(Solved)Low percentage of steps completed
Smookin_Joe
Post by Smookin_Joe »
++++Update++++
My concern is an error on my part. I found out that it reports small percentages of steps it has completed and these percentages will increase as more steps of the WU are being completed.
:oops:
Hello
I am concerned with the low percentage reported with steps being completed
I think this is a new issue
Just an example complete log follows
Joe
04:29:19:WU00:FS01:0x21:Completed 3075000 out of 7500000 steps (41%)
04:30:09:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
04:31:14:WU00:FS01:0x21:Completed 3150000 out of 7500000 steps (42%)
04:31:36:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
04:33:03:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
04:33:10:WU00:FS01:0x21:Completed 3225000 out of 7500000 steps (43%)
04:34:30:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
04:35:07:WU00:FS01:0x21:Completed 3300000 out of 7500000 steps (44%)
04:35:57:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
04:37:03:WU00:FS01:0x21:Completed 3375000 out of 7500000 steps (45%)
*********************** Log Started 2019-12-31T03:55:05Z ***********************
03:55:05:************************* Folding@home Client *************************
03:55:05:        Website: https://foldingathome.org/
03:55:05:      Copyright: (c) 2009-2018 foldingathome.org
03:55:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:55:05:           Args:
03:55:05:         Config: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\config.xml
03:55:05:******************************** Build ********************************
03:55:05:        Version: 7.5.1
03:55:05:           Date: May 11 2018
03:55:05:           Time: 13:06:32
03:55:05:     Repository: Git
03:55:05:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:55:05:         Branch: master
03:55:05:       Compiler: Visual C++ 2008
03:55:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:55:05:       Platform: win32 10
03:55:05:           Bits: 32
03:55:05:           Mode: Release
03:55:05:******************************* System ********************************
03:55:05:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
03:55:05:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:55:05:           CPUs: 8
03:55:05:         Memory: 63.86GiB
03:55:05:    Free Memory: 60.82GiB
03:55:05:        Threads: WINDOWS_THREADS
03:55:05:     OS Version: 6.2
03:55:05:    Has Battery: false
03:55:05:     On Battery: false
03:55:05:     UTC Offset: -8
03:55:05:            PID: 9416
03:55:05:            CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient
03:55:05:             OS: Windows 10 Enterprise
03:55:05:        OS Arch: AMD64
03:55:05:           GPUs: 1
03:55:05:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
03:55:05:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
03:55:05:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
03:55:05:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
03:55:05:  Win32 Service: false
03:55:05:***********************************************************************
03:55:05:<config>
03:55:05:  <!-- Network -->
03:55:05:  <proxy v=':8080'/>
03:55:05:
03:55:05:  <!-- Slot Control -->
03:55:05:  <power v='FULL'/>
03:55:05:
03:55:05:  <!-- User Information -->
03:55:05:  <passkey v='********************************'/>
03:55:05:  <team v='111065'/>
03:55:05:  <user v='SmookinJoe'/>
03:55:05:
03:55:05:  <!-- Folding Slots -->
03:55:05:  <slot id='0' type='CPU'/>
03:55:05:  <slot id='1' type='GPU'/>
03:55:05:</config>
03:55:05:Trying to access database...
