Newbie just posting Log as per intructions
Smookin_Joe
Post by Smookin_Joe »
*********************** Log Started 2019-12-25T23:51:04Z ***********************
23:51:04:************************* Folding@home Client *************************
23:51:04:        Website: https://foldingathome.org/
23:51:04:      Copyright: (c) 2009-2018 foldingathome.org
23:51:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:51:04:           Args:
23:51:04:         Config: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\config.xml
23:51:04:******************************** Build ********************************
23:51:04:        Version: 7.5.1
23:51:04:           Date: May 11 2018
23:51:04:           Time: 13:06:32
23:51:04:     Repository: Git
23:51:04:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
23:51:04:         Branch: master
23:51:04:       Compiler: Visual C++ 2008
23:51:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
23:51:04:       Platform: win32 10
23:51:04:           Bits: 32
23:51:04:           Mode: Release
23:51:04:******************************* System ********************************
23:51:04:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
23:51:04:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
23:51:04:           CPUs: 8
23:51:04:         Memory: 63.86GiB
23:51:04:    Free Memory: 60.77GiB
23:51:04:        Threads: WINDOWS_THREADS
23:51:04:     OS Version: 6.2
23:51:04:    Has Battery: false
23:51:04:     On Battery: false
23:51:04:     UTC Offset: -8
23:51:04:            PID: 9912
23:51:04:            CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient
23:51:04:             OS: Windows 10 Enterprise
23:51:04:        OS Arch: AMD64
23:51:04:           GPUs: 1
23:51:04:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
23:51:04:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.1
23:51:04:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
23:51:04:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:432.0
23:51:04:  Win32 Service: false
23:51:04:***********************************************************************
23:51:04:<config>
23:51:04:  <!-- Folding Core -->
23:51:04:  <core-priority v='low'/>
23:51:04:
23:51:04:  <!-- Network -->
23:51:04:  <proxy v=':8080'/>
23:51:04:
23:51:04:  <!-- Slot Control -->
23:51:04:  <power v='FULL'/>
23:51:04:
23:51:04:  <!-- User Information -->
23:51:04:  <passkey v='********************************'/>
23:51:04:  <team v='111065'/>
23:51:04:  <user v='SmookinJoe'/>
23:51:04:
23:51:04:  <!-- Folding Slots -->
23:51:04:  <slot id='0' type='CPU'>
23:51:04:    <paused v='true'/>
23:51:04:  </slot>
23:51:04:  <slot id='1' type='GPU'>
23:51:04:  </slot>
23:51:04:</config>
23:51:04:Trying to access database...
23:51:04:Successfully acquired database lock
23:51:04:Enabled folding slot 00: PAUSED cpu:7 (by user)
23:51:04:Enabled folding slot 01: PAUSED gpu:0:TU106 [Geforce RTX 2060] (by user)
00:02:05:FS00:Unpaused
00:02:05:FS01:Unpaused
00:02:05:WU01:FS01:Starting
00:02:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 705 -lifeline 9912 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
00:02:06:WU01:FS01:Started FahCore on PID 2696
00:02:06:WU01:FS01:Core PID:7180
00:02:06:WU01:FS01:FahCore 0x21 started
00:02:06:WU02:FS00:Starting
00:02:06:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 9912 -checkpoint 15 -np 7
00:02:06:WU02:FS00:Started FahCore on PID 8504
00:02:07:WU02:FS00:Core PID:2904
00:02:07:WU02:FS00:FahCore 0xa7 started
00:02:07:WU01:FS01:0x21:*********************** Log Started 2019-12-26T00:02:06Z ***********************
00:02:07:WU01:FS01:0x21:Project: 11714 (Run 0, Clone 12687, Gen 17)
00:02:07:WU01:FS01:0x21:Unit: 0x0000001a8ca304f15de0497d629d2dc2
00:02:07:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
00:02:07:WU01:FS01:0x21:Machine: 1
00:02:07:WU01:FS01:0x21:Digital signatures verified
00:02:07:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
00:02:07:WU01:FS01:0x21:Version 0.0.20
00:02:07:WU02:FS00:0xa7:*********************** Log Started 2019-12-26T00:02:07Z ***********************
00:02:07:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
00:02:07:WU02:FS00:0xa7:       Type: 0xa7
00:02:07:WU02:FS00:0xa7:       Core: Gromacs
