Problems obtaining GPU WU
ClemSNide
Hardware configuration: CPU: Intel Core i7 860
Motherboard: Gigabyte GA-P55-UD3R
Graphics: Sapphire ATi Radeon HD5850
Memory: 8 GB Patriot Viper series PC3-12800
Boot HD: OCZ Agility SSD 64 GB
Secondary HD: Two WD Caviar Green 1 TB in RAID-1 array
Post by ClemSNide »
I'm using a 2009 vintage PC with a Radeon HD5850. Previously it did a fine job on work units, but a couple of years ago it stopped.
It kept trying to obtain a WU assignment to no avail. Thinking it might be a problem with the server, I uninstalled F@H and reinstalled after a few months. Same deal each time. Lately the logs have shown that there was a problem connecting:
04:22:41:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:23:02:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
The CPU slot is working but it seems a waste to just use it when the GPU has done so well in the past.
All device drivers are up to date and the F@H client version is 7.5.1. Is there something I'm missing? I'm nearly blind so it's easy for me to miss little things, but again, it had been working.
Re: Problems obtaining GPU WU
We need more information from FAH's log. The address 192.0.2.1 is not one associated with obtaining a WU for your GPU to process. although it might be used for other purposes.
The Radeon HD 5850 should be supported but apparently is not, for reasons that I do not understand. There are several versions of the 5850 and I'd like to know which one you have. Please run FAHClient --lspci and capture that portion of the output that lists your GPU.
By chance did you elect to install the new client as a service? That's just a guess, but it could explain why your GPU cannot fold.
For some unknown reason, all Cypress GPUs are set to species 4 (no DP support) although they seem to support it. Since those GPUs are using old Terascale 2 architecture, maybe they have been disabled because we thought they can't meet the deadlines ...
We need to know the PCIe ID of your GPU (you can use GPUZ to get it easily) so that we can try to enable it again and give it another try.
ClemSNide
Post by ClemSNide »
(Hope I can get this in before the system logs me out.)
The card is a Sapphire HD 5850, as close to the AMD version as you can get. GPU-Z reports it as rev 00. It's in the lone x16 PCIe slot of a Gigabyte P55-UD3R motherboard.
Up until it stopped getting WS assignments entirely it was doing a fine job, making all deadlines and leaving the CPU in the dust. I accumulated a fair number of points with it.
When I ran the command line with parameters, it displayed a small window for a moment and quit with no other results. Perhaps the results are in the (unexcerpted) log but if this is vital to the troubleshooting you'll have to find another way to do it.
Here's the full log.
*********************** Log Started 2019-12-22T03:50:48Z ***********************
03:50:48:************************* Folding@home Client *************************
03:50:48:        Website: https://foldingathome.org/
03:50:48:      Copyright: (c) 2009-2018 foldingathome.org
03:50:48:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:50:48:           Args:
03:50:48:         Config: D:\Users\Saint John\AppData\Roaming\FAHClient\config.xml
03:50:48:******************************** Build ********************************
03:50:48:        Version: 7.5.1
03:50:48:           Date: May 11 2018
03:50:48:           Time: 13:06:32
03:50:48:     Repository: Git
03:50:48:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:50:48:         Branch: master
03:50:48:       Compiler: Visual C++ 2008
03:50:48:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:50:48:       Platform: win32 10
03:50:48:           Bits: 32
03:50:48:           Mode: Release
03:50:48:******************************* System ********************************
03:50:48:            CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
03:50:48:         CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
03:50:48:           CPUs: 8
03:50:48:         Memory: 8.00GiB
03:50:48:    Free Memory: 6.74GiB
03:50:48:        Threads: WINDOWS_THREADS
03:50:48:     OS Version: 6.1
03:50:48:    Has Battery: false
03:50:48:     On Battery: false
03:50:48:     UTC Offset: -5
03:50:48:            PID: 2484
03:50:48:            CWD: D:\Users\Saint John\AppData\Roaming\FAHClient
03:50:48:             OS: Windows 7 Home Premium
03:50:48:        OS Arch: AMD64
03:50:48:           GPUs: 1
03:50:48:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 Cypress [Radeon HD 5800/6850]
03:50:48:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
03:50:48:                 specified module could not be found.
03:50:48:
03:50:48:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:1800.8
03:50:48:  Win32 Service: false
03:50:48:***********************************************************************
03:50:48:<config>
03:50:48:  <!-- Network -->
03:50:48:  <proxy v=':8080'/>
03:50:48:
03:50:48:  <!-- Slot Control -->
03:50:48:  <power v='FULL'/>
03:50:48:
03:50:48:  <!-- User Information -->
03:50:48:  <user v='ClemSnide'/>
03:50:48:
03:50:48:  <!-- Folding Slots -->
03:50:48:  <slot id='0' type='CPU'>
03:50:48:    <idle v='true'/>
03:50:48:  </slot>
03:50:48:  <slot id='1' type='GPU'>
03:50:48:  </slot>
03:50:48:</config>
03:50:48:Trying to access database...
