16:16:33:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:16:33:WU01:FS01:Started FahCore on PID 5336
16:16:33:WU01:FS01:Core PID:2984
16:16:33:WU01:FS01:FahCore 0x21 started
16:16:33:WU02:FS00:Starting
16:16:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -np 1
16:16:33:WU02:FS00:Started FahCore on PID 6508
16:16:33:WU02:FS00:Core PID:4944
16:16:33:WU02:FS00:FahCore 0xa7 started
16:16:34:WU01:FS01:0x21:*********************** Log Started 2020-01-10T16:16:33Z ***********************
16:16:34:WU01:FS01:0x21:Project: 14196 (Run 4, Clone 317, Gen 89)
16:16:34:WU01:FS01:0x21:Unit: 0x000000880002894b5d924655e77538e4
16:16:34:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:16:34:WU01:FS01:0x21:Machine: 1
16:16:34:WU01:FS01:0x21:Digital signatures verified
16:16:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:16:34:WU01:FS01:0x21:Version 0.0.20
16:16:34:WU01:FS01:0x21:  Found a checkpoint file
16:16:34:WU02:FS00:0xa7:*********************** Log Started 2020-01-10T16:16:33Z ***********************
16:16:34:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:16:34:WU02:FS00:0xa7:       Type: 0xa7
16:16:34:WU02:FS00:0xa7:       Core: Gromacs
16:16:34:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 6508 -checkpoint 15 -np 1
16:16:34:WU02:FS00:0xa7:************************************ CBang *************************************
16:16:34:WU02:FS00:0xa7:       Date: Oct 26 2019
16:16:34:WU02:FS00:0xa7:       Time: 01:38:25
16:16:34:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:16:34:WU02:FS00:0xa7:     Branch: master
16:16:34:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
16:16:34:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:16:34:WU02:FS00:0xa7:   Platform: win32 10
16:16:34:WU02:FS00:0xa7:       Bits: 64
16:16:34:WU02:FS00:0xa7:       Mode: Release
16:16:34:WU02:FS00:0xa7:************************************ System ************************************
16:16:34:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-3550 CPU @ 3.30GHz
16:16:34:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
16:16:34:WU02:FS00:0xa7:       CPUs: 4
16:16:34:WU02:FS00:0xa7:     Memory: 7.95GiB
16:16:34:WU02:FS00:0xa7:Free Memory: 5.07GiB
16:16:34:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
16:16:34:WU02:FS00:0xa7: OS Version: 6.1
16:16:34:WU02:FS00:0xa7:Has Battery: false
16:16:34:WU02:FS00:0xa7: On Battery: false
16:16:34:WU02:FS00:0xa7: UTC Offset: 4
16:16:34:WU02:FS00:0xa7:        PID: 4944
16:16:34:WU02:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
16:16:34:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
16:16:34:WU02:FS00:0xa7:    Version: 0.0.18
16:16:34:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:16:34:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:16:34:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
16:16:34:WU02:FS00:0xa7:       Time: 01:52:30
16:16:34:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:16:34:WU02:FS00:0xa7:************************************ Build *************************************
16:16:34:WU02:FS00:0xa7:       SIMD: avx_256
16:16:34:WU02:FS00:0xa7:********************************************************************************
16:16:34:WU02:FS00:0xa7:Project: 13826 (Run 649, Clone 1, Gen 86)
16:16:34:WU02:FS00:0xa7:Unit: 0x0000006680fccb095c979a8e86466d00
16:16:34:WU02:FS00:0xa7:Digital signatures verified
16:16:34:WU02:FS00:0xa7:Calling: mdrun -s frame86.tpr -o frame86.trr -x frame86.xtc -cpi state.cpt -cpt 15 -nt 1
16:16:34:WU02:FS00:0xa7:Steps: first=10750000 total=125000
16:16:36:WU02:FS00:0xa7:Completed 3412 out of 125000 steps (2%)
16:16:37:Removing old file 'configs/config-20170512-015859.xml'
16:16:37:Saving configuration to config.xml
16:16:37:<config>
16:16:37:  <!-- Network -->
16:16:37:  <proxy v=':8080'/>
16:16:37:
16:16:37:  <!-- Slot Control -->
16:16:37:  <power v='FULL'/>
16:16:37:
16:16:37:  <!-- User Information -->
16:16:37:  <passkey v='********************************'/>
16:16:37:  <user v='gravitonian'/>
16:16:37:
16:16:37:  <!-- Folding Slots -->
16:16:37:  <slot id='0' type='CPU'>
16:16:37:    <cpus v='1'/>
16:16:37:  </slot>
16:16:37:  <slot id='1' type='GPU'/>
16:16:37:</config>
16:16:40:WU01:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
16:16:40:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:19:52:WU01:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
16:19:53:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
16:23:02:WU01:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
16:26:13:WU01:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
16:29:23:WU01:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
16:31:59:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
16:32:33:WU01:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
16:35:46:WU01:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
16:38:56:WU01:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
16:42:06:WU01:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
16:44:02:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
16:45:17:WU01:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
16:48:28:WU01:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
16:51:40:WU01:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
16:54:50:WU01:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
16:56:14:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
16:58:01:WU01:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
17:01:10:WU01:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
17:04:21:WU01:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
17:07:33:WU01:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
17:08:21:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
17:10:43:WU01:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
17:13:53:WU01:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
17:17:02:WU01:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
17:20:12:WU01:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
17:20:19:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
17:23:25:WU01:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
17:26:35:WU01:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
17:29:45:WU01:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
17:32:27:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
17:32:55:WU01:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
17:36:05:WU01:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
17:39:18:WU01:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
17:42:28:WU01:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
17:44:24:ERROR:Receive error: 10053: Программа на вашем хост-компьютере разорвала установленное подключение.
17:44:33:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
17:44:40:ERROR:Receive error: 10053: Программа на вашем хост-компьютере разорвала установленное подключение.