00:02:07:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 8504 -checkpoint 15 -np 7
00:02:07:WU02:FS00:0xa7:************************************ CBang *************************************
00:02:07:WU02:FS00:0xa7:       Date: Oct 26 2019
00:02:07:WU02:FS00:0xa7:       Time: 01:38:25
00:02:07:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
00:02:07:WU02:FS00:0xa7:     Branch: master
00:02:07:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
00:02:07:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
00:02:07:WU02:FS00:0xa7:   Platform: win32 10
00:02:07:WU02:FS00:0xa7:       Bits: 64
00:02:07:WU02:FS00:0xa7:       Mode: Release
00:02:07:WU02:FS00:0xa7:************************************ System ************************************
00:02:07:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
00:02:07:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
00:02:07:WU02:FS00:0xa7:       CPUs: 8
00:02:07:WU02:FS00:0xa7:     Memory: 63.86GiB
00:02:07:WU02:FS00:0xa7:Free Memory: 60.32GiB
00:02:07:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
00:02:07:WU02:FS00:0xa7: OS Version: 6.2
00:02:07:WU02:FS00:0xa7:Has Battery: false
00:02:07:WU02:FS00:0xa7: On Battery: false
00:02:07:WU02:FS00:0xa7: UTC Offset: -8
00:02:07:WU02:FS00:0xa7:        PID: 2904
00:02:07:WU02:FS00:0xa7:        CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\work
00:02:07:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
00:02:07:WU02:FS00:0xa7:    Version: 0.0.18
00:02:07:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:02:07:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
00:02:07:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
00:02:07:WU02:FS00:0xa7:       Time: 01:52:30
00:02:07:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
00:02:07:WU02:FS00:0xa7:************************************ Build *************************************
00:02:07:WU02:FS00:0xa7:       SIMD: avx_256
00:02:07:WU02:FS00:0xa7:********************************************************************************
00:02:07:WU02:FS00:0xa7:Project: 13829 (Run 283, Clone 1, Gen 78)
00:02:07:WU02:FS00:0xa7:Unit: 0x0000005f80fccb095d66d43db772c08e
00:02:07:WU02:FS00:0xa7:Digital signatures verified
00:02:07:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
00:02:07:WU02:FS00:0xa7:Calling: mdrun -s frame78.tpr -o frame78.trr -x frame78.xtc -cpi state.cpt -cpt 15 -nt 6
00:02:07:WU01:FS01:0x21:  Found a checkpoint file
00:02:08:WU02:FS00:0xa7:Steps: first=9750000 total=125000
00:02:10:WU02:FS00:0xa7:Completed 1042 out of 125000 steps (0%)
00:02:12:WU01:FS01:0x21:Completed 1500000 out of 7500000 steps (20%)
00:02:12:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:02:15:Removing old file 'configs/config-20191224-222300.xml'
00:02:15:Saving configuration to config.xml
00:02:15:<config>
00:02:15:  <!-- Folding Core -->
00:02:15:  <core-priority v='low'/>
00:02:15:
00:02:15:  <!-- Network -->
00:02:15:  <proxy v=':8080'/>
00:02:15:
00:02:15:  <!-- Slot Control -->
00:02:15:  <power v='FULL'/>
00:02:15:
00:02:15:  <!-- User Information -->
00:02:15:  <passkey v='********************************'/>
00:02:15:  <team v='111065'/>
00:02:15:  <user v='SmookinJoe'/>
00:02:15:
00:02:15:  <!-- Folding Slots -->
00:02:15:  <slot id='0' type='CPU'/>
00:02:15:  <slot id='1' type='GPU'/>
00:02:15:</config>
00:02:27:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
00:04:06:WU01:FS01:0x21:Completed 1575000 out of 7500000 steps (21%)
00:04:08:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
00:05:50:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
00:06:00:WU01:FS01:0x21:Completed 1650000 out of 7500000 steps (22%)
00:07:31:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
00:07:55:WU01:FS01:0x21:Completed 1725000 out of 7500000 steps (23%)
00:09:13:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
00:09:37:9:127.0.0.1:New Web connection
00:09:39:36:127.0.0.1:New Web connection
00:09:51:WU01:FS01:0x21:Completed 1800000 out of 7500000 steps (24%)
00:10:59:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
00:11:46:WU01:FS01:0x21:Completed 1875000 out of 7500000 steps (25%)
00:12:42:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