03:50:48:Successfully acquired database lock
03:50:48:Enabled folding slot 00: PAUSED cpu:7 (waiting for idle)
03:50:48:Enabled folding slot 01: PAUSED gpu:0:Cypress [Radeon HD 5800/6850] (waiting for idle)
03:53:58:WU01:FS00:Starting
03:53:58:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Users\Saint John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -np 7
03:53:58:WU01:FS00:Started FahCore on PID 4720
03:53:58:WU01:FS00:Core PID:4732
03:53:58:WU01:FS00:FahCore 0xa7 started
03:54:00:WU01:FS00:0xa7:*********************** Log Started 2019-12-22T03:54:00Z ***********************
03:54:00:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:54:00:WU01:FS00:0xa7:       Type: 0xa7
03:54:00:WU01:FS00:0xa7:       Core: Gromacs
03:54:00:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 4720 -checkpoint 15 -np 7
03:54:00:WU01:FS00:0xa7:************************************ CBang *************************************
03:54:00:WU01:FS00:0xa7:       Date: Oct 26 2019
03:54:00:WU01:FS00:0xa7:       Time: 01:38:35
03:54:00:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:54:00:WU01:FS00:0xa7:     Branch: master
03:54:00:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
03:54:00:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:54:00:WU01:FS00:0xa7:   Platform: win32 10
03:54:00:WU01:FS00:0xa7:       Bits: 64
03:54:00:WU01:FS00:0xa7:       Mode: Release
03:54:00:WU01:FS00:0xa7:************************************ System ************************************
03:54:00:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
03:54:00:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
03:54:00:WU01:FS00:0xa7:       CPUs: 8
03:54:00:WU01:FS00:0xa7:     Memory: 8.00GiB
03:54:00:WU01:FS00:0xa7:Free Memory: 6.24GiB
03:54:00:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
03:54:00:WU01:FS00:0xa7: OS Version: 6.1
03:54:00:WU01:FS00:0xa7:Has Battery: false
03:54:00:WU01:FS00:0xa7: On Battery: false
03:54:00:WU01:FS00:0xa7: UTC Offset: -5
03:54:00:WU01:FS00:0xa7:        PID: 4732
03:54:00:WU01:FS00:0xa7:        CWD: D:\Users\Saint John\AppData\Roaming\FAHClient\work
03:54:00:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
03:54:00:WU01:FS00:0xa7:    Version: 0.0.18
03:54:00:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:54:00:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:54:00:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
03:54:00:WU01:FS00:0xa7:       Time: 01:52:44
03:54:00:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:54:00:WU01:FS00:0xa7:************************************ Build *************************************
03:54:00:WU01:FS00:0xa7:       SIMD: sse2
03:54:00:WU01:FS00:0xa7:********************************************************************************
03:54:00:WU01:FS00:0xa7:Project: 13827 (Run 973, Clone 2, Gen 94)
03:54:00:WU01:FS00:0xa7:Unit: 0x0000007180fccb095c9f83319bb9b53e
03:54:00:WU01:FS00:0xa7:Digital signatures verified
03:54:00:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
03:54:00:WU01:FS00:0xa7:Calling: mdrun -s frame94.tpr -o frame94.trr -x frame94.xtc -cpi state.cpt -cpt 15 -nt 6
03:54:01:WU01:FS00:0xa7:Steps: first=11750000 total=125000
03:54:07:WU01:FS00:0xa7:Completed 66672 out of 125000 steps (53%)
03:54:11:WU00:FS01:Connecting to 65.254.110.245:8080
03:54:12:WU00:FS01:Assigned to work server 192.0.2.1
03:54:12:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
03:54:12:WU00:FS01:Connecting to 192.0.2.1:8080
03:54:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
03:54:33:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:54:33:WU00:FS01:Connecting to 192.0.2.1:80
03:54:52:Saving configuration to config.xml
03:54:52:<config>
03:54:52:  <!-- Network -->
03:54:52:  <proxy v=':8080'/>
03:54:52:
03:54:52:  <!-- Slot Control -->
03:54:52:  <power v='FULL'/>
03:54:52:
03:54:52:  <!-- User Information -->
03:54:52:  <user v='ClemSnide'/>
03:54:52:
03:54:52:  <!-- Folding Slots -->
03:54:52:  <slot id='0' type='CPU'/>
03:54:52:  <slot id='1' type='GPU'/>
03:54:52:</config>
03:54:54:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:54:54:WU00:FS01:Connecting to 65.254.110.245:8080
03:54:55:WU00:FS01:Assigned to work server 192.0.2.1
03:54:55:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
03:54:55:WU00:FS01:Connecting to 192.0.2.1:8080
03:55:16:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:55:16:WU00:FS01:Connecting to 192.0.2.1:80
03:55:37:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:55:54:WU00:FS01:Connecting to 65.254.110.245:8080
03:55:54:WU00:FS01:Assigned to work server 192.0.2.1
03:55:55:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
03:55:55:WU00:FS01:Connecting to 192.0.2.1:8080
03:56:16:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:56:16:WU00:FS01:Connecting to 192.0.2.1:80
03:56:37:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:56:56:WU01:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
03:57:32:WU00:FS01:Connecting to 65.254.110.245:8080
03:57:32:WU00:FS01:Assigned to work server 192.0.2.1
03:57:32:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
03:57:32:WU00:FS01:Connecting to 192.0.2.1:8080
03:57:53:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
03:57:53:WU00:FS01:Connecting to 192.0.2.1:80
03:58:14:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:00:09:WU00:FS01:Connecting to 65.254.110.245:8080
04:00:09:WU00:FS01:Assigned to work server 192.0.2.1
04:00:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
04:00:09:WU00:FS01:Connecting to 192.0.2.1:8080
04:00:30:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:00:30:WU00:FS01:Connecting to 192.0.2.1:80
04:00:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:01:14:WU01:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
04:04:23:WU00:FS01:Connecting to 65.254.110.245:8080
04:04:23:WU00:FS01:Assigned to work server 192.0.2.1
04:04:23:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
04:04:23:WU00:FS01:Connecting to 192.0.2.1:8080
04:04:44:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:04:44:WU00:FS01:Connecting to 192.0.2.1:80
04:05:05:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:05:25:WU01:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
04:09:36:WU01:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
04:11:14:WU00:FS01:Connecting to 65.254.110.245:8080
04:11:14:WU00:FS01:Assigned to work server 192.0.2.1
04:11:15:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
04:11:15:WU00:FS01:Connecting to 192.0.2.1:8080
04:11:36:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:11:36:WU00:FS01:Connecting to 192.0.2.1:80
04:11:57:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:13:43:WU01:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
04:17:43:WU01:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
04:21:39:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
04:22:20:WU00:FS01:Connecting to 65.254.110.245:8080
04:22:20:WU00:FS01:Assigned to work server 192.0.2.1
04:22:20:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
04:22:20:WU00:FS01:Connecting to 192.0.2.1:8080