03:55:05:Successfully acquired database lock
03:55:05:Enabled folding slot 00: READY cpu:7
03:55:05:Enabled folding slot 01: READY gpu:0:TU106 [Geforce RTX 2060]
03:55:05:WU02:FS00:Starting
03:55:05:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 9416 -checkpoint 15 -np 7
03:55:06:WU02:FS00:Started FahCore on PID 9736
03:55:06:WU02:FS00:Core PID:9752
03:55:06:WU02:FS00:FahCore 0xa7 started
03:55:06:WU00:FS01:Starting
03:55:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 9416 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
03:55:06:WU00:FS01:Started FahCore on PID 9784
03:55:07:WU00:FS01:Core PID:9796
03:55:07:WU00:FS01:FahCore 0x21 started
03:55:07:WU02:FS00:0xa7:*********************** Log Started 2019-12-31T03:55:06Z ***********************
03:55:07:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:55:07:WU02:FS00:0xa7:       Type: 0xa7
03:55:07:WU02:FS00:0xa7:       Core: Gromacs
03:55:07:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 9736 -checkpoint 15 -np 7
03:55:07:WU02:FS00:0xa7:************************************ CBang *************************************
03:55:07:WU02:FS00:0xa7:       Date: Oct 26 2019
03:55:07:WU02:FS00:0xa7:       Time: 01:38:25
03:55:07:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:55:07:WU02:FS00:0xa7:     Branch: master
03:55:07:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
03:55:07:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:55:07:WU02:FS00:0xa7:   Platform: win32 10
03:55:07:WU02:FS00:0xa7:       Bits: 64
03:55:07:WU02:FS00:0xa7:       Mode: Release
03:55:07:WU02:FS00:0xa7:************************************ System ************************************
03:55:07:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
03:55:07:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:55:07:WU02:FS00:0xa7:       CPUs: 8
03:55:07:WU02:FS00:0xa7:     Memory: 63.86GiB
03:55:07:WU02:FS00:0xa7:Free Memory: 60.59GiB
03:55:07:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
03:55:07:WU02:FS00:0xa7: OS Version: 6.2
03:55:07:WU02:FS00:0xa7:Has Battery: false
03:55:07:WU02:FS00:0xa7: On Battery: false
03:55:07:WU02:FS00:0xa7: UTC Offset: -8
03:55:07:WU02:FS00:0xa7:        PID: 9752
03:55:07:WU02:FS00:0xa7:        CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\work
03:55:07:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
03:55:07:WU02:FS00:0xa7:    Version: 0.0.18
03:55:07:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:55:07:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:55:07:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
03:55:07:WU02:FS00:0xa7:       Time: 01:52:30
03:55:07:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:55:07:WU02:FS00:0xa7:************************************ Build *************************************
03:55:07:WU02:FS00:0xa7:       SIMD: avx_256
03:55:07:WU02:FS00:0xa7:********************************************************************************
03:55:07:WU02:FS00:0xa7:Project: 13831 (Run 914, Clone 1, Gen 98)
03:55:07:WU02:FS00:0xa7:Unit: 0x0000007780fccb095d693a39e8975983
03:55:07:WU02:FS00:0xa7:Digital signatures verified
03:55:07:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
03:55:07:WU02:FS00:0xa7:Calling: mdrun -s frame98.tpr -o frame98.trr -x frame98.xtc -cpi state.cpt -cpt 15 -nt 6
03:55:09:WU00:FS01:0x21:*********************** Log Started 2019-12-31T03:55:09Z ***********************
03:55:09:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 14500, Gen 3)
03:55:09:WU00:FS01:0x21:Unit: 0x000000048ca304f15de049830c82b577
03:55:09:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:55:09:WU00:FS01:0x21:Machine: 1
03:55:09:WU00:FS01:0x21:Digital signatures verified
03:55:09:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:55:09:WU00:FS01:0x21:Version 0.0.20
03:55:10:WU00:FS01:0x21:  Found a checkpoint file
03:55:13:WU02:FS00:0xa7:Steps: first=12250000 total=125000
03:55:15:WU02:FS00:0xa7:Completed 112851 out of 125000 steps (90%)
03:55:18:WU00:FS01:0x21:Completed 1750000 out of 7500000 steps (23%)
03:55:18:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:56:36:WU00:FS01:0x21:Completed 1800000 out of 7500000 steps (24%)
03:56:38:WU02:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