00:13:41:WU01:FS01:0x21:Completed 1950000 out of 7500000 steps (26%)
00:14:30:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
00:15:39:WU01:FS01:0x21:Completed 2025000 out of 7500000 steps (27%)
00:16:19:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
00:17:35:WU01:FS01:0x21:Completed 2100000 out of 7500000 steps (28%)
00:18:12:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
00:19:31:WU01:FS01:0x21:Completed 2175000 out of 7500000 steps (29%)
00:20:06:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
00:21:26:WU01:FS01:0x21:Completed 2250000 out of 7500000 steps (30%)
00:21:56:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
00:23:24:WU01:FS01:0x21:Completed 2325000 out of 7500000 steps (31%)
00:23:47:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
00:25:20:WU01:FS01:0x21:Completed 2400000 out of 7500000 steps (32%)
00:25:35:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
00:27:15:WU01:FS01:0x21:Completed 2475000 out of 7500000 steps (33%)
00:27:23:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
00:29:12:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
00:29:12:WU01:FS01:0x21:Completed 2550000 out of 7500000 steps (34%)
00:31:00:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
00:31:08:WU01:FS01:0x21:Completed 2625000 out of 7500000 steps (35%)
00:32:51:WU02:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
00:33:04:WU01:FS01:0x21:Completed 2700000 out of 7500000 steps (36%)
00:34:39:WU02:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
00:35:02:WU01:FS01:0x21:Completed 2775000 out of 7500000 steps (37%)
00:36:27:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
00:36:57:WU01:FS01:0x21:Completed 2850000 out of 7500000 steps (38%)
00:38:14:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
00:38:53:WU01:FS01:0x21:Completed 2925000 out of 7500000 steps (39%)
00:40:02:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
00:40:48:WU01:FS01:0x21:Completed 3000000 out of 7500000 steps (40%)
00:41:49:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
00:42:45:WU01:FS01:0x21:Completed 3075000 out of 7500000 steps (41%)
00:43:37:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
00:44:41:WU01:FS01:0x21:Completed 3150000 out of 7500000 steps (42%)
00:45:25:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
00:46:37:WU01:FS01:0x21:Completed 3225000 out of 7500000 steps (43%)
00:47:15:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
00:48:34:WU01:FS01:0x21:Completed 3300000 out of 7500000 steps (44%)
00:49:03:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
00:50:29:WU01:FS01:0x21:Completed 3375000 out of 7500000 steps (45%)
00:50:50:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
00:52:25:WU01:FS01:0x21:Completed 3450000 out of 7500000 steps (46%)
00:52:38:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
00:54:22:WU01:FS01:0x21:Completed 3525000 out of 7500000 steps (47%)
00:54:26:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
00:56:13:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
00:56:18:WU01:FS01:0x21:Completed 3600000 out of 7500000 steps (48%)
00:58:01:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
00:58:13:WU01:FS01:0x21:Completed 3675000 out of 7500000 steps (49%)
00:59:48:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
01:00:09:WU01:FS01:0x21:Completed 3750000 out of 7500000 steps (50%)
01:01:36:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
01:02:06:WU01:FS01:0x21:Completed 3825000 out of 7500000 steps (51%)
01:03:26:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
01:04:01:WU01:FS01:0x21:Completed 3900000 out of 7500000 steps (52%)
01:05:14:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
01:05:57:WU01:FS01:0x21:Completed 3975000 out of 7500000 steps (53%)
01:07:02:WU02:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
01:07:54:WU01:FS01:0x21:Completed 4050000 out of 7500000 steps (54%)
01:08:49:WU02:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
01:09:50:WU01:FS01:0x21:Completed 4125000 out of 7500000 steps (55%)
01:10:37:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
01:11:45:WU01:FS01:0x21:Completed 4200000 out of 7500000 steps (56%)