04:22:41:WU00:FS01:Connecting to 192.0.2.1:80
04:25:40:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
04:29:35:WU01:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
04:33:32:WU01:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
04:37:33:WU01:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
04:40:17:WU00:FS01:Connecting to 65.254.110.245:8080
04:40:17:WU00:FS01:Assigned to work server 192.0.2.1
04:40:17:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
04:40:17:WU00:FS01:Connecting to 192.0.2.1:8080
04:40:38:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
04:40:38:WU00:FS01:Connecting to 192.0.2.1:80
04:40:59:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
04:41:56:WU01:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
04:45:53:WU01:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
04:49:49:WU01:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
04:53:46:WU01:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
04:57:44:WU01:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
05:01:41:WU01:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
05:05:37:WU01:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
05:09:19:WU00:FS01:Connecting to 65.254.110.245:8080
05:09:19:WU00:FS01:Assigned to work server 192.0.2.1
05:09:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
05:09:19:WU00:FS01:Connecting to 192.0.2.1:8080
05:09:36:WU01:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
05:09:40:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:09:40:WU00:FS01:Connecting to 192.0.2.1:80
05:10:01:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:13:32:WU01:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
05:17:29:WU01:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
05:21:25:WU01:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
05:25:23:WU01:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
05:29:20:WU01:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
05:33:17:WU01:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
05:37:13:WU01:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
05:41:12:WU01:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
05:45:08:WU01:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
05:49:05:WU01:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
05:53:01:WU01:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
05:56:18:WU00:FS01:Connecting to 65.254.110.245:8080
05:56:18:WU00:FS01:Assigned to work server 192.0.2.1
05:56:18:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
05:56:18:WU00:FS01:Connecting to 192.0.2.1:8080
05:56:39:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
05:56:39:WU00:FS01:Connecting to 192.0.2.1:80
05:56:59:WU01:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
05:57:00:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
06:00:58:WU01:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
06:01:00:FS00:Shutting core down
06:01:00:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 4732
06:01:00:WU01:FS00:0xa7:Exiting, please wait. . .
06:01:03:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
06:01:04:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:01:57:Saving configuration to config.xml
06:01:57:<config>
06:01:57:  <!-- Network -->
06:01:57:  <proxy v=':8080'/>
06:01:57:
06:01:57:  <!-- Slot Control -->
06:01:57:  <power v='FULL'/>
06:01:57:
06:01:57:  <!-- User Information -->
06:01:57:  <user v='ClemSnide'/>
06:01:57:
06:01:57:  <!-- Folding Slots -->
06:01:57:  <slot id='0' type='CPU'>
06:01:57:    <idle v='true'/>
06:01:57:  </slot>
06:01:57:  <slot id='1' type='GPU'>
06:01:57:  </slot>
06:01:57:</config>
08:16:09:WU01:FS00:Starting
08:16:09:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Users\Saint John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -np 7
08:16:09:WU01:FS00:Started FahCore on PID 6520
08:16:09:WU01:FS00:Core PID:6292
08:16:09:WU01:FS00:FahCore 0xa7 started
08:16:10:WU00:FS01:Connecting to 65.254.110.245:8080
08:16:10:WU01:FS00:0xa7:*********************** Log Started 2019-12-22T08:16:10Z ***********************
08:16:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:16:10:WU01:FS00:0xa7:       Type: 0xa7
08:16:10:WU01:FS00:0xa7:       Core: Gromacs
08:16:10:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 6520 -checkpoint 15 -np 7
08:16:10:WU01:FS00:0xa7:************************************ CBang *************************************
08:16:10:WU01:FS00:0xa7:       Date: Oct 26 2019
08:16:10:WU01:FS00:0xa7:       Time: 01:38:35
08:16:10:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:16:10:WU01:FS00:0xa7:     Branch: master
08:16:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
08:16:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:16:10:WU01:FS00:0xa7:   Platform: win32 10
08:16:10:WU01:FS00:0xa7:       Bits: 64
08:16:10:WU01:FS00:0xa7:       Mode: Release
08:16:10:WU01:FS00:0xa7:************************************ System ************************************
08:16:10:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
08:16:10:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
08:16:10:WU01:FS00:0xa7:       CPUs: 8
08:16:10:WU01:FS00:0xa7:     Memory: 8.00GiB
08:16:10:WU01:FS00:0xa7:Free Memory: 6.14GiB
08:16:10:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
08:16:10:WU01:FS00:0xa7: OS Version: 6.1
08:16:10:WU01:FS00:0xa7:Has Battery: false
08:16:10:WU01:FS00:0xa7: On Battery: false
08:16:10:WU01:FS00:0xa7: UTC Offset: -5
08:16:10:WU01:FS00:0xa7:        PID: 6292
08:16:10:WU01:FS00:0xa7:        CWD: D:\Users\Saint John\AppData\Roaming\FAHClient\work
08:16:10:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
08:16:10:WU01:FS00:0xa7:    Version: 0.0.18
08:16:10:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:16:10:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:16:10:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
08:16:10:WU01:FS00:0xa7:       Time: 01:52:44
08:16:10:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:16:10:WU01:FS00:0xa7:************************************ Build *************************************
08:16:10:WU01:FS00:0xa7:       SIMD: sse2
08:16:10:WU01:FS00:0xa7:********************************************************************************
08:16:10:WU01:FS00:0xa7:Project: 13827 (Run 973, Clone 2, Gen 94)
08:16:10:WU01:FS00:0xa7:Unit: 0x0000007180fccb095c9f83319bb9b53e
08:16:10:WU01:FS00:0xa7:Digital signatures verified
08:16:10:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
08:16:10:WU01:FS00:0xa7:Calling: mdrun -s frame94.tpr -o frame94.trr -x frame94.xtc -cpi state.cpt -cpt 15 -nt 6
08:16:10:WU01:FS00:0xa7:Steps: first=11750000 total=125000
08:16:14:WU01:FS00:0xa7:Completed 106262 out of 125000 steps (85%)
08:16:25:WU00:FS01:Assigned to work server 192.0.2.1
08:16:25:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
08:16:25:WU00:FS01:Connecting to 192.0.2.1:8080
08:16:27:FS00:Shutting core down
08:16:27:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 6292
08:16:27:WU01:FS00:0xa7:Exiting, please wait. . .