17:45:39:WU01:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
17:48:49:WU01:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
17:52:00:WU01:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
17:55:13:WU01:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
17:56:42:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
17:58:23:WU01:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
18:01:33:WU01:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
18:04:44:WU01:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
18:07:55:WU01:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
18:08:50:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
18:11:08:WU01:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
18:14:18:WU01:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
18:17:29:WU01:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
18:20:39:WU01:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
18:20:55:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
18:23:49:WU01:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
18:27:02:WU01:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
18:30:12:WU01:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
18:32:59:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
18:33:22:WU01:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
18:36:32:WU01:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
18:39:42:WU01:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
18:42:54:WU01:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
18:45:02:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
18:46:04:WU01:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
18:49:13:WU01:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
18:52:23:WU01:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
18:55:33:WU01:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
18:57:07:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
18:58:45:WU01:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
19:01:55:WU01:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
19:05:05:WU01:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
19:08:15:WU01:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
19:08:16:WU00:FS01:Connecting to 65.254.110.245:8080
19:08:17:WU00:FS01:Assigned to work server 155.247.166.219
19:08:17:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU116 [GeForce GTX 1660 SUPER] from 155.247.166.219
19:08:17:WU00:FS01:Connecting to 155.247.166.219:8080
19:08:17:WU00:FS01:Downloading 27.50MiB
19:08:23:WU00:FS01:Download 4.77%
19:08:29:WU00:FS01:Download 8.18%
19:08:35:WU00:FS01:Download 11.59%
19:08:41:WU00:FS01:Download 14.09%
19:08:47:WU00:FS01:Download 17.50%
19:08:53:WU00:FS01:Download 20.68%
19:08:59:WU00:FS01:Download 23.41%
19:09:05:WU00:FS01:Download 27.28%
19:09:11:WU00:FS01:Download 35.69%
19:09:13:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
19:09:17:WU00:FS01:Download 41.60%
19:09:23:WU00:FS01:Download 46.82%
19:09:29:WU00:FS01:Download 49.78%
19:09:35:WU00:FS01:Download 52.51%
19:09:41:WU00:FS01:Download 55.23%
19:09:47:WU00:FS01:Download 58.87%
19:09:53:WU00:FS01:Download 62.05%
19:09:59:WU00:FS01:Download 65.46%
19:10:05:WU00:FS01:Download 68.19%
19:10:11:WU00:FS01:Download 70.69%
19:10:17:WU00:FS01:Download 74.33%
19:10:23:WU00:FS01:Download 77.51%
19:10:29:WU00:FS01:Download 81.60%
19:10:35:WU00:FS01:Download 86.60%
19:10:41:WU00:FS01:Download 91.15%
19:10:47:WU00:FS01:Download 95.92%
19:10:51:WU00:FS01:Download complete
19:10:51:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14196 run:18 clone:71 gen:105 core:0x21 unit:0x000000a40002894b5d9246a7e78a781d
19:11:25:WU01:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
19:11:27:WU01:FS01:0x21:Saving result file logfile_01.txt
19:11:27:WU01:FS01:0x21:Saving result file checkpointState.xml
19:11:27:WU01:FS01:0x21:Saving result file checkpt.crc
19:11:27:WU01:FS01:0x21:Saving result file log.txt
19:11:27:WU01:FS01:0x21:Saving result file positions.xtc
19:11:27:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
19:11:27:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:11:27:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14196 run:4 clone:317 gen:89 core:0x21 unit:0x000000880002894b5d924655e77538e4
19:11:27:WU01:FS01:Uploading 19.40MiB to 155.247.166.219
19:11:27:WU01:FS01:Connecting to 155.247.166.219:8080
19:11:28:WU00:FS01:Starting
19:11:28:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
19:11:28:WU00:FS01:Started FahCore on PID 6608
19:11:28:WU00:FS01:Core PID:4332
19:11:28:WU00:FS01:FahCore 0x21 started
19:11:28:WU00:FS01:0x21:*********************** Log Started 2020-01-10T19:11:28Z ***********************
19:11:28:WU00:FS01:0x21:Project: 14196 (Run 18, Clone 71, Gen 105)
19:11:28:WU00:FS01:0x21:Unit: 0x000000a40002894b5d9246a7e78a781d
19:11:28:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:11:28:WU00:FS01:0x21:Machine: 1
19:11:28:WU00:FS01:0x21:Reading tar file core.xml
19:11:28:WU00:FS01:0x21:Reading tar file integrator.xml
19:11:28:WU00:FS01:0x21:Reading tar file state.xml
19:11:28:WU00:FS01:0x21:Reading tar file system.xml
19:11:28:WU00:FS01:0x21:Digital signatures verified
19:11:28:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:11:28:WU00:FS01:0x21:Version 0.0.20
19:11:33:WU01:FS01:Upload 2.58%
19:11:37:WU00:FS01:0x21:Completed 0 out of 5000000 steps (0%)
19:11:37:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:11:39:WU01:FS01:Upload 5.48%
19:11:45:WU01:FS01:Upload 8.37%
19:11:51:WU01:FS01:Upload 11.60%
19:11:57:WU01:FS01:Upload 14.49%
19:12:03:WU01:FS01:Upload 17.39%
19:12:09:WU01:FS01:Upload 20.29%
19:12:15:WU01:FS01:Upload 23.51%
19:12:21:WU01:FS01:Upload 26.41%
19:12:27:WU01:FS01:Upload 29.31%
19:12:33:WU01:FS01:Upload 32.21%
19:12:39:WU01:FS01:Upload 35.43%
19:12:45:WU01:FS01:Upload 38.33%
19:12:51:WU01:FS01:Upload 41.23%
19:12:57:WU01:FS01:Upload 44.13%
19:13:03:WU01:FS01:Upload 47.02%
19:13:09:WU01:FS01:Upload 50.25%
19:13:15:WU01:FS01:Upload 53.14%
19:13:21:WU01:FS01:Upload 56.04%
19:13:27:WU01:FS01:Upload 58.94%
19:13:33:WU01:FS01:Upload 61.84%
19:13:39:WU01:FS01:Upload 65.06%
19:13:45:WU01:FS01:Upload 67.96%
19:13:51:WU01:FS01:Upload 70.86%
19:13:57:WU01:FS01:Upload 74.08%
19:14:03:WU01:FS01:Upload 76.98%
19:14:09:WU01:FS01:Upload 79.88%
19:14:15:WU01:FS01:Upload 83.10%
19:14:21:WU01:FS01:Upload 86.00%
19:14:27:WU01:FS01:Upload 88.90%
19:14:33:WU01:FS01:Upload 91.79%
19:14:39:WU01:FS01:Upload 95.02%
19:14:45:WU01:FS01:Upload 97.91%