01:12:24:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
01:13:42:WU01:FS01:0x21:Completed 4275000 out of 7500000 steps (57%)
01:14:12:WU02:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
01:15:38:WU01:FS01:0x21:Completed 4350000 out of 7500000 steps (58%)
01:15:59:WU02:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
01:17:34:WU01:FS01:0x21:Completed 4425000 out of 7500000 steps (59%)
01:17:50:WU02:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
01:19:29:WU01:FS01:0x21:Completed 4500000 out of 7500000 steps (60%)
01:19:38:WU02:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
01:21:26:WU02:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
01:21:26:WU01:FS01:0x21:Completed 4575000 out of 7500000 steps (61%)
01:23:13:WU02:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
01:23:22:WU01:FS01:0x21:Completed 4650000 out of 7500000 steps (62%)
01:25:01:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
01:25:18:WU01:FS01:0x21:Completed 4725000 out of 7500000 steps (63%)
01:26:48:WU02:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
01:27:15:WU01:FS01:0x21:Completed 4800000 out of 7500000 steps (64%)
01:28:36:WU02:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
01:29:10:WU01:FS01:0x21:Completed 4875000 out of 7500000 steps (65%)
01:30:23:WU02:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
01:31:06:WU01:FS01:0x21:Completed 4950000 out of 7500000 steps (66%)
01:32:14:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
01:33:03:WU01:FS01:0x21:Completed 5025000 out of 7500000 steps (67%)
01:34:01:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
01:34:58:WU01:FS01:0x21:Completed 5100000 out of 7500000 steps (68%)
01:35:49:WU02:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
01:36:54:WU01:FS01:0x21:Completed 5175000 out of 7500000 steps (69%)
01:37:36:WU02:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
01:38:50:WU01:FS01:0x21:Completed 5250000 out of 7500000 steps (70%)
01:39:24:WU02:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
01:40:47:WU01:FS01:0x21:Completed 5325000 out of 7500000 steps (71%)
01:41:12:WU02:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
01:42:43:WU01:FS01:0x21:Completed 5400000 out of 7500000 steps (72%)
01:42:59:WU02:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
01:44:39:WU01:FS01:0x21:Completed 5475000 out of 7500000 steps (73%)
01:44:47:WU02:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
01:46:34:WU02:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
01:46:36:WU01:FS01:0x21:Completed 5550000 out of 7500000 steps (74%)
01:48:25:WU02:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
01:48:31:WU01:FS01:0x21:Completed 5625000 out of 7500000 steps (75%)
01:50:12:WU02:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
01:50:27:WU01:FS01:0x21:Completed 5700000 out of 7500000 steps (76%)
01:52:00:WU02:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
01:52:24:WU01:FS01:0x21:Completed 5775000 out of 7500000 steps (77%)
01:53:48:WU02:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
01:54:19:WU01:FS01:0x21:Completed 5850000 out of 7500000 steps (78%)
01:55:36:WU02:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
01:56:15:WU01:FS01:0x21:Completed 5925000 out of 7500000 steps (79%)
01:57:24:WU02:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
01:58:11:WU01:FS01:0x21:Completed 6000000 out of 7500000 steps (80%)
01:59:11:WU02:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
02:00:07:WU01:FS01:0x21:Completed 6075000 out of 7500000 steps (81%)
02:00:59:WU02:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
02:02:03:WU01:FS01:0x21:Completed 6150000 out of 7500000 steps (82%)
02:02:50:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
02:03:59:WU01:FS01:0x21:Completed 6225000 out of 7500000 steps (83%)
02:04:37:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
02:05:56:WU01:FS01:0x21:Completed 6300000 out of 7500000 steps (84%)
02:06:25:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
02:07:52:WU01:FS01:0x21:Completed 6375000 out of 7500000 steps (85%)
02:08:13:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
02:09:47:WU01:FS01:0x21:Completed 6450000 out of 7500000 steps (86%)
02:10:00:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