08:16:32:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
08:16:32:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:16:46:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
08:16:46:WU00:FS01:Connecting to 192.0.2.1:80
08:17:07:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:05:06:WU01:FS00:Starting
09:05:06:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Users\Saint John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -np 7
09:05:06:WU01:FS00:Started FahCore on PID 1276
09:05:06:WU01:FS00:Core PID:3388
09:05:06:WU01:FS00:FahCore 0xa7 started
09:05:07:WU01:FS00:0xa7:*********************** Log Started 2019-12-22T09:05:07Z ***********************
09:05:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:05:07:WU01:FS00:0xa7:       Type: 0xa7
09:05:07:WU01:FS00:0xa7:       Core: Gromacs
09:05:07:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 1276 -checkpoint 15 -np 7
09:05:07:WU01:FS00:0xa7:************************************ CBang *************************************
09:05:07:WU01:FS00:0xa7:       Date: Oct 26 2019
09:05:07:WU01:FS00:0xa7:       Time: 01:38:35
09:05:07:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:05:07:WU01:FS00:0xa7:     Branch: master
09:05:07:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:05:07:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:05:07:WU01:FS00:0xa7:   Platform: win32 10
09:05:07:WU01:FS00:0xa7:       Bits: 64
09:05:07:WU01:FS00:0xa7:       Mode: Release
09:05:07:WU01:FS00:0xa7:************************************ System ************************************
09:05:07:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
09:05:07:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
09:05:07:WU01:FS00:0xa7:       CPUs: 8
09:05:07:WU01:FS00:0xa7:     Memory: 8.00GiB
09:05:07:WU01:FS00:0xa7:Free Memory: 6.14GiB
09:05:07:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:05:07:WU01:FS00:0xa7: OS Version: 6.1
09:05:07:WU01:FS00:0xa7:Has Battery: false
09:05:07:WU01:FS00:0xa7: On Battery: false
09:05:07:WU01:FS00:0xa7: UTC Offset: -5
09:05:07:WU01:FS00:0xa7:        PID: 3388
09:05:07:WU01:FS00:0xa7:        CWD: D:\Users\Saint John\AppData\Roaming\FAHClient\work
09:05:07:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:05:07:WU01:FS00:0xa7:    Version: 0.0.18
09:05:07:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:05:07:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:05:07:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:05:07:WU01:FS00:0xa7:       Time: 01:52:44
09:05:07:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:05:07:WU01:FS00:0xa7:************************************ Build *************************************
09:05:07:WU01:FS00:0xa7:       SIMD: sse2
09:05:07:WU01:FS00:0xa7:********************************************************************************
09:05:07:WU01:FS00:0xa7:Project: 13827 (Run 973, Clone 2, Gen 94)
09:05:07:WU01:FS00:0xa7:Unit: 0x0000007180fccb095c9f83319bb9b53e
09:05:07:WU01:FS00:0xa7:Digital signatures verified
09:05:07:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
09:05:07:WU01:FS00:0xa7:Calling: mdrun -s frame94.tpr -o frame94.trr -x frame94.xtc -cpi state.cpt -cpt 15 -nt 6
09:05:07:WU01:FS00:0xa7:Steps: first=11750000 total=125000
09:05:07:WU00:FS01:Connecting to 65.254.110.245:8080
09:05:10:WU01:FS00:0xa7:Completed 106342 out of 125000 steps (85%)
09:05:22:WU00:FS01:Assigned to work server 192.0.2.1
09:05:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:05:22:WU00:FS01:Connecting to 192.0.2.1:8080
09:05:43:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:05:43:WU00:FS01:Connecting to 192.0.2.1:80
09:06:04:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:07:45:WU00:FS01:Connecting to 65.254.110.245:8080
09:07:45:WU00:FS01:Assigned to work server 192.0.2.1
09:07:59:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:07:59:WU00:FS01:Connecting to 192.0.2.1:8080
09:08:20:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:08:20:WU00:FS01:Connecting to 192.0.2.1:80
09:08:42:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:08:50:WU01:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
09:11:59:WU00:FS01:Connecting to 65.254.110.245:8080
09:11:59:WU00:FS01:Assigned to work server 192.0.2.1
09:12:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:12:14:WU00:FS01:Connecting to 192.0.2.1:8080
09:12:35:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:12:35:WU00:FS01:Connecting to 192.0.2.1:80
09:12:47:WU01:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
09:12:56:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:16:43:WU01:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
09:18:50:WU00:FS01:Connecting to 65.254.110.245:8080
09:18:50:WU00:FS01:Assigned to work server 192.0.2.1
09:19:05:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:19:05:WU00:FS01:Connecting to 192.0.2.1:8080
09:19:26:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:19:26:WU00:FS01:Connecting to 192.0.2.1:80
09:19:47:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:20:41:WU01:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
09:24:38:WU01:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
09:28:35:WU01:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
09:29:56:WU00:FS01:Connecting to 65.254.110.245:8080
09:29:56:WU00:FS01:Assigned to work server 192.0.2.1
09:30:10:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:30:10:WU00:FS01:Connecting to 192.0.2.1:8080
09:30:32:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:30:32:WU00:FS01:Connecting to 192.0.2.1:80
09:30:53:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:32:32:WU01:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
09:36:31:WU01:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
09:40:28:WU01:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
09:44:25:WU01:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
09:47:52:WU00:FS01:Connecting to 65.254.110.245:8080
09:47:53:WU00:FS01:Assigned to work server 192.0.2.1
09:48:07:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
09:48:07:WU00:FS01:Connecting to 192.0.2.1:8080
09:48:22:WU01:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
09:48:28:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:48:28:WU00:FS01:Connecting to 192.0.2.1:80
09:48:49:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2019-12-22 *******************************
09:52:21:WU01:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
09:56:18:WU01:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
10:00:15:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
10:00:16:WU02:FS00:Connecting to 65.254.110.245:8080
10:00:17:WU02:FS00:Assigned to work server 128.252.203.9
10:00:17:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.252.203.9
10:00:17:WU02:FS00:Connecting to 128.252.203.9:8080