19:14:47:WU00:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
19:14:49:WU01:FS01:Upload complete
19:14:49:WU01:FS01:Server responded WORK_ACK (400)
19:14:49:WU01:FS01:Final credit estimate, 91739.00 points
19:14:49:WU01:FS01:Cleaning up
19:17:57:WU00:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
19:21:07:WU00:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
19:21:22:WU02:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
19:24:17:WU00:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
19:27:27:WU00:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
19:30:39:WU00:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
19:33:27:WU02:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
19:33:49:WU00:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
19:36:59:WU00:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
19:40:09:WU00:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
19:43:19:WU00:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
19:45:32:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
19:46:31:WU00:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
19:49:41:WU00:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
19:52:51:WU00:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
19:56:01:WU00:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
19:57:37:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
19:59:12:WU00:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
20:02:25:WU00:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
20:05:35:WU00:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
20:08:45:WU00:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
20:09:42:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
20:11:55:WU00:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
20:15:05:WU00:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
20:18:17:WU00:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
20:21:27:WU00:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
20:21:39:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
20:24:36:WU00:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
20:27:46:WU00:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
20:30:55:WU00:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
20:33:38:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
20:34:07:WU00:FS01:0x21:Completed 1300000 out of 5000000 steps (26%)
20:37:16:WU00:FS01:0x21:Completed 1350000 out of 5000000 steps (27%)
20:40:26:WU00:FS01:0x21:Completed 1400000 out of 5000000 steps (28%)
20:43:36:WU00:FS01:0x21:Completed 1450000 out of 5000000 steps (29%)
20:45:35:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
20:46:45:WU00:FS01:0x21:Completed 1500000 out of 5000000 steps (30%)
20:49:57:WU00:FS01:0x21:Completed 1550000 out of 5000000 steps (31%)
20:53:06:WU00:FS01:0x21:Completed 1600000 out of 5000000 steps (32%)
20:56:16:WU00:FS01:0x21:Completed 1650000 out of 5000000 steps (33%)
20:57:33:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
20:59:25:WU00:FS01:0x21:Completed 1700000 out of 5000000 steps (34%)
21:02:34:WU00:FS01:0x21:Completed 1750000 out of 5000000 steps (35%)
21:05:47:WU00:FS01:0x21:Completed 1800000 out of 5000000 steps (36%)
21:08:59:WU00:FS01:0x21:Completed 1850000 out of 5000000 steps (37%)
21:09:40:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
21:12:10:WU00:FS01:0x21:Completed 1900000 out of 5000000 steps (38%)
21:15:20:WU00:FS01:0x21:Completed 1950000 out of 5000000 steps (39%)
21:18:30:WU00:FS01:0x21:Completed 2000000 out of 5000000 steps (40%)
21:21:42:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
21:21:42:WU00:FS01:0x21:Completed 2050000 out of 5000000 steps (41%)
21:24:52:WU00:FS01:0x21:Completed 2100000 out of 5000000 steps (42%)
21:28:02:WU00:FS01:0x21:Completed 2150000 out of 5000000 steps (43%)
21:31:12:WU00:FS01:0x21:Completed 2200000 out of 5000000 steps (44%)
21:33:46:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
21:34:24:WU00:FS01:0x21:Completed 2250000 out of 5000000 steps (45%)
21:37:37:WU00:FS01:0x21:Completed 2300000 out of 5000000 steps (46%)
******************************* Date: 2020-01-10 *******************************
21:40:47:WU00:FS01:0x21:Completed 2350000 out of 5000000 steps (47%)
21:43:57:WU00:FS01:0x21:Completed 2400000 out of 5000000 steps (48%)
21:45:43:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
21:47:07:WU00:FS01:0x21:Completed 2450000 out of 5000000 steps (49%)
21:50:17:WU00:FS01:0x21:Completed 2500000 out of 5000000 steps (50%)
21:53:29:WU00:FS01:0x21:Completed 2550000 out of 5000000 steps (51%)
21:56:38:WU00:FS01:0x21:Completed 2600000 out of 5000000 steps (52%)
21:57:40:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
21:59:48:WU00:FS01:0x21:Completed 2650000 out of 5000000 steps (53%)
22:02:57:WU00:FS01:0x21:Completed 2700000 out of 5000000 steps (54%)
22:06:07:WU00:FS01:0x21:Completed 2750000 out of 5000000 steps (55%)
22:09:19:WU00:FS01:0x21:Completed 2800000 out of 5000000 steps (56%)
22:09:38:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
22:12:28:WU00:FS01:0x21:Completed 2850000 out of 5000000 steps (57%)
22:15:37:WU00:FS01:0x21:Completed 2900000 out of 5000000 steps (58%)
22:18:47:WU00:FS01:0x21:Completed 2950000 out of 5000000 steps (59%)
22:21:35:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
22:21:56:WU00:FS01:0x21:Completed 3000000 out of 5000000 steps (60%)
22:25:08:WU00:FS01:0x21:Completed 3050000 out of 5000000 steps (61%)
22:28:17:WU00:FS01:0x21:Completed 3100000 out of 5000000 steps (62%)
22:31:27:WU00:FS01:0x21:Completed 3150000 out of 5000000 steps (63%)
22:33:33:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
22:34:36:WU00:FS01:0x21:Completed 3200000 out of 5000000 steps (64%)
22:37:46:WU00:FS01:0x21:Completed 3250000 out of 5000000 steps (65%)
22:40:58:WU00:FS01:0x21:Completed 3300000 out of 5000000 steps (66%)
22:44:07:WU00:FS01:0x21:Completed 3350000 out of 5000000 steps (67%)
22:45:29:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
22:47:16:WU00:FS01:0x21:Completed 3400000 out of 5000000 steps (68%)
22:50:26:WU00:FS01:0x21:Completed 3450000 out of 5000000 steps (69%)
22:53:35:WU00:FS01:0x21:Completed 3500000 out of 5000000 steps (70%)
22:56:47:WU00:FS01:0x21:Completed 3550000 out of 5000000 steps (71%)
22:57:26:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
22:59:56:WU00:FS01:0x21:Completed 3600000 out of 5000000 steps (72%)
23:03:06:WU00:FS01:0x21:Completed 3650000 out of 5000000 steps (73%)