03:58:21:WU02:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
03:58:31:WU00:FS01:0x21:Completed 1875000 out of 7500000 steps (25%)
04:00:04:WU02:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
04:00:25:WU00:FS01:0x21:Completed 1950000 out of 7500000 steps (26%)
04:01:50:WU02:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
04:02:22:WU00:FS01:0x21:Completed 2025000 out of 7500000 steps (27%)
04:03:34:WU02:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
04:04:13:6:127.0.0.1:New Web connection
04:04:15:33:127.0.0.1:New Web connection
04:04:16:WU00:FS01:0x21:Completed 2100000 out of 7500000 steps (28%)
04:05:22:WU02:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
04:06:12:WU00:FS01:0x21:Completed 2175000 out of 7500000 steps (29%)
04:07:09:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
04:08:07:WU00:FS01:0x21:Completed 2250000 out of 7500000 steps (30%)
04:08:58:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
04:10:03:WU00:FS01:0x21:Completed 2325000 out of 7500000 steps (31%)
04:10:46:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
04:10:46:WU01:FS00:Connecting to 65.254.110.245:8080
04:10:46:WU01:FS00:Assigned to work server 128.252.203.9
04:10:46:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.252.203.9
04:10:46:WU01:FS00:Connecting to 128.252.203.9:8080
04:10:47:WU01:FS00:Downloading 7.29MiB
04:10:50:WU01:FS00:Download complete
04:10:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14400 run:0 clone:3988 gen:6 core:0xa7 unit:0x0000000880fccb095dcad74b6112e3a1
04:11:58:WU00:FS01:0x21:Completed 2400000 out of 7500000 steps (32%)
04:12:30:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
04:12:37:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
04:12:37:WU02:FS00:0xa7:Saving result file frame98.trr
04:12:37:WU02:FS00:0xa7:Saving result file frame98.xtc
04:12:37:WU02:FS00:0xa7:Saving result file md.log
04:12:37:WU02:FS00:0xa7:Saving result file science.log
04:12:37:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:12:37:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:12:37:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13831 run:914 clone:1 gen:98 core:0xa7 unit:0x0000007780fccb095d693a39e8975983
04:12:37:WU02:FS00:Uploading 11.27MiB to 128.252.203.9
04:12:37:WU02:FS00:Connecting to 128.252.203.9:8080
04:12:37:WU01:FS00:Starting
04:12:37:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 9416 -checkpoint 15 -np 7
04:12:37:WU01:FS00:Started FahCore on PID 10524
04:12:37:WU01:FS00:Core PID:5648
04:12:37:WU01:FS00:FahCore 0xa7 started
04:12:38:WU01:FS00:0xa7:*********************** Log Started 2019-12-31T04:12:37Z ***********************
04:12:38:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:12:38:WU01:FS00:0xa7:       Type: 0xa7
04:12:38:WU01:FS00:0xa7:       Core: Gromacs
04:12:38:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 10524 -checkpoint 15 -np
04:12:38:WU01:FS00:0xa7:             7
04:12:38:WU01:FS00:0xa7:************************************ CBang *************************************
04:12:38:WU01:FS00:0xa7:       Date: Oct 26 2019
04:12:38:WU01:FS00:0xa7:       Time: 01:38:25
04:12:38:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:12:38:WU01:FS00:0xa7:     Branch: master
04:12:38:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
04:12:38:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:12:38:WU01:FS00:0xa7:   Platform: win32 10
04:12:38:WU01:FS00:0xa7:       Bits: 64
04:12:38:WU01:FS00:0xa7:       Mode: Release
04:12:38:WU01:FS00:0xa7:************************************ System ************************************
04:12:38:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
04:12:38:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:12:38:WU01:FS00:0xa7:       CPUs: 8
04:12:38:WU01:FS00:0xa7:     Memory: 63.86GiB
04:12:38:WU01:FS00:0xa7:Free Memory: 59.51GiB
04:12:38:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
04:12:38:WU01:FS00:0xa7: OS Version: 6.2
04:12:38:WU01:FS00:0xa7:Has Battery: false
04:12:38:WU01:FS00:0xa7: On Battery: false
04:12:38:WU01:FS00:0xa7: UTC Offset: -8
04:12:38:WU01:FS00:0xa7:        PID: 5648