10:00:17:WU02:FS00:Downloading 8.14MiB
10:00:18:WU02:FS00:Download complete
10:00:18:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13830 run:614 clone:1 gen:89 core:0xa7 unit:0x0000006b80fccb095d693cfe9e7538b1
10:04:12:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
10:04:18:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
10:04:18:WU01:FS00:0xa7:Saving result file frame94.trr
10:04:18:WU01:FS00:0xa7:Saving result file frame94.xtc
10:04:18:WU01:FS00:0xa7:Saving result file md.log
10:04:18:WU01:FS00:0xa7:Saving result file science.log
10:04:18:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
10:04:19:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:04:19:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13827 run:973 clone:2 gen:94 core:0xa7 unit:0x0000007180fccb095c9f83319bb9b53e
10:04:19:WU01:FS00:Uploading 11.35MiB to 128.252.203.9
10:04:19:WU01:FS00:Connecting to 128.252.203.9:8080
10:04:19:WU02:FS00:Starting
10:04:19:WU02:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Users\Saint John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe" -dir 02 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -np 7
10:04:19:WU02:FS00:Started FahCore on PID 1012
10:04:19:WU02:FS00:Core PID:6360
10:04:19:WU02:FS00:FahCore 0xa7 started
10:04:19:WU02:FS00:0xa7:*********************** Log Started 2019-12-22T10:04:19Z ***********************
10:04:19:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:04:19:WU02:FS00:0xa7:       Type: 0xa7
10:04:19:WU02:FS00:0xa7:       Core: Gromacs
10:04:19:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 1012 -checkpoint 15 -np 7
10:04:19:WU02:FS00:0xa7:************************************ CBang *************************************
10:04:19:WU02:FS00:0xa7:       Date: Oct 26 2019
10:04:19:WU02:FS00:0xa7:       Time: 01:38:35
10:04:19:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
10:04:19:WU02:FS00:0xa7:     Branch: master
10:04:19:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
10:04:19:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:04:19:WU02:FS00:0xa7:   Platform: win32 10
10:04:19:WU02:FS00:0xa7:       Bits: 64
10:04:19:WU02:FS00:0xa7:       Mode: Release
10:04:19:WU02:FS00:0xa7:************************************ System ************************************
10:04:19:WU02:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
10:04:19:WU02:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
10:04:19:WU02:FS00:0xa7:       CPUs: 8
10:04:19:WU02:FS00:0xa7:     Memory: 8.00GiB
10:04:19:WU02:FS00:0xa7:Free Memory: 6.17GiB
10:04:19:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
10:04:19:WU02:FS00:0xa7: OS Version: 6.1
10:04:19:WU02:FS00:0xa7:Has Battery: false
10:04:19:WU02:FS00:0xa7: On Battery: false
10:04:19:WU02:FS00:0xa7: UTC Offset: -5
10:04:19:WU02:FS00:0xa7:        PID: 6360
10:04:19:WU02:FS00:0xa7:        CWD: D:\Users\Saint John\AppData\Roaming\FAHClient\work
10:04:19:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
10:04:19:WU02:FS00:0xa7:    Version: 0.0.18
10:04:19:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:04:19:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
10:04:19:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
10:04:19:WU02:FS00:0xa7:       Time: 01:52:44
10:04:19:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
10:04:19:WU02:FS00:0xa7:************************************ Build *************************************
10:04:19:WU02:FS00:0xa7:       SIMD: sse2
10:04:19:WU02:FS00:0xa7:********************************************************************************
10:04:19:WU02:FS00:0xa7:Project: 13830 (Run 614, Clone 1, Gen 89)
10:04:19:WU02:FS00:0xa7:Unit: 0x0000006b80fccb095d693cfe9e7538b1
10:04:19:WU02:FS00:0xa7:Reading tar file core.xml
10:04:19:WU02:FS00:0xa7:Reading tar file frame89.tpr
10:04:19:WU02:FS00:0xa7:Digital signatures verified
10:04:19:WU02:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
10:04:19:WU02:FS00:0xa7:Calling: mdrun -s frame89.tpr -o frame89.trr -x frame89.xtc -cpt 15 -nt 6
10:04:20:WU02:FS00:0xa7:Steps: first=11125000 total=125000
10:04:24:WU02:FS00:0xa7:Completed 1 out of 125000 steps (0%)
10:04:25:WU01:FS00:Upload 12.12%
10:04:31:WU01:FS00:Upload 25.33%
10:04:37:WU01:FS00:Upload 39.10%
10:04:43:WU01:FS00:Upload 52.32%
10:04:49:WU01:FS00:Upload 66.08%
10:04:55:WU01:FS00:Upload 78.75%
10:05:01:WU01:FS00:Upload 91.97%
10:05:04:WU01:FS00:Upload complete
10:05:04:WU01:FS00:Server responded WORK_ACK (400)
10:05:04:WU01:FS00:Final credit estimate, 2857.00 points
10:05:05:WU01:FS00:Cleaning up
10:08:20:WU02:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
10:12:16:WU02:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
10:16:17:WU02:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
10:16:55:WU00:FS01:Connecting to 65.254.110.245:8080
10:16:55:WU00:FS01:Assigned to work server 192.0.2.1
10:17:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
10:17:09:WU00:FS01:Connecting to 192.0.2.1:8080
10:17:30:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
10:17:30:WU00:FS01:Connecting to 192.0.2.1:80
10:17:52:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:20:24:WU02:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
10:24:30:WU02:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
10:28:34:WU02:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
10:32:31:WU02:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
10:36:30:WU02:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
10:40:27:WU02:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
10:44:24:WU02:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
10:48:20:WU02:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
10:52:19:WU02:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
10:56:15:WU02:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
11:00:13:WU02:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
11:03:53:WU00:FS01:Connecting to 65.254.110.245:8080
11:03:54:WU00:FS01:Assigned to work server 192.0.2.1
11:04:08:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
11:04:08:WU00:FS01:Connecting to 192.0.2.1:8080
11:04:10:WU02:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
11:04:29:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:04:29:WU00:FS01:Connecting to 192.0.2.1:80
11:04:50:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:08:09:WU02:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
11:12:05:WU02:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
11:16:02:WU02:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
11:20:01:WU02:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
11:23:59:WU02:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
11:27:56:WU02:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
11:31:53:WU02:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