23:06:15:WU00:FS01:0x21:Completed 3700000 out of 5000000 steps (74%)
23:09:24:WU02:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
23:09:25:WU00:FS01:0x21:Completed 3750000 out of 5000000 steps (75%)
23:12:37:WU00:FS01:0x21:Completed 3800000 out of 5000000 steps (76%)
23:15:46:WU00:FS01:0x21:Completed 3850000 out of 5000000 steps (77%)
23:18:56:WU00:FS01:0x21:Completed 3900000 out of 5000000 steps (78%)
23:21:22:WU02:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
23:22:05:WU00:FS01:0x21:Completed 3950000 out of 5000000 steps (79%)
23:25:15:WU00:FS01:0x21:Completed 4000000 out of 5000000 steps (80%)
23:28:26:WU00:FS01:0x21:Completed 4050000 out of 5000000 steps (81%)
23:31:36:WU00:FS01:0x21:Completed 4100000 out of 5000000 steps (82%)
23:33:19:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
23:34:45:WU00:FS01:0x21:Completed 4150000 out of 5000000 steps (83%)
23:37:55:WU00:FS01:0x21:Completed 4200000 out of 5000000 steps (84%)
23:41:04:WU00:FS01:0x21:Completed 4250000 out of 5000000 steps (85%)
23:44:16:WU00:FS01:0x21:Completed 4300000 out of 5000000 steps (86%)
23:45:15:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
23:47:26:WU00:FS01:0x21:Completed 4350000 out of 5000000 steps (87%)
23:50:35:WU00:FS01:0x21:Completed 4400000 out of 5000000 steps (88%)
23:53:45:WU00:FS01:0x21:Completed 4450000 out of 5000000 steps (89%)
23:56:54:WU00:FS01:0x21:Completed 4500000 out of 5000000 steps (90%)
23:57:13:WU02:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
00:00:06:WU00:FS01:0x21:Completed 4550000 out of 5000000 steps (91%)
00:03:15:WU00:FS01:0x21:Completed 4600000 out of 5000000 steps (92%)
00:06:25:WU00:FS01:0x21:Completed 4650000 out of 5000000 steps (93%)
00:09:10:WU02:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
00:09:34:WU00:FS01:0x21:Completed 4700000 out of 5000000 steps (94%)
00:12:44:WU00:FS01:0x21:Completed 4750000 out of 5000000 steps (95%)
00:15:55:WU00:FS01:0x21:Completed 4800000 out of 5000000 steps (96%)
00:19:05:WU00:FS01:0x21:Completed 4850000 out of 5000000 steps (97%)
00:21:07:WU02:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
00:22:14:WU00:FS01:0x21:Completed 4900000 out of 5000000 steps (98%)
00:25:24:WU00:FS01:0x21:Completed 4950000 out of 5000000 steps (99%)
00:25:25:WU01:FS01:Connecting to 65.254.110.245:8080
00:25:25:WU01:FS01:Assigned to work server 128.252.203.10
00:25:25:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU116 [GeForce GTX 1660 SUPER] from 128.252.203.10
00:25:25:WU01:FS01:Connecting to 128.252.203.10:8080
00:25:26:WU01:FS01:Downloading 68.55MiB
00:25:32:WU01:FS01:Download 10.30%
00:25:38:WU01:FS01:Download 25.35%
00:25:44:WU01:FS01:Download 55.71%
00:25:50:WU01:FS01:Download 95.19%
00:25:50:WU01:FS01:Download complete
00:25:50:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14274 run:0 clone:58 gen:116 core:0x21 unit:0x000000b980fccb0a5d98ab542e2252d8
00:28:34:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
00:28:36:WU00:FS01:0x21:Saving result file logfile_01.txt
00:28:36:WU00:FS01:0x21:Saving result file checkpointState.xml
00:28:36:WU00:FS01:0x21:Saving result file checkpt.crc
00:28:36:WU00:FS01:0x21:Saving result file log.txt
00:28:36:WU00:FS01:0x21:Saving result file positions.xtc
00:28:36:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
00:28:37:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:28:37:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14196 run:18 clone:71 gen:105 core:0x21 unit:0x000000a40002894b5d9246a7e78a781d
00:28:37:WU00:FS01:Uploading 19.40MiB to 155.247.166.219
00:28:37:WU00:FS01:Connecting to 155.247.166.219:8080
00:28:37:WU01:FS01:Starting
00:28:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
00:28:37:WU01:FS01:Started FahCore on PID 6780
00:28:37:WU01:FS01:Core PID:6388
00:28:37:WU01:FS01:FahCore 0x21 started
00:28:37:WU01:FS01:0x21:*********************** Log Started 2020-01-11T00:28:37Z ***********************
00:28:37:WU01:FS01:0x21:Project: 14274 (Run 0, Clone 58, Gen 116)
00:28:37:WU01:FS01:0x21:Unit: 0x000000b980fccb0a5d98ab542e2252d8
00:28:37:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:28:37:WU01:FS01:0x21:Machine: 1
00:28:37:WU01:FS01:0x21:Reading tar file core.xml
00:28:37:WU01:FS01:0x21:Reading tar file integrator.xml
00:28:37:WU01:FS01:0x21:Reading tar file state.xml
00:28:37:WU01:FS01:0x21:Reading tar file system.xml
00:28:38:WU01:FS01:0x21:Digital signatures verified
00:28:38:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:28:38:WU01:FS01:0x21:Version 0.0.20
00:28:43:WU00:FS01:Upload 2.90%
00:28:49:WU00:FS01:Upload 5.80%
00:28:55:WU00:FS01:Upload 9.02%
00:28:55:WU01:FS01:0x21:Completed 0 out of 1000000 steps (0%)
00:28:56:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:29:01:WU00:FS01:Upload 11.92%
00:29:07:WU00:FS01:Upload 14.82%
00:29:13:WU00:FS01:Upload 18.04%
00:29:19:WU00:FS01:Upload 20.94%
00:29:25:WU00:FS01:Upload 24.16%
00:29:31:WU00:FS01:Upload 27.06%
00:29:37:WU00:FS01:Upload 29.96%
00:29:43:WU00:FS01:Upload 33.18%
00:29:49:WU00:FS01:Upload 36.08%
00:29:55:WU00:FS01:Upload 38.98%
00:30:01:WU00:FS01:Upload 42.20%
00:30:07:WU00:FS01:Upload 45.10%
00:30:13:WU00:FS01:Upload 48.00%
00:30:19:WU00:FS01:Upload 51.22%
00:30:25:WU00:FS01:Upload 54.12%
00:30:31:WU00:FS01:Upload 57.34%
00:30:37:WU00:FS01:Upload 60.24%
00:30:43:WU00:FS01:Upload 63.46%
00:30:44:WU01:FS01:0x21:Completed 10000 out of 1000000 steps (1%)
00:30:49:WU00:FS01:Upload 66.36%
00:30:55:WU00:FS01:Upload 69.26%
00:31:01:WU00:FS01:Upload 72.48%
00:31:07:WU00:FS01:Upload 75.38%
00:31:13:WU00:FS01:Upload 78.28%
00:31:19:WU00:FS01:Upload 81.50%
00:31:25:WU00:FS01:Upload 84.40%
00:31:31:WU00:FS01:Upload 87.62%
00:31:37:WU00:FS01:Upload 90.52%
00:31:43:WU00:FS01:Upload 93.42%
00:31:49:WU00:FS01:Upload 96.64%
00:31:55:WU00:FS01:Upload 99.54%
00:31:56:WU00:FS01:Upload complete
00:31:56:WU00:FS01:Server responded WORK_ACK (400)
00:31:56:WU00:FS01:Final credit estimate, 132902.00 points
00:31:56:WU00:FS01:Cleaning up
00:32:32:WU01:FS01:0x21:Completed 20000 out of 1000000 steps (2%)
00:33:03:WU02:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
00:34:25:WU01:FS01:0x21:Completed 30000 out of 1000000 steps (3%)
00:36:13:WU01:FS01:0x21:Completed 40000 out of 1000000 steps (4%)
00:38:07:WU01:FS01:0x21:Completed 50000 out of 1000000 steps (5%)
00:39:55:WU01:FS01:0x21:Completed 60000 out of 1000000 steps (6%)
00:41:48:WU01:FS01:0x21:Completed 70000 out of 1000000 steps (7%)
00:43:37:WU01:FS01:0x21:Completed 80000 out of 1000000 steps (8%)
