GPU CORE22 0.0.2 coming to FAH - p11737-9 feedback thread
See rafwiewiora's announcement thread here : viewtopic.php?f=24&t=32070
Please use this thread to report you experiences with the new core and the test project.
Re: GPU CORE22 0.0.2 coming to ADVANCED - p11737 feedback th
The new core immediately dumps WUs as a cause of too high of an overclock, where as 21 resumes from prior savestate.
I've seen as high as +3M PPD on a 2080Ti, but need to lower overclock by 1-2Mhz compared to core 21.
Other than that, I have had a WU hang, meaning after the results were uploaded, no new Wu was downloaded. I'm not sure if this is related to core 22, as other users had reported slow downloads as well (about 2 to 5 days ago).
Yes, the test project (p11737) is more demanding for the GPU than we're used to. Some overclocks (or power optimizations) might become unstable and must be reviewed.
My main issue is the immediate dump of the WU, rather than the continuation from the last savestate.
BTW, does core 22 also work on CPU? Or only GPU?
We need logs showing the errors ...MeeLee wrote:My main issue is the immediate dump of the WU, rather than the continuation from the last savestate.
It's the continuation of core 21, so it's a GPU core.MeeLee wrote:BTW, does core 22 also work on CPU? Or only GPU?
rafwiewiora
- Scientist
6% failure rate in the first batch -- not great, not too bad -- (cf. core21 failure rate on full F@h is ~5%) -- I call this good enough to start a second batch of about 500 WUs - distributing now. Very interestingly, 8/9 failures seen in the first batch were due to the same error - `clWaitForEvents`, and I'm investigating further.
MeeLee -- any chance you were seeing the clWaitForEvents errors? I'm looking for someone who's seeing this and willing to help us and the OpenMM team debug.
rafwiewiora
- Scientist
Currently seeing only a 3% failure rate in the second batch, so I'm leaving the ADVANCED flag on constantly now.
That's useful information for other overclockers reading this topic, but it's not something FAH is going to do anything about. Officially, FAH does not support overclocking. If you do overclock you're operating totally on your own. If the margin/tolerance for overclocking changes, you're responsible for dealing with it. (but you already knew that).MeeLee wrote:The new core immediately dumps WUs as a cause of too high of an overclock, where as 21 resumes from prior savestate.
There will be an unknown percentage of FAH donors who will not be critically overclocked, and their global performance increase will be good for science. To time required to compensate for those of you who have to dial things back will be a temporary issue.
road-runner
Looks like I had a few of them in the benchmark viewer of HFM
Project ID: 11737
Core: OPENMM_22
Credit: 7498
Frames: 100
Name: 1070s little room Slot 02
Path: 192.168.1.11-36330
Number of Frames Observed: 197
Min. Time / Frame : 00:01:09 - 823,910.4 PPD
Avg. Time / Frame : 00:01:10 - 806,318.1 PPD
Name: 1080 living room Slot 01
Path: 192.168.1.39-36330
Number of Frames Observed: 300
Min. Time / Frame : 00:01:01 - 991,194.7 PPD
Avg. Time / Frame : 00:01:01 - 991,194.7 PPD
Name: 1080 living room Slot 02
Min. Time / Frame : 00:01:00 - 1,016,077.0 PPD
Name: 1080 TI Upstairs Slot 01
Path: 192.168.1.225-36330
Number of Frames Observed: 100
Min. Time / Frame : 00:00:43 - 1,674,753.8 PPD
Avg. Time / Frame : 00:00:43 - 1,674,753.8 PPD
Name: 1080 TI Upstairs Slot 02
Min. Time / Frame : 00:00:44 - 1,617,985.2 PPD
Avg. Time / Frame : 00:00:44 - 1,617,985.2 PPD
Name: home Slot 01
Path: 127.0.0.1-36330
Number of Frames Observed: 200
Avg. Time / Frame : 00:00:45 - 1,564,353.0 PPD
Right. Small variations are to be expected. Live with it.road-runner wrote:Looks like I had a few of them in the benchmark viewer of HFM
road-runner
There different cards 1070, 1080 and 1080ti lot more points than core 21bruce wrote:Right. Small variations are to be expected. Live with it.road-runner wrote:Looks like I had a few of them in the benchmark viewer of HFM
We're not comparing PPD with a 1070 with a 1080 or with a 1080Ti.
Where do you see a variation of > 10% for a specific GPU and project? I don't see anything in your report that suggests otherwise. If I missed it, please point it out.
road-runner
I didnt say anything about point variation you did, I was just pointing out it was different cards is why there different. I was just posting what the viewer showed I was happy to see more pointsbruce wrote:We're not comparing PPD with a 1070 with a 1080 or with a 1080Ti.
FAHCore22:
project 11737
3 X Vega64 on PCIe 1X gen 2 with Risers v007
celeron G4400.
no over/underclock.
1 GPU got the project.
Gives 568k PPD with TPF of 1min 29.
core21 on overall projects (disregarding outliners) gave 600k PPD, so on risers(or on low end CPU) it gives a slight bottleneck.
It runs stable thou
*EDIT the PPD were wrong, now corrected
project 11737
celeron G4400.
no over/underclock.
It runs stable thou