02:11:45:WU01:FS01:0x21:Completed 6525000 out of 7500000 steps (87%)
02:11:48:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
02:13:35:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
02:13:40:WU01:FS01:0x21:Completed 6600000 out of 7500000 steps (88%)
02:15:23:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
02:15:36:WU01:FS01:0x21:Completed 6675000 out of 7500000 steps (89%)
02:17:10:WU02:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
02:17:32:WU01:FS01:0x21:Completed 6750000 out of 7500000 steps (90%)
02:19:01:WU02:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
02:19:29:WU01:FS01:0x21:Completed 6825000 out of 7500000 steps (91%)
02:20:48:WU02:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
02:21:25:WU01:FS01:0x21:Completed 6900000 out of 7500000 steps (92%)
02:22:36:WU02:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
02:23:20:WU01:FS01:0x21:Completed 6975000 out of 7500000 steps (93%)
02:24:23:WU02:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
02:25:17:WU01:FS01:0x21:Completed 7050000 out of 7500000 steps (94%)
02:26:11:WU02:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
02:27:13:WU01:FS01:0x21:Completed 7125000 out of 7500000 steps (95%)
02:27:59:WU02:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
02:29:09:WU01:FS01:0x21:Completed 7200000 out of 7500000 steps (96%)
02:29:46:WU02:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
02:31:06:WU01:FS01:0x21:Completed 7275000 out of 7500000 steps (97%)
02:31:34:WU02:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
02:33:01:WU01:FS01:0x21:Completed 7350000 out of 7500000 steps (98%)
02:33:25:WU02:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
02:34:57:WU01:FS01:0x21:Completed 7425000 out of 7500000 steps (99%)
02:34:58:WU00:FS01:Connecting to 65.254.110.245:8080
02:34:58:WU00:FS01:Assigned to work server 140.163.4.241
02:34:58:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU106 [Geforce RTX 2060] from 140.163.4.241
02:34:58:WU00:FS01:Connecting to 140.163.4.241:8080
02:34:59:WU00:FS01:Downloading 16.53MiB
02:35:05:WU00:FS01:Download 88.84%
02:35:05:WU00:FS01:Download complete
02:35:05:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11714 run:0 clone:12488 gen:46 core:0x21 unit:0x000000488ca304f15de0497bd5644dd0
02:35:13:WU02:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
02:36:52:WU01:FS01:0x21:Completed 7500000 out of 7500000 steps (100%)
02:36:54:WU01:FS01:0x21:Saving result file logfile_01.txt
02:36:54:WU01:FS01:0x21:Saving result file checkpointState.xml
02:36:54:WU01:FS01:0x21:Saving result file checkpt.crc
02:36:54:WU01:FS01:0x21:Saving result file log.txt
02:36:54:WU01:FS01:0x21:Saving result file positions.xtc
02:36:54:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
02:36:55:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:36:55:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11714 run:0 clone:12687 gen:17 core:0x21 unit:0x0000001a8ca304f15de0497d629d2dc2
02:36:55:WU01:FS01:Uploading 11.80MiB to 140.163.4.241
02:36:55:WU01:FS01:Connecting to 140.163.4.241:8080
02:36:55:WU00:FS01:Starting
02:36:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/nvidia/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 705 -lifeline 9912 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
02:36:55:WU00:FS01:Started FahCore on PID 3164
02:36:55:WU00:FS01:Core PID:11884
02:36:55:WU00:FS01:FahCore 0x21 started
02:36:55:WU00:FS01:0x21:*********************** Log Started 2019-12-26T02:36:55Z ***********************
02:36:55:WU00:FS01:0x21:Project: 11714 (Run 0, Clone 12488, Gen 46)
02:36:55:WU00:FS01:0x21:Unit: 0x000000488ca304f15de0497bd5644dd0
02:36:55:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:36:55:WU00:FS01:0x21:Machine: 1
02:36:55:WU00:FS01:0x21:Reading tar file core.xml
02:36:55:WU00:FS01:0x21:Reading tar file integrator.xml
02:36:55:WU00:FS01:0x21:Reading tar file state.xml
02:36:55:WU00:FS01:0x21:Reading tar file system.xml
02:36:55:WU00:FS01:0x21:Digital signatures verified
02:36:55:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:36:55:WU00:FS01:0x21:Version 0.0.20
02:36:59:WU01:FS01:Upload complete
02:36:59:WU01:FS01:Server responded WORK_ACK (400)