00:44:53:WU02:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
00:45:30:WU01:FS01:0x21:Completed 90000 out of 1000000 steps (9%)
00:47:18:WU01:FS01:0x21:Completed 100000 out of 1000000 steps (10%)
00:49:11:WU01:FS01:0x21:Completed 110000 out of 1000000 steps (11%)
00:51:00:WU01:FS01:0x21:Completed 120000 out of 1000000 steps (12%)
00:52:53:WU01:FS01:0x21:Completed 130000 out of 1000000 steps (13%)
00:54:41:WU01:FS01:0x21:Completed 140000 out of 1000000 steps (14%)
00:56:34:WU01:FS01:0x21:Completed 150000 out of 1000000 steps (15%)
00:56:45:WU02:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
00:58:22:WU01:FS01:0x21:Completed 160000 out of 1000000 steps (16%)
01:00:16:WU01:FS01:0x21:Completed 170000 out of 1000000 steps (17%)
01:02:04:WU01:FS01:0x21:Completed 180000 out of 1000000 steps (18%)
01:03:57:WU01:FS01:0x21:Completed 190000 out of 1000000 steps (19%)
01:05:46:WU01:FS01:0x21:Completed 200000 out of 1000000 steps (20%)
01:07:39:WU01:FS01:0x21:Completed 210000 out of 1000000 steps (21%)
01:08:37:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
01:09:27:WU01:FS01:0x21:Completed 220000 out of 1000000 steps (22%)
01:11:21:WU01:FS01:0x21:Completed 230000 out of 1000000 steps (23%)
01:13:09:WU01:FS01:0x21:Completed 240000 out of 1000000 steps (24%)
01:15:02:WU01:FS01:0x21:Completed 250000 out of 1000000 steps (25%)
01:16:51:WU01:FS01:0x21:Completed 260000 out of 1000000 steps (26%)
01:18:44:WU01:FS01:0x21:Completed 270000 out of 1000000 steps (27%)
01:20:28:WU02:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
01:20:32:WU01:FS01:0x21:Completed 280000 out of 1000000 steps (28%)
01:22:26:WU01:FS01:0x21:Completed 290000 out of 1000000 steps (29%)
01:24:14:WU01:FS01:0x21:Completed 300000 out of 1000000 steps (30%)
01:26:07:WU01:FS01:0x21:Completed 310000 out of 1000000 steps (31%)
01:27:56:WU01:FS01:0x21:Completed 320000 out of 1000000 steps (32%)
01:29:49:WU01:FS01:0x21:Completed 330000 out of 1000000 steps (33%)
01:31:37:WU01:FS01:0x21:Completed 340000 out of 1000000 steps (34%)
01:32:19:WU02:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
01:33:31:WU01:FS01:0x21:Completed 350000 out of 1000000 steps (35%)
01:35:19:WU01:FS01:0x21:Completed 360000 out of 1000000 steps (36%)
01:37:12:WU01:FS01:0x21:Completed 370000 out of 1000000 steps (37%)
01:39:01:WU01:FS01:0x21:Completed 380000 out of 1000000 steps (38%)
01:40:54:WU01:FS01:0x21:Completed 390000 out of 1000000 steps (39%)
01:42:42:WU01:FS01:0x21:Completed 400000 out of 1000000 steps (40%)
01:44:10:WU02:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
01:44:36:WU01:FS01:0x21:Completed 410000 out of 1000000 steps (41%)
01:46:24:WU01:FS01:0x21:Completed 420000 out of 1000000 steps (42%)
01:48:17:WU01:FS01:0x21:Completed 430000 out of 1000000 steps (43%)
01:50:06:WU01:FS01:0x21:Completed 440000 out of 1000000 steps (44%)
01:51:59:WU01:FS01:0x21:Completed 450000 out of 1000000 steps (45%)
01:53:47:WU01:FS01:0x21:Completed 460000 out of 1000000 steps (46%)
01:55:41:WU01:FS01:0x21:Completed 470000 out of 1000000 steps (47%)
01:56:01:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
01:57:29:WU01:FS01:0x21:Completed 480000 out of 1000000 steps (48%)
01:59:23:WU01:FS01:0x21:Completed 490000 out of 1000000 steps (49%)
02:01:11:WU01:FS01:0x21:Completed 500000 out of 1000000 steps (50%)
02:03:04:WU01:FS01:0x21:Completed 510000 out of 1000000 steps (51%)
02:04:53:WU01:FS01:0x21:Completed 520000 out of 1000000 steps (52%)
02:06:46:WU01:FS01:0x21:Completed 530000 out of 1000000 steps (53%)
02:07:53:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
02:08:34:WU01:FS01:0x21:Completed 540000 out of 1000000 steps (54%)
02:10:27:WU01:FS01:0x21:Completed 550000 out of 1000000 steps (55%)
02:12:16:WU01:FS01:0x21:Completed 560000 out of 1000000 steps (56%)
02:14:09:WU01:FS01:0x21:Completed 570000 out of 1000000 steps (57%)
02:15:58:WU01:FS01:0x21:Completed 580000 out of 1000000 steps (58%)
02:17:51:WU01:FS01:0x21:Completed 590000 out of 1000000 steps (59%)
02:19:39:WU01:FS01:0x21:Completed 600000 out of 1000000 steps (60%)
02:19:45:WU02:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
02:21:33:WU01:FS01:0x21:Completed 610000 out of 1000000 steps (61%)
02:23:21:WU01:FS01:0x21:Completed 620000 out of 1000000 steps (62%)
02:25:14:WU01:FS01:0x21:Completed 630000 out of 1000000 steps (63%)
02:27:02:WU01:FS01:0x21:Completed 640000 out of 1000000 steps (64%)
02:28:56:WU01:FS01:0x21:Completed 650000 out of 1000000 steps (65%)
02:30:44:WU01:FS01:0x21:Completed 660000 out of 1000000 steps (66%)
02:31:36:WU02:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
02:32:38:WU01:FS01:0x21:Completed 670000 out of 1000000 steps (67%)
02:34:26:WU01:FS01:0x21:Completed 680000 out of 1000000 steps (68%)
02:36:19:WU01:FS01:0x21:Completed 690000 out of 1000000 steps (69%)
02:38:08:WU01:FS01:0x21:Completed 700000 out of 1000000 steps (70%)
02:40:01:WU01:FS01:0x21:Completed 710000 out of 1000000 steps (71%)
02:41:49:WU01:FS01:0x21:Completed 720000 out of 1000000 steps (72%)
02:43:28:WU02:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
02:43:43:WU01:FS01:0x21:Completed 730000 out of 1000000 steps (73%)
02:45:31:WU01:FS01:0x21:Completed 740000 out of 1000000 steps (74%)
02:47:24:WU01:FS01:0x21:Completed 750000 out of 1000000 steps (75%)
02:49:13:WU01:FS01:0x21:Completed 760000 out of 1000000 steps (76%)
02:51:06:WU01:FS01:0x21:Completed 770000 out of 1000000 steps (77%)
02:52:54:WU01:FS01:0x21:Completed 780000 out of 1000000 steps (78%)
02:54:48:WU01:FS01:0x21:Completed 790000 out of 1000000 steps (79%)
02:55:20:WU02:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
02:56:36:WU01:FS01:0x21:Completed 800000 out of 1000000 steps (80%)
02:58:29:WU01:FS01:0x21:Completed 810000 out of 1000000 steps (81%)
03:00:17:WU01:FS01:0x21:Completed 820000 out of 1000000 steps (82%)
03:02:10:WU01:FS01:0x21:Completed 830000 out of 1000000 steps (83%)
03:03:58:WU01:FS01:0x21:Completed 840000 out of 1000000 steps (84%)
03:05:52:WU01:FS01:0x21:Completed 850000 out of 1000000 steps (85%)
03:07:11:WU02:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
03:07:40:WU01:FS01:0x21:Completed 860000 out of 1000000 steps (86%)
03:09:33:WU01:FS01:0x21:Completed 870000 out of 1000000 steps (87%)
03:11:21:WU01:FS01:0x21:Completed 880000 out of 1000000 steps (88%)
03:13:14:WU01:FS01:0x21:Completed 890000 out of 1000000 steps (89%)
03:15:02:WU01:FS01:0x21:Completed 900000 out of 1000000 steps (90%)