11:35:52:WU02:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
11:39:49:WU02:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
11:43:46:WU02:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
11:47:44:WU02:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
11:51:42:WU02:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
11:55:39:WU02:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
11:59:36:WU02:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
12:03:33:WU02:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
12:07:31:WU02:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
12:11:28:WU02:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
12:15:26:WU02:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
12:19:23:WU02:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
12:19:54:WU00:FS01:Connecting to 65.254.110.245:8080
12:19:55:WU00:FS01:Assigned to work server 192.0.2.1
12:20:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
12:20:09:WU00:FS01:Connecting to 192.0.2.1:8080
12:20:30:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
12:20:30:WU00:FS01:Connecting to 192.0.2.1:80
12:20:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:23:22:WU02:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
12:27:18:WU02:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
12:31:16:WU02:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
12:35:14:WU02:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
12:39:11:WU02:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
12:43:08:WU02:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
12:47:05:WU02:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
12:51:04:WU02:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
12:55:02:WU02:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
12:58:59:WU02:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
13:02:56:WU02:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
13:06:55:WU02:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
13:10:52:WU02:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
13:14:49:WU02:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
13:18:45:WU02:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
13:22:44:WU02:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
13:26:41:WU02:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
13:30:37:WU02:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
13:34:36:WU02:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
13:38:33:WU02:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
13:42:30:WU02:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
13:46:28:WU02:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
13:50:26:WU02:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
13:54:23:WU02:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
13:58:20:WU02:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
14:02:17:WU02:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
14:06:16:WU02:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
14:10:13:WU02:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
14:14:10:WU02:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
14:18:07:WU02:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
14:22:05:WU02:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
14:22:54:WU00:FS01:Connecting to 65.254.110.245:8080
14:22:54:WU00:FS01:Assigned to work server 192.0.2.1
14:23:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
14:23:09:WU00:FS01:Connecting to 192.0.2.1:8080
14:23:30:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
14:23:30:WU00:FS01:Connecting to 192.0.2.1:80
14:23:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:26:02:WU02:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
14:29:59:WU02:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
14:33:57:WU02:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
14:37:55:WU02:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
14:41:52:WU02:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
14:45:49:WU02:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
14:49:48:WU02:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
14:53:45:WU02:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
14:57:42:WU02:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
15:01:39:WU02:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
15:05:37:WU02:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
15:09:34:WU02:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
15:13:31:WU02:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
15:17:28:WU02:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
15:21:27:WU02:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
15:25:24:WU02:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
15:29:21:WU02:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
15:33:18:WU02:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
15:37:16:WU02:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
15:41:13:WU02:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
15:45:10:WU02:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
15:49:07:WU02:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
15:53:05:WU02:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
15:57:02:WU02:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
16:00:59:WU02:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
16:04:59:WU02:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
16:08:56:WU02:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
16:12:53:WU02:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
16:16:50:WU02:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
16:20:48:WU02:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
16:24:45:WU02:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
16:28:42:WU02:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
16:32:39:WU02:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
16:36:37:WU02:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
16:36:38:WU01:FS00:Connecting to 65.254.110.245:8080
16:36:39:WU01:FS00:Assigned to work server 128.252.203.9
16:36:39:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:7 from 128.252.203.9
16:36:39:WU01:FS00:Connecting to 128.252.203.9:8080
16:36:39:WU01:FS00:Downloading 8.14MiB
16:36:40:WU01:FS00:Download complete
16:36:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13831 run:979 clone:2 gen:89 core:0xa7 unit:0x0000006780fccb095d693a206a0be457
16:40:34:WU02:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
16:40:41:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
16:40:41:WU02:FS00:0xa7:Saving result file frame89.trr
16:40:41:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
16:40:41:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13830 run:614 clone:1 gen:89 core:0xa7 unit:0x0000006b80fccb095d693cfe9e7538b1