02:36:59:WU01:FS01:Final credit estimate, 94591.00 points
02:36:59:WU01:FS01:Cleaning up
02:37:00:WU00:FS01:0x21:Completed 0 out of 7500000 steps (0%)
02:37:00:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:37:01:WU02:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
02:38:48:WU02:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
02:38:56:WU00:FS01:0x21:Completed 75000 out of 7500000 steps (1%)
02:40:36:WU02:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
02:40:52:WU00:FS01:0x21:Completed 150000 out of 7500000 steps (2%)
02:42:23:WU02:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
02:42:47:WU00:FS01:0x21:Completed 225000 out of 7500000 steps (3%)
02:44:11:WU02:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
02:44:45:WU00:FS01:0x21:Completed 300000 out of 7500000 steps (4%)
02:45:59:WU02:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
02:46:40:WU00:FS01:0x21:Completed 375000 out of 7500000 steps (5%)
02:47:49:WU02:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
02:48:36:WU00:FS01:0x21:Completed 450000 out of 7500000 steps (6%)
02:49:37:WU02:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
02:50:32:WU00:FS01:0x21:Completed 525000 out of 7500000 steps (7%)
02:51:25:WU02:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
02:52:28:WU00:FS01:0x21:Completed 600000 out of 7500000 steps (8%)
02:53:12:WU02:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
02:54:23:WU00:FS01:0x21:Completed 675000 out of 7500000 steps (9%)
02:55:00:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
02:56:19:WU00:FS01:0x21:Completed 750000 out of 7500000 steps (10%)
02:56:47:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
02:58:16:WU00:FS01:0x21:Completed 825000 out of 7500000 steps (11%)
02:58:35:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
02:58:36:WU01:FS00:Connecting to 65.254.110.245:8080
02:58:37:WU01:FS00:Assigned to work server 128.252.203.9
02:58:37:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.252.203.9
02:58:37:WU01:FS00:Connecting to 128.252.203.9:8080
02:58:37:WU01:FS00:Downloading 7.29MiB
02:58:39:WU01:FS00:Download complete
02:58:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14400 run:0 clone:3048 gen:0 core:0xa7 unit:0x0000000180fccb095dcad7bf28d96100
03:00:12:WU00:FS01:0x21:Completed 900000 out of 7500000 steps (12%)
03:00:23:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
03:00:29:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
03:00:29:WU02:FS00:0xa7:Saving result file frame78.trr
03:00:29:WU02:FS00:0xa7:Saving result file frame78.xtc
03:00:30:WU02:FS00:0xa7:Saving result file md.log
03:00:30:WU02:FS00:0xa7:Saving result file science.log
03:00:30:WU02:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:00:30:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:00:30:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13829 run:283 clone:1 gen:78 core:0xa7 unit:0x0000005f80fccb095d66d43db772c08e
03:00:30:WU02:FS00:Uploading 11.26MiB to 128.252.203.9
03:00:30:WU02:FS00:Connecting to 128.252.203.9:8080
03:00:30:WU01:FS00:Starting
03:00:30:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Smokin Joe\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 9912 -checkpoint 15 -np 7
03:00:30:WU01:FS00:Started FahCore on PID 4232
03:00:30:WU01:FS00:Core PID:4148
03:00:30:WU01:FS00:FahCore 0xa7 started
03:00:31:WU01:FS00:0xa7:*********************** Log Started 2019-12-26T03:00:30Z ***********************
03:00:31:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:00:31:WU01:FS00:0xa7:       Type: 0xa7
03:00:31:WU01:FS00:0xa7:       Core: Gromacs
03:00:31:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4232 -checkpoint 15 -np 7
03:00:31:WU01:FS00:0xa7:************************************ CBang *************************************
03:00:31:WU01:FS00:0xa7:       Date: Oct 26 2019
03:00:31:WU01:FS00:0xa7:       Time: 01:38:25
03:00:31:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:00:31:WU01:FS00:0xa7:     Branch: master
03:00:31:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:00:31:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:00:31:WU01:FS00:0xa7:   Platform: win32 10
03:00:31:WU01:FS00:0xa7:       Bits: 64