03:16:55:WU01:FS01:0x21:Completed 910000 out of 1000000 steps (91%)
03:18:43:WU01:FS01:0x21:Completed 920000 out of 1000000 steps (92%)
03:19:03:WU02:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
03:20:37:WU01:FS01:0x21:Completed 930000 out of 1000000 steps (93%)
03:22:25:WU01:FS01:0x21:Completed 940000 out of 1000000 steps (94%)
03:24:18:WU01:FS01:0x21:Completed 950000 out of 1000000 steps (95%)
03:26:06:WU01:FS01:0x21:Completed 960000 out of 1000000 steps (96%)
03:27:59:WU01:FS01:0x21:Completed 970000 out of 1000000 steps (97%)
03:29:48:WU01:FS01:0x21:Completed 980000 out of 1000000 steps (98%)
03:30:53:WU02:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
03:31:41:WU01:FS01:0x21:Completed 990000 out of 1000000 steps (99%)
03:31:41:WU00:FS01:Connecting to 65.254.110.245:8080
03:31:42:WU00:FS01:Assigned to work server 140.163.4.241
03:31:42:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.241
03:31:42:WU00:FS01:Connecting to 140.163.4.241:8080
03:31:42:WU00:FS01:Downloading 16.53MiB
03:31:48:WU00:FS01:Download 36.67%
03:31:54:WU00:FS01:Download 78.63%
03:31:56:WU00:FS01:Download complete
03:31:56:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:4720 gen:83 core:0x21 unit:0x000000858ca304f15b21ad255e90e690
03:33:29:WU01:FS01:0x21:Completed 1000000 out of 1000000 steps (100%)
03:33:35:WU01:FS01:0x21:Saving result file logfile_01.txt
03:33:35:WU01:FS01:0x21:Saving result file checkpointState.xml
03:33:36:WU01:FS01:0x21:Saving result file checkpt.crc
03:33:36:WU01:FS01:0x21:Saving result file log.txt
03:33:36:WU01:FS01:0x21:Saving result file positions.xtc
03:33:36:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
03:33:36:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:33:36:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14274 run:0 clone:58 gen:116 core:0x21 unit:0x000000b980fccb0a5d98ab542e2252d8
03:33:36:WU01:FS01:Uploading 64.63MiB to 128.252.203.10
03:33:36:WU01:FS01:Connecting to 128.252.203.10:8080
03:33:36:WU00:FS01:Starting
03:33:36:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
03:33:36:WU00:FS01:Started FahCore on PID 1648
03:33:36:WU00:FS01:Core PID:2736
03:33:36:WU00:FS01:FahCore 0x21 started
03:33:37:WU00:FS01:0x21:*********************** Log Started 2020-01-11T03:33:36Z ***********************
03:33:37:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 4720, Gen 83)
03:33:37:WU00:FS01:0x21:Unit: 0x000000858ca304f15b21ad255e90e690
03:33:37:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:33:37:WU00:FS01:0x21:Machine: 1
03:33:37:WU00:FS01:0x21:Reading tar file core.xml
03:33:37:WU00:FS01:0x21:Reading tar file integrator.xml
03:33:37:WU00:FS01:0x21:Reading tar file state.xml
03:33:37:WU00:FS01:0x21:Reading tar file system.xml
03:33:37:WU00:FS01:0x21:Digital signatures verified
03:33:37:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:33:37:WU00:FS01:0x21:Version 0.0.20
03:33:42:WU01:FS01:Upload 0.68%
03:33:42:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
03:33:42:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:33:48:WU01:FS01:Upload 1.45%
03:33:54:WU01:FS01:Upload 2.22%
03:34:00:WU01:FS01:Upload 3.00%
03:34:06:WU01:FS01:Upload 3.77%
03:34:12:WU01:FS01:Upload 4.55%
03:34:18:WU01:FS01:Upload 5.32%
03:34:24:WU01:FS01:Upload 6.09%
03:34:30:WU01:FS01:Upload 6.77%
03:34:36:WU01:FS01:Upload 7.54%
03:34:42:WU01:FS01:Upload 8.32%
03:34:48:WU01:FS01:Upload 9.09%
03:34:54:WU01:FS01:Upload 9.86%
03:35:00:WU01:FS01:Upload 10.64%
03:35:06:WU01:FS01:Upload 11.41%
03:35:12:WU01:FS01:Upload 12.19%
03:35:18:WU01:FS01:Upload 12.86%
03:35:24:WU01:FS01:Upload 13.64%
03:35:30:WU01:FS01:Upload 14.41%
03:35:36:WU01:FS01:Upload 15.18%
03:35:42:WU01:FS01:Upload 15.96%
03:35:48:WU01:FS01:Upload 16.73%
03:35:54:WU01:FS01:Upload 17.41%
03:36:00:WU01:FS01:Upload 18.18%
03:36:04:WU00:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
03:36:06:WU01:FS01:Upload 18.96%
03:36:12:WU01:FS01:Upload 19.73%
03:36:18:WU01:FS01:Upload 20.50%
03:36:24:WU01:FS01:Upload 21.18%
03:36:30:WU01:FS01:Upload 21.95%
03:36:36:WU01:FS01:Upload 22.73%
03:36:42:WU01:FS01:Upload 23.50%
03:36:48:WU01:FS01:Upload 24.27%
03:36:54:WU01:FS01:Upload 25.05%
03:37:00:WU01:FS01:Upload 25.82%
03:37:06:WU01:FS01:Upload 26.50%
03:37:12:WU01:FS01:Upload 27.27%
03:37:18:WU01:FS01:Upload 28.05%
03:37:24:WU01:FS01:Upload 28.82%
03:37:30:WU01:FS01:Upload 29.59%
03:37:36:WU01:FS01:Upload 30.37%
03:37:42:WU01:FS01:Upload 31.04%
03:37:48:WU01:FS01:Upload 31.82%
03:37:54:WU01:FS01:Upload 32.59%
03:38:00:WU01:FS01:Upload 33.37%
03:38:06:WU01:FS01:Upload 34.14%
03:38:12:WU01:FS01:Upload 34.91%
03:38:18:WU01:FS01:Upload 35.69%
03:38:24:WU01:FS01:Upload 36.36%
03:38:27:WU00:FS01:0x21:Completed 150000 out of 7500000 steps (2%)
03:38:30:WU01:FS01:Upload 37.14%
03:38:36:WU01:FS01:Upload 37.91%
03:38:42:WU01:FS01:Upload 38.68%
03:38:48:WU01:FS01:Upload 39.46%
03:38:54:WU01:FS01:Upload 40.14%
03:39:00:WU01:FS01:Upload 40.91%
03:39:06:WU01:FS01:Upload 41.68%
03:39:12:WU01:FS01:Upload 42.46%
03:39:18:WU01:FS01:Upload 43.23%
03:39:24:WU01:FS01:Upload 44.00%
03:39:30:WU01:FS01:Upload 44.68%
03:39:36:WU01:FS01:Upload 45.45%
03:39:42:WU01:FS01:Upload 46.23%
03:39:48:WU01:FS01:Upload 47.00%
03:39:54:WU01:FS01:Upload 47.78%
03:40:00:WU01:FS01:Upload 48.45%
03:40:06:WU01:FS01:Upload 49.23%
03:40:12:WU01:FS01:Upload 50.00%
03:40:18:WU01:FS01:Upload 50.77%
03:40:24:WU01:FS01:Upload 51.55%
03:40:30:WU01:FS01:Upload 52.32%
03:40:36:WU01:FS01:Upload 53.09%
03:40:42:WU01:FS01:Upload 53.87%
******************************* Date: 2020-01-11 *******************************
03:40:48:WU01:FS01:Upload 54.55%
03:40:49:WU00:FS01:0x21:Completed 225000 out of 7500000 steps (3%)
03:40:54:WU01:FS01:Upload 55.32%
03:41:00:WU01:FS01:Upload 56.09%
03:41:06:WU01:FS01:Upload 56.87%
03:41:12:WU01:FS01:Upload 57.64%
03:41:18:WU01:FS01:Upload 58.41%
03:41:24:WU01:FS01:Upload 59.09%
03:41:30:WU01:FS01:Upload 59.86%
03:41:36:WU01:FS01:Upload 60.64%
03:41:42:WU01:FS01:Upload 61.41%
03:41:48:WU01:FS01:Upload 62.19%
03:41:54:WU01:FS01:Upload 62.96%
03:42:00:WU01:FS01:Upload 63.73%
03:42:06:WU01:FS01:Upload 64.41%
03:42:12:WU01:FS01:Upload 65.18%
03:42:18:WU01:FS01:Upload 65.96%
03:42:24:WU01:FS01:Upload 66.73%
03:42:30:WU01:FS01:Upload 67.50%
03:42:36:WU01:FS01:Upload 68.28%
03:42:42:WU01:FS01:Upload 69.05%
03:42:48:WU01:FS01:Upload 69.73%
03:42:53:WU02:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
03:42:54:WU01:FS01:Upload 70.50%
03:43:00:WU01:FS01:Upload 71.28%
03:43:06:WU01:FS01:Upload 72.05%
03:43:12:WU01:FS01:Upload 72.82%
