F@H Control not loading, howto see status via CLI
lleb
Post by lleb »
For what ever reason on this older laptop I am unable to get FAHControl to start. It is roughly a 10yr laptop, so not really worth the fight to get a GUI interface.
I am running Fedora 31 with the LXDE GUI.
Is there a command to issue to get the status (% complete), WU#, team name, and user name?
# cat /etc/fahclient/config.xml
<config>
  <gpu v='false'/>
  <!-- User Information -->
  <user v='Mr.Brunkow'/>
  <team v='134546'/>
  <power v='medium'/>
  <!-- Folding Slots -->
  <slot id='0' type='CPU'/>
</config>
Another system I have (no access atm, as I am not near that system, and have ssh from external disabled) shows value="foo" not v='foo'
do both work, is either better, etc?
Thank you in advance.
P.S. I would also like to set the default WU to Alzheimer, how is that done via CLI?
Re: F@H Control not loading, howto see status via CLI
Do you have python 2.7 installed ? It is required for FAHControl and it won't work with python 3 ...
MeeLee
Post by MeeLee »
Fedora 30 should fully support it
lleb
Post by lleb »
$ ls /usr/bin/python*
/usr/bin/python   /usr/bin/python2.7  /usr/bin/python3.7   /usr/bin/python-argcomplete-check-easy-install-script
/usr/bin/python2  /usr/bin/python3    /usr/bin/python3.7m  /usr/bin/python-argcomplete-tcsh
looks like both are installed.
lleb
Post by lleb »
Thank you for the link, sadly I have already attempted that fix with no luck. Thus my request on how to get the information from just the command line. I am not stressing about not having access to FAHControl, but would love to be able to check the status on this older laptop.
Did you try If I changing the first line from
#!/usr/bin/python
to
#!/usr/bin/python2
per that link?
Do you have another computer on your LAN which does run FAHAControl?
lleb
Post by lleb »
yes I did make the changes to the first line. That link is only partially correct, the actual line is #!/usr/bin/evn python
so I tried /env python2 as well as /bin/python2
I am not at my house, I currently have another laptop and a workstation at home that are running the normal Fedora 31 without issue. I am guessing this might have something to do with the GUI being used on this older laptop.