03:00:31:WU01:FS00:0xa7:       Mode: Release
03:00:31:WU01:FS00:0xa7:************************************ System ************************************
03:00:31:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
03:00:31:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:00:31:WU01:FS00:0xa7:       CPUs: 8
03:00:31:WU01:FS00:0xa7:     Memory: 63.86GiB
03:00:31:WU01:FS00:0xa7:Free Memory: 59.45GiB
03:00:31:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:00:31:WU01:FS00:0xa7: OS Version: 6.2
03:00:31:WU01:FS00:0xa7:Has Battery: false
03:00:31:WU01:FS00:0xa7: On Battery: false
03:00:31:WU01:FS00:0xa7: UTC Offset: -8
03:00:31:WU01:FS00:0xa7:        PID: 4148
03:00:31:WU01:FS00:0xa7:        CWD: C:\Users\Smokin Joe\AppData\Roaming\FAHClient\work
03:00:31:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:00:31:WU01:FS00:0xa7:    Version: 0.0.18
03:00:31:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:00:31:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:00:31:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:00:31:WU01:FS00:0xa7:       Time: 01:52:30
03:00:31:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:00:31:WU01:FS00:0xa7:************************************ Build *************************************
03:00:31:WU01:FS00:0xa7:       SIMD: avx_256
03:00:31:WU01:FS00:0xa7:********************************************************************************
03:00:31:WU01:FS00:0xa7:Project: 14400 (Run 0, Clone 3048, Gen 0)
03:00:31:WU01:FS00:0xa7:Unit: 0x0000000180fccb095dcad7bf28d96100
03:00:31:WU01:FS00:0xa7:Reading tar file core.xml
03:00:31:WU01:FS00:0xa7:Reading tar file frame0.tpr
03:00:31:WU01:FS00:0xa7:Digital signatures verified
03:00:31:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
03:00:31:WU01:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -cpt 15 -nt 6
03:00:31:WU01:FS00:0xa7:Steps: first=0 total=125000
03:00:33:WU02:FS00:Upload complete
03:00:33:WU02:FS00:Server responded WORK_ACK (400)
03:00:33:WU02:FS00:Final credit estimate, 5235.00 points
03:00:33:WU02:FS00:Cleaning up
:wink:
MeeLee
Re: Newbie just posting Log as per intructions
Post by MeeLee »
You only need to post a log, if you have any issues.
First glance, you run a 64 bit version, do CPU and GPU folding, and it seems to work fine?
Right.
Posting that log is important if you need support. What support do you think you need?
Smookin_Joe
Hi Guys
I am pretty limited in knowledge as to how I should tweak my machines. I am glad that it meets with your approval and you feel it is running ok.
I will start a new post with the exact configurations (s) in a while when I start to have issues concerning ppd or anything else.
I originally had a Team FLDC username but due to the complexity of the team software configuration I was having problems getting statistics to rack up consistently. I discovered my username on the FAH client was incorrect...more than once...My Bad!
Search the donors list SmookinJoe and you will see what I mean...lol
I was almost ready to give up but the guys at Discord Curecoin changed my mind. I jumped over to Team Evga and this is the log from my EVGA team machine. My past issues were stumbling around trying to get statistics for my folding and it can take a toll on your ability to focus on the machine itself.
Glad to hear you guys say it seems fine.
I have ordered up a new AMD mobo and Ryzen chip for to recreate my team FLDC machine. I have also ordered 2 more EVGA GeForce RTX 2060 XC Ultra's which are going to be divided between the two machines.
Thank You for your time
Joe :)
:wink:
MeeLee
Post by MeeLee »
Here are your userstats on FAH:
https://stats.foldingathome.org/donor/50732586
Stats on F@EOC:
https://folding.extremeoverclocking.com ... =&u=838135
Smookin_Joe wrote:Hi Guys
Joe :)
As a newbie, I strongly suggest that you don't tweak your machines. When FAH is installed, it does a reasonable job of configuring your machine and most of the tweaking you might consider is unlikely to do any good. DO NOT TWEAK your machine unless you understand what you're doing and why.
Adding hardware is a good thing and you will probably benefit by just reinstalling FAH after the hardware and driviers have been configured.