16:40:41:WU02:FS00:Uploading 11.26MiB to 128.252.203.9
16:40:41:WU02:FS00:Connecting to 128.252.203.9:8080
16:40:41:WU01:FS00:Starting
16:40:41:WU01:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:\Users\Saint John\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_a7.fah/FahCore_a7.exe" -dir 01 -suffix 01 -version 705 -lifeline 2484 -checkpoint 15 -np 7
16:40:41:WU01:FS00:Started FahCore on PID 9000
16:40:41:WU01:FS00:Core PID:8680
16:40:41:WU01:FS00:FahCore 0xa7 started
16:40:42:WU01:FS00:0xa7:*********************** Log Started 2019-12-22T16:40:41Z ***********************
16:40:42:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:40:42:WU01:FS00:0xa7:       Type: 0xa7
16:40:42:WU01:FS00:0xa7:       Core: Gromacs
16:40:42:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 9000 -checkpoint 15 -np 7
16:40:42:WU01:FS00:0xa7:************************************ CBang *************************************
16:40:42:WU01:FS00:0xa7:       Date: Oct 26 2019
16:40:42:WU01:FS00:0xa7:       Time: 01:38:35
16:40:42:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:40:42:WU01:FS00:0xa7:     Branch: master
16:40:42:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
16:40:42:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:40:42:WU01:FS00:0xa7:   Platform: win32 10
16:40:42:WU01:FS00:0xa7:       Bits: 64
16:40:42:WU01:FS00:0xa7:       Mode: Release
16:40:42:WU01:FS00:0xa7:************************************ System ************************************
16:40:42:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
16:40:42:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
16:40:42:WU01:FS00:0xa7:       CPUs: 8
16:40:42:WU01:FS00:0xa7:     Memory: 8.00GiB
16:40:42:WU01:FS00:0xa7:Free Memory: 6.04GiB
16:40:42:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
16:40:42:WU01:FS00:0xa7: OS Version: 6.1
16:40:42:WU01:FS00:0xa7:Has Battery: false
16:40:42:WU01:FS00:0xa7: On Battery: false
16:40:42:WU01:FS00:0xa7: UTC Offset: -5
16:40:42:WU01:FS00:0xa7:        PID: 8680
16:40:42:WU01:FS00:0xa7:        CWD: D:\Users\Saint John\AppData\Roaming\FAHClient\work
16:40:42:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
16:40:42:WU01:FS00:0xa7:    Version: 0.0.18
16:40:42:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:40:42:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:40:42:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
16:40:42:WU01:FS00:0xa7:       Time: 01:52:44
16:40:42:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:40:42:WU01:FS00:0xa7:************************************ Build *************************************
16:40:42:WU01:FS00:0xa7:       SIMD: sse2
16:40:42:WU01:FS00:0xa7:********************************************************************************
16:40:42:WU01:FS00:0xa7:Project: 13831 (Run 979, Clone 2, Gen 89)
16:40:42:WU01:FS00:0xa7:Unit: 0x0000006780fccb095d693a206a0be457
16:40:42:WU01:FS00:0xa7:Reading tar file core.xml
16:40:42:WU01:FS00:0xa7:Reading tar file frame89.tpr
16:40:42:WU01:FS00:0xa7:Digital signatures verified
16:40:42:WU01:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
16:40:42:WU01:FS00:0xa7:Calling: mdrun -s frame89.tpr -o frame89.trr -x frame89.xtc -cpt 15 -nt 6
16:40:42:WU01:FS00:0xa7:Steps: first=11125000 total=125000
16:40:46:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
16:40:47:WU02:FS00:Upload 12.77%
16:40:53:WU02:FS00:Upload 26.65%
16:40:59:WU02:FS00:Upload 40.53%
16:41:05:WU02:FS00:Upload 54.41%
16:41:11:WU02:FS00:Upload 68.29%
16:41:17:WU02:FS00:Upload 82.18%
16:41:23:WU02:FS00:Upload 96.06%
16:41:24:WU02:FS00:Upload complete
16:41:24:WU02:FS00:Server responded WORK_ACK (400)
16:41:24:WU02:FS00:Final credit estimate, 3907.00 points
16:41:25:WU02:FS00:Cleaning up
16:44:43:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
16:48:40:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
16:52:37:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
16:56:36:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
17:00:34:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
17:04:38:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
17:08:40:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
17:12:43:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
17:16:40:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
17:20:37:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
17:24:35:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
17:28:34:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
17:32:32:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
17:36:30:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
17:40:27:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
17:41:54:WU00:FS01:Connecting to 65.254.110.245:8080
17:41:55:WU00:FS01:Assigned to work server 192.0.2.1
17:42:09:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Cypress [Radeon HD 5800/6850] from 192.0.2.1
17:42:09:WU00:FS01:Connecting to 192.0.2.1:8080
17:42:30:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:42:30:WU00:FS01:Connecting to 192.0.2.1:80
17:42:51:ERROR:WU00:FS01:Exception: Failed to connect to 192.0.2.1:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:44:26:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
17:48:23:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
17:52:21:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
17:56:20:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
18:00:17:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
18:04:15:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
18:08:12:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
18:12:12:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
18:16:09:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
18:20:06:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
18:24:03:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
18:28:03:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
18:32:00:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
18:35:57:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
18:39:55:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
18:43:53:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
18:47:50:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
18:51:48:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
18:55:45:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
18:59:44:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
19:03:41:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
19:07:39:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
19:11:38:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
19:15:36:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
19:19:33:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
19:23:30:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