03:43:13:WU00:FS01:0x21:Completed 300000 out of 7500000 steps (4%)
03:43:18:WU01:FS01:Upload 73.60%
03:43:24:WU01:FS01:Upload 74.37%
03:43:30:WU01:FS01:Upload 75.15%
03:43:36:WU01:FS01:Upload 75.82%
03:43:42:WU01:FS01:Upload 76.60%
03:43:48:WU01:FS01:Upload 77.37%
03:43:54:WU01:FS01:Upload 78.14%
03:44:00:WU01:FS01:Upload 78.92%
03:44:06:WU01:FS01:Upload 79.69%
03:44:12:WU01:FS01:Upload 80.46%
03:44:18:WU01:FS01:Upload 81.24%
03:44:24:WU01:FS01:Upload 81.91%
03:44:30:WU01:FS01:Upload 82.69%
03:44:36:WU01:FS01:Upload 83.46%
03:44:42:WU01:FS01:Upload 84.24%
03:44:48:WU01:FS01:Upload 85.01%
03:44:54:WU01:FS01:Upload 85.78%
03:45:00:WU01:FS01:Upload 86.56%
03:45:06:WU01:FS01:Upload 87.33%
03:45:12:WU01:FS01:Upload 88.01%
03:45:18:WU01:FS01:Upload 88.78%
03:45:24:WU01:FS01:Upload 89.56%
03:45:30:WU01:FS01:Upload 90.33%
03:45:35:WU00:FS01:0x21:Completed 375000 out of 7500000 steps (5%)
03:45:36:WU01:FS01:Upload 91.10%
03:45:42:WU01:FS01:Upload 91.88%
03:45:48:WU01:FS01:Upload 92.65%
03:45:54:WU01:FS01:Upload 93.42%
03:46:00:WU01:FS01:Upload 94.10%
03:46:06:WU01:FS01:Upload 94.87%
03:46:12:WU01:FS01:Upload 95.65%
03:46:18:WU01:FS01:Upload 96.42%
03:46:24:WU01:FS01:Upload 97.20%
03:46:30:WU01:FS01:Upload 97.97%
03:46:36:WU01:FS01:Upload 98.74%
03:46:42:WU01:FS01:Upload 99.52%
03:46:46:WU01:FS01:Upload complete
03:46:46:WU01:FS01:Server responded WORK_ACK (400)
03:46:46:WU01:FS01:Final credit estimate, 70463.00 points
03:46:46:WU01:FS01:Cleaning up
03:47:57:WU00:FS01:0x21:Completed 450000 out of 7500000 steps (6%)
03:50:21:WU00:FS01:0x21:Completed 525000 out of 7500000 steps (7%)
03:52:43:WU00:FS01:0x21:Completed 600000 out of 7500000 steps (8%)
03:54:54:WU02:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
03:55:05:WU00:FS01:0x21:Completed 675000 out of 7500000 steps (9%)
03:57:28:WU00:FS01:0x21:Completed 750000 out of 7500000 steps (10%)
03:59:51:WU00:FS01:0x21:Completed 825000 out of 7500000 steps (11%)
04:02:13:WU00:FS01:0x21:Completed 900000 out of 7500000 steps (12%)
04:04:36:WU00:FS01:0x21:Completed 975000 out of 7500000 steps (13%)
04:06:54:WU02:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
04:06:59:WU00:FS01:0x21:Completed 1050000 out of 7500000 steps (14%)
04:09:22:WU00:FS01:0x21:Completed 1125000 out of 7500000 steps (15%)
04:11:44:WU00:FS01:0x21:Completed 1200000 out of 7500000 steps (16%)
04:14:07:WU00:FS01:0x21:Completed 1275000 out of 7500000 steps (17%)
04:16:30:WU00:FS01:0x21:Completed 1350000 out of 7500000 steps (18%)
04:18:52:WU00:FS01:0x21:Completed 1425000 out of 7500000 steps (19%)
04:18:55:WU02:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
04:21:15:WU00:FS01:0x21:Completed 1500000 out of 7500000 steps (20%)
04:23:38:WU00:FS01:0x21:Completed 1575000 out of 7500000 steps (21%)
04:26:00:WU00:FS01:0x21:Completed 1650000 out of 7500000 steps (22%)
04:28:23:WU00:FS01:0x21:Completed 1725000 out of 7500000 steps (23%)
04:30:46:WU00:FS01:0x21:Completed 1800000 out of 7500000 steps (24%)
04:30:55:WU02:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
04:33:09:WU00:FS01:0x21:Completed 1875000 out of 7500000 steps (25%)
04:35:31:WU00:FS01:0x21:Completed 1950000 out of 7500000 steps (26%)
04:37:54:WU00:FS01:0x21:Completed 2025000 out of 7500000 steps (27%)
04:40:17:WU00:FS01:0x21:Completed 2100000 out of 7500000 steps (28%)
04:42:39:WU00:FS01:0x21:Completed 2175000 out of 7500000 steps (29%)
04:42:55:WU02:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
04:45:02:WU00:FS01:0x21:Completed 2250000 out of 7500000 steps (30%)
04:47:25:WU00:FS01:0x21:Completed 2325000 out of 7500000 steps (31%)
04:49:48:WU00:FS01:0x21:Completed 2400000 out of 7500000 steps (32%)
04:52:10:WU00:FS01:0x21:Completed 2475000 out of 7500000 steps (33%)
04:54:34:WU00:FS01:0x21:Completed 2550000 out of 7500000 steps (34%)
04:54:56:WU02:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
04:56:56:WU00:FS01:0x21:Completed 2625000 out of 7500000 steps (35%)
04:59:19:WU00:FS01:0x21:Completed 2700000 out of 7500000 steps (36%)
05:01:42:WU00:FS01:0x21:Completed 2775000 out of 7500000 steps (37%)
05:04:04:WU00:FS01:0x21:Completed 2850000 out of 7500000 steps (38%)
05:06:27:WU00:FS01:0x21:Completed 2925000 out of 7500000 steps (39%)
05:06:57:WU02:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
05:08:49:WU00:FS01:0x21:Completed 3000000 out of 7500000 steps (40%)
05:11:13:WU00:FS01:0x21:Completed 3075000 out of 7500000 steps (41%)
05:13:35:WU00:FS01:0x21:Completed 3150000 out of 7500000 steps (42%)
05:15:58:WU00:FS01:0x21:Completed 3225000 out of 7500000 steps (43%)
05:18:21:WU00:FS01:0x21:Completed 3300000 out of 7500000 steps (44%)
05:18:57:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
05:20:43:WU00:FS01:0x21:Completed 3375000 out of 7500000 steps (45%)
05:23:06:WU00:FS01:0x21:Completed 3450000 out of 7500000 steps (46%)
05:25:29:WU00:FS01:0x21:Completed 3525000 out of 7500000 steps (47%)
05:27:52:WU00:FS01:0x21:Completed 3600000 out of 7500000 steps (48%)
05:30:14:WU00:FS01:0x21:Completed 3675000 out of 7500000 steps (49%)
05:30:57:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
05:32:37:WU00:FS01:0x21:Completed 3750000 out of 7500000 steps (50%)
05:35:00:WU00:FS01:0x21:Completed 3825000 out of 7500000 steps (51%)
05:37:23:WU00:FS01:0x21:Completed 3900000 out of 7500000 steps (52%)
05:39:45:WU00:FS01:0x21:Completed 3975000 out of 7500000 steps (53%)
05:42:08:WU00:FS01:0x21:Completed 4050000 out of 7500000 steps (54%)
05:42:58:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
05:44:31:WU00:FS01:0x21:Completed 4125000 out of 7500000 steps (55%)
05:46:53:WU00:FS01:0x21:Completed 4200000 out of 7500000 steps (56%)
05:49:17:WU00:FS01:0x21:Completed 4275000 out of 7500000 steps (57%)
05:51:39:WU00:FS01:0x21:Completed 4350000 out of 7500000 steps (58%)
05:54:02:WU00:FS01:0x21:Completed 4425000 out of 7500000 steps (59%)
05:54:57:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
05:56:25:WU00:FS01:0x21:Completed 4500000 out of 7500000 steps (60%)
05:58:48:WU00:FS01:0x21:Completed 4575000 out of 7500000 steps (61%)
06:01:10:WU00:FS01:0x21:Completed 4650000 out of 7500000 steps (62%)
06:03:33:WU00:FS01:0x21:Completed 4725000 out of 7500000 steps (63%)
06:05:56:WU00:FS01:0x21:Completed 4800000 out of 7500000 steps (64%)
06:06:58:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
06:08:19:WU00:FS01:0x21:Completed 4875000 out of 7500000 steps (65%)
06:10:41:WU00:FS01:0x21:Completed 4950000 out of 7500000 steps (66%)