04:12:38:WU01:FS00:0xa7:        CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\work
04:12:38:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
04:12:38:WU01:FS00:0xa7:    Version: 0.0.18
04:12:38:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:12:38:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
04:12:38:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
04:12:38:WU01:FS00:0xa7:       Time: 01:52:30
04:12:38:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:12:38:WU01:FS00:0xa7:************************************ Build *************************************
04:12:38:WU01:FS00:0xa7:       SIMD: avx_256
04:12:38:WU01:FS00:0xa7:********************************************************************************
04:12:38:WU01:FS00:0xa7:Project: 14400 (Run 0, Clone 3988, Gen 6)
04:12:38:WU01:FS00:0xa7:Unit: 0x0000000880fccb095dcad74b6112e3a1
04:12:38:WU01:FS00:0xa7:Reading tar file core.xml
04:12:38:WU01:FS00:0xa7:Reading tar file frame6.tpr
04:12:38:WU01:FS00:0xa7:Digital signatures verified
04:12:38:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
04:12:38:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -x frame6.xtc -cpt 15 -nt 6
04:12:38:WU01:FS00:0xa7:Steps: first=750000 total=125000
04:12:40:WU02:FS00:Upload complete
04:12:40:WU02:FS00:Server responded WORK_ACK (400)
04:12:40:WU02:FS00:Final credit estimate, 5641.00 points
04:12:40:WU02:FS00:Cleaning up
04:12:41:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
04:13:53:WU00:FS01:0x21:Completed 2475000 out of 7500000 steps (33%)
04:14:09:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
04:15:38:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
04:15:49:WU00:FS01:0x21:Completed 2550000 out of 7500000 steps (34%)
04:17:06:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
04:17:44:WU00:FS01:0x21:Completed 2625000 out of 7500000 steps (35%)
04:18:33:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
04:19:39:WU00:FS01:0x21:Completed 2700000 out of 7500000 steps (36%)
04:20:00:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
04:21:27:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
04:21:36:WU00:FS01:0x21:Completed 2775000 out of 7500000 steps (37%)
04:22:53:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
04:23:31:WU00:FS01:0x21:Completed 2850000 out of 7500000 steps (38%)
04:24:20:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
04:25:27:WU00:FS01:0x21:Completed 2925000 out of 7500000 steps (39%)
04:25:48:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
04:27:14:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
04:27:22:WU00:FS01:0x21:Completed 3000000 out of 7500000 steps (40%)
04:28:43:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
:wink:
Re: (Solved)Low percentage of steps completed
I'm not sure where the first part of this topic is. Your +++UPDATE+++ sounds reasonable without a Part 1 being somewhere. Did you intend to make this part of your earlier posts about posting a log? A Mod can merge those posts and this one into a single topic, but that may not be what you intended.
Each active project writes a progress message to FAH's log informing you every time that another 1% of progress has been made. Once a project reaches 100%, the results will be uploaded to a server and a new project will be downloaded. If, for some reason, the project cannot be uploaded, FAHClient will keep trying until the WU expires.
In the log above, you are obviously running two WUs and the output from each of them more-or-less alternates. WU00 is running in FAH Slot 01 using FAHCore_21 using the resources of your GPU plus one CPU. That particular WU is known by the four numbers Project: 11714 (Run 0, Clone 14500, Gen 3) (commonly called PRCG). It gets about 1% closer to completion every couple of minutes, which means it will run for about 200 minutes, upload the result, download a new WU (which may or may not be similar) and go back to work.
Six of your CPU threads are processing WU01 which is running in FAH Slot 00 using the FAHCore_a7 software. It also completes about 1% every two minutes. That WU is known by the four numbers PRCG: 14400 (0,3988,6)
Earlier, you completed PRCG: 13831 (914,1,98) which was returned for credit at about 04:12 GMT.