19:27:29:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
19:31:26:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
19:35:30:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
19:39:28:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
19:43:27:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
19:47:24:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
19:51:22:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
19:55:19:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
19:59:18:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
20:03:16:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
20:07:13:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
20:11:12:WU01:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
20:15:09:WU01:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
20:19:07:WU01:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
20:23:04:WU01:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
20:27:03:WU01:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
20:31:00:WU01:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
20:34:58:WU01:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
20:38:55:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
20:42:54:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
20:46:51:WU01:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
20:50:48:WU01:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
20:54:46:WU01:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
20:58:45:WU01:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
21:02:43:WU01:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
21:06:41:WU01:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
21:10:38:WU01:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
21:14:37:WU01:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
21:18:35:WU01:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
21:22:32:WU01:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
21:26:31:WU01:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
21:30:29:WU01:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
21:34:26:WU01:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
21:38:24:WU01:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
21:42:22:WU01:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
21:46:20:WU01:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
21:50:17:WU01:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
21:54:15:WU01:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
21:58:13:WU01:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
22:02:10:WU01:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
22:06:08:WU01:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
22:10:05:WU01:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
22:14:04:WU01:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
22:18:01:WU01:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
22:21:58:WU01:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
22:25:57:WU01:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
22:26:36:FS00:Shutting core down
22:26:36:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 8680
22:26:36:WU01:FS00:0xa7:Exiting, please wait. . .
22:26:41:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
22:26:41:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Another way to get the GPU Info is to screen capture GPU -Z
toTOW wrote:For some unknown reason, all Cypress GPUs are set to species 4 (no DP support) although they seem to support it. Since those GPUs are using old Terascale 2 architecture, maybe they have been disabled because we thought they can't meet the deadlines ...
That explains the issue, but it's not clear why. AMD Species 4 is evolving into a category for GPUs that do not support Double Precision, and apparently this GPU is misclassified. As you suggest, we should try that, but we need to know which it is so GPU-Z is the place to look if you can't capture the output of FAHClient --lspci.
ClemSNide
Post by ClemSNide »
What should I look for in GPU-Z? I didn't see a PCIe ID. There was a Device ID: 1002 6890 - 1002 0B00.
ClemSNide
Post by ClemSNide »
Correction: 1002 6899 - 1002 0B00. There was also a Bus Interface: PCIe x16 2.0 @ x16 2.0.
Sorry. The GPU-Z text is very small and no way to copy and paste so I'm going through screen magnifiers.
That's better. I couldn't find 6890 but I did find a match:
AMD 6899 Cypress PRO [Radeon HD 5850]
(The AMD 0B00 is probably the associated sound card device.)
I've changed it to subspecies 5 which should allow WUs to be assigned to it. Let us know if it works.
ClemSNide
Post by ClemSNide »
Thanks, Bruce! That got it running like a spoonful of castor oil and now I'm a happy folder.
Is it capable of making the deadlines ?
bruce> if ClemSNide confirms that everything is OK, I guess I can switch some misclassified species 4 GPUs with DP support back to species 5 using this list, based on GPU codename : https://en.wikipedia.org/wiki/List_of_A ... sing_units
MeeLee
Post by MeeLee »
toTOW wrote:Is it capable of making the deadlines ?
They're benchmarked as just a bit slower than a GT 1030, or GT 750. Meaning WUs could be finished around the 24 hours mark, if not interrupted.
Why anyone would do this, I don't know; Since they use over 6x the power consumption of a GT 1030.
Answer: Becuase I already own the hardware and somebody else pays for the electricity.
... Or maybe I use electricity to heat my home anyway.
Not necessarily a good reason, but we're all capable of rationalizing to suit our own situation.
All Cypress GPUs should be able to get work.
db5fp
Hardware configuration: i3 2100 / HD6450
Post by db5fp »
Hi,
I'm new here and using quiet old Hardware, but i does not copmute on the GPU
13:22:06:WU00:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
13:26:36:WU01:FS01:Connecting to 65.254.110.245:8080
13:26:36:WU01:FS01:Assigned to work server 192.0.2.1
13:26:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Caicos [AMD RADEON HD 6450] from 192.0.2.1
13:26:36:WU01:FS01:Connecting to 192.0.2.1:8080
13:26:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:26:58:WU01:FS01:Connecting to 192.0.2.1:80
13:27:19:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
17:11:57:WU01:FS01:Connecting to 65.254.110.245:8080
17:11:57:WU01:FS01:Assigned to work server 192.0.2.1
17:11:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Caicos [AMD RADEON HD 6450] from 192.0.2.1
17:11:57:WU01:FS01:Connecting to 192.0.2.1:8080
17:12:18:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:12:18:WU01:FS01:Connecting to 192.0.2.1:80
17:12:23:WU00:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
17:12:39:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80:
Device ID 1002 6779 - 103C 2128
GPU-Z says OPEN-CL YES
Any Hints?
Best regards
Frank