06:13:05:WU00:FS01:0x21:Completed 5025000 out of 7500000 steps (67%)
06:15:27:WU00:FS01:0x21:Completed 5100000 out of 7500000 steps (68%)
06:17:49:WU00:FS01:0x21:Completed 5175000 out of 7500000 steps (69%)
06:18:58:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
06:20:12:WU00:FS01:0x21:Completed 5250000 out of 7500000 steps (70%)
06:22:35:WU00:FS01:0x21:Completed 5325000 out of 7500000 steps (71%)
06:24:58:WU00:FS01:0x21:Completed 5400000 out of 7500000 steps (72%)
06:27:20:WU00:FS01:0x21:Completed 5475000 out of 7500000 steps (73%)
06:29:43:WU00:FS01:0x21:Completed 5550000 out of 7500000 steps (74%)
06:30:58:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
06:32:06:WU00:FS01:0x21:Completed 5625000 out of 7500000 steps (75%)
06:34:28:WU00:FS01:0x21:Completed 5700000 out of 7500000 steps (76%)
06:36:52:WU00:FS01:0x21:Completed 5775000 out of 7500000 steps (77%)
06:39:14:WU00:FS01:0x21:Completed 5850000 out of 7500000 steps (78%)
06:41:37:WU00:FS01:0x21:Completed 5925000 out of 7500000 steps (79%)
06:42:59:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
06:43:59:WU00:FS01:0x21:Completed 6000000 out of 7500000 steps (80%)
06:46:23:WU00:FS01:0x21:Completed 6075000 out of 7500000 steps (81%)
06:48:45:WU00:FS01:0x21:Completed 6150000 out of 7500000 steps (82%)
06:51:07:WU00:FS01:0x21:Completed 6225000 out of 7500000 steps (83%)
06:53:31:WU00:FS01:0x21:Completed 6300000 out of 7500000 steps (84%)
06:54:59:WU02:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
06:55:53:WU00:FS01:0x21:Completed 6375000 out of 7500000 steps (85%)
06:58:16:WU00:FS01:0x21:Completed 6450000 out of 7500000 steps (86%)
07:00:39:WU00:FS01:0x21:Completed 6525000 out of 7500000 steps (87%)
07:03:02:WU00:FS01:0x21:Completed 6600000 out of 7500000 steps (88%)
07:05:24:WU00:FS01:0x21:Completed 6675000 out of 7500000 steps (89%)
07:07:00:WU02:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
07:07:47:WU00:FS01:0x21:Completed 6750000 out of 7500000 steps (90%)
07:10:10:WU00:FS01:0x21:Completed 6825000 out of 7500000 steps (91%)
07:12:33:WU00:FS01:0x21:Completed 6900000 out of 7500000 steps (92%)
07:14:55:WU00:FS01:0x21:Completed 6975000 out of 7500000 steps (93%)
07:17:19:WU00:FS01:0x21:Completed 7050000 out of 7500000 steps (94%)
07:19:00:WU02:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
07:19:41:WU00:FS01:0x21:Completed 7125000 out of 7500000 steps (95%)
07:22:04:WU00:FS01:0x21:Completed 7200000 out of 7500000 steps (96%)
07:24:27:WU00:FS01:0x21:Completed 7275000 out of 7500000 steps (97%)
07:26:50:WU00:FS01:0x21:Completed 7350000 out of 7500000 steps (98%)
07:29:12:WU00:FS01:0x21:Completed 7425000 out of 7500000 steps (99%)
07:29:13:WU01:FS01:Connecting to 65.254.110.245:8080
07:29:14:WU01:FS01:Assigned to work server 140.163.4.241
07:29:14:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU116 [GeForce GTX 1660 SUPER] from 140.163.4.241
07:29:14:WU01:FS01:Connecting to 140.163.4.241:8080
07:29:14:WU01:FS01:Downloading 16.53MiB
07:29:20:WU01:FS01:Download 57.46%
07:29:23:WU01:FS01:Download complete
07:29:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:5279 gen:69 core:0x21 unit:0x0000006f8ca304f15b21ad266fcaeb4b
07:31:01:WU02:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
07:31:35:WU00:FS01:0x21:Completed 7500000 out of 7500000 steps (100%)
07:31:36:WU00:FS01:0x21:Saving result file logfile_01.txt
07:31:36:WU00:FS01:0x21:Saving result file checkpointState.xml
07:31:36:WU00:FS01:0x21:Saving result file checkpt.crc
07:31:36:WU00:FS01:0x21:Saving result file log.txt
07:31:36:WU00:FS01:0x21:Saving result file positions.xtc
07:31:36:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
07:31:37:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:31:37:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11714 run:0 clone:4720 gen:83 core:0x21 unit:0x000000858ca304f15b21ad255e90e690
07:31:37:WU00:FS01:Uploading 11.83MiB to 140.163.4.241
07:31:37:WU00:FS01:Connecting to 140.163.4.241:8080
07:31:37:WU01:FS01:Starting
07:31:37:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 705 -lifeline 4120 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:31:37:WU01:FS01:Started FahCore on PID 7076
07:31:37:WU01:FS01:Core PID:5768
07:31:37:WU01:FS01:FahCore 0x21 started
07:31:37:WU01:FS01:0x21:*********************** Log Started 2020-01-11T07:31:37Z ***********************
07:31:37:WU01:FS01:0x21:Project: 11714 (Run 0, Clone 5279, Gen 69)
07:31:37:WU01:FS01:0x21:Unit: 0x0000006f8ca304f15b21ad266fcaeb4b
07:31:37:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
07:31:37:WU01:FS01:0x21:Machine: 1
07:31:37:WU01:FS01:0x21:Reading tar file core.xml
07:31:37:WU01:FS01:0x21:Reading tar file integrator.xml
07:31:37:WU01:FS01:0x21:Reading tar file state.xml
07:31:37:WU01:FS01:0x21:Reading tar file system.xml
07:31:37:WU01:FS01:0x21:Digital signatures verified
07:31:37:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
07:31:37:WU01:FS01:0x21:Version 0.0.20
07:31:41:WU01:FS01:0x21:Completed 0 out of 7500000 steps (0%)
07:31:41:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:31:43:WU00:FS01:Upload 4.76%
07:31:49:WU00:FS01:Upload 9.51%
07:31:55:WU00:FS01:Upload 14.27%
07:32:01:WU00:FS01:Upload 19.55%
07:32:07:WU00:FS01:Upload 23.25%
07:32:13:WU00:FS01:Upload 26.95%
07:32:19:WU00:FS01:Upload 32.23%
07:32:25:WU00:FS01:Upload 36.46%
07:32:31:WU00:FS01:Upload 41.22%
07:32:37:WU00:FS01:Upload 45.97%
07:32:43:WU00:FS01:Upload 50.73%
07:32:49:WU00:FS01:Upload 56.01%
07:32:55:WU00:FS01:Upload 60.77%
07:33:01:WU00:FS01:Upload 65.52%
07:33:07:WU00:FS01:Upload 70.28%
07:33:13:WU00:FS01:Upload 75.03%
07:33:19:WU00:FS01:Upload 79.79%
07:33:25:WU00:FS01:Upload 84.54%
07:33:31:WU00:FS01:Upload 89.83%
07:33:37:WU00:FS01:Upload 94.06%
07:33:43:WU00:FS01:Upload 98.81%
07:33:46:WU00:FS01:Upload complete
07:33:46:WU00:FS01:Server responded WORK_ACK (400)
07:33:46:WU00:FS01:Final credit estimate, 106638.00 points
07:33:46:WU00:FS01:Cleaning up
Re: How to check correct completes of wu?
Sometime late Thursday or early Friday stats reporting went down as covered in this topic. As of this morning when I checked the stats database was responding to queries, you can check WU's yourself from the WU status page. There are some other checks you can make listed on apps.foldingathome.org.
I have already checked the WU listed as being completed and uploaded for you:
Hi gravitonian (team 0), Your WU (P11714 R0 C4720 G83) was added to the stats database on Sun, 12 Jan 2020 00:45:01 GMT for 106646 points of credit.
